nrf5340dk - sdk v2.6.1 - SPIM4 designed pin P0.10 & 32MHz speed not working
Good evening,
I have been working for a while on a project that requires the maximum possible speed from both app core and SPIM4 peripheral. To do so, I set the app core clock speed to 128MHz executing these lines as first operation in main function:
printk("CPU clock during booting: %u Hz\n", SystemCoreClock);
printk("NRF_CLOCK_S.HFCLKCTRL:%d\n",NRF_CLOCK_S->HFCLKCTRL);
printk("Switching application core from 64 MHz and 128 MHz. \n");
*(volatile uint32_t *)0x5084450C= 0x4040;
*(volatile uint32_t *)0x50026548 = 0x40;
*(volatile uint32_t *)0x50081EE4 = 0x4D;
NRF_CLOCK_S->HFCLKCTRL = 0;
nrfx_clock_divider_set(NRF_CLOCK_DOMAIN_HFCLK, NRF_CLOCK_HFCLK_DIV_1);
printk("NRF_CLOCK_S.HFCLKCTRL:%d\n", NRF_CLOCK_S->HFCLKCTRL);
printk("Check freq status running:%d\n", NRF_CLOCK_S->HFCLKSTAT);
for what concerns the SPIM4 configuration, in the overlay file I have:
&pinctrl {
spi4_default: spi4_default {
group1 {
nordic,drive-mode = <NRF_DRIVE_H0H1>;
psels = <NRF_PSEL(SPIM_MOSI, 0, 9)>,
<NRF_PSEL(SPIM_SCK, 0, 8)>,
<NRF_PSEL(SPIM_MISO, 0, 12)>;
spi4_sleep: spi4_sleep {
group1 {
low-power-enable;
&spi4 {
cs-gpios = <&gpio0 11 GPIO_ACTIVE_LOW>;
max-frequency = <DT_FREQ_M(16)>;
#address-cells = <1>;
#size-cells = <0>;
rx-delay-supported;
rx-delay = <0>;
status = "okay";
pinctrl-0 = <&spi4_default>;
pinctrl-1 = <&spi4_sleep>;
NOTE: at the moment max-frequency is set to 16MHz and MISO pin is associated to P0.12 since it was the only way I found to make this peripheral work.
in main function, instead I execute this function after setting the app core clock freq. to 128MHz:
bool spim_initialization(void)
nrfx_spim_config_t spim_config = NRFX_SPIM_DEFAULT_CONFIG(SCK_PIN,
MOSI_PIN,
MISO_PIN,
CS1_PIN);
spim_config.frequency = NRFX_MHZ_TO_HZ(16);
spim_config.miso_pull = NRF_GPIO_PIN_NOPULL;
NRFX_COND_CODE_1(NRFX_SPIM_EXTENDED_ENABLED, (spim_config.use_hw_ss = true; spim_config.ss_duration = 0x01;), ()); //prova con 0x00
nrfx_err_t status = nrfx_spim_init(&spim_inst, &spim_config, NULL, NULL);
if (status != NRFX_SUCCESS)
printk("SPI initialization failed with error code: %d\n", status);
return 0;
return 1;
I read some tickets that mentioned about the UARTE pin control configuration on net core, but I do not know how I could fix this. So my questions are:
- how to make SPIM4 work at 32MHz?
- how to make MISO pin associated with P0.10 work? -- in this sense, how could I integrate e.g. another overlay file for the cpunet core that changes uarte pin control configuration to my project? ( I work on VS code on MacOS).
- should I execute *(volatile uint32_t *)0x5000ac04 = 1; ? if yes, at which point of my main function?
NOTE 2: SPIM4 configured as above seems to work at 16MHz, configuring P0.12 as MISO pin.
Thank you,
Sara L.
  • here in the following lines you can find my nrf5340dk_nrf5340_cpuapp.overlay complete file. I can guarantee that MISO signal is not properly received from P0.10 with the following configuration.
    &pinctrl {
    group1 {
    <NRF_PSEL(SPIM_MISO, 0, 10)>;
    group1 {
    low-power-enable;
    spi1_default: spi1_default {
    group1 {
    psels = <NRF_PSEL(SPIM_SCK, 0, 6)>,
    <NRF_PSEL(SPIM_MOSI, 0, 5)>,
    <NRF_PSEL(SPIM_MISO, 0, 26)>;
    spi1_sleep: spi1_sleep {
    group1 {
    low-power-enable;
    &spi4 {
    #size-cells = <0>;
    rx-delay-supported;
    rx-delay = <0>;
    status = "okay";
    &spi1 {
    status = "okay";
    pinctrl-0 = <&spi1_default>;
    pinctrl-1 = <&spi1_sleep>;
    interrupts = <9 NRF_DEFAULT_IRQ_PRIORITY>;
    max-frequency = <DT_FREQ_M(8)>;
    cs-gpios = <&gpio0 25 GPIO_ACTIVE_LOW>;
    sdhc0: sdhc@0 {
    compatible = "zephyr,sdhc-spi-slot";
    reg = <0>;
    status = "okay";
    spi-max-frequency = <25000000>;
    mmc {
    compatible = "zephyr,sdmmc-disk";
    status = "okay";
    &button2 {
    gpios = <&gpio0 7 0>;
    status = "disabled";
    &button3 {
    gpios = <&gpio0 27 0>;
    &timer0 {
    status = "okay";
    &timer1 {
    status ="okay";
    &timer2 {
    status ="okay";
    chosen {
    zephyr,shell-uart = &uart0;
    aliases {
    led0 = &led0;
    sw0 = &button0;
    &i2c0 { status = "disabled";};
    &spi0 { status = "disabled";};
    &i2c1 { status = "disabled";};
    &adc { status = "disabled";};
    &qspi { status = "disabled";};
    &uart1 { status = "disabled";};
    &gpio_fwd {
    uart {
    gpios = <&gpio0 0 0>, <&gpio0 1 0>, <&gpio1 1 0>, <&gpio1 0 0>;
  • I thought that maybe there is some other peripherals that is already associated with P0.10 through some default configuration in the NET core?
  • Correct me if I am wrong, but maybe P0.10 could be configured on NET core as uart0 UART_CTS pin (saw it on nrf5340dk_nrf5340_cpunet.pincntrl.dtsi file in sdk v2.6.1>zephyr>boards>arm>nrf5340dk_nrf5340 folder).
    considering that I have worked on APP core only so far, how could I modify this configuration?
    - i enabled CONFIG_BT=in my prj.conf file;
    - should I put gpio_fwd status as enabled and perhaps change part gpio pins?
    - should I add another .overlay file for the NET core and add it as Extra devicetree overlay in my build configuration?
    could you propose any other solution for me?
    thank you
  • If you enable log/serial from the netcore it will use uart pins yes, however the netcore should not be able to control pins that the appcore don't add to the overlay/dts file for the gpio_fwd: nrf-gpio-forwarder node. So maybe take a look at the zephyr.dts file in the build folder for the appcore and check which pins that are given control to the netcore.
    Kenneth
