enable coexistence between Wi-Fi & BLE on thingy91x
I am trying to find a solution how to use wifi and ble on thingy91x and manage the coexistence between them, I have found a sample Wi-Fi: Bluetooth LE coexistence but when I try to build it in nrf5340 SoC I got some errors (for example he doesn't recognize wifi or RAM overflowed) but I have added wifi node to my overlay but I get RAM overflowed.
The question is whether this sample supports thingy91x or not. If not, can you provide a solution to manage it? There are not many documents about thingy91x.
Best Regards
Terminal output :
[327/332] Linking C executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /home/youssef/git/ble/build/mcuboot/zephyr/zephyr_pre0.map
: && ccache /home/youssef/zephyr-sdk-0.17.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/youssef/git/ble/build/mcuboot/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/soc/soc/nrf5340/libsoc__nordic.a  zephyr/boards/boards/arm/thingy91x/lib..__nrf__boards__nordic__thingy91x.a  zephyr/subsys/retention/libsubsys__retention.a  zephyr/drivers/usb/device/libdrivers__usb__device.a  zephyr/drivers/usb/common/nrf_usbd_common/libdrivers__usb__common__nrf_usbd_common.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/hwinfo/libdrivers__hwinfo.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/retained_mem/libdrivers__retained_mem.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/nrf/subsys/pcd/lib..__nrf__subsys__pcd.a  modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a  modules/nrf/modules/mcuboot/hooks/lib..__nrf__modules__mcuboot__hooks.a  modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/mbedtls/libmbedTLSBase.a  modules/mbedtls/libmbedTLSCrypto.a  modules/mbedtls/libmbedTLSX509.a  modules/mbedtls/libmodules__mbedtls.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  modules/zcbor/libmodules__zcbor.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/home/youssef/zephyr-sdk-0.17.0/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main/nofp"  -L/home/youssef/git/ble/build/mcuboot/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  modules/mbedtls/libmbedTLSBase.a  modules/mbedtls/libmbedTLSCrypto.a  modules/mbedtls/libmbedTLSX509.a  -mcpu=cortex-m33  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  /home/youssef/git/nrfxlib/crypto/nrf_cc312_platform/lib/cortex-m33/soft-float/no-interrupts/libnrf_cc312_platform_0.9.19.a && cd /home/youssef/git/ble/build/mcuboot/zephyr && /usr/bin/cmake -E true
/home/youssef/zephyr-sdk-0.17.0/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `bss' will not fit in region `RAM'
/home/youssef/zephyr-sdk-0.17.0/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `RAM' overflowed by 271248 bytes
collect2: error: ld returned 1 exit status
[27/591] Generating include/generated/driver-validation.h
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf /home/youssef/git/ble/build/modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build /home/youssef/git/ble/build/mcuboot/zephyr/zephyr.hex /home/youssef/git/ble/build/mcuboot/zephyr/zephyr.elf
cd /home/youssef/git/ble/build/mcuboot && /usr/bin/cmake --build . --
[29/591] Generating ../../tfm/CMakeCache.txt
-- Found Git: /usr/bin/git (found version "2.34.1")
-- Found assembler: /home/youssef/zephyr-sdk-0.17.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
-- Found Python3: /home/youssef/git/nrf/samples/wifi/ble_coex/env/bin/python3 (found version "3.10.12") found components: Interpreter
-- Found Python3: /home/youssef/git/nrf/samples/wifi/ble_coex/env/bin/python3 (found suitable version "3.10.12", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: /home/youssef/.cache/zephyr
-- Configuring done
-- Generating done
-- Build files have been written to: /home/youssef/git/ble/build/tfm
FATAL ERROR: command exited with status 1: /usr/bin/cmake --build /home/youssef/git/ble/build
.overlay :
    aliases {
        zephyr,wifi = &nordic_wlan0;
    nordic_wlan0: nordic_wlan0 {
		compatible = "nordic,wlan0";
		status = "okay";
    nrf700x: nrf7000@1 {
		compatible = "nordic,nrf700x-spi";
		status = "okay";
		reg = <1>;
		spi-max-frequency = <DT_FREQ_M(8)>;
		iovdd-ctrl-gpios = <&gpio0 27 (GPIO_ACTIVE_HIGH | GPIO_PULL_DOWN)>;
		bucken-gpios = <&gpio0 28 (GPIO_ACTIVE_HIGH | GPIO_PULL_DOWN)>;
		host-irq-gpios = <&gpio0 16 GPIO_ACTIVE_HIGH>;
	nrf_radio_coex: nrf7002-coex {
		status = "okay";
		compatible = "nordic,nrf700x-coex";
		req-gpios =     <&gpio0 24 (GPIO_ACTIVE_HIGH)>;
		status0-gpios = <&gpio0 14 (GPIO_ACTIVE_HIGH)>;
		grant-gpios =   <&gpio0 25 (GPIO_ACTIVE_HIGH | GPIO_PULL_UP)>;
  • Hi Dejan,
    I have recently switched to NCS v2.9.0 and successfully built the Wi-Fi shell sample using the thingy91x/nrf5340/cpuapp target. However, I am unable to view any logs using RTT, even though I have activated RTT in the configuration file.
    Additionally, I attempted to build the BLE coexistence (ble_coex) sample but encountered the following error:
    [163/605] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/class/cdc_acm.c.obj
    /home/youssef/git/zephyr/subsys/usb/device/class/cdc_acm.c:64:2: warning: #warning "USB_CDC_ACM_LOG_LEVEL forced to LOG_LEVEL_NONE" [-Wcpp]
       64 | #warning "USB_CDC_ACM_LOG_LEVEL forced to LOG_LEVEL_NONE"
    [479/605] Building C object zephyr/drivers/wifi/nrf_wifi/CMakeFiles/nrf_wifi.dir/src/coex.c.obj
    FAILED: zephyr/drivers/wifi/nrf_wifi/CMakeFiles/nrf_wifi.dir/src/coex.c.obj
    ccache /home/youssef/zephyr-sdk-0.17.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=230000 -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DMBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE=\"nrf-psa-crypto-user-config.h\" -DNRF5340_XXAA_APPLICATION -DNRF70_ANT_GAIN_2G=0 -DNRF70_ANT_GAIN_5G_BAND1=0 -DNRF70_ANT_GAIN_5G_BAND2=0 -DNRF70_ANT_GAIN_5G_BAND3=0 -DNRF70_BAND_2G_LOWER_EDGE_BACKOFF_DSSS=0 -DNRF70_BAND_2G_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_2G_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_2G_UPPER_EDGE_BACKOFF_DSSS=0 -DNRF70_BAND_2G_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_2G_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_1_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_1_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_1_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_1_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_2A_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_2A_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_2A_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_2A_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_2C_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_2C_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_2C_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_2C_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_3_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_3_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_3_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_3_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_4_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_4_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_4_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_4_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_DATA_TX -DNRF70_LOG_VERBOSE -DNRF70_MAX_TX_PENDING_QLEN=12 -DNRF70_MAX_TX_TOKENS=10 -DNRF70_PCB_LOSS_2G=0 -DNRF70_PCB_LOSS_5G_BAND1=0 -DNRF70_PCB_LOSS_5G_BAND2=0 -DNRF70_PCB_LOSS_5G_BAND3=0 -DNRF70_REG_DOMAIN=00 -DNRF70_RPU_PS_IDLE_TIMEOUT_MS=10 -DNRF70_RX_MAX_DATA_SIZE=1600 -DNRF70_RX_NUM_BUFS=48 -DNRF70_STA_MODE -DNRF70_SYSTEM_MODE -DNRF70_TCP_IP_CHECKSUM_OFFLOAD -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_WIFI_AP_DEAD_DETECT_TIMEOUT=20 -DNRF_WIFI_IFACE_MTU=1500 -DNRF_WIFI_LOW_POWER -DNRF_WIFI_MGMT_BUFF_OFFLOAD -DNRF_WIFI_PS_INT_PS=y -DNRF_WIFI_RPU_RECOVERY -DNRF_WIFI_RPU_RECOVERY_PS_ACTIVE_TIMEOUT_MS=50000 -DPICOLIBC_LONG_LONG_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -I/home/youssef/git/apps_wifi/ble_coex/build/ble_coex/zephyr/include/generated/zephyr -I/home/youssef/git/zephyr/include -I/home/youssef/git/apps_wifi/ble_coex/build/ble_coex/zephyr/include/generated -I/home/youssef/git/zephyr/soc/nordic -I/home/youssef/git/zephyr/include/zephyr/posix -I/home/youssef/git/zephyr/soc/nordic/nrf53/. -I/home/youssef/git/zephyr/soc/nordic/common/. -I/home/youssef/git/zephyr/subsys/usb/device -I/home/youssef/git/zephyr/subsys/bluetooth -I/home/youssef/git/zephyr/subsys/net/l2 -I/home/youssef/git/zephyr/drivers/usb/common/nrf_usbd_common/. -I/home/youssef/git/zephyr/drivers/wifi/nrf_wifi/inc -I/home/youssef/git/zephyr/subsys/net/ip -I/home/youssef/git/nrf/include -I/home/youssef/git/apps_wifi/ble_coex/build/ble_coex/zephyr/misc/generated -I/home/youssef/git/modules/lib/hostap/port/mbedtls -I/home/youssef/git/nrf/tests/include -I/home/youssef/git/modules/hal/cmsis/CMSIS/Core/Include -I/home/youssef/git/zephyr/modules/cmsis/. -I/home/youssef/git/modules/hal/nordic/nrfx -I/home/youssef/git/modules/hal/nordic/nrfx/drivers/include -I/home/youssef/git/modules/hal/nordic/nrfx/mdk -I/home/youssef/git/zephyr/modules/hal_nordic/nrfx/. -I/home/youssef/git/zephyr/modules/hostap/src -I/home/youssef/git/modules/lib/hostap -I/home/youssef/git/modules/lib/hostap/wpa_supplicant -I/home/youssef/git/modules/lib/hostap/src -I/home/youssef/git/modules/lib/hostap/src/common -I/home/youssef/git/modules/lib/hostap/src/eap_common -I/home/youssef/git/modules/lib/hostap/src/eap_server -I/home/youssef/git/modules/lib/hostap/src/radius -I/home/youssef/git/modules/lib/hostap/src/crypto -I/home/youssef/git/modules/lib/hostap/src/ap -I/home/youssef/git/modules/lib/hostap/src/drivers -I/home/youssef/git/modules/lib/hostap/src/rsn_supp -I/home/youssef/git/apps_wifi/ble_coex/build/ble_coex/modules/libmetal/libmetal/lib/include -I/home/youssef/git/modules/lib/open-amp/open-amp/lib/include -I/home/youssef/git/modules/crypto/tinycrypt/lib/include -I/home/youssef/git/nrfxlib/softdevice_controller/include -I/home/youssef/git/apps_wifi/ble_coex/build/ble_coex/generated/library_nrf_security_psa -I/home/youssef/git/nrf/subsys/nrf_security/include -I/home/youssef/git/nrf/subsys/nrf_security/src/threading/include -I/home/youssef/git/nrf/subsys/nrf_security/src/utils -I/home/youssef/git/modules/crypto/oberon-psa-crypto/oberon/drivers -I/home/youssef/git/modules/crypto/oberon-psa-crypto/include -I/home/youssef/git/modules/crypto/oberon-psa-crypto/library -I/home/youssef/git/modules/crypto/mbedtls/library -I/home/youssef/git/modules/crypto/mbedtls/include -I/home/youssef/git/modules/crypto/mbedtls/include/library -I/home/youssef/git/nrfxlib/crypto/nrf_oberon/include -I/home/youssef/git/nrfxlib/crypto/nrf_oberon/include/mbedtls -I/home/youssef/git/zephyr/modules/nrf_wifi/os -I/home/youssef/git/zephyr/modules/nrf_wifi/os/../bus -I/home/youssef/git/modules/lib/nrf_wifi/utils/inc -I/home/youssef/git/modules/lib/nrf_wifi/os_if/inc -I/home/youssef/git/modules/lib/nrf_wifi/bus_if/bus/qspi/inc -I/home/youssef/git/modules/lib/nrf_wifi/bus_if/bal/inc -I/home/youssef/git/modules/lib/nrf_wifi/fw_if/umac_if/inc -I/home/youssef/git/modules/lib/nrf_wifi/fw_load/mips/fw/inc -I/home/youssef/git/modules/lib/nrf_wifi/hw_if/hal/inc -I/home/youssef/git/modules/lib/nrf_wifi/hw_if/hal/inc/fw -I/home/youssef/git/modules/lib/nrf_wifi/fw_if/umac_if/inc/fw -I/home/youssef/git/modules/lib/nrf_wifi/fw_if/umac_if/inc/default -isystem /home/youssef/git/zephyr/lib/libc/common/include -isystem /home/youssef/git/nrfxlib/crypto/nrf_cc312_platform/include -Os -DNDEBUG -Wshadow -fno-strict-aliasing -Os -imacros /home/youssef/git/apps_wifi/ble_coex/build/ble_coex/zephyr/include/generated/zephyr/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=/home/youssef/zephyr-sdk-0.17.0/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/youssef/git/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/youssef/git/apps_wifi/ble_coex=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/youssef/git/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/youssef/git=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -D_POSIX_THREADS -std=c99 -MD -MT zephyr/drivers/wifi/nrf_wifi/CMakeFiles/nrf_wifi.dir/src/coex.c.obj -MF zephyr/drivers/wifi/nrf_wifi/CMakeFiles/nrf_wifi.dir/src/coex.c.obj.d -o zephyr/drivers/wifi/nrf_wifi/CMakeFiles/nrf_wifi.dir/src/coex.c.obj -c /home/youssef/git/zephyr/drivers/wifi/nrf_wifi/src/coex.c
    In file included from /home/youssef/git/zephyr/include/zephyr/toolchain/gcc.h:98,
                     from /home/youssef/git/zephyr/include/zephyr/toolchain.h:50,
                     from /home/youssef/git/zephyr/include/zephyr/kernel_includes.h:23,
                     from /home/youssef/git/zephyr/include/zephyr/kernel.h:17,
                     from /home/youssef/git/zephyr/drivers/wifi/nrf_wifi/src/coex.c:13:
    /home/youssef/git/zephyr/include/zephyr/device.h:92:41: error: '__device_dts_ord_DT_N_S_soc_S_peripheral_50000000_S_spi_c000_S_wifi_1_P_srrf_switch_gpios_IDX_0_PH_ORD' undeclared here (not in a function); did you mean 'DT_N_S_soc_S_peripheral_50000000_S_spi_c000_S_wifi_1_P_host_irq_gpios_IDX_0_PH'?
       92 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
    /home/youssef/git/zephyr/include/zephyr/toolchain/common.h:137:26: note: in definition of macro '_DO_CONCAT'
      137 | #define _DO_CONCAT(x, y) x ## y
    /home/youssef/git/zephyr/include/zephyr/device.h:92:33: note: in expansion of macro '_CONCAT'
    /home/youssef/git/zephyr/include/zephyr/device.h:229:37: note: in expansion of macro 'DEVICE_NAME_GET'
      229 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_ID(node_id))
    /home/youssef/git/zephyr/include/zephyr/device.h:246:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
      246 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
    /home/youssef/git/zephyr/include/zephyr/drivers/gpio.h:333:25: note: in expansion of macro 'DEVICE_DT_GET'
      333 |                 .port = DEVICE_DT_GET(DT_GPIO_CTLR_BY_IDX(node_id, prop, idx)),\
    /home/youssef/git/zephyr/include/zephyr/drivers/gpio.h:369:9: note: in expansion of macro 'GPIO_DT_SPEC_GET_BY_IDX'
      369 |         GPIO_DT_SPEC_GET_BY_IDX(node_id, prop, 0)
    /home/youssef/git/zephyr/drivers/wifi/nrf_wifi/src/coex.c:46:9: note: in expansion of macro 'GPIO_DT_SPEC_GET'
       46 |         GPIO_DT_SPEC_GET(NRF_RADIO_COEX_NODE, srrf_switch_gpios);
    In file included from /home/youssef/git/zephyr/include/zephyr/arch/arm/arch.h:20,
                     from /home/youssef/git/zephyr/include/zephyr/arch/cpu.h:19,
                     from /home/youssef/git/zephyr/include/zephyr/kernel_includes.h:36:
    /home/youssef/git/apps_wifi/ble_coex/build/ble_coex/zephyr/include/generated/zephyr/devicetree_generated.h:17659:40: error: 'DT_N_S_soc_S_peripheral_50000000_S_spi_c000_S_wifi_1_P_srrf_switch_gpios_IDX_0_VAL_pin' undeclared here (not in a function); did you mean 'DT_N_S_soc_S_peripheral_50000000_S_spi_c000_S_wifi_1_P_host_irq_gpios_IDX_0_VAL_pin'?
    17659 | #define DT_N_NODELABEL_nrf70           DT_N_S_soc_S_peripheral_50000000_S_spi_c000_S_wifi_1
    /home/youssef/git/zephyr/include/zephyr/devicetree.h:4888:9: note: in definition of macro 'DT_CAT7'
     4888 |         a1 ## a2 ## a3 ## a4 ## a5 ## a6 ## a7
    /home/youssef/git/zephyr/include/zephyr/devicetree/gpio.h:110:9: note: in expansion of macro 'DT_PHA_BY_IDX'
      110 |         DT_PHA_BY_IDX(node_id, gpio_pha, idx, pin)
    /home/youssef/git/zephyr/include/zephyr/drivers/gpio.h:334:24: note: in expansion of macro 'DT_GPIO_PIN_BY_IDX'
      334 |                 .pin = DT_GPIO_PIN_BY_IDX(node_id, prop, idx),                 \
    /home/youssef/git/zephyr/include/zephyr/devicetree.h:4877:24: note: in expansion of macro 'DT_N_NODELABEL_nrf70'
     4877 | #define DT_CAT(a1, a2) a1 ## a2
    /home/youssef/git/zephyr/include/zephyr/devicetree.h:200:29: note: in expansion of macro 'DT_CAT'
      200 | #define DT_NODELABEL(label) DT_CAT(DT_N_NODELABEL_, label)
    /home/youssef/git/zephyr/drivers/wifi/nrf_wifi/src/coex.c:44:37: note: in expansion of macro 'DT_NODELABEL'
       44 |         #define NRF_RADIO_COEX_NODE DT_NODELABEL(nrf70)
    /home/youssef/git/zephyr/drivers/wifi/nrf_wifi/src/coex.c:46:26: note: in expansion of macro 'NRF_RADIO_COEX_NODE'
    [496/605] Building C object zephyr/drivers/wifi/nrf_wifi/CMakeFiles/nrf_wifi.dir/src/wpa_supp_if.c.obj
    FAILED: _sysbuild/sysbuild/images/ble_coex-prefix/src/ble_coex-stamp/ble_coex-build /home/youssef/git/apps_wifi/ble_coex/build/_sysbuild/sysbuild/images/ble_coex-prefix/src/ble_coex-stamp/ble_coex-build
    cd /home/youssef/git/apps_wifi/ble_coex/build/ble_coex && /usr/bin/cmake --build .
    FATAL ERROR: command exited with status 1: /usr/bin/cmake --build /home/youssef/git/apps_wifi/ble_coex/build
    Please note that I have already activated the nrf70 node in the configuration.
    If needed, I can share my .conf and overlay files for reference. They are identical to those used in the shell sample, except for RTT activation.
    Looking forward to your guidance.
    Youssef
    thingy91x_nrf5340_cpuapp.conf
    thingy91x_nrf5340_cpuapp.overlay
  • Hi Dejan,
    I noticed that when I add this Kconfig to my sysbuild.conf, I no longer see any LOGs on the RTT. However, if I remove it, I encounter a flash overflow issue. Could you please suggest a solution to resolve this problem?
    SB_CONFIG_THINGY91X_STATIC_PARTITIONS_NRF53_EXTERNAL_FLASH=y
    Thank you!
    For testing Wi-fi shell, you could try to build the sample using this command
    west build -b thingy91x/nrf5340/cpuapp -- -DSB_CONFIG_THINGY91X_STATIC_PARTITIONS_NRF53_EXTERNAL_FLASH=y
    and then use Serial Terminal to connect to your Thingy91X.
    Dejan
