Questions about factory Data
1.After I burn AP CODE, executing "nrfjprog -f nrf53 --program factory_data.hex –sectorerase" instruction will cause the following error.
This issue wasn't happened in prior 2.4.1 version, but occured after updated 2.6.1.
2.Was factory data stored in TrustZone? If not how to get factory data stored in TrustZone?
  • SunHuang said:
    If I configure it like this, I can burn the AP CODE first and then update the factory data.
    # Enable Factory Data feature
    CONFIG_CHIP_FACTORY_DATA=y
    CONFIG_CHIP_FACTORY_DATA_BUILD=n
    Then why do you want to flash the factory data again? I assume that if you erase the entire flash, and re-flash the application and factory data, then it works?
    Edvin
  • Hi Edvin
    When I use prj_release.conf, a factory data is automatically generated and then written to the device.
    So I want to flash the factory data again, although I think it doesn't make sense.
    Using the same configuration, the results of prj.conf and prj_release.conf are different. Why is this?
    You can compare the prj.conf and prj_release.conf files. I don't know what sample you based your application on, but looking at the light_bulb sample, the difference is that the prj_release.conf has disabled debugging, disabled the shell feature, and enabled the watchdog. That is pretty much the only difference. Both CONFIG_CHIP_FACTORY_DATA and CONFIG_CHIP_FACTORY_DATA_BUILD are set to "y" in prj.conf and prj_release.conf in the light bulb sample (and all the other samples, as far as I can tell).
    My guess is that if you program the sample with a set of factory data, and reset the device, then the application will start processing this, and start using it and storing something in it's settings. When it later starts up with a new set of factory data, that doesn't match what it believes it had, it asserts.
    When you re-flash the factory data. Do you use nrfjprog? Do you use the argument --sectorerase? Do you use the argument --verify? If not, can you please try to use those? Does it change anything?
    Edvin
    I created a new project with the same configuration as my project (as attached).
    This new project will not run without factory data.
    So it seems that the prj_release.conf is not the cause of the factory data error.
    It looks more like a memory configuration issue.
    8461.config.zip
  • I am not sure exactly what to look for here.
    But it works if you program the factory data?
    Can you please copy and paste your build command here? If you are using VS Code, right click the build configuration, and select copy build command:
    Edvin
