Can you use GDB for your app code if soft device was merged in the final hex?
In general you can't single-step through softdevice calls, or break while the softdevice is running, with any debugger because the softdevice has timing requirements which single stepping breaks.
Here's a recent blog about monitor mode debugging which attempts to work around this
but it's an advanced technique. This all has nothing to do with GDB.
Because of how the SoftDevice works you are not able to debug it by stepping the code. This is because it will report a fault upon failing timing checks. These timing checks are critical in order to be able to operate a BLE connection.
Øyvind
This is exactly the type of answer I was looking for. Thank you! There any documentation discussing this ?
You can refer to this answer for more info.
