nrf5340 NCS 2.8 cannot get TLS socket to load CA certif due to net_sock_tls / mbedtls error -0x262e
Using Zephyr in NCS 2.8 on nrf5340/nrf7002 wifi combo, and trying to get https to work. I'm using the option where the TLS setup is done in the socket layer (enabled in prj.conf)
# use TLS in socket directly
CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
CONFIG_TLS_CREDENTIALS=y
CONFIG_TLS_MAX_CREDENTIALS_NUMBER=10
CONFIG_NET_SOCKETS_TLS_MAX_CREDENTIALS=10
However, I cannot get this to parse a server certificate (.der or .pem formats). Every time it fails when it tries to parse the certificate to load the url, with the following:
[00:00:24.298,767] <inf> app: host [timeapi.io/api/time/current/zone?timeZone=Europe%2FParis&id="app.sysctrl.checkhttp"&value="00:00:00"] port [NULL] path [/api/time/current/zone?timeZone=Europe%2FParis&id="app.sysctrl.checkhttp"&value="00:00:00"] query [?timeZone=E
[00:00:24.322,906] <inf> app: Looking up host [timeapi.io][443], asking for path[/api/time/current/zone?timeZone=Europe%2FParis&id="app.sysctrl.checkhttp"&value="00:00:00"]
[00:00:24.360,046] <inf> app: Resolved 86.105.246.247 (AF_INET)
[00:00:24.366,485] <inf> app: httpmgr: checking certs/ca for certs
[00:00:24.376,586] <inf> app: httpmgr : registered cert [certs/ca/timeapi.io.der]
[00:00:24.387,054] <inf> app: httpmgr : registered cert [certs/ca/www.infrafon.cloud.der]
[00:00:24.395,996] <inf> app: httpmgr: checking certs/cli for certs
[00:00:24.403,930] <inf> app: httpmgr: added 2 TLS certificates
[00:00:24.410,308] <inf> app: httpmgr : TLS setup OK on socket
[00:00:24.416,595] <inf> app: Connecting to timeapi.io:443
[00:00:24.455,474] <err> net_sock_tls: Failed to parse CA certificate, err: -0x262e
[00:00:24.463,867] <wrn> app: Failed to connect socket (-1), [22]
[00:00:24.470,947] <wrn> app: uimgr : http req fails to start to time;timeapi.io/.../zone
Note:
 - I'm using timeapi.io as an easy test URL, not really because this is my target server!
 - at init, I load (once) the certificates from my flash FS by mallocing space for the data and then calling tls_credential_add() to give the buffer to the socket TLS system referenced by a "security tag" id for each one
 - when I create the socket, I setsockopt(TLS_SEC_TAG_LIST) it with the list of all the security tag values I previously added the certificates under so it can reference them.
The problem occurs when I call connect() on the socket, as that's when the TLS layer tries to parse the certificates....
In the debugger; the fail is in
x509.c : mbedtls_x509_crt_parse()
which calls
mbedtls_x509_crt_parse_der()
which ends up in
x509_crt_parse_der_core()
As far as I can tell, its when it calls in line 1168:
mbedtls_x509_get_sig_alg() (in x509.c)
that it gets a return value of  -0x262e. in this function This is the add of
MBEDTLS_ERR_X509_UNKNOWN_SIG_ALG + the ret from
mbedtls_oid_get_sig_alg()
This is a function created by lovely macro cin oid.c:
int mbedtls_oid_get_sig_alg(const mbedtls_asn1_buf *oid, mbedtls_md_type_t * md_alg, mbedtls_pk_type_t * pk_alg) {
  const oid_sig_alg_t *data = oid_sig_alg_from_asn1(oid);
  if (data == ((void *)0))
       return -0x002E;
  *(md_alg) = data->md_alg;
  *(pk_alg) = data->pk_alg;
  return 0;
(btw this kind of macro *** really makes the debugger hard to follow...)
The oid_sig_alg_from_asn1() function which tries to extract the OID of the certificate's signature algo from the asn.1 and map it to the mbedtls types... is another macro defined function in oid.c:
FN_OID_TYPED_FROM_ASN1(oid_sig_alg_t, sig_alg, oid_sig_alg)
which gives us:
static const oid_sig_alg_t *oid_sig_alg_from_asn1( const mbedtls_asn1_buf *oid) {
  const oid_sig_alg_t *p = (oid_sig_alg);
  const mbedtls_oid_descriptor_t *cur = (const mbedtls_oid_descriptor_t *) p;
  if (p == ((void *)0) || oid == ((void *)0))
    return ((void *)0);
  while (cur->asn1 != ((void *)0)) {
    if (cur->asn1_len == oid->len && memcmp(cur->asn1, oid->p, oid->len) == 0) {
      return p;
    p++;
  return ((void *)0);
Unpacking this, its searching for the oid given in the certificate in a static array (oid_sig_alg in oic.c) generated with a load of ifdefs depending on which crypto algos are compiled in...
The certificate is using PKCS#1 SHA-256 with RSA (the public key of the certificate of timeapi.io is 2048 size) according to chrome's handy popup...
And indeed, in my oid.c, only sha256 with ECDSA algos are enabled...in fact no RSA algo is enabled (MBEDTLS_RSA_C is not defined)
All this hidden behinf that errno=-22 from connect().... lucky I got that nice error log from the TLS layer eh?
So, it seems I just need to define :
MBEDTLS_RSA_C
However, the saga continues - this define is already set in the mbedtls config file I select (zephyr/modules/mbedtls/config/config-mini-tls1_2.h) in my prj.conf:
CONFIG_NRF_SECURITY=n
CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=n
CONFIG_CUSTOM_MBEDTLS_CFG_FILE=y
CONFIG_MBEDTLS_CFG_FILE="config-mini-tls1_2.h"
CONFIG_MBEDTLS_PEM_CERTIFICATE_FORMAT=y
However, visual code studio tells me that in the build NRF_SECURITY is 'y', and the MBEDTLS_CFG_FILE is set to 'nrf-config.h'!
The only place I can find this file is in
build/generated/library_nrf_security_psa/nrf-config.h
... and it indeed does NOT define MBEDTLS_RSA_C....
(and why does it all have to be so complicated and wrapped in 27 layers of kconfig files and macros???)
So finally my question : how do I get the nrf wrappers round the zephyr KConfig to accept that I want to use a specific mbedtls config, which includes MBEDTLS_RSA_C?
Also, it seems the sockets TLS code is hardcoded to use mbedtls functions : is there an alternative (which might take up less flash space, eg tinycrypt?
Naively I though I could just do
CONFIG_MBEDTLS=n
CONFIG_TINYCRYPT=y
but no joy (although maybe this is because its forcing mbedtls/nrf_security?)
  • I am now on NCS 2.9, but still with just mbedtls as it seems the PSA integration in Zephyr/NCS is not yet fully operational.
    I stil find it incredible how much flash/RAM is required to do a 'simple' https GET over wifi using the nordic solution. It would be (IMHO) very much to Nordics benefit if they put some effort into providing a minimal config setup that actually works in the real world (ie with mix of RSA up to 4K, common ECC curves etc) and doesn't use up 2/3 of the available resources to do so....
    btw one of the reasons to move to 2.9 was to get fixes in the wifi, and to put the "wifi patches' (aka the nrf70 firmware) into the external flash as a DFU able image - that saved me nearly 80kB flash right there.... I lost a little to mcuboot (68kB) to be able to get 3 image DFUable system with the serial recovery over USB vcom, but it was worth it to gain the 80kB of wifi fw space....
  • Hi all,
    I'm stuck with this situation as well.  Of course, I want to use PSA but it's not fully developed for offloaded sockets yet.
    It should be noted that offloaded sockets can't use ECC keys either, if those keys have RSA signatures, which is what Amazon AWS signs ECC keys with.  There's no way to change this that I've found, hence we are unable to connect to AWS using offloaded sockets.
    Any update on improving support for X.509 certificates when using mbedTLS,  ?
    Since there's not enough RAM on the nRF9160/61/51 to use PSA and mbedTLS together, the way forward is disabling PSA and all hardware crypto and using mbedTLS only, but this is not ideal.
