nrf_desktop: nrf52840dongle no signs of life after flash
I'm trying to use the nrf_desktop application 100% standard, with NO changes to the codebase at all.
My initial assumption is, that once I flash the nrf52840dongle, it should act as a forwarder, as stated here https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/applications/nrf_desktop/board_configuration.html .
However, once flashed, nothing happens. dmesg does not detect the device when plugged in, and I get no signs of life (no LED, buttons do nothing, etc.). This is a fully standard nrf52840dongle, where I press the reset button to flash the device. The commands I use for flashing and building are the following:
west build -b nrf52840dongle/nrf52840 nrf/applications/nrf_desktop
nrfutil pkg generate --hw-version 52 --sd-req=0x00  --application build/merged.hex --application-version 1 build/zephyr.zip
nrfutil dfu usb-serial -pkg build/zephyr.zip -p /dev/ttyACM2
I've tried for a couple of days getting it to work, but without any luck. I must be missing something obvious! I don't have any debugger atm. but this is seriously making me consider getting one.
But my assumption is, that anything in the repo should work by default, without having to tweak many things (maybe?).
  • I've done a git bisect of nrf-sdk, and it works on v1.9.99-dev1, but breaks on v2.0.0. The bisect log isolates the following commit as the first bad commit https://github.com/nrfconnect/sdk-nrf/commit/92fa69aa64511da3876f9278b03718fc2ad956f4 , which does a lot of changes. I suspect that this still means it's some bootloader stuff, that's the issue.
    The bisect log is as follows
    git bisect start
    # status: waiting for both good and bad commits
    # good: [651142deec73bd7d975743dcce340bc3fca3e4d9] version: Update VERSION to 1.9.99-dev1
    git bisect good 651142deec73bd7d975743dcce340bc3fca3e4d9
    # status: waiting for bad commit, 1 good commit known
    # bad: [880c82dba48655ee3a75edaefa0208782967ff17] VERSION: Update to 2.0.0
    git bisect bad 880c82dba48655ee3a75edaefa0208782967ff17
    # bad: [fe195bdc3a4eefd346f1db3396b8284c8cb4a3cb] bluetooth: fast_pair: Add definition of ECDH public key
    git bisect bad fe195bdc3a4eefd346f1db3396b8284c8cb4a3cb
    # good: [b5f0eee0570aef591a9406f45f7f04a3725afccc] samples/nrf9160/http_update: Switch overlay to PINCTRL.
    git bisect good b5f0eee0570aef591a9406f45f7f04a3725afccc
    # good: [b1d10c6cc46b53752471023a165d9ed521a37eec] samples: lwm2m_client: Session lifetime update
    git bisect good b1d10c6cc46b53752471023a165d9ed521a37eec
    # good: [c1ef2d973c9c0023fa34eb216211e38d93e6c08e] manifest: Update sdk-nrf-802154 and nrfxlib revisions
    git bisect good c1ef2d973c9c0023fa34eb216211e38d93e6c08e
    # bad: [9adb5598b1d53e8402ac6cf8da3c17bae828dd8e] changelog: Update changelog with the DTM changes
    git bisect bad 9adb5598b1d53e8402ac6cf8da3c17bae828dd8e
    # good: [16f6fc5a53d45222786d2ef1b68809f953894a1e] manifest: Zephyr update with OpenThread changes
    git bisect good 16f6fc5a53d45222786d2ef1b68809f953894a1e
    # bad: [a3986baabf70e78c5e769f52b2771c77fea26229] samples: lwm2m: LwM2M v1.1 SenML CBOR enabled
    git bisect bad a3986baabf70e78c5e769f52b2771c77fea26229
    # bad: [92fa69aa64511da3876f9278b03718fc2ad956f4] applications: nrf_desktop: Rework of nrf_desktop configurations
    git bisect bad 92fa69aa64511da3876f9278b03718fc2ad956f4
    # good: [34348d3910edf723ec28a6165ceae8811075ce9f] cmake: Propagate the NCS Zephyr SDK install dir
    git bisect good 34348d3910edf723ec28a6165ceae8811075ce9f
    # first bad commit: [92fa69aa64511da3876f9278b03718fc2ad956f4] applications: nrf_desktop: Rework of nrf_desktop configurations
  • I further checked it, and I could get it to build all the way up to v2.6.99-cs2, if I "patched" the nrf52840dongle_nrf52840 configuration directory (basically just copied the directory from v1.9.99-dev1).
    I did a new bisect, and it seems to be when zephyr was bumped in this commit https://github.com/nrfconnect/sdk-nrf/commit/0e05e8638b6ed372de0c5f9b531e76bf5f8b82ce that it would not work. It is also the same time, where the build hex from start being named `build/merged.hex` and `build/nrf_desktop/zephyr/zephyr.hex`, then it doesn't seem to want to work anymore. Surely this is a biproduct of something, which I do not know. Likely it's a simple option that needs to be tweaked somewhere.
    More git bisect logs
    git bisect start
    # good: [45555695a3c3a44d231584b2e1554518c685698e] version: update VERSION to 2.6.99-cs2
    git bisect good 45555695a3c3a44d231584b2e1554518c685698e
    # bad: [5cb85570ca43bc344d3145c2338128eacf4b48ec] version: Update to 2.7.0
    git bisect bad 5cb85570ca43bc344d3145c2338128eacf4b48ec
    # good: [a3fa49d4905dc0d9dbc2d35ab4fbbe25426833f4] applications: nrf_desktop: Fix DTS conflicts on nRF54L (pwm_led0 label)
    git bisect good a3fa49d4905dc0d9dbc2d35ab4fbbe25426833f4
    # bad: [34de71650de7981a30025ad3caad90a5bf35e776] samples: bluetooth: add sysbuild config
    git bisect bad 34de71650de7981a30025ad3caad90a5bf35e776
    # bad: [80c4de5756c519679fa85a4be0c0ff1200bf40e1] tools: Use ncs-build image based on ubuntu 22
    git bisect bad 80c4de5756c519679fa85a4be0c0ff1200bf40e1
    # good: [a61663aeebe6a90431e553bb9edf8e54ce03d8a9] manifest: Update zephyr with nrf54h20 DCACHE enabling
    git bisect good a61663aeebe6a90431e553bb9edf8e54ce03d8a9
    # good: [3d4f19ebab2856ba1aebbbc7b75c3abe3b77a9a7] suit: move envelope creation options to sysbuild Kconfig
    git bisect good 3d4f19ebab2856ba1aebbbc7b75c3abe3b77a9a7
    # good: [9cac27c18cd696abf0898bb2599f11326170c0f3] manifest: update sdk-mcuboot, fix build warnings
    git bisect good 9cac27c18cd696abf0898bb2599f11326170c0f3
    # good: [2c96632f3e8b63ebd0d21b4f02c7d77f3f300d73] samples/applications/tests: Add sysbuild configurations
    git bisect good 2c96632f3e8b63ebd0d21b4f02c7d77f3f300d73
    # good: [4aa365deb0924a4c72601e3fa145618718339bcc] boards: thingy91: Add initial sysbuild options
    git bisect good 4aa365deb0924a4c72601e3fa145618718339bcc
    # bad: [202eaabe96c19bb309b27dbfc2b359289bc7a9b8] doc: Change build type to file suffix
    git bisect bad 202eaabe96c19bb309b27dbfc2b359289bc7a9b8
    # bad: [0e05e8638b6ed372de0c5f9b531e76bf5f8b82ce] manifest: Update find-my, sidewalk and zephyr
    git bisect bad 0e05e8638b6ed372de0c5f9b531e76bf5f8b82ce
    # good: [5d41f8b00d9432f188ba2ce04b3f15016767c370] cmake: sysbuild: Fix partition manager not escaping variables
    git bisect good 5d41f8b00d9432f188ba2ce04b3f15016767c370
    # first bad commit: [0e05e8638b6ed372de0c5f9b531e76bf5f8b82ce] manifest: Update find-my, sidewalk and zephyr
    I'll just continue to post here, if I have more findings :)
    The configuration in nRF_desktop for the nRF52840 dongle  (nrf52840dongle/nrf52840) by default is not compatible with the pre-installed bootloader in the nRF52840dongle. Here are the changes needed for the nRF52840 dongle to work with the pre-installed bootloader:
    diff --git a/applications/nrf_desktop/configuration/nrf52840dongle_nrf52840/prj.conf b/applications/nrf_desktop/configuration/nrf52840dongle_nrf52840/prj.conf
    index 1c3716b0ba..dfc1b41003 100644
    --- a/applications/nrf_desktop/configuration/nrf52840dongle_nrf52840/prj.conf
    +++ b/applications/nrf_desktop/configuration/nrf52840dongle_nrf52840/prj.conf
    @@ -29,15 +29,15 @@ CONFIG_DESKTOP_BLE_NEW_PEER_SCAN_ON_BOOT=y
     CONFIG_DESKTOP_BLE_PEER_ERASE=y
     CONFIG_DESKTOP_CONFIG_CHANNEL_ENABLE=y
    -CONFIG_DESKTOP_CONFIG_CHANNEL_DFU_ENABLE=y
    +CONFIG_DESKTOP_CONFIG_CHANNEL_DFU_ENABLE=n
     CONFIG_DESKTOP_BLE_QOS_ENABLE=y
     # Zephyr Configuration
    -CONFIG_ROM_START_OFFSET=0
    -CONFIG_BOARD_HAS_NRF5_BOOTLOADER=n
    +CONFIG_FLASH_LOAD_OFFSET=0x1000
    +CONFIG_BOARD_HAS_NRF5_BOOTLOADER=y
     CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1536
     CONFIG_ISR_STACK_SIZE=1280
    Also, rename/remove the nrf_desktop/configuration/nrf52840dongle_nrf52840/pm_static.yml to avoid building with it, and then build without sysbuild (--no-sysbuild).
    Please be aware that the above modifications would only support the nRF5 bootloader performing DFU updates instead of the background DFU over configuration channel (we need either B0 or MCUboot for that purpose). For the DFU over the config channel, you can flash the build/zephyr/zephyr.hex into the dongle with the default settings via the SWD interface and a Sggger J-LINK.
    Amanda H.
