Regarding mouse HID example code
Hello Developers,
                             I am k.hemasundar and i am working on the nRF52833 QAAA0 micro controller with segger embedded studio IDE. I have used nRF SDK of version 17.1.0 and 16.0.0 with my micro controller. I am using the BLE_MOUSE_HID example code with both versions, here the problem is the peripheral (pca10100) is advertising well and i am able to see the name of peripheral in central device but i am trying to connect with the perpheral it is not connecting with both the SDK versions. And i have used soft device s113 and s140 but i am central device is not able to connect with the device and i've tried with nrf connect application in my andriod mobile still it is not connecting.
please give me any suggestions regarding this problem.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_sdm.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_hids.h"
#include "ble_bas.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "bsp_btn_ble.h"
#include "app_scheduler.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "ble_advertising.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "peer_manager_handler.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME                     "nRF5_Mouse"                                /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define BATTERY_LEVEL_MEAS_INTERVAL     APP_TIMER_TICKS(2000)                       /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL               81                                          /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL               100                                         /**< Maximum simulated battery level. */
#define BATTERY_LEVEL_INCREMENT         1                                           /**< Increment between each simulated battery level measurement. */
#define PNP_ID_VENDOR_ID_SOURCE         0x02                                        /**< Vendor ID Source. */
#define PNP_ID_VENDOR_ID                0x1915                                      /**< Vendor ID. */
#define PNP_ID_PRODUCT_ID               0xEEEE                                      /**< Product ID. */
#define PNP_ID_PRODUCT_VERSION          0x0001                                      /**< Product Version. */
/*lint -emacro(524, MIN_CONN_INTERVAL) // Loss of precision */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)            /**< Minimum connection interval (7.5 ms). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(15, UNIT_1_25_MS)             /**< Maximum connection interval (15 ms). */
#define SLAVE_LATENCY                   20                                          /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(3000, UNIT_10_MS)             /**< Connection supervisory timeout (3000 ms). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAM_UPDATE_COUNT     3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
#define SWIFT_PAIR_SUPPORTED            1                                           /**< Swift Pair feature is supported. */
#if SWIFT_PAIR_SUPPORTED == 1
#define MICROSOFT_VENDOR_ID             0x0006                                      /**< Microsoft Vendor ID.*/
#define MICROSOFT_BEACON_ID             0x03                                        /**< Microsoft Beacon ID, used to indicate that Swift Pair feature is supported. */
#define MICROSOFT_BEACON_SUB_SCENARIO   0x00                                        /**< Microsoft Beacon Sub Scenario, used to indicate how the peripheral will pair using Swift Pair feature. */
#define RESERVED_RSSI_BYTE              0x80                                        /**< Reserved RSSI byte, used to maintain forwards and backwards compatibility. */
#define MOVEMENT_SPEED                  5                                           /**< Number of pixels by which the cursor is moved each time a button is pushed. */
#define INPUT_REPORT_COUNT              3                                           /**< Number of input reports in this application. */
#define INPUT_REP_BUTTONS_LEN           3                                           /**< Length of Mouse Input Report containing button data. */
#define INPUT_REP_MOVEMENT_LEN          3                                           /**< Length of Mouse Input Report containing movement data. */
#define INPUT_REP_MEDIA_PLAYER_LEN      1                                           /**< Length of Mouse Input Report containing media player data. */
#define INPUT_REP_BUTTONS_INDEX         0                                           /**< Index of Mouse Input Report containing button data. */
#define INPUT_REP_MOVEMENT_INDEX        1                                           /**< Index of Mouse Input Report containing movement data. */
#define INPUT_REP_MPLAYER_INDEX         2                                           /**< Index of Mouse Input Report containing media player data. */
#define INPUT_REP_REF_BUTTONS_ID        1                                           /**< Id of reference to Mouse Input Report containing button data. */
#define INPUT_REP_REF_MOVEMENT_ID       2                                           /**< Id of reference to Mouse Input Report containing movement data. */
#define INPUT_REP_REF_MPLAYER_ID        3                                           /**< Id of reference to Mouse Input Report containing media player data. */
#define BASE_USB_HID_SPEC_VERSION       0x0101                                      /**< Version number of base USB HID Specification implemented by this application. */
#define SCHED_MAX_EVENT_DATA_SIZE       APP_TIMER_SCHED_EVENT_DATA_SIZE             /**< Maximum size of scheduler events. */
#ifdef SVCALL_AS_NORMAL_FUNCTION
#define SCHED_QUEUE_SIZE                20                                          /**< Maximum number of events in the scheduler queue. More is needed in case of Serialization. */
#else
#define SCHED_QUEUE_SIZE                10                                          /**< Maximum number of events in the scheduler queue. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define APP_ADV_FAST_INTERVAL           0x0028                                      /**< Fast advertising interval (in units of 0.625 ms. This value corresponds to 25 ms.). */
#define APP_ADV_SLOW_INTERVAL           0x00A0                                      /**< Slow advertising interval (in units of 0.625 ms. This value corresponds to 100 ms.). */
#define APP_ADV_FAST_DURATION           3000                                        /**< The advertising duration of fast advertising in units of 10 milliseconds. */
#define APP_ADV_SLOW_DURATION           18000                                       /**< The advertising duration of slow advertising in units of 10 milliseconds. */
APP_TIMER_DEF(m_battery_timer_id);                                                  /**< Battery timer. */
BLE_BAS_DEF(m_bas);        /**< Battery service instance. */
BLE_HIDS_DEF(m_hids,        /**< HID service instance. */
             NRF_SDH_BLE_TOTAL_LINK_COUNT,
             INPUT_REP_BUTTONS_LEN,
             INPUT_REP_MOVEMENT_LEN,
             INPUT_REP_MEDIA_PLAYER_LEN);
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static bool              m_in_boot_mode = false;                                    /**< Current protocol mode. */
static uint16_t          m_conn_handle  = BLE_CONN_HANDLE_INVALID;                  /**< Handle of the current connection. */
static pm_peer_id_t      m_peer_id;                                                 /**< Device reference handle to the current bonded central. */
static sensorsim_cfg_t   m_battery_sim_cfg;                                         /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state;                                       /**< Battery Level sensor simulator state. */
static ble_uuid_t        m_adv_uuids[] =                                            /**< Universally unique service identifiers. */
    {BLE_UUID_HUMAN_INTERFACE_DEVICE_SERVICE, BLE_UUID_TYPE_BLE}
static uint8_t m_sp_payload[] =                                                     /**< Payload of advertising data structure for Microsoft Swift Pair feature. */
    MICROSOFT_BEACON_ID,
    MICROSOFT_BEACON_SUB_SCENARIO,
    RESERVED_RSSI_BYTE
static ble_advdata_manuf_data_t m_sp_manuf_advdata =                                /**< Advertising data structure for Microsoft Swift Pair feature. */
    .company_identifier = MICROSOFT_VENDOR_ID,
    .data               =
        .size   = sizeof(m_sp_payload),
        .p_data = &m_sp_payload[0]
static ble_advdata_t m_sp_advdata;
static void on_hids_evt(ble_hids_t * p_hids, ble_hids_evt_t * p_evt);
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
/**@brief Function for setting filtered whitelist.
 * @param[in] skip  Filter passed to @ref pm_peer_id_list.
static void whitelist_set(pm_peer_id_list_skip_t skip)
    pm_peer_id_t peer_ids[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
    uint32_t     peer_id_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
    ret_code_t err_code = pm_peer_id_list(peer_ids, &peer_id_count, PM_PEER_ID_INVALID, skip);
    NRF_LOG_INFO("\tm_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d",
                   peer_id_count + 1,
                   BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
    err_code = pm_whitelist_set(peer_ids, peer_id_count);
/**@brief Function for setting filtered device identities.
static void identities_set(pm_peer_id_list_skip_t skip)
    pm_peer_id_t peer_ids[BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT];
    uint32_t     peer_id_count = BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT;
    err_code = pm_device_identities_list_set(peer_ids, peer_id_count);
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    ret_code_t err_code;
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
static void advertising_start(bool erase_bonds)
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        whitelist_set(PM_PEER_ID_LIST_SKIP_NO_ID_ADDR);
        ret_code_t ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        if(ret == NRF_SUCCESS)
        printf("ble_advertising_start successfull....!\n");
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_disconnect_on_sec_failure(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
        case PM_EVT_CONN_SEC_SUCCEEDED:
            m_peer_id = p_evt->peer_id;
            advertising_start(false);
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            if (     p_evt->params.peer_data_update_succeeded.flash_changed
                 && (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
                NRF_LOG_INFO("New Bond, add the peer to the whitelist if possible");
                // Note: You should check on what kind of white list policy your application should use.
/**@brief Function for handling Service errors.
static void service_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling advertising errors.
static void ble_advertising_error_handler(uint32_t nrf_error)
/**@brief Function for performing a battery measurement, and update the Battery Level characteristic in the Battery Service.
static void battery_level_update(void)
    uint8_t  battery_level;
    battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
    err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
    if ((err_code != NRF_SUCCESS) &&
        (err_code != NRF_ERROR_BUSY) &&
        (err_code != NRF_ERROR_FORBIDDEN) &&
        (err_code != NRF_ERROR_INVALID_STATE) &&
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in]   p_context   Pointer used for passing some arbitrary information (context) from the
 *                          app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    battery_level_update();
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module.
static void timers_init(void)
    err_code = app_timer_init();
    // Create battery timer.
    err_code = app_timer_create(&m_battery_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                battery_level_meas_timeout_handler);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    printf("\n");
    printf("I am in gap_params_init function\n");
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    if(err_code == NRF_SUCCESS)
        printf("\nsd_ble_gap_device_name_set....!\n");
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HID_MOUSE);
        printf("\nsd_ble_gap_appearance_set....!\n");
        printf("\nsd_ble_gap_ppcp_set....!\n");
    printf("\n");
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
     printf("\n");
     printf("i am in the gatt_init function\n");
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
        printf("\nnrf_ble_gatt_init successfull....!\n");
/**@brief Function for initializing the Queued Write Module.
static void qwr_init(void)
    nrf_ble_qwr_init_t qwr_init_obj = {0};
    qwr_init_obj.error_handler = nrf_qwr_error_handler;
    err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init_obj);
/**@brief Function for initializing Device Information Service.
static void dis_init(void)
    ble_dis_init_t   dis_init_obj;
    ble_dis_pnp_id_t pnp_id;
    pnp_id.vendor_id_source = PNP_ID_VENDOR_ID_SOURCE;
    pnp_id.vendor_id        = PNP_ID_VENDOR_ID;
    pnp_id.product_id       = PNP_ID_PRODUCT_ID;
    pnp_id.product_version  = PNP_ID_PRODUCT_VERSION;
    memset(&dis_init_obj, 0, sizeof(dis_init_obj));
    ble_srv_ascii_to_utf8(&dis_init_obj.manufact_name_str, MANUFACTURER_NAME);
    dis_init_obj.p_pnp_id = &pnp_id;
    dis_init_obj.dis_char_rd_sec = SEC_JUST_WORKS;
    err_code = ble_dis_init(&dis_init_obj);
/**@brief Function for initializing Battery Service.
static void bas_init(void)
    ble_bas_init_t bas_init_obj;
    memset(&bas_init_obj, 0, sizeof(bas_init_obj));
    bas_init_obj.evt_handler          = NULL;
    bas_init_obj.support_notification = true;
    bas_init_obj.p_report_ref         = NULL;
    bas_init_obj.initial_batt_level   = 100;
    bas_init_obj.bl_rd_sec        = SEC_JUST_WORKS;
    bas_init_obj.bl_cccd_wr_sec   = SEC_JUST_WORKS;
    bas_init_obj.bl_report_rd_sec = SEC_JUST_WORKS;
    err_code = ble_bas_init(&m_bas, &bas_init_obj);
/**@brief Function for initializing HID Service.
static void hids_init(void)
    ble_hids_init_t           hids_init_obj;
    ble_hids_inp_rep_init_t * p_input_report;
    uint8_t                   hid_info_flags;
    static ble_hids_inp_rep_init_t inp_rep_array[INPUT_REPORT_COUNT];
    static uint8_t rep_map_data[] =
        0x05, 0x01, // Usage Page (Generic Desktop)
        0x09, 0x02, // Usage (Mouse)
        0xA1, 0x01, // Collection (Application)
        // Report ID 1: Mouse buttons + scroll/pan
        0x85, 0x01,       // Report Id 1
        0x09, 0x01,       // Usage (Pointer)
        0xA1, 0x00,       // Collection (Physical)
        0x95, 0x05,       // Report Count (3)
        0x75, 0x01,       // Report Size (1)
        0x05, 0x09,       // Usage Page (Buttons)
        0x19, 0x01,       // Usage Minimum (01)
        0x29, 0x05,       // Usage Maximum (05)
        0x15, 0x00,       // Logical Minimum (0)
        0x25, 0x01,       // Logical Maximum (1)
        0x81, 0x02,       // Input (Data, Variable, Absolute)
        0x95, 0x01,       // Report Count (1)
        0x75, 0x03,       // Report Size (3)
        0x81, 0x01,       // Input (Constant) for padding
        0x75, 0x08,       // Report Size (8)
        0x09, 0x38,       // Usage (Wheel)
        0x15, 0x81,       // Logical Minimum (-127)
        0x25, 0x7F,       // Logical Maximum (127)
        0x81, 0x06,       // Input (Data, Variable, Relative)
        0x05, 0x0C,       // Usage Page (Consumer)
        0x0A, 0x38, 0x02, // Usage (AC Pan)
        0x81, 0x06,       // Input (Data,Value,Relative,Bit Field)
        0xC0,             // End Collection (Physical)
        // Report ID 2: Mouse motion
        0x85, 0x02,       // Report Id 2
        0x75, 0x0C,       // Report Size (12)
        0x95, 0x02,       // Report Count (2)
        0x09, 0x30,       // Usage (X)
        0x09, 0x31,       // Usage (Y)
        0x16, 0x01, 0xF8, // Logical maximum (2047)
        0x26, 0xFF, 0x07, // Logical minimum (-2047)
        0xC0,             // End Collection (Application)
        // Report ID 3: Advanced buttons
        0x09, 0x01,       // Usage (Consumer Control)
        0x85, 0x03,       // Report Id (3)
        0x15, 0x00,       // Logical minimum (0)
        0x25, 0x01,       // Logical maximum (1)
        0x09, 0xCD,       // Usage (Play/Pause)
        0x0A, 0x83, 0x01, // Usage (AL Consumer Control Configuration)
        0x09, 0xB5,       // Usage (Scan Next Track)
        0x09, 0xB6,       // Usage (Scan Previous Track)
        0x09, 0xEA,       // Usage (Volume Down)
        0x09, 0xE9,       // Usage (Volume Up)
        0x0A, 0x25, 0x02, // Usage (AC Forward)
        0x0A, 0x24, 0x02, // Usage (AC Back)
        0xC0              // End Collection
    memset(inp_rep_array, 0, sizeof(inp_rep_array));
    // Initialize HID Service.
    p_input_report                      = &inp_rep_array[INPUT_REP_BUTTONS_INDEX];
    p_input_report->max_len             = INPUT_REP_BUTTONS_LEN;
    p_input_report->rep_ref.report_id   = INPUT_REP_REF_BUTTONS_ID;
    p_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
    p_input_report->sec.cccd_wr = SEC_JUST_WORKS;
    p_input_report->sec.wr      = SEC_JUST_WORKS;
    p_input_report->sec.rd      = SEC_JUST_WORKS;
    p_input_report                      = &inp_rep_array[INPUT_REP_MOVEMENT_INDEX];
    p_input_report->max_len             = INPUT_REP_MOVEMENT_LEN;
    p_input_report->rep_ref.report_id   = INPUT_REP_REF_MOVEMENT_ID;
    p_input_report                      = &inp_rep_array[INPUT_REP_MPLAYER_INDEX];
    p_input_report->max_len             = INPUT_REP_MEDIA_PLAYER_LEN;
    p_input_report->rep_ref.report_id   = INPUT_REP_REF_MPLAYER_ID;
    hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
    memset(&hids_init_obj, 0, sizeof(hids_init_obj));
    hids_init_obj.evt_handler                    = on_hids_evt;
    hids_init_obj.error_handler                  = service_error_handler;
    hids_init_obj.is_kb                          = false;
    hids_init_obj.is_mouse                       = true;
    hids_init_obj.inp_rep_count                  = INPUT_REPORT_COUNT;
    hids_init_obj.p_inp_rep_array                = inp_rep_array;
    hids_init_obj.outp_rep_count                 = 0;
    hids_init_obj.p_outp_rep_array               = NULL;
    hids_init_obj.feature_rep_count              = 0;
    hids_init_obj.p_feature_rep_array            = NULL;
    hids_init_obj.rep_map.data_len               = sizeof(rep_map_data);
    hids_init_obj.rep_map.p_data                 = rep_map_data;
    hids_init_obj.hid_information.bcd_hid        = BASE_USB_HID_SPEC_VERSION;
    hids_init_obj.hid_information.b_country_code = 0;
    hids_init_obj.hid_information.flags          = hid_info_flags;
    hids_init_obj.included_services_count        = 0;
    hids_init_obj.p_included_services_array      = NULL;
    hids_init_obj.rep_map.rd_sec         = SEC_JUST_WORKS;
    hids_init_obj.hid_information.rd_sec = SEC_JUST_WORKS;
    hids_init_obj.boot_mouse_inp_rep_sec.cccd_wr = SEC_JUST_WORKS;
    hids_init_obj.boot_mouse_inp_rep_sec.wr      = SEC_JUST_WORKS;
    hids_init_obj.boot_mouse_inp_rep_sec.rd      = SEC_JUST_WORKS;
    hids_init_obj.protocol_mode_rd_sec = SEC_JUST_WORKS;
    hids_init_obj.protocol_mode_wr_sec = SEC_JUST_WORKS;
    hids_init_obj.ctrl_point_wr_sec    = SEC_JUST_WORKS;
    err_code = ble_hids_init(&m_hids, &hids_init_obj);
    qwr_init();
    dis_init();
    bas_init();
    hids_init();
/**@brief Function for initializing the battery sensor simulator.
static void sensor_simulator_init(void)
    m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
    m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
    m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
    m_battery_sim_cfg.start_at_max = true;
    sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
/**@brief Function for handling a Connection Parameters error.
    cp_init.max_conn_params_update_count   = MAX_CONN_PARAM_UPDATE_COUNT;
    cp_init.evt_handler                    = NULL;
/**@brief Function for starting timers.
static void timers_start(void)
    err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
    // Prepare wakeup buttons.
/**@brief Function for handling HID events.
 * @details This function will be called for all HID events which are passed to the application.
 * @param[in]   p_hids  HID service structure.
 * @param[in]   p_evt   Event received from the HID service.
    switch (p_evt->evt_type)
        case BLE_HIDS_EVT_BOOT_MODE_ENTERED:
            m_in_boot_mode = true;
        case BLE_HIDS_EVT_REPORT_MODE_ENTERED:
        case BLE_HIDS_EVT_NOTIF_ENABLED:
            // No implementation needed.
    switch (ble_adv_evt)
        case BLE_ADV_EVT_DIRECTED_HIGH_DUTY:
            NRF_LOG_INFO("Directed advertising.");
            err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_DIRECTED);
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
        case BLE_ADV_EVT_SLOW:
            NRF_LOG_INFO("Slow advertising.");
            m_sp_advdata.p_manuf_specific_data = NULL;
            err_code = ble_advertising_advdata_update(&m_advertising, &m_sp_advdata, NULL);
            err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
        case BLE_ADV_EVT_FAST_WHITELIST:
            NRF_LOG_INFO("Fast advertising with whitelist.");
            err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
        case BLE_ADV_EVT_SLOW_WHITELIST:
            NRF_LOG_INFO("Slow advertising with whitelist.");
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
        case BLE_ADV_EVT_WHITELIST_REQUEST:
            ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
            ble_gap_irk_t  whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
            uint32_t       addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
            uint32_t       irk_cnt  = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
            err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
                                        whitelist_irks,  &irk_cnt);
            NRF_LOG_DEBUG("pm_whitelist_get returns %d addr in whitelist and %d irk whitelist",
                           addr_cnt,
                           irk_cnt);
            // Set the correct identities list (no excluding peers with no Central Address Resolution).
            identities_set(PM_PEER_ID_LIST_SKIP_NO_IRK);
            // Apply the whitelist.
            err_code = ble_advertising_whitelist_reply(&m_advertising,
                                                       whitelist_addrs,
                                                       addr_cnt,
                                                       whitelist_irks,
                                                       irk_cnt);
        case BLE_ADV_EVT_PEER_ADDR_REQUEST:
            pm_peer_data_bonding_t peer_bonding_data;
            // Only Give peer address if we have a handle to the bonded peer.
            if (m_peer_id != PM_PEER_ID_INVALID)
                err_code = pm_peer_data_bonding_load(m_peer_id, &peer_bonding_data);
                if (err_code != NRF_ERROR_NOT_FOUND)
                    // Manipulate identities to exclude peers with no Central Address Resolution.
                    identities_set(PM_PEER_ID_LIST_SKIP_ALL);
                    ble_gap_addr_t * p_peer_addr = &(peer_bonding_data.peer_ble_id.id_addr_info);
                    err_code = ble_advertising_peer_addr_reply(&m_advertising, p_peer_addr);
    printf("\n");
    printf("\nI am in ble_evt_handler fucntion\n");
    printf("\nble_event_id=%d\n",p_ble_evt->header.evt_id);
        case BLE_GAP_EVT_CONNECTED:
            printf("Connected\n");
            printf("\nConn.handler data=%d",p_ble_evt->evt.gap_evt.conn_handle);
            printf("\nm_conn_handle=0x%04x",m_conn_handle);
                 printf("\nnrf_ble_qwr_conn_handle_assign successfull....!\n");
             printf("\n");
            printf("\nDisconnected\n");
    printf("\n");
    printf("I am in the ble stack init function\n");
        printf("\nnrf_sdh_enable_request successfull....!\n");
    uint32_t ram_start = 0;
        printf("\nnrf_sdh_ble_default_cfg_set successfull....!\n");
    // Enable BLE stack.
        printf("\nnrf_sdh_ble_enable successfull....!\n");
    printf("\n");
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    printf("\n");
    printf("i am in the advertising_init function\n");
    uint8_t                adv_flags;
    ble_advertising_init_t init;
    adv_flags                            = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = adv_flags;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    init.advdata.p_manuf_specific_data = &m_sp_manuf_advdata;
    memcpy(&m_sp_advdata, &init.advdata, sizeof(m_sp_advdata));
    init.config.ble_adv_whitelist_enabled          = true;
    init.config.ble_adv_directed_high_duty_enabled = true;
    init.config.ble_adv_directed_enabled           = false;
    init.config.ble_adv_directed_interval          = 0;
    init.config.ble_adv_directed_timeout           = 0;
    init.config.ble_adv_fast_enabled               = true;
    init.config.ble_adv_fast_interval              = APP_ADV_FAST_INTERVAL;
    init.config.ble_adv_fast_timeout               = APP_ADV_FAST_DURATION;
    init.config.ble_adv_slow_enabled               = true;
    init.config.ble_adv_slow_interval              = APP_ADV_SLOW_INTERVAL;
    init.config.ble_adv_slow_timeout               = APP_ADV_SLOW_DURATION;
    init.evt_handler   = on_adv_evt;
    init.error_handler = ble_advertising_error_handler;
        printf("\nble_advertising_init successfull....!\n");
/**@brief Function for the Event Scheduler initialization.
static void scheduler_init(void)
    APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
/**@brief Function for sending a Mouse Movement.
 * @param[in]   x_delta   Horizontal movement.
 * @param[in]   y_delta   Vertical movement.
static void mouse_movement_send(int16_t x_delta, int16_t y_delta)
    if (m_in_boot_mode)
        x_delta = MIN(x_delta, 0x00ff);
        y_delta = MIN(y_delta, 0x00ff);
        err_code = ble_hids_boot_mouse_inp_rep_send(&m_hids,
                                                    0x00,
                                                    (int8_t)x_delta,
                                                    (int8_t)y_delta,
                                                    0,
                                                    NULL,
                                                    m_conn_handle);
        uint8_t buffer[INPUT_REP_MOVEMENT_LEN];
        APP_ERROR_CHECK_BOOL(INPUT_REP_MOVEMENT_LEN == 3);
        x_delta = MIN(x_delta, 0x0fff);
        y_delta = MIN(y_delta, 0x0fff);
        buffer[0] = x_delta & 0x00ff;
        buffer[1] = ((y_delta & 0x000f) << 4) | ((x_delta & 0x0f00) >> 8);
        buffer[2] = (y_delta & 0x0ff0) >> 4;
        err_code = ble_hids_inp_rep_send(&m_hids,
                                         INPUT_REP_MOVEMENT_INDEX,
                                         buffer,
                                         m_conn_handle);
 * @param[in]   event   Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle,
        case BSP_EVENT_WHITELIST_OFF:
        case BSP_EVENT_KEY_0:
            if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
                mouse_movement_send(-MOVEMENT_SPEED, 0);
        case BSP_EVENT_KEY_1:
                mouse_movement_send(0, -MOVEMENT_SPEED);
        case BSP_EVENT_KEY_2:
                mouse_movement_send(MOVEMENT_SPEED, 0);
        case BSP_EVENT_KEY_3:
                mouse_movement_send(0, MOVEMENT_SPEED);
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
    printf("\n");
        printf("Power Management initialized successfull....!\n");
    app_sched_execute();
        nrf_pwr_mgmt_run();
/**@brief Function for application main entry.
    bool erase_bonds;
    log_init();
    timers_init();
    power_management_init();
    printf("\n");
    ble_stack_init();
    scheduler_init();
    gap_params_init();
    printf("\n");
    gatt_init();
    printf("\n");
    advertising_init();
    services_init();
    sensor_simulator_init();
    conn_params_init();
    peer_manager_init();
    printf("\n");
    // Start execution.
    printf("\nHID Mouse example started.\n");
    timers_start();
    printf("\n");
    advertising_start(erase_bonds);
    printf("\n");
    // Enter main loop.
    for (;;)
        printf("\nI am in the main loop\n");
        idle_state_handle();
here i am attaching my example ble_hids_mouse code with my debugging functions and i also uploading my debug terminal output
Debug Terminal outpur:
ble_event_id=16
Connected
Conn.handler data=0
m_conn_handle=0x0000
ble_event_id=17
Disconnected
i am using my custom board with nrf52833 micro controller so here i didn't have the TX and RX pins for using NRF_LOG_INFO so , i am using prinf function please help me with my problem , i cant figure it out what happning. And i have a doubt on
on this parameters.
K.hemasundar
