Spikes in current consumption after using semaphores
can anyone tell me what are these spikes
i am some part of my code:
_SPRINTLN(DEBUG_INFO, "LOW-PWR-SYS-ON"); // debug log to show device will enter standby state
        // turn off peripherals
        pm_device_action_run(uart_dev, PM_DEVICE_ACTION_SUSPEND);
        pm_device_action_run(adc_dev, PM_DEVICE_ACTION_SUSPEND);
        // Block (sleep) the main thread, it will wake up on GPIO interrupt or timer timeout
        k_sem_take(&main_sem, K_FOREVER);
        pm_device_action_run(uart_dev, PM_DEVICE_ACTION_RESUME);
        pm_device_action_run(adc_dev, PM_DEVICE_ACTION_RESUME);
    I have tried your code, but I am not able replicate what you are seeing. I see some different behavior in mode 1 and mode 2, but I don't have the Lora radio that you are using, so I needed to strip out that part.
    As far as I can tell, the only difference between mode 1 and 2 is that you call shutdown_cpu(DU_SLEEP_STANDBY); in mode 1. It doesn't look like that one returns, but it is stuck in there for some reason. Does it return in your case?
    Do you have something that I can use to replicate your issue on an nRF52840 DK?
    Edvin
  • Also, while I remember, have you tried removing
    CONFIG_PM=y
    from your prj.conf? I get a warning when this is enabled. I see that you also have CONFIG_PM_DEVICE=y. That is the correct one.
    Edvin
  • I have applied below changes in mode=1 and did not see any raise in current once it enters into SYSTEM_OFF mode.
    void shutdown_cpu(bool mode)
        led_ctrl(HIGH, HIGH, HIGH);
        du_radio_sleep(DU_SLEEP_SHUTDOWN);
        sx126x_hal_deinit();
        // clear all the wakeup reasons before going to sleep
        clear_wakeup_reason();
        // get zephyr-console pointer:
        const struct device *uart_dev = DEVICE_DT_GET(DT_CHOSEN(zephyr_console));
        if (mode)
            _SPRINTLN(DEBUG_INFO, "LOW-PWR-SYS-OFF"); // debug log to show device will enter shutdown state
            gf_pwr_once = 0;
            // Disable the UART, SPI, I2C, and other communication peripherals
            NRF_UART0->ENABLE = UART_ENABLE_ENABLE_Disabled;
            NRF_SPI0->ENABLE = SPI_ENABLE_ENABLE_Disabled;
            NRF_TWI0->ENABLE = TWI_ENABLE_ENABLE_Disabled;
            // Disable the ADC (if enabled)
            NRF_SAADC->ENABLE = SAADC_ENABLE_ENABLE_Disabled;
            // Disable RTC
            NRF_RTC0->TASKS_STOP = 1;
            // Disable timers
            NRF_TIMER0->TASKS_STOP = 1;
            // Disable PWM
            NRF_PWM0->ENABLE = PWM_ENABLE_ENABLE_Disabled;
            // Disable the radio (Bluetooth)
            NRF_RADIO->POWER = RADIO_POWER_POWER_Disabled;
            // Disable the CPU clock and enter low power mode
            NRF_POWER->TASKS_LOWPWR = 1;
            // Enter System OFF mode
            NRF_POWER->SYSTEMOFF = 1; // This will cause the chip to enter System OFF mode
            // Disable RTC
            // Disable timers
            // Disable PWM
            // If 'use_timer' is true, it means we want to use the timer to wake up the device after 'RTC_TIME' seconds.
            // This will block the main thread until the timer expires or an interrupt occurs (based on the RTC_TIME).
            if (use_timer)
                // Wait for the semaphore to be given, with a timeout of 'RTC_TIME' seconds.
                // If the semaphore is not given within this period, it means a timeout has occurred.
                int ret = k_sem_take(&main_sem, K_SECONDS(RTC_TIME)); // Store the return value for error handling
                // Error handling based on the return value of k_sem_take:
                if (ret == 0)
                    // Semaphore successfully taken, no timeout occurred
                    timeout_flag = false; // Reset the timeout flag
                else if (ret == -EBUSY)
                    // The semaphore was already taken (not a typical case for k_sem_take with timeout)
                    _SPRINTLN(DEBUG_ERROR, "Semaphore already taken. This should not happen.");
                    k_msleep(5000);
                else if (ret == -EAGAIN)
                    // Timeout occurred
                    timeout_flag = true; // Set the timeout flag to indicate the timer has expired
                    _SPRINTLN(DEBUG_WARNING, "Timer expired without semaphore being taken.");
                    // Catch any other unexpected error codes
                    _SPRINTLN(DEBUG_ERROR, "Unexpected error during semaphore take operation: %d", ret);
                    k_msleep(5000);
                // If 'use_timer' is false, block the main thread indefinitely until a GPIO interrupt occurs.
                // The main thread will wake up when a semaphore is given by an ISR.
                int ret = k_sem_take(&main_sem, K_FOREVER); // Store the return value for error handling
                if (ret != 0)
                    // If we exit unexpectedly (e.g., an ISR failure or other issue), log the error
                    _SPRINTLN(DEBUG_ERROR, "Failed to take semaphore with indefinite wait.");
                    k_msleep(5000);
        adc_init();
        // lines to be executed after wakeup:
        du_radio_init();
        du_radio_sleep(DU_SLEEP_STANDBY);
        _SPRINTLN(DEBUG_CRITICAL, "WAKE-UP");
        k_msleep(100); // Simultaneous Button press
  • CONFIG_PM=y
    This line does not seem to be doing anything.
