Hello Team,
Please help in guiding to enable L4 security & detailed guide to enable L4 in latest nRF Connect SDK having nRF54L15 chipset on nRF connect SDK 2.7.0
Thank you,
Hitesh
Hello Team,
Thank you,
Hitesh
We're looking for L4 on both PB-GATT or when doing Mesh Proxy
Our requirement is to enable L4 security, we're configuring BLE Mesh & BLE GATT (PB-GATT) both in our application, so as per above mentioned excercise we were able to experiment L4 with the help of peripheral lbs sample, we need to experiment the sample having BLE mesh & L4 security being enabled in configurations so that when proceed with BLE connection we need to add passkey while pairing.
nCS SDK we're referring is V2.9.0
Thank you,
As Hung is away at the moment, I'll take over this case. I believe you can enable L4 the same way you normally would, did you try CONFIG_BT_SMP_SC_ONLY?
Elfving
