Trouble migrating from NCS 2.6 to 2.8
Due to issues with the wifi stack, I have to move my project from 2.6 to 2.8.
I downloaded the new tools set (toolchains\cf2149caf2) and new nordic connect version 2.8.0 as per
https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/installation/updating.html
I read the migration guides for 2.7 and 2.8, and the 'using sysbuild for multi-image builds guides:
https://docs.nordicsemi.com/bundle/ncs-latest/page/zephyr/build/sysbuild/index.html#sysbuild
https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/releases_and_maturity/migration/migration_sysbuild.html
https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/releases_and_maturity/migration/migration_guide_2.8.html
Mostly this gave me a headache.
I created sysbuild.conf (at the root where I run west - is this right?), and filled in the stuff from the migration guides for mcuboot and nrf70 support.
# MCU boot config now handled by sysbuild
SB_CONFIG_BOOTLOADER_MCUBOOT=y
SB_CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH=y
SB_CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE=y
SB_CONFIG_NETCORE_HCI_IPC=y
SB_CONFIG_NETCORE_APP_UPDATE=y
SB_CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="/work/dev/if-device-nrf53/keys/bootloader_priv-ecdsa256.pem"
#CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="/work/dev/if-device-nrf53/keys/bootloader_priv-ecdsa256.pem"
# nrf7002 firmware handled by sysbuild
SB_CONFIG_WIFI_NRF70=y
SB_CONFIG_WIFI_NRF70_SYSTEM_MODE=y
#SB_CONFIG_WIFI_PATCHES_EXT_FLASH_XIP=y     later
# build of dfu packages
SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD=y
SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_APP=y
SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_NET=y
SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_WIFI_FW_PATCH=y
SB_CONFIG_DFU_ZIP=y
SB_CONFIG_DFU_ZIP_APP=y
SB_CONFIG_DFU_ZIP_NET=y
SB_CONFIG_DFU_ZIP_WIFI_FW_PATCH=y
# put slot2 in external flash
SB_CONFIG_PARTITION_MANAGER=y
SB_CONFIG_PM_MCUBOOT_PAD=y
SB_CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
I updated my prj.conf for the changes to nrf70 config option names
I created sysbuild/mcuboot and copied in the prj.conf from the previous child_image/mcuboot.conf
There was already a sysbuild/hci_ipc/prj.conf, I updated it with changes I had made to child_image/hci_ipc.conf
Then I set west to use my board and sysbuild and try to build:
> west config build.board cc1medv1_nrf5340_cpuapp
> west config build.sysbuild True
> west build --build-dir cc1-med/build cc1-med --board cc1medv1_nrf5340_cpuapp --pristine -DBOARD_ROOT=%CD%
This got me cmake failing.
-- west build: making build dir C:\work\dev\if-device-nrf53\cc1-med\build pristine
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: C:/ncs/toolchains/2d382dcd92/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.8.0/zephyr/.cache
-- Board: cc1medv1_nrf5340_cpuapp
Parsing C:/work/dev/if-device-nrf53/cc1-med/Kconfig.sysbuild
Loaded configuration 'C:/work/dev/if-device-nrf53/cc1-med/build/_sysbuild/empty.conf'
Merged configuration 'C:/work/dev/if-device-nrf53/cc1-med/build/_sysbuild/empty.conf'
Configuration saved to 'C:/work/dev/if-device-nrf53/cc1-med/build/zephyr/.config'
Kconfig header saved to 'C:/work/dev/if-device-nrf53/cc1-med/build/_sysbuild/autoconf.h'
CMake Error at C:/ncs/v2.8.0/nrf/sysbuild/CMakeLists.txt:117 (list):
  list GET given empty list
  cmake/modules/sysbuild_extensions.cmake:583 (nrf_PRE_CMAKE)
  cmake/modules/sysbuild_extensions.cmake:583 (cmake_language)
  cmake/modules/sysbuild_images.cmake:16 (sysbuild_module_call)
  cmake/modules/sysbuild_default.cmake:20 (include)
  C:/ncs/v2.8.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
  C:/ncs/v2.8.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  C:/ncs/v2.8.0/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
  template/CMakeLists.txt:10 (find_package)
   * Running CMake for cc1-med *
-- Application: C:/work/dev/if-device-nrf53/cc1-med
-- CMake version: 3.21.0
-- Using NCS Toolchain 2.8.20241106.194216054162 for building. (C:/ncs/toolchains/2d382dcd92/cmake)
-- Zephyr version: 3.7.99 (C:/ncs/v2.8.0/zephyr)
-- Found host-tools: zephyr 0.16.8 (C:/ncs/toolchains/2d382dcd92/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.8 (C:/ncs/toolchains/2d382dcd92/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/2d382dcd92/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/work/dev/if-device-nrf53/boards/arm/cc1medv1_nrf5340/cc1medv1_nrf5340_cpuapp.dts
'label' is marked as deprecated in 'properties:' in C:/ncs/v2.8.0/zephyr/dts/bindings\audio\nordic,nrf-pdm.yaml for node /soc/peripheral@50000000/pdm@26000.
devicetree error: gpio controller <Node /soc/peripheral@50000000/i2c@9000/mcp23017@20 in 'C:/ncs/v2.8.0/zephyr/misc/empty_file.c'> for <Node /soc/peripheral@50000000/pdm@26000/en in 'C:/ncs/v2.8.0/zephyr/misc/empty_file.c'> lacks binding
CMake Error at C:/ncs/v2.8.0/zephyr/cmake/modules/dts.cmake:295 (execute_process):
  execute_process failed command indexes:
    1: "Child return code: 1"
  C:/ncs/v2.8.0/zephyr/cmake/modules/zephyr_default.cmake:133 (include)
  C:/ncs/v2.8.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  C:/ncs/v2.8.0/zep-- Configuring incomplete, errors occurred!
  CMakeLists.txt:8 (find_package)
CMake Error at cmake/modules/sysbuild_extensions.cmake:514 (message):
  CMake configure failed for Zephyr project: cc1-med
  cmake/modules/sysbuild_images.cmake:20 (ExternalZephyrProject_Cmake)
See also "C:/work/dev/if-device-nrf53/cc1-med/build/CMakeFiles/CMakeOutput.log".
←[91mFATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\2d382dcd92\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/2d382dcd92/opt/bin/python.exe '-BC:\work\dev\if-device-nrf53\cc1-med\build' -GNinja -DBOARD=cc1medv1_nrf5340_cpuapp '-DBOARD_ROOT=C:\work\dev\if-device-nrf53' '-SC:\ncs\v2.8.0\zephyr\share\sysbuild' '-DAPP_DIR:PATH=C:\work\dev\if-device-nrf53\cc1-med'
The DTS also seems to now fail (didn't with 2.6) with:
Now I'm stuck....I'll look at the DTS thing tomorrow... I think I already knew that the DTS stuff had changed 2.6 to 2.8... but the migration guide doesn't reference it as far as I can see?
  • Hi Andreas
    Ok. Lets start with the migration to HWMv2. I have managed to rename/update my board files so that doing west boards can see the board, and that it manages to do the dtc part.
    I have 3 issues I think here:
    1/ warnings about depreciated labels
    -- Found BOARD.dts: C:/work/dev/if-device-nrf53/boards/infrafon/cc2v1/cc2v1_nrf5340_cpuapp.dts
    'label' is marked as deprecated in 'properties:' in C:/ncs/v2.8.0/zephyr/dts/bindings\i2s\nordic,nrf-i2s.yaml for node /soc/peripheral@50000000/i2s@28000.
    I can ignore these, yes?
    2/ a more serious looking warning, but related (as far as I can tell) to dts definitions in the SDK
    -- Including generated dts.cmake file: C:/work/dev/if-device-nrf53/cc1-med/build/mcuboot/zephyr/dts.cmake
    CMake Warning at C:/ncs/v2.8.0/zephyr/cmake/modules/dts.cmake:389 (message):
      dtc raised one or more warnings:
      <stdout>: Warning (avoid_unnecessary_addr_size):
      /soc/peripheral@50000000/i2s@28000: unnecessary #address-cells/#size-cells
      without "ranges" or child "reg" property
      CMakeLists.txt:12 (find_package)
    The dtsi file that defines the i2s reg and address-cells for the controller is in the SDK: file zephyr/dts/arm/noridc/nrf5340_cpuapp_peripherals.dtsi :
    i2s0: i2s@28000 {
        compatible = "nordic,nrf-i2s";
        #address-cells = <1>;
        #size-cells = <0>;
        reg = <0x28000 0x1000>;
        interrupts = <40 NRF_DEFAULT_IRQ_PRIORITY>;
        status = "disabled";
    My dts just enables it and adds pinctrl definition, as well as a gpio used for the sdmode of the amp.
    &i2s0 {
        status = "okay";
        label="I2S audio out MAX98357A";
        pinctrl-0 = <&i2s0_default>;
        pinctrl-1 = <&i2s0_sleep>;
        i2s_sdmode: sdmode {
            compatible = "nordic,gpio-pins";
            gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>;        // P1.14
    Is there a way for me to 'correct' the warning for the base definition?
    3/ enabling the PDM driver
    My DTS has the PDM defined as:
    &pdm0 {
        status = "okay";
        compatible = "nordic,nrf-pdm";
        label="PDM micro in";
        pinctrl-0 = <&pdm0_default>;
        pinctrl-1 = <&pdm0_sleep>;
        pdm_en: en {
            gpios = <&ioexp0 12 GPIO_ACTIVE_HIGH>;        // GPB.04
    This doesn't cause an issue for the dtc, but I saw a problem for KConfig which didn't like having CONFIG_NRFX_PDM=y (which was ok for v2.6). Do I need to evolve something in the dts to allow me to define the CONFIG to include the PDM driver?
    btw, I updated the nrf7002/wifi bits of the DTS, and it now accepts that the DTS has a valid wifi DT to let the wifi stuff in prj.conf be accepted.
    thanks
  • Now for sysbuild with mcuboot. btw, if I build without sysbuild (build.sysbuild=False), then the KConfig part gives some warnings buit gets further. With sysbuild, it breaks at the KConfig checking stage.
    What you previously had within <your_project>/child_images/mcuboot.conf is now present within <your_project>/sysbuild/mcuboot.conf
    Ok, I see the example has the file called mcuboot.conf, however if I name it that then I get:
    CMake Error at C:/ncs/v2.8.0/zephyr/cmake/modules/extensions.cmake:2861 (message):
      No prj.conf file(s) was found in the
      C:/work/dev/if-device-nrf53/cc1-med/sysbuild/mcuboot folder(s), please read
      the Zephyr documentation on application development.
    So I will name it prj.conf.
    Do you have SB_CONFIG_BOOTLOADER_MCUBOOT=y within sysbuild.conf or is it just within sysbuild/mcuboot.conf?
    In sysbuild.conf :
    #SB_CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH=y
    #SB_CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE=y
    #SB_CONFIG_NETCORE_APP_UPDATE=y
    # todo get dfu packaging to work
    #SB_CONFIG_SUPPORT_NETCORE=y
    #SB_CONFIG_SECURE_BOOT=y
    #SB_CONFIG_SECURE_BOOT_NETCORE=y
    #SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD=y
    #SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_APP=y
    #SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_NET=y
    #SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_WIFI_FW_PATCH=y
    #SB_CONFIG_DFU_ZIP=y
    #SB_CONFIG_DFU_ZIP_APP=y
    #SB_CONFIG_DFU_ZIP_NET=y
    #SB_CONFIG_DFU_ZIP_WIFI_FW_PATCH=y
    SB_CONFIG_PM_MCUBOOT_PAD=0x200
    And my sysbuild/mcuboot/prj.conf:
    # mcuboot serial recovery makes image too big for flash space... TODO find more space
    CONFIG_MCUBOOT_SERIAL=n
    CONFIG_BOOT_SERIAL_CDC_ACM=n
    # Enable wait for DFU functionality at boot?
    CONFIG_BOOT_SERIAL_WAIT_FOR_DFU=n
    #CONFIG_BOOT_SERIAL_WAIT_FOR_DFU_TIMEOUT=5000
    # DFU directly as special USB device? - nO, this required winusb zadig driver which then broke usb FS mounting...
    CONFIG_BOOT_USB_DFU_WAIT=n
    #CONFIG_BOOT_USB_DFU_WAIT_DELAY_MS=5000
    #CONFIG_USB_DEVICE_STACK=y
    #CONFIG_USB_DEVICE_PRODUCT="Infrafon CC2-WDD"
    # USB VID is MCS electronics, who sell individual PIDs. 0x138F is for CC2 purchases 25/08/2024
    #CONFIG_USB_DEVICE_VID=0x16D0
    #CONFIG_USB_DEVICE_PID=0x138F
    #CONFIG_USB_DRIVER_LOG_LEVEL_ERR=y
    CONFIG_BOOT_MAX_IMG_SECTORS=256
    CONFIG_FPROTECT=n
    # now handled by sysbuild
    #CONFIG_BOOTLOADER_MCUBOOT=y
    #CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
    #CONFIG_BOOT_SIGNATURE_KEY_FILE="/work/dev/if-device-nrf53/keys/bootloader_priv-ecdsa256.pem"
    CONFIG_MCUBOOT_SHELL=n
    CONFIG_DEBUG_COREDUMP=n
    CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=n
    CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN=n
    # Use minimal C library instead of the Picolib
    CONFIG_MINIMAL_LIBC=y
    CONFIG_DEBUG=n
    CONFIG_DEBUG_INFO=n
    # all functions in seperate sections so linker can discard unused code
    CONFIG_COMPILER_OPT="-Os"
    # -fdata-sections -ffunction-sections -Wl,--gc-sections -Wl,--strip-all"
    CONFIG_THREAD_NAME=n
    CONFIG_THREAD_ANALYZER=n
    CONFIG_THREAD_ANALYZER_USE_PRINTK=n
    CONFIG_THREAD_ANALYZER_AUTO=n
    CONFIG_SYS_HEAP_RUNTIME_STATS=n
    CONFIG_INIT_STACKS=n
    CONFIG_ASSERT=n
    CONFIG_ASSERT_VERBOSE=n
    CONFIG_ASSERT_NO_MSG_INFO=y
    CONFIG_ASSERT_NO_COND_INFO=y
    CONFIG_ASSERT_NO_FILE_INFO=y
    CONFIG_STACK_SENTINEL=n
    CONFIG_RESET_ON_FATAL_ERROR=y
    CONFIG_REBOOT=y
    # turn off serial and uart console to save space (later)
    CONFIG_CONSOLE=y
    CONFIG_CONSOLE_HANDLER=n
    CONFIG_SERIAL=y
    CONFIG_UART_CONSOLE=y
    CONFIG_STDOUT_CONSOLE=y
    # turn off log to save image size
    CONFIG_LOG=y
    CONFIG_LOG_MODE_MINIMAL=y
    CONFIG_LOG_MODE_IMMEDIATE=n
    #CONFIG_LOG_BACKEND_UART=y
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_LOG_PRINTK=n
    CONFIG_SHELL=n
    CONFIG_SHELL_MINIMAL=n
    CONFIG_SHELL_LOG_BACKEND=n
    CONFIG_GPIO=n
    CONFIG_GPIO_MCP230XX=n
    CONFIG_USE_SEGGER_RTT=n
    CONFIG_I2C=n
    CONFIG_SPI=n
    CONFIG_BOOT_BANNER=n
    #CONFIG_TIMESLICING=n
    #CONFIG_MULTITHREADING=n
    CONFIG_TICKLESS_KERNEL=n
    CONFIG_TIMEOUT_64BIT=n
    CONFIG_NRF_ENABLE_ICACHE=n
    This stops "due to Kconfig warnings":
    -- Board: cc2v1, qualifiers: nrf5340/cpuapp
    Merged configuration 'C:/work/dev/if-device-nrf53/cc1-med/sysbuild.conf'
       * Running CMake for mcuboot *
    -- Application: C:/ncs/v2.8.0/bootloader/mcuboot/boot/zephyr
    -- Generated zephyr.dts: C:/work/dev/if-device-nrf53/cc1-med/build/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/work/dev/if-device-nrf53/cc1-med/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    warning: The choice symbol MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH (defined at
    modules/Kconfig.mcuboot:164) was selected (set =y), but no symbol ended up as the choice selection.
    See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SC
    RATCH and/or look up MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH in the menuconfig/guiconfig
    interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and
    Best Practices sections of the manual might be helpful too.
    Parsing C:/ncs/v2.8.0/bootloader/mcuboot/boot/zephyr/Kconfig
    warning: FLASH_MAP (defined at subsys/storage/flash_map/Kconfig:10) has direct dependencies FLASH_HAS_DRIVER_ENABLED with value n, but is currently being y-selected by the following symbols:
     - MCUBOOT_DEVICE_SETTINGS (defined at C:/ncs/v2.8.0/bootloader/mcuboot/boot/zephyr/Kconfig:977), with value y, direct dependencies y (value: y)Loaded configuration 'C:/work/dev/if-device-nrf53/boards/infrafon/cc2v1/cc2v1_nrf5340_cpuapp_defconfig'
    Merged configuration 'C:/work/dev/if-device-nrf53/cc1-med/sysbuild/mcuboot/prj.conf'
    Merged configuration 'C:/ncs/v2.8.0/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
    Merged configuration 'C:/work/dev/if-device-nrf53/cc1-med/build/mcuboot/zephyr/.config.sysbuild'
    error: Aborting due to Kconfig warnings
    CMake Error at C:/ncs/v2.8.0/zephyr/cmake/modules/kconfig.cmake:396 (message):
      command failed with return code: 1
      C:/ncs/v2.8.0/nrf/cmake/modules/kconfig.cmake:29 (include)
      CMake configure failed for Zephyr project: mcuboot
      Location: C:/ncs/v2.8.0/bootloader/mcuboot/boot/zephyr/
    ←[91mFATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\2d382dcd92\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/2d382dcd92/opt/bin/python.exe '-BC:\work\dev\if-device-nrf53\cc1-med\build' -GNinja -DBOARD=cc2v1/nrf5340/cpuapp '-DBOARD_ROOT=C:\work\dev\if-device-nrf53' '-SC:\ncs\v2.8.0\zephyr\share\sysbuild' '-DAPP_DIR:PATH=C:\work\dev\if-device-nrf53\cc1-med'
    ←[0m
    It seems it doesn't like something about the flash driver? But this worked fine in 2.6... and also I don't get this error if using child_images build system...
    Note I have a pm_static.yml to define my partitions as I have an external flash chip also - does this make a difference? (again, all fine on 2.6)
  • And, as I said, with the old childimage system it gets further thru the config process (does the CPUNET, and mcuboot, then gets (I assume) to app), and it stops with this:
    -- Target:  Generic/arm
    -- Machine: arm
    -- Looking for include file stdatomic.h
    -- Looking for include file stdatomic.h - found
    -- open-amp version: 1.6.1 (C:/ncs/v2.8.0/modules/lib/open-amp/open-amp)
    -- Host:    Windows/AMD64
    -- Machine: arm
    -- C_FLAGS :  -Wall -Wextra
    -- Looking for include file fcntl.h
    -- Looking for include file fcntl.h - found
    -- Setting build type to 'MinSizeRel' as none was specified.
    CMake Warning at C:/ncs/v2.8.0/zephyr/CMakeLists.txt:952 (message):
      No SOURCES given to Zephyr library: drivers__disk
      Excluding target from build.
      No SOURCES given to Zephyr library: drivers__pwm
    CMake Warning at C:/ncs/v2.8.0/zephyr/CMakeLists.txt:2134 (message):
    CMake Deprecation Warning at C:/ncs/v2.8.0/nrf/cmake/partition_manager.cmake:32 (message):
                --- WARNING: Child and parent image functionality is deprecated   ---
                --- and should be replaced with sysbuild. Child and parent image  ---
                --- support remains only to allow existing customer applications  ---
                --- to build and allow porting to sysbuild, it is no longer       ---
                --- receiving updates or new features and it will not be possible ---
                --- to build using child/parent image at all in nRF Connect SDK   ---
                --- version 2.9 onwards.                                          ---
      C:/ncs/v2.8.0/zephyr/cmake/modules/kernel.cmake:255 (include)
      C:/ncs/v2.8.0/zephyr/cmake/modules/zephyr_default.cmake:142 (include)
    -- Found partition manager static configuration: C:/work/dev/if-device-nrf53/cc1-med/pm_static.yml
    Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
    Partition 'nvs_storage' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
    Partition 'pcd_sram' is not included in the dynamic resolving since it is statically defined.
    Partition 'rpmsg_nrf53_sram' is not included in the dynamic resolving since it is statically defined.
    See also "C:/work/dev/if-device-nrf53/cc1-med/build/CMakeFiles/CMakeError.log".
    ←[91mFATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\2d382dcd92\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/2d382dcd92/opt/bin/python.exe '-BC:\work\dev\if-device-nrf53\cc1-med\build' -GNinja -DBOARD=cc2v1/nrf5340/cpuapp -DBOARD_ROOT=/work/dev/if-device-nrf53 '-SC:\work\dev\if-device-nrf53\cc1-med'
    ←[0m
    and in ther cc1-med/build/CMakeFiles/CMakeError.log it says:
    Compiling the C compiler identification source file "CMakeCCompilerId.c" failed.
    Compiler: C:/ncs/toolchains/2d382dcd92/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    Build flags:
    Id flags:
    The output was:
    1
    c:/ncs/toolchains/2d382dcd92/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.exe: c:/ncs/toolchains/2d382dcd92/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/lib\libc.a(lib_a-exit.o): in function `exit':
    exit.c:(.text.exit+0x34): undefined reference to `_exit'
    collect2.exe: error: ld returned 1 exit status
    Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
    Build flags:
    Id flags:
    The output was:
    1
    I don't understand?
  • It seems it doesn't like something about the flash driver? But this worked fine in 2.6... and also I don't get this error if using child_images build system...
    After diving into a maze of nasty twisty little KConfig dependancies, it seems this is because I need CONFIG_FLASH=y in the sysbuild/mcuboot/prj.conf. Previously this was configured just in the main prj.conf for the project.
    I'm thinking that with sysbuild the 'main app' prj.conf is NOT merged in with the mcuboot one, so this has to stand on its own?
  • after finding the fix for the CONFIG_FLASH for the sysbuild, it also stops at this step. Can you explain why, given it seems to be using all the elements from the correct toolchain?
    Without a fix for this I am completely blocked.
