I'd like to evaluate dual mic recording on three 5340 audio DKs: two of them work as CIS headsets(Unicast server?) and the other one as CIS gateway(Unicast client?).
The two headsets will capture the voice data by the onboard PDM mic and encode and transmit mic data to the gateway via LE audio CIS stream from left and right channel respectively.
And when the gateway is configured to use I2S audio then it should playback the recorded mic data via its headphone jack, otherwise it can send that to USB host as a soundcard.
My question: Is there any workable example code from Nordic for this kind of application?
I found that there is a branch https://github.com/rick1082/sdk-nrf/commits/dual_mic_sample_2_4_2 crreated by Nordic engineer Rick in 2022, based on NCS2.4.2, I compiled and flash both CIS headset and gateway firmware images into my three 5340 audio DKs based on that code, but it does not work at all! I see error "Failed to establish CIS, ret = -22" in gateway log,
Here are the more logs from the gateway:
GW [00:01:46.169,555] <dbg> cis_gateway: ep_sta*** Booting Zephyr OS build v3.3.99-ncs1-2 *** GW [00:00:00.255,249] <dbg> main: main: nRF5340 APP core started GW [00:00:00.255,462] <inf> fw_info: nRF5340 Audio nRF5340 Audio DK cpuapp NCS base version: 2.4.2 Cmake run : Tue Dec 17 16:51:52 2024 GW [00:00:00.255,462] <inf> fw_info: ------- DEBUG BUILD ------- GW [00:00:00.255,493] <inf> fw_info: Compiled for GATEWAY device GW [00:00:00.266,113] <inf> board_version: Compatible board/HW version found: 1.0.0 GW [00:00:00.303,741] <wrn> bt_hci_core: Controller to host flow control not supported GW [00:00:00.306,884] <inf> ble: MAC: 00:00:00:00:00:00 (public) GW [00:00:00.307,464] <inf> ble: Controller version: 3349 GW [00:00:00.309,417] <inf> bt_keys: SC LTK: 0x1b081f1d4c6e0c8e9cc78196b5bfb645 GW [00:00:00.309,417] <inf> bt_keys: SC LTK: 0xc27ee2a3d8723fdc80e002fc08b0b3a3 GW [00:00:00.427,185] <inf> cis_gateway: Stored bonding found: CD:28:C6:83:F0:4D (random) GW [00:00:00.427,276] <inf> cis_gateway: Stored bonding found: EA:1F:9F:80:A9:0A (random) GW [00:00:00.427,276] <inf> cis_gateway: All bonded slots filled, will not accept new devices GW [00:00:00.429,290] <inf> cis_gateway: Scanning successfully started GW [00:00:01.186,523] <dbg> cis_gateway: bond_connect: Found bonded device GW [00:00:01.393,768] <inf> cis_gateway: Connected: EA:1F:9F:80:A9:0A (random) GW [00:00:01.394,012] <dbg> cis_gateway: connected_cb: TX power set to 0 dBm for connection 0x20005e98 GW [00:00:01.574,462] <dbg> cis_gateway: security_changed_cb: Security changed: level 2 GW [00:00:02.014,617] <inf> cis_gateway: Stored bonding found: CD:28:C6:83:F0:4D (random) GW [00:00:02.014,709] <inf> cis_gateway: Stored bonding found: EA:1F:9F:80:A9:0A (random) GW [00:00:02.014,709] <inf> cis_gateway: All bonded slots filled, will not accept new devices GW [00:00:02.015,319] <inf> cis_gateway: Scanning successfully started GW [00:00:02.223,114] <dbg> cis_gateway: bond_connect: Found bonded device GW [00:00:02.326,232] <inf> cis_gateway: Connected: CD:28:C6:83:F0:4D (random) GW [00:00:02.326,446] <dbg> cis_gateway: connected_cb: TX power set to 0 dBm for connection 0x20005f60 GW [00:00:02.414,642] <dbg> cis_gateway: available_contexts_cb: conn: EA:1F:9F:80:A9:0A (random), snk ctx 7 src ctx 7 GW [00:00:02.514,495] <dbg> cis_gateway: security_changed_cb: Security changed: level 2 GW [00:00:02.954,589] <inf> cis_gateway: All headsets connected GW [00:00:03.054,565] <dbg> cis_gateway: discover_source_cb: Source discover complete: err 0 GW [00:00:03.054,595] <dbg> bt_bap_stream: bt_bap_stream_config: conn 0x20005e98 stream 0x20001f0c, ep 0x20011af4 codec 0x200003b4 codec id 0x06 codec cid 0x0000 codec vid 0x0000 GW [00:00:03.054,595] <dbg> bt_bap_stream: bt_bap_stream_attach: conn 0x20005e98 stream 0x20001f0c ep 0x20011af4 codec 0x200003b4 GW [00:00:03.135,406] <inf> cis_gateway: LEFT source stream configured GW [00:00:03.135,406] <dbg> bt_bap_stream: bt_bap_stream_qos: conn 0x20005e98 group 0x20012234 GW [00:00:03.135,437] <dbg> bt_bap_stream: bt_bap_stream_verify_qos: Latency 20 higher than preferred max 10 GW [00:00:03.214,721] <dbg> cis_gateway: stream_qos_set_cb: Set LEFT to PD: 10000 GW [00:00:03.214,721] <dbg> bt_bap_stream: bt_bap_stream_enable: stream 0x20001f0c GW [00:00:03.214,782] <inf> cis_gateway: Enable stream 0x20001f0c GW [00:00:03.295,257] <inf> cis_gateway: Stream enabled: 0x20001f0c GW [00:00:03.295,257] <dbg> cis_gateway: stream_enabled_cb: k_msg_put: ch: 0, dir: 1, retries 0 GW [00:00:03.295,288] <dbg> cis_gateway: stream_enabled_cb: k_msg_put: ch: 0, dir: 2, retries 0 GW [00:00:03.295,318] <dbg> cis_gateway: work_stream_start: k_msg_get: ch: 0, dir: 1, retries 0 GW [00:00:03.295,349] <dbg> bt_bap_stream: bt_bap_stream_start: stream 0x20001cec ep (nil) GW [00:00:03.295,349] <dbg> bt_bap_stream: bt_bap_stream_start: Invalid stream GW [00:00:03.295,349] <err> cis_gateway: Failed to establish CIS, ret = -22 GW [00:00:03.295,379] <dbg> cis_gateway: work_stream_start: k_msg_get: ch: 0, dir: 2, retries 0 GW [00:00:03.295,379] <dbg> bt_bap_stream: bt_bap_stream_start: stream 0x20001f0c ep 0x20011af4 GW [00:00:03.354,675] <dbg> cis_gateway: available_contexts_cb: conn: CD:28:C6:83:F0:4D (random), snk ctx 7 src ctx 7 GW [00:00:03.654,663] <inf> cis_gateway: Stream 0x20001f0c started GW [00:00:03.654,724] <dbg> streamctrl: le_audio_msg_sub_thread: Received event = 2, current state = 1 GW [00:00:03.654,754] <dbg> streamctrl: le_audio_msg_sub_thread: LE audio evt streaming GW [00:00:03.659,240] <dbg> sw_codec_select: sw_codec_init: Encode: 48000Hz 16bits 10000us 64000bps 2 channel(s) GW [00:00:03.659,759] <dbg> sw_codec_select: sw_codec_init: Decode: 48000Hz 16bits 10000us 2 channel(s) GW [00:00:03.681,152] <dbg> cis_gateway: ep_state_check: Endpoint is NULL GW [00:00:03.681,182] <dbg> cis_gateway: ep_state_check: Endpoint is NULL GW [00:00:03.681,182] <wrn> streamctrl: Problem with sending LE audio data, ret: -140 GW [00:00:03.692,169] <dbg> cis_gateway: ep_state_check: Endpoint is NULL GW [00:00:03.692,199] <dbg> cis_gateway: ep_state_check: Endpoint is NULL GW [00:00:03.701,416] <dbg> cis_gateway: ep_state_check: Endpoint is NULL GW [00:00:03.701,446] <dbg> cis_gateway: ep_state_check: Endpoint is NULL GW [00:00:03.711,791] <dbg> cis_gateway: ep_state_check: Endpoint is NULL GW [00:00:03.711,791] <dbg> cis_gateway: ep_state_check: Endpoint is NULL GW [00:00:03.721,252] <dbg> cis_gateway: ep_state_check: Endpoint is NULL GW [00:00:03.721,252] <dbg> cis_gateway: ep_state_check: Endpoint is NULL
Can you take a look at it? If there is any new branch that implemented what I want, please let me know.
Thanks
