Unable to flash a build of the sample blinky following the nRF Connect SDK Fundamentals tutorial
Hey everyone,
I am new to the development of Nordic chips so I might get some things wronog here or there.
I am using windows 11 and am trying to flash a nRF54l15 DK board
Lets start with the sittuation. I am attempting to follow the nRF Connect SDK Fundamentals tutorial with a new nRF54l15-DK board. I followed all the steps for installing the nRF Connect SDK and VS Code. I then imported, build and tried to flash the code. When I did I had the fatal error that the nrfutil was not installed or in the path. I downloaded that, placed it in the blinky folder and used my windows command prompt to install it. After having done that, I lost the nrfutil fatal error but gained a new one. I also tried connecting using the quick start of the nRF connect for desktop and got to the program step. Here the Erase device shows green but the others are red.
Here is the log of the quick start, which has the same error I get from VSCode's terminal.
2025-01-10T11:01:13.537Z INFO Initialising the bundled nrfutil device
2025-01-10T11:01:13.545Z DEBUG Started watching devices
2025-01-10T11:01:14.562Z INFO Using the bundled core version for nrfutil device: 7.13.0
2025-01-10T11:01:15.012Z INFO Using nrfutil-device version: 2.7.5
2025-01-10T11:01:15.012Z INFO Using nrf-device-lib version: 0.17.41
2025-01-10T11:01:15.012Z INFO Using nrfjprog DLL version: 10.24.2
2025-01-10T11:01:15.012Z INFO Using JLink version: JLink_V7.94i
2025-01-10T11:01:16.538Z DEBUG Selected device: nRF54L15 DK
2025-01-10T11:01:16.558Z DEBUG Changed step: Info
2025-01-10T11:01:23.661Z DEBUG Changed step: Rename
2025-01-10T11:02:17.819Z DEBUG Changed step: Program
2025-01-10T11:02:45.962Z ERROR  NRFDLException(1): [Probe] Emulator error: No emulator with connection info 'Usb(JLinkSerialNumber(1057701372))' was found
2025-01-10T11:02:45.967Z ERROR [ProbeLib] [2025-01-10 11:02:45.963873Z] Trace channel disconnected unexpectedly.
I have already installed a new version of J-Link, v794i (conform these specs: https://docs.nordicsemi.com/bundle/ncs-2.9.0/page/nrf/installation/recommended_versions.html). I didn't remove the older version though, v794e.
If anyone has any idea how I can fix this problem please let me know!
Geert
  • Please try the following:
    nrfutil device --version
    and then run the following and upload the logs:
    nrfutil device list --log-level trace
    nrfutil device fw-info --serial-number 1057701372 --log-level trace
    This will create a log file in C:\Users\geert\.nrfutil\logs\nrfutil-device.log, which should provide some more information about what's happening.
    Regards
    Runar
  • Hey Runar,
    Thank you for your time. Below is the log of the cmd of all the commands you told me to use.
    PS C:\Users\geert> nrfutil device --version
    nrfutil-device 2.7.11 (7005884 2025-01-15)
    commit-hash: 70058847a6226212a758c274d19aa8f95dc23cdc
    commit-date: 2025-01-15
    host: x86_64-pc-windows-msvc
    build-timestamp: 2025-01-16T09:18:42.423984900Z
    classification: nrf-external
    Detected SEGGER J-Link version: JLink_V7.94i
    The device command version you are currently using was tested with a different J-Link version (JLink_V8.10f) than the one you have installed (JLink_V7.94i). The tested version is not required, and your J-Link version will most likely work fine. If you get issues related to J-Link with your devices, use the tested version.
    PS C:\Users\geert> nrfutil device list --log-level trace
    1057701372
    product         J-Link
    board version   PCA10156
    ports           COM3, vcom: 0
                    COM4, vcom: 1
    traits          boardController, devkit, jlink, seggerUsb, serialPorts, usb
    Found 1 supported device(s)
    PS C:\Users\geert> nrfutil device fw-info --serial-number 1057701372 --log-level trace
    Error: Failed to get firmware info for one or more devices:
     * 1057701372: [Probe] Emulator error: No emulator with connection info 'Usb(JLinkSerialNumber(1057701372))' was found, code: Generic
    PS C:\Users\geertvanlammeren>
    Here is the log of the nrfutil-device file within .nrfutil/log. Hopefully you can find something within it. I definitly can't.
    [2025-01-16T15:19:02.432Z] [29064] INFO - nrfutil-device (version = 2.7.11, platform = x86_64-pc-windows-msvc) invoked with --version
    [2025-01-16T15:19:02.444Z] [29064] INFO - [ProbeLib] [2025-01-16 15:19:02.444586Z] Opened J-Link DLL at C:\Program Files\SEGGER\JLink_V794i\JLink_x64.dll with version 7.94i
    [2025-01-16T15:19:02.698Z] [29064] WARN - [JlinkARM] nrfutil device commands were tested using SEGGER J-Link version JLink_V8.10f, but the J-Link version you are using is JLink_V7.94i. Your installed version will most likely work fine, but if you get issues related to J-Link with your devices, use the tested version
    [2025-01-16T15:19:06.969Z] [10864] INFO - nrfutil-device (version = 2.7.11, platform = x86_64-pc-windows-msvc) invoked with list --log-level trace
    [2025-01-16T15:19:06.969Z] [10864] DEBUG - cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false
    [2025-01-16T15:19:06.969Z] [10864] DEBUG - Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be C:\Users\geert\.nrfutil\lib\nrfutil-device
    [2025-01-16T15:19:06.978Z] [10864] TRACE - [ProbeLib] [2025-01-16 15:19:06.978097Z] J-Link installation directory configured in registry: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\SEGGER\J-Link="C:\\Program Files\\SEGGER\\JLink_V794i"
    [2025-01-16T15:19:06.980Z] [10864] INFO - [ProbeLib] [2025-01-16 15:19:06.980767Z] Opened J-Link DLL at C:\Program Files\SEGGER\JLink_V794i\JLink_x64.dll with version 7.94i
    [2025-01-16T15:19:07.077Z] [10864] DEBUG - [jlink] [NRFJPROG][Client][-] open
    [2025-01-16T15:19:07.077Z] [10864] DEBUG - [jlink] [NRFJPROG][Client][-] start
    [2025-01-16T15:19:07.123Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    [2025-01-16T15:19:07.123Z] [10864] DEBUG - [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    [2025-01-16T15:19:07.123Z] [10864] DEBUG - [jlink] [NRFJPROG][nRFXX][-] open
    [2025-01-16T15:19:07.123Z] [10864] DEBUG - [jlink] [NRFJPROG][nRFXX][-] just_check_family
    [2025-01-16T15:19:07.123Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    [2025-01-16T15:19:07.123Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    [2025-01-16T15:19:07.126Z] [10864] TRACE - [jlink] [NRFJPROG][Client][-] Command open executed for 44 milliseconds with result 0
    [2025-01-16T15:19:07.126Z] [10864] DEBUG - [jlink] [NRFJPROG][Client][-] jlink_dll_version
    [2025-01-16T15:19:07.126Z] [10864] TRACE - [jlink] [NRFJPROG][Client][-] Command jlink_dll_version executed for 0 milliseconds with result 0
    [2025-01-16T15:19:07.145Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    [2025-01-16T15:19:07.145Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    [2025-01-16T15:19:07.145Z] [10864] TRACE - [jlink] [NRFJPROG][Worker][-] Command open executed for 4 milliseconds with result 0
    [2025-01-16T15:19:07.145Z] [10864] DEBUG - [jlink] [NRFJPROG][nRFXX][-] dll_version
    [2025-01-16T15:19:07.145Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    [2025-01-16T15:19:07.145Z] [10864] TRACE - [jlink] [NRFJPROG][Worker][-] Command jlink_dll_version executed for 0 milliseconds with result 0
    [2025-01-16T15:19:07.145Z] [10864] DEBUG - [jlink] [NRFJPROG][nRFXX][-] close
    [2025-01-16T15:19:07.146Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    [2025-01-16T15:19:07.146Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] close
    [2025-01-16T15:19:07.146Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    [2025-01-16T15:19:07.146Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    [2025-01-16T15:19:07.146Z] [10864] DEBUG - [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    [2025-01-16T15:19:07.164Z] [10864] TRACE - [jlink] [NRFJPROG][Client][-] Command close executed for 37 milliseconds with result 0
    [2025-01-16T15:19:07.164Z] [10864] DEBUG - [jlink] [NRFJPROG][Client][-] terminate
    [2025-01-16T15:19:07.178Z] [10864] TRACE - [jlink] [NRFJPROG][Client][-] Command terminate executed for 14 milliseconds with result 0
    [2025-01-16T15:19:07.179Z] [10864] TRACE - [jlink] [NRFJPROG][Worker][-] Command close executed for 34 milliseconds with result 0
    [2025-01-16T15:19:07.194Z] [10864] TRACE - [jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0
    [2025-01-16T15:19:07.194Z] [10864] TRACE - [jlink] [NRFJPROG][Worker][-] Executed 4 commands for 38 milliseconds
    [2025-01-16T15:19:07.227Z] [10864] DEBUG - [jlink] [NRFJPROG][Client][-] Worker process exited with code: 0
    [2025-01-16T15:19:07.228Z] [10864] DEBUG - [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    [2025-01-16T15:19:07.228Z] [10864] TRACE - [jlink] [NRFJPROG][Client][-] Executed 4 commands for 95 milliseconds
    [2025-01-16T15:19:07.228Z] [10864] DEBUG - [jlink] [NRFJPROG][Client][-] terminate
    [2025-01-16T15:19:07.241Z] [10864] WARN - [JlinkARM] nrfutil device commands were tested using SEGGER J-Link version JLink_V8.10f, but the J-Link version you are using is JLink_V7.94i. Your installed version will most likely work fine, but if you get issues related to J-Link with your devices, use the tested version
    [2025-01-16T15:19:07.241Z] [10864] TRACE - DeviceLister::enumerate: Checking future_status of enumerate_task_status
    [2025-01-16T15:19:07.241Z] [10864] TRACE - DeviceLister::enumerate: Waiting for enumeration to complete
    [2025-01-16T15:19:07.242Z] [10864] TRACE - DeviceLister::enumerate::enumerate_task: Start
    [2025-01-16T15:19:07.242Z] [10864] TRACE - DeviceLister::enumerate::enumerate_task: Before async_lister->enumerate
    [2025-01-16T15:19:07.242Z] [10864] DEBUG - USBLister: enumerate
    [2025-01-16T15:19:07.242Z] [10864] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_17EF&PID_30FC#1SSD21K04345ZZQ01K9J#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:07.242Z] [10864] DEBUG - usb-lister-rs: Container ID: '{2ECEDC5C-CD9E-11EF-AF27-806E6F6E6963}'
    [2025-01-16T15:19:07.242Z] [10864] DEBUG - usb-lister-rs: Hub device path: \\?\USB#VID_17EF&PID_3102#6&3640C1B5&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {2ECEDC5C-CD9E-11EF-AF27-806E6F6E6963}
    [2025-01-16T15:19:07.250Z] [10864] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_17EF&PID_3103#000000000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:07.250Z] [10864] DEBUG - usb-lister-rs: Container ID: '{2ECEDC5C-CD9E-11EF-AF27-806E6F6E6963}'
    [2025-01-16T15:19:07.250Z] [10864] DEBUG - usb-lister-rs: Hub device path: \\?\USB#VID_17EF&PID_3102#6&3640C1B5&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {2ECEDC5C-CD9E-11EF-AF27-806E6F6E6963}
    [2025-01-16T15:19:07.259Z] [10864] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_0489&PID_E0CD#000000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:07.259Z] [10864] DEBUG - usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'
    [2025-01-16T15:19:07.259Z] [10864] DEBUG - usb-lister-rs: Hub device path: \\?\USB#ROOT_HUB30#5&33210E6E&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    [2025-01-16T15:19:07.259Z] [10864] WARN - usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:07.259Z] [10864] WARN - usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:07.259Z] [10864] WARN - usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:07.259Z] [10864] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_1366&PID_1059#001057701372#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:07.259Z] [10864] DEBUG - usb-lister-rs: Container ID: '{B2E35B05-90B7-5F9E-BAFC-9CE5785D7D25}'
    [2025-01-16T15:19:07.259Z] [10864] DEBUG - usb-lister-rs: Hub device path: \\?\USB#ROOT_HUB30#5&1A87E6C4&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {B2E35B05-90B7-5F9E-BAFC-9CE5785D7D25}
    [2025-01-16T15:19:07.264Z] [10864] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_04F2&PID_B7B4#0001#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:07.264Z] [10864] DEBUG - usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'
    [2025-01-16T15:19:07.264Z] [10864] DEBUG - usb-lister-rs: Hub device path: \\?\USB#ROOT_HUB30#5&1A87E6C4&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    [2025-01-16T15:19:07.264Z] [10864] WARN - usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:07.264Z] [10864] WARN - usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:07.264Z] [10864] WARN - usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:07.264Z] [10864] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_10A5&PID_9800#6&3640c1b5&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:07.264Z] [10864] DEBUG - usb-lister-rs: Hub device path: \\?\USB#ROOT_HUB30#5&33210E6E&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    [2025-01-16T15:19:07.264Z] [10864] WARN - usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index
    [2025-01-16T15:19:07.264Z] [10864] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_046D&PID_C077#9&2dd1df7a&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:07.264Z] [10864] DEBUG - usb-lister-rs: Container ID: '{2ECEDC97-CD9E-11EF-AF27-806E6F6E6963}'
    [2025-01-16T15:19:07.264Z] [10864] DEBUG - usb-lister-rs: Hub device path: \\?\USB#VID_17EF&PID_3101#MSFT20000000001#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {2ECEDC97-CD9E-11EF-AF27-806E6F6E6963}
    [2025-01-16T15:19:07.268Z] [10864] WARN - usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index
    [2025-01-16T15:19:07.268Z] [10864] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_0BDA&PID_8153#3213000001#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:07.268Z] [10864] DEBUG - usb-lister-rs: Container ID: '{31E1993F-C3D3-411E-AF53-664157077175}'
    [2025-01-16T15:19:07.268Z] [10864] DEBUG - usb-lister-rs: Hub device path: \\?\USB#VID_17EF&PID_30FE#MSFT30000000001#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 1, origin: {31E1993F-C3D3-411E-AF53-664157077175}
    [2025-01-16T15:19:07.268Z] [10864] WARN - usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:07.268Z] [10864] WARN - usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:07.268Z] [10864] WARN - usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:07.268Z] [10864] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_0BF8&PID_101E#8&135bddd1&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:07.268Z] [10864] DEBUG - usb-lister-rs: Container ID: '{2ECEDC83-CD9E-11EF-AF27-806E6F6E6963}'
    [2025-01-16T15:19:07.268Z] [10864] DEBUG - usb-lister-rs: Hub device path: \\?\USB#VID_17EF&PID_30FF#MSFT20000000001#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {2ECEDC83-CD9E-11EF-AF27-806E6F6E6963}
    [2025-01-16T15:19:07.273Z] [10864] WARN - usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index
    [2025-01-16T15:19:07.273Z] [10864] DEBUG - USBLister: Adding new device with ID 1 and serial number: '1SSD21K04345ZZQ01K9J'
    [2025-01-16T15:19:07.273Z] [10864] DEBUG - USBLister: Adding new device with ID 2 and serial number: 'NONE'
    [2025-01-16T15:19:07.273Z] [10864] DEBUG - USBLister: Adding new device with ID 3 and serial number: 'NONE'
    [2025-01-16T15:19:07.273Z] [10864] DEBUG - USBLister: Adding new device with ID 4 and serial number: 'NONE'
    [2025-01-16T15:19:07.273Z] [10864] DEBUG - USBLister: Adding new device with ID 5 and serial number: 'NONE'
    [2025-01-16T15:19:07.273Z] [10864] DEBUG - USBLister: Adding new device with ID 6 and serial number: 'NONE'
    [2025-01-16T15:19:07.273Z] [10864] DEBUG - USBLister: Adding new device with ID 7 and serial number: 'NONE'
    [2025-01-16T15:19:07.273Z] [10864] DEBUG - USBLister: Adding new device with ID 8 and serial number: '000000000000'
    [2025-01-16T15:19:07.273Z] [10864] DEBUG - USBLister: Adding new device with ID 9 and serial number: '001057701372'
    [2025-01-16T15:19:07.273Z] [10864] TRACE - DeviceLister::enumerate::enumerate_task: After async_lister->enumerate
    [2025-01-16T15:19:07.275Z] [10864] DEBUG - Enumeration for plugin 'devkit' took 1 ms
    [2025-01-16T15:19:07.275Z] [10864] TRACE - [ProbeLib] [2025-01-16 15:19:07.275773Z] J-Link installation directory configured in registry: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\SEGGER\J-Link="C:\\Program Files\\SEGGER\\JLink_V794i"
    [2025-01-16T15:19:07.275Z] [10864] INFO - [ProbeLib] [2025-01-16 15:19:07.275945Z] Opened J-Link DLL at C:\Program Files\SEGGER\JLink_V794i\JLink_x64.dll with version 7.94i
    [2025-01-16T15:19:07.279Z] [10864] INFO - [ProbeLib] [2025-01-16 15:19:07.279067Z] Found 0 attached J-Link devices
    [2025-01-16T15:19:07.279Z] [10864] DEBUG - [ProbeLib] [2025-01-16 15:19:07.279087Z] No J-Link devices found
    [2025-01-16T15:19:07.279Z] [10864] DEBUG - Enumeration for plugin 'Probe' took 3 ms
    [2025-01-16T15:19:07.279Z] [10864] TRACE - [jlink] JLinkPlugin::enumerate
    [2025-01-16T15:19:07.372Z] [10864] DEBUG - [jlink] [NRFJPROG][Client][-] open
    [2025-01-16T15:19:07.372Z] [10864] DEBUG - [jlink] [NRFJPROG][Client][-] start
    [2025-01-16T15:19:07.418Z] [10864] TRACE - [jlink] [NRFJPROG][Client][-] Command open executed for 42 milliseconds with result 0
    [2025-01-16T15:19:07.418Z] [10864] DEBUG - [jlink] [NRFJPROG][Client][-] enum_emu_snr
    [2025-01-16T15:19:07.421Z] [10864] TRACE - [jlink] [NRFJPROG][Client][-] Command enum_emu_snr executed for 2 milliseconds with result 0
    [2025-01-16T15:19:07.421Z] [10864] DEBUG - [jlink] Found 0 J-Link devices connected
    [2025-01-16T15:19:07.429Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    [2025-01-16T15:19:07.429Z] [10864] DEBUG - [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    [2025-01-16T15:19:07.429Z] [10864] DEBUG - [jlink] [NRFJPROG][nRFXX][-] open
    [2025-01-16T15:19:07.429Z] [10864] DEBUG - [jlink] [NRFJPROG][nRFXX][-] just_check_family
    [2025-01-16T15:19:07.429Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    [2025-01-16T15:19:07.429Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    [2025-01-16T15:19:07.429Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    [2025-01-16T15:19:07.429Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    [2025-01-16T15:19:07.429Z] [10864] TRACE - [jlink] [NRFJPROG][Worker][-] Command open executed for 4 milliseconds with result 0
    [2025-01-16T15:19:07.429Z] [10864] DEBUG - [jlink] [NRFJPROG][nRFXX][-] enum_emu_snr
    [2025-01-16T15:19:07.429Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    [2025-01-16T15:19:07.429Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr
    [2025-01-16T15:19:07.429Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr
    [2025-01-16T15:19:07.429Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus
    [2025-01-16T15:19:07.429Z] [10864] TRACE - [jlink] [NRFJPROG][Worker][-] Command enum_emu_snr executed for 2 milliseconds with result 0
    [2025-01-16T15:19:07.430Z] [10864] DEBUG - [jlink] [NRFJPROG][nRFXX][-] close
    [2025-01-16T15:19:07.430Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    [2025-01-16T15:19:07.430Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] close
    [2025-01-16T15:19:07.430Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    [2025-01-16T15:19:07.430Z] [10864] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    [2025-01-16T15:19:07.430Z] [10864] DEBUG - [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    [2025-01-16T15:19:07.444Z] [10864] TRACE - [jlink] [NRFJPROG][Client][-] Command close executed for 22 milliseconds with result 0
    [2025-01-16T15:19:07.444Z] [10864] DEBUG - [jlink] [NRFJPROG][Client][-] terminate
    [2025-01-16T15:19:07.444Z] [10864] TRACE - [jlink] [NRFJPROG][Client][-] Command terminate executed for 0 milliseconds with result 0
    [2025-01-16T15:19:07.476Z] [10864] TRACE - [jlink] [NRFJPROG][Worker][-] Command close executed for 22 milliseconds with result 0
    [2025-01-16T15:19:07.477Z] [10864] TRACE - [jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0
    [2025-01-16T15:19:07.477Z] [10864] TRACE - [jlink] [NRFJPROG][Worker][-] Executed 4 commands for 28 milliseconds
    [2025-01-16T15:19:07.494Z] [10864] DEBUG - [jlink] [NRFJPROG][Client][-] Worker process exited with code: 0
    [2025-01-16T15:19:07.494Z] [10864] DEBUG - [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    [2025-01-16T15:19:07.494Z] [10864] TRACE - [jlink] [NRFJPROG][Client][-] Executed 4 commands for 66 milliseconds
    [2025-01-16T15:19:07.494Z] [10864] DEBUG - [jlink] [NRFJPROG][Client][-] terminate
    [2025-01-16T15:19:07.501Z] [10864] DEBUG - Enumeration for plugin 'jlink' took 222 ms
    [2025-01-16T15:19:07.544Z] [10864] DEBUG - Enumeration for plugin 'BOARDCONTROLLER' took 43 ms
    [2025-01-16T15:19:07.546Z] [10864] DEBUG - [serialport] Looking for GUID: {b2e35b05-90b7-5f9e-bafc-9ce5785d7d25}
    [2025-01-16T15:19:07.546Z] [10864] DEBUG - [serialport] Serial numbers found: ["001051173446", "001057701372", "001057731788"]
    [2025-01-16T15:19:07.546Z] [10864] DEBUG - [serialport] Serial number: 001051173446 -> GUID: {aeda0321-676b-5c08-9c37-766349129945}
    [2025-01-16T15:19:07.546Z] [10864] DEBUG - [serialport] Serial number: 001057701372 -> GUID: {b2e35b05-90b7-5f9e-bafc-9ce5785d7d25}
    [2025-01-16T15:19:07.546Z] [10864] DEBUG - [serialport] Matching serial number? Some("001057701372")
    [2025-01-16T15:19:07.546Z] [10864] DEBUG - [serialport] serial port \\?\USB#VID_1366&PID_1059&MI_00#7&2054A236&0&0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\?\USB#VID_1366&PID_1059#001057701372#{A5DCBF10-6530-11D2-901F-00C04FB951ED}
    [2025-01-16T15:19:07.547Z] [10864] DEBUG - [serialport] Serial numbers found: ["001051173446", "001057701372", "001057731788"]
    [2025-01-16T15:19:07.547Z] [10864] DEBUG - [serialport] Serial number: 001051173446 -> GUID: {aeda0321-676b-5c08-9c37-766349129945}
    [2025-01-16T15:19:07.547Z] [10864] DEBUG - [serialport] Serial number: 001057701372 -> GUID: {b2e35b05-90b7-5f9e-bafc-9ce5785d7d25}
    [2025-01-16T15:19:07.547Z] [10864] DEBUG - [serialport] Matching serial number? Some("001057701372")
    [2025-01-16T15:19:07.547Z] [10864] DEBUG - [serialport] serial port \\?\USB#VID_1366&PID_1059&MI_02#7&2054A236&0&0002#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\?\USB#VID_1366&PID_1059#001057701372#{A5DCBF10-6530-11D2-901F-00C04FB951ED}
    [2025-01-16T15:19:07.547Z] [10864] DEBUG - [serialport] try to map FTDI to segger device
    [2025-01-16T15:19:07.547Z] [10864] DEBUG - [serialport] serialport enumerate update device: '001057701372'
    [2025-01-16T15:19:07.547Z] [10864] DEBUG - Enumeration for plugin 'serialport' took 2 ms
    [2025-01-16T15:19:07.547Z] [10864] DEBUG - Enumeration for plugin 'sdfu' took 0 ms
    [2025-01-16T15:19:07.547Z] [10864] DEBUG - Enumeration for plugin 'mcuBoot' took 0 ms
    [2025-01-16T15:19:07.547Z] [10864] TRACE - [broken] BrokenPlugin::enumerate
    [2025-01-16T15:19:07.548Z] [10864] DEBUG - Enumeration for plugin 'broken' took 0 ms
    [2025-01-16T15:19:07.548Z] [10864] TRACE - DeviceLister::enumerate: Found device with serial number: '1SSD21K04345ZZQ01K9J'
    [2025-01-16T15:19:07.548Z] [10864] TRACE - DeviceLister::enumerate: Found device with serial number: '<unknown>'
    [2025-01-16T15:19:07.548Z] [10864] TRACE - DeviceLister::enumerate: Found device with serial number: '000000000000'
    [2025-01-16T15:19:07.548Z] [10864] TRACE - DeviceLister::enumerate: Found device with serial number: '001057701372'
    [2025-01-16T15:19:07.548Z] [10864] TRACE - DeviceLister::enumerate: device registered to device list
    [2025-01-16T15:19:07.548Z] [10864] TRACE - DeviceLister::enumerate: Finished in 306 ms
    [2025-01-16T15:19:07.548Z] [10864] TRACE - DeviceLister::enumerate: Completed waiting for enumeration
    [2025-01-16T15:19:07.548Z] [10864] TRACE - DeviceLister::enumerate: done
    [2025-01-16T15:19:07.548Z] [10864] TRACE - DeviceLister::shutDown()
    [2025-01-16T15:19:10.640Z] [13476] INFO - nrfutil-device (version = 2.7.11, platform = x86_64-pc-windows-msvc) invoked with fw-info --serial-number 1057701372 --log-level trace
    [2025-01-16T15:19:10.640Z] [13476] DEBUG - cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false
    [2025-01-16T15:19:10.640Z] [13476] DEBUG - Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be C:\Users\geert\.nrfutil\lib\nrfutil-device
    [2025-01-16T15:19:10.648Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:10.648934Z] J-Link installation directory configured in registry: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\SEGGER\J-Link="C:\\Program Files\\SEGGER\\JLink_V794i"
    [2025-01-16T15:19:10.651Z] [13476] INFO - [ProbeLib] [2025-01-16 15:19:10.651338Z] Opened J-Link DLL at C:\Program Files\SEGGER\JLink_V794i\JLink_x64.dll with version 7.94i
    [2025-01-16T15:19:10.746Z] [13476] DEBUG - [jlink] [NRFJPROG][Client][-] open
    [2025-01-16T15:19:10.746Z] [13476] DEBUG - [jlink] [NRFJPROG][Client][-] start
    [2025-01-16T15:19:10.793Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    [2025-01-16T15:19:10.793Z] [13476] DEBUG - [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    [2025-01-16T15:19:10.793Z] [13476] TRACE - [jlink] [NRFJPROG][Client][-] Command open executed for 43 milliseconds with result 0
    [2025-01-16T15:19:10.793Z] [13476] DEBUG - [jlink] [NRFJPROG][nRFXX][-] open
    [2025-01-16T15:19:10.793Z] [13476] DEBUG - [jlink] [NRFJPROG][nRFXX][-] just_check_family
    [2025-01-16T15:19:10.793Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    [2025-01-16T15:19:10.793Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    [2025-01-16T15:19:10.793Z] [13476] DEBUG - [jlink] [NRFJPROG][Client][-] jlink_dll_version
    [2025-01-16T15:19:10.793Z] [13476] TRACE - [jlink] [NRFJPROG][Client][-] Command jlink_dll_version executed for 0 milliseconds with result 0
    [2025-01-16T15:19:10.824Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    [2025-01-16T15:19:10.824Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    [2025-01-16T15:19:10.824Z] [13476] TRACE - [jlink] [NRFJPROG][Worker][-] Command open executed for 4 milliseconds with result 0
    [2025-01-16T15:19:10.824Z] [13476] DEBUG - [jlink] [NRFJPROG][nRFXX][-] dll_version
    [2025-01-16T15:19:10.824Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    [2025-01-16T15:19:10.824Z] [13476] TRACE - [jlink] [NRFJPROG][Worker][-] Command jlink_dll_version executed for 0 milliseconds with result 0
    [2025-01-16T15:19:10.824Z] [13476] DEBUG - [jlink] [NRFJPROG][nRFXX][-] close
    [2025-01-16T15:19:10.824Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] close
    [2025-01-16T15:19:10.825Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    [2025-01-16T15:19:10.825Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    [2025-01-16T15:19:10.825Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    [2025-01-16T15:19:10.825Z] [13476] DEBUG - [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    [2025-01-16T15:19:10.825Z] [13476] TRACE - [jlink] [NRFJPROG][Client][-] Command close executed for 30 milliseconds with result 0
    [2025-01-16T15:19:10.825Z] [13476] DEBUG - [jlink] [NRFJPROG][Client][-] terminate
    [2025-01-16T15:19:10.840Z] [13476] TRACE - [jlink] [NRFJPROG][Client][-] Command terminate executed for 15 milliseconds with result 0
    [2025-01-16T15:19:10.840Z] [13476] TRACE - [jlink] [NRFJPROG][Worker][-] Command close executed for 29 milliseconds with result 0
    [2025-01-16T15:19:10.870Z] [13476] TRACE - [jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0
    [2025-01-16T15:19:10.870Z] [13476] TRACE - [jlink] [NRFJPROG][Worker][-] Executed 4 commands for 33 milliseconds
    [2025-01-16T15:19:10.887Z] [13476] DEBUG - [jlink] [NRFJPROG][Client][-] Worker process exited with code: 0
    [2025-01-16T15:19:10.888Z] [13476] DEBUG - [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    [2025-01-16T15:19:10.888Z] [13476] TRACE - [jlink] [NRFJPROG][Client][-] Executed 4 commands for 88 milliseconds
    [2025-01-16T15:19:10.888Z] [13476] DEBUG - [jlink] [NRFJPROG][Client][-] terminate
    [2025-01-16T15:19:10.895Z] [13476] WARN - [JlinkARM] nrfutil device commands were tested using SEGGER J-Link version JLink_V8.10f, but the J-Link version you are using is JLink_V7.94i. Your installed version will most likely work fine, but if you get issues related to J-Link with your devices, use the tested version
    [2025-01-16T15:19:10.895Z] [13476] DEBUG - operation to get devices for : Ok("{\"operations\":[{\"operation\":{\"type\":\"fw-read-info\"},\"core\":\"NRFDL_DEVICE_CORE_APPLICATION\"}]}")
    [2025-01-16T15:19:10.895Z] [13476] TRACE - Operations required by a device to do: {"fw-read-info"}
    [2025-01-16T15:19:10.895Z] [13476] TRACE - DeviceLister::enumerate: Checking future_status of enumerate_task_status
    [2025-01-16T15:19:10.895Z] [13476] TRACE - DeviceLister::enumerate: Waiting for enumeration to complete
    [2025-01-16T15:19:10.895Z] [13476] TRACE - DeviceLister::enumerate::enumerate_task: Start
    [2025-01-16T15:19:10.895Z] [13476] TRACE - DeviceLister::enumerate::enumerate_task: Before async_lister->enumerate
    [2025-01-16T15:19:10.895Z] [13476] DEBUG - USBLister: enumerate
    [2025-01-16T15:19:10.895Z] [13476] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_17EF&PID_30FC#1SSD21K04345ZZQ01K9J#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:10.895Z] [13476] DEBUG - usb-lister-rs: Container ID: '{2ECEDC5C-CD9E-11EF-AF27-806E6F6E6963}'
    [2025-01-16T15:19:10.896Z] [13476] DEBUG - usb-lister-rs: Hub device path: \\?\USB#VID_17EF&PID_3102#6&3640C1B5&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {2ECEDC5C-CD9E-11EF-AF27-806E6F6E6963}
    [2025-01-16T15:19:10.904Z] [13476] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_17EF&PID_3103#000000000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:10.904Z] [13476] DEBUG - usb-lister-rs: Container ID: '{2ECEDC5C-CD9E-11EF-AF27-806E6F6E6963}'
    [2025-01-16T15:19:10.904Z] [13476] DEBUG - usb-lister-rs: Hub device path: \\?\USB#VID_17EF&PID_3102#6&3640C1B5&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {2ECEDC5C-CD9E-11EF-AF27-806E6F6E6963}
    [2025-01-16T15:19:10.913Z] [13476] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_0489&PID_E0CD#000000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:10.913Z] [13476] DEBUG - usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'
    [2025-01-16T15:19:10.913Z] [13476] DEBUG - usb-lister-rs: Hub device path: \\?\USB#ROOT_HUB30#5&33210E6E&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    [2025-01-16T15:19:10.913Z] [13476] WARN - usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:10.913Z] [13476] WARN - usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:10.913Z] [13476] WARN - usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:10.913Z] [13476] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_1366&PID_1059#001057701372#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:10.913Z] [13476] DEBUG - usb-lister-rs: Container ID: '{B2E35B05-90B7-5F9E-BAFC-9CE5785D7D25}'
    [2025-01-16T15:19:10.913Z] [13476] DEBUG - usb-lister-rs: Hub device path: \\?\USB#ROOT_HUB30#5&1A87E6C4&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {B2E35B05-90B7-5F9E-BAFC-9CE5785D7D25}
    [2025-01-16T15:19:10.918Z] [13476] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_04F2&PID_B7B4#0001#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:10.918Z] [13476] DEBUG - usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'
    [2025-01-16T15:19:10.918Z] [13476] DEBUG - usb-lister-rs: Hub device path: \\?\USB#ROOT_HUB30#5&1A87E6C4&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    [2025-01-16T15:19:10.918Z] [13476] WARN - usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:10.918Z] [13476] WARN - usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:10.918Z] [13476] WARN - usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:10.918Z] [13476] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_10A5&PID_9800#6&3640c1b5&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:10.918Z] [13476] DEBUG - usb-lister-rs: Hub device path: \\?\USB#ROOT_HUB30#5&33210E6E&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    [2025-01-16T15:19:10.918Z] [13476] WARN - usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index
    [2025-01-16T15:19:10.918Z] [13476] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_046D&PID_C077#9&2dd1df7a&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:10.918Z] [13476] DEBUG - usb-lister-rs: Container ID: '{2ECEDC97-CD9E-11EF-AF27-806E6F6E6963}'
    [2025-01-16T15:19:10.918Z] [13476] DEBUG - usb-lister-rs: Hub device path: \\?\USB#VID_17EF&PID_3101#MSFT20000000001#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {2ECEDC97-CD9E-11EF-AF27-806E6F6E6963}
    [2025-01-16T15:19:10.923Z] [13476] WARN - usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index
    [2025-01-16T15:19:10.923Z] [13476] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_0BDA&PID_8153#3213000001#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:10.923Z] [13476] DEBUG - usb-lister-rs: Container ID: '{31E1993F-C3D3-411E-AF53-664157077175}'
    [2025-01-16T15:19:10.923Z] [13476] DEBUG - usb-lister-rs: Hub device path: \\?\USB#VID_17EF&PID_30FE#MSFT30000000001#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 1, origin: {31E1993F-C3D3-411E-AF53-664157077175}
    [2025-01-16T15:19:10.923Z] [13476] WARN - usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:10.923Z] [13476] WARN - usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:10.923Z] [13476] WARN - usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: A device attached to the system is not functioning. (0x8007001F)
    [2025-01-16T15:19:10.923Z] [13476] DEBUG - usb-lister-rs: Enumerating device 'DeviceInstanceId(\\?\USB#VID_0BF8&PID_101E#8&135bddd1&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'
    [2025-01-16T15:19:10.923Z] [13476] DEBUG - usb-lister-rs: Container ID: '{2ECEDC83-CD9E-11EF-AF27-806E6F6E6963}'
    [2025-01-16T15:19:10.923Z] [13476] DEBUG - usb-lister-rs: Hub device path: \\?\USB#VID_17EF&PID_30FF#MSFT20000000001#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {2ECEDC83-CD9E-11EF-AF27-806E6F6E6963}
    [2025-01-16T15:19:10.929Z] [13476] WARN - usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index
    [2025-01-16T15:19:10.929Z] [13476] DEBUG - USBLister: Adding new device with ID 1 and serial number: 'NONE'
    [2025-01-16T15:19:10.929Z] [13476] DEBUG - USBLister: Adding new device with ID 2 and serial number: 'NONE'
    [2025-01-16T15:19:10.929Z] [13476] DEBUG - USBLister: Adding new device with ID 3 and serial number: '1SSD21K04345ZZQ01K9J'
    [2025-01-16T15:19:10.929Z] [13476] DEBUG - USBLister: Adding new device with ID 4 and serial number: 'NONE'
    [2025-01-16T15:19:10.929Z] [13476] DEBUG - USBLister: Adding new device with ID 5 and serial number: '001057701372'
    [2025-01-16T15:19:10.929Z] [13476] DEBUG - USBLister: Adding new device with ID 6 and serial number: 'NONE'
    [2025-01-16T15:19:10.929Z] [13476] DEBUG - USBLister: Adding new device with ID 7 and serial number: '000000000000'
    [2025-01-16T15:19:10.929Z] [13476] DEBUG - USBLister: Adding new device with ID 8 and serial number: 'NONE'
    [2025-01-16T15:19:10.929Z] [13476] DEBUG - USBLister: Adding new device with ID 9 and serial number: 'NONE'
    [2025-01-16T15:19:10.929Z] [13476] TRACE - DeviceLister::enumerate::enumerate_task: After async_lister->enumerate
    [2025-01-16T15:19:10.932Z] [13476] DEBUG - Enumeration for plugin 'devkit' took 1 ms
    [2025-01-16T15:19:10.932Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:10.932319Z] J-Link installation directory configured in registry: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\SEGGER\J-Link="C:\\Program Files\\SEGGER\\JLink_V794i"
    [2025-01-16T15:19:10.932Z] [13476] INFO - [ProbeLib] [2025-01-16 15:19:10.932452Z] Opened J-Link DLL at C:\Program Files\SEGGER\JLink_V794i\JLink_x64.dll with version 7.94i
    [2025-01-16T15:19:10.935Z] [13476] INFO - [ProbeLib] [2025-01-16 15:19:10.935912Z] Found 0 attached J-Link devices
    [2025-01-16T15:19:10.935Z] [13476] DEBUG - [ProbeLib] [2025-01-16 15:19:10.935930Z] No J-Link devices found
    [2025-01-16T15:19:10.935Z] [13476] DEBUG - Enumeration for plugin 'Probe' took 3 ms
    [2025-01-16T15:19:10.936Z] [13476] TRACE - [jlink] JLinkPlugin::enumerate
    [2025-01-16T15:19:11.031Z] [13476] DEBUG - [jlink] [NRFJPROG][Client][-] open
    [2025-01-16T15:19:11.031Z] [13476] DEBUG - [jlink] [NRFJPROG][Client][-] start
    [2025-01-16T15:19:11.078Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    [2025-01-16T15:19:11.078Z] [13476] DEBUG - [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    [2025-01-16T15:19:11.078Z] [13476] DEBUG - [jlink] [NRFJPROG][nRFXX][-] open
    [2025-01-16T15:19:11.078Z] [13476] DEBUG - [jlink] [NRFJPROG][nRFXX][-] just_check_family
    [2025-01-16T15:19:11.078Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    [2025-01-16T15:19:11.078Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    [2025-01-16T15:19:11.081Z] [13476] TRACE - [jlink] [NRFJPROG][Client][-] Command open executed for 45 milliseconds with result 0
    [2025-01-16T15:19:11.081Z] [13476] DEBUG - [jlink] [NRFJPROG][Client][-] enum_emu_snr
    [2025-01-16T15:19:11.085Z] [13476] TRACE - [jlink] [NRFJPROG][Client][-] Command enum_emu_snr executed for 4 milliseconds with result 0
    [2025-01-16T15:19:11.085Z] [13476] DEBUG - [jlink] Found 0 J-Link devices connected
    [2025-01-16T15:19:11.119Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    [2025-01-16T15:19:11.119Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    [2025-01-16T15:19:11.119Z] [13476] TRACE - [jlink] [NRFJPROG][Worker][-] Command open executed for 4 milliseconds with result 0
    [2025-01-16T15:19:11.119Z] [13476] DEBUG - [jlink] [NRFJPROG][nRFXX][-] enum_emu_snr
    [2025-01-16T15:19:11.119Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    [2025-01-16T15:19:11.119Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr
    [2025-01-16T15:19:11.119Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr
    [2025-01-16T15:19:11.119Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus
    [2025-01-16T15:19:11.119Z] [13476] TRACE - [jlink] [NRFJPROG][Worker][-] Command enum_emu_snr executed for 2 milliseconds with result 0
    [2025-01-16T15:19:11.119Z] [13476] DEBUG - [jlink] [NRFJPROG][nRFXX][-] close
    [2025-01-16T15:19:11.119Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] close
    [2025-01-16T15:19:11.119Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    [2025-01-16T15:19:11.119Z] [13476] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    [2025-01-16T15:19:11.119Z] [13476] DEBUG - [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    [2025-01-16T15:19:11.135Z] [13476] TRACE - [jlink] [NRFJPROG][Client][-] Command close executed for 49 milliseconds with result 0
    [2025-01-16T15:19:11.135Z] [13476] DEBUG - [jlink] [NRFJPROG][Client][-] terminate
    [2025-01-16T15:19:11.149Z] [13476] TRACE - [jlink] [NRFJPROG][Client][-] Command terminate executed for 14 milliseconds with result 0
    [2025-01-16T15:19:11.166Z] [13476] TRACE - [jlink] [NRFJPROG][Worker][-] Command close executed for 47 milliseconds with result 0
    [2025-01-16T15:19:11.166Z] [13476] TRACE - [jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0
    [2025-01-16T15:19:11.166Z] [13476] TRACE - [jlink] [NRFJPROG][Worker][-] Executed 4 commands for 53 milliseconds
    [2025-01-16T15:19:11.199Z] [13476] DEBUG - [jlink] [NRFJPROG][Client][-] Worker process exited with code: 0
    [2025-01-16T15:19:11.200Z] [13476] DEBUG - [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    [2025-01-16T15:19:11.200Z] [13476] TRACE - [jlink] [NRFJPROG][Client][-] Executed 4 commands for 112 milliseconds
    [2025-01-16T15:19:11.200Z] [13476] DEBUG - [jlink] [NRFJPROG][Client][-] terminate
    [2025-01-16T15:19:11.213Z] [13476] DEBUG - Enumeration for plugin 'jlink' took 277 ms
    [2025-01-16T15:19:11.256Z] [13476] DEBUG - Enumeration for plugin 'BOARDCONTROLLER' took 43 ms
    [2025-01-16T15:19:11.258Z] [13476] DEBUG - [serialport] Looking for GUID: {b2e35b05-90b7-5f9e-bafc-9ce5785d7d25}
    [2025-01-16T15:19:11.258Z] [13476] DEBUG - [serialport] Serial numbers found: ["001051173446", "001057701372", "001057731788"]
    [2025-01-16T15:19:11.258Z] [13476] DEBUG - [serialport] Serial number: 001051173446 -> GUID: {aeda0321-676b-5c08-9c37-766349129945}
    [2025-01-16T15:19:11.258Z] [13476] DEBUG - [serialport] Serial number: 001057701372 -> GUID: {b2e35b05-90b7-5f9e-bafc-9ce5785d7d25}
    [2025-01-16T15:19:11.258Z] [13476] DEBUG - [serialport] Matching serial number? Some("001057701372")
    [2025-01-16T15:19:11.258Z] [13476] DEBUG - [serialport] serial port \\?\USB#VID_1366&PID_1059&MI_00#7&2054A236&0&0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\?\USB#VID_1366&PID_1059#001057701372#{A5DCBF10-6530-11D2-901F-00C04FB951ED}
    [2025-01-16T15:19:11.259Z] [13476] DEBUG - [serialport] Serial number: 001057701372 -> GUID: {b2e35b05-90b7-5f9e-bafc-9ce5785d7d25}
    [2025-01-16T15:19:11.259Z] [13476] DEBUG - [serialport] Matching serial number? Some("001057701372")
    [2025-01-16T15:19:11.259Z] [13476] DEBUG - [serialport] serial port \\?\USB#VID_1366&PID_1059&MI_02#7&2054A236&0&0002#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\?\USB#VID_1366&PID_1059#001057701372#{A5DCBF10-6530-11D2-901F-00C04FB951ED}
    [2025-01-16T15:19:11.259Z] [13476] DEBUG - [serialport] try to map FTDI to segger device
    [2025-01-16T15:19:11.259Z] [13476] DEBUG - [serialport] serialport enumerate update device: '001057701372'
    [2025-01-16T15:19:11.259Z] [13476] DEBUG - Enumeration for plugin 'serialport' took 2 ms
    [2025-01-16T15:19:11.259Z] [13476] DEBUG - Enumeration for plugin 'sdfu' took 0 ms
    [2025-01-16T15:19:11.259Z] [13476] DEBUG - Enumeration for plugin 'mcuBoot' took 0 ms
    [2025-01-16T15:19:11.259Z] [13476] TRACE - [broken] BrokenPlugin::enumerate
    [2025-01-16T15:19:11.259Z] [13476] DEBUG - Enumeration for plugin 'broken' took 0 ms
    [2025-01-16T15:19:11.259Z] [13476] TRACE - DeviceLister::enumerate: Found device with serial number: '<unknown>'
    [2025-01-16T15:19:11.259Z] [13476] TRACE - DeviceLister::enumerate: Found device with serial number: '1SSD21K04345ZZQ01K9J'
    [2025-01-16T15:19:11.259Z] [13476] TRACE - DeviceLister::enumerate: Found device with serial number: '001057701372'
    [2025-01-16T15:19:11.259Z] [13476] TRACE - DeviceLister::enumerate: device registered to device list
    [2025-01-16T15:19:11.259Z] [13476] TRACE - DeviceLister::enumerate: Found device with serial number: '000000000000'
    [2025-01-16T15:19:11.259Z] [13476] TRACE - DeviceLister::enumerate: Finished in 364 ms
    [2025-01-16T15:19:11.259Z] [13476] TRACE - DeviceLister::enumerate: Completed waiting for enumeration
    [2025-01-16T15:19:11.259Z] [13476] TRACE - DeviceLister::enumerate: done
    [2025-01-16T15:19:11.260Z] [13476] DEBUG - [ProbeLib] [2025-01-16 15:19:11.260398Z] probe-plugin will check if the device is a NRF54H/NRF54L to determine if it should claim it
    [2025-01-16T15:19:11.260Z] [13476] DEBUG - [ProbeLib] [2025-01-16 15:19:11.260416Z] The device is recognized as a device with a supported probe. Need to run device identification to determine the device family
    [2025-01-16T15:19:11.260Z] [13476] DEBUG - [ProbeLib] [2025-01-16 15:19:11.260442Z] Looking for file in C:\Users\geert\.nrfutil\lib\nrfutil-device\plugin-probe-worker.exe
    [2025-01-16T15:19:11.260Z] [13476] DEBUG - [ProbeLib] [2025-01-16 15:19:11.260528Z] Found file at C:\Users\geert\.nrfutil\lib\nrfutil-device\plugin-probe-worker.exe
    [2025-01-16T15:19:11.260Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.260622Z] Created IPC server 49184e42-5500-43d0-997c-d350a69607fa
    [2025-01-16T15:19:11.265Z] [13476] DEBUG - [ProbeLib] [2025-01-16 15:19:11.265138Z] Spawned worker process with id 14696
    [2025-01-16T15:19:11.265Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.265198Z] Accepting IPC connection
    [2025-01-16T15:19:11.273Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.273427Z] Accepted IPC connection
    [2025-01-16T15:19:11.273Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.273456Z] The worker supervisor's role is finished
    [2025-01-16T15:19:11.275Z] [13476] DEBUG - [ProbeLib] [2025-01-16 15:19:11.275518Z] Received signal from master, returning alive worker.
    [2025-01-16T15:19:11.275Z] [13476] INFO - [ProbeLib] [2025-01-16 15:19:11.275548Z] Handshake signatures match
    [2025-01-16T15:19:11.275Z] [13476] INFO - [ProbeLib] [2025-01-16 15:19:11.275615Z] Connection with Probe worker established.
    [2025-01-16T15:19:11.275Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.275715Z] Starting trace thread
    [2025-01-16T15:19:11.275Z] [13476] INFO - [ProbeLib] [2025-01-16 15:19:11.273297Z] {jlink_usb_001057701372} nrf-probe version 0.29.0
    [2025-01-16T15:19:11.275Z] [13476] DEBUG - [ProbeLib] [2025-01-16 15:19:11.273333Z] {jlink_usb_001057701372} Sending IPC handshake response from worker...
    [2025-01-16T15:19:11.275Z] [13476] DEBUG - [ProbeLib] [2025-01-16 15:19:11.273439Z] {jlink_usb_001057701372} Started worker message processing loop
    [2025-01-16T15:19:11.275Z] [13476] DEBUG - [ProbeLib] [2025-01-16 15:19:11.275691Z] {jlink_usb_001057701372} Probe worker received initial message: Initialize(InitializeRequest { configuration: Configuration { jlink: JLinkConfig { dll_location: None }, target: TargetConfig { adac_timeout: None, swd_clock_frequency: None } }, firmware_config: None, target_family: None, override_detection: None })
    [2025-01-16T15:19:11.275Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.275730Z] {jlink_usb_001057701372} -> new
    [2025-01-16T15:19:11.275Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.275811Z] {jlink_usb_001057701372} J-Link installation directory configured in registry: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\SEGGER\J-Link="C:\\Program Files\\SEGGER\\JLink_V794i"
    [2025-01-16T15:19:11.275Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.275917Z] {jlink_usb_001057701372} -> new_from_path
    [2025-01-16T15:19:11.281Z] [13476] INFO - [ProbeLib] [2025-01-16 15:19:11.281724Z] {jlink_usb_001057701372} Opened J-Link DLL at C:\Program Files\SEGGER\JLink_V794i\JLink_x64.dll with version 7.94i
    [2025-01-16T15:19:11.281Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.281752Z] {jlink_usb_001057701372} <- new_from_path
    [2025-01-16T15:19:11.281Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.281757Z] {jlink_usb_001057701372} <- new
    [2025-01-16T15:19:11.281Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.281771Z] {jlink_usb_001057701372} Setting up JLink interface.
    [2025-01-16T15:19:11.281Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.281780Z] {jlink_usb_001057701372} -> connect
    [2025-01-16T15:19:11.281Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.281789Z] {jlink_usb_001057701372} Selecting J-Link with serial number 001057701372
    [2025-01-16T15:19:11.284Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.284245Z] {jlink_usb_001057701372} <- connect
    [2025-01-16T15:19:11.284Z] [13476] ERROR - [ProbeLib] [2025-01-16 15:19:11.284290Z] Failed to initialize worker: Emulator error: No emulator with connection info 'Usb(JLinkSerialNumber(1057701372))' was found
    [2025-01-16T15:19:11.284Z] [13476] DEBUG - [ProbeLib] [2025-01-16 15:19:11.284308Z] Terminating worker with id 14696
    [2025-01-16T15:19:11.284Z] [13476] DEBUG - [ProbeLib] [2025-01-16 15:19:11.284299Z] {jlink_usb_001057701372} Probe worker stopped.
    [2025-01-16T15:19:11.284Z] [13476] ERROR - [ProbeLib] [2025-01-16 15:19:11.284343Z] Failed to shutdown client: Io(Os { code: -2147024664, kind: Uncategorized, message: "The pipe is being closed." })
    [2025-01-16T15:19:11.284Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.284354Z] Waiting for worker to exit.
    [2025-01-16T15:19:11.285Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.285751Z] Waiting for worker to exit.
    [2025-01-16T15:19:11.286Z] [13476] ERROR - [ProbeLib] [2025-01-16 15:19:11.286227Z] Trace channel disconnected unexpectedly.
    [2025-01-16T15:19:11.286Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.286240Z] Trace thread ends now...
    [2025-01-16T15:19:11.286Z] [13476] TRACE - [ProbeLib] [2025-01-16 15:19:11.286784Z] Waiting for worker to exit.
    [2025-01-16T15:19:11.288Z] [13476] INFO - [ProbeLib] [2025-01-16 15:19:11.288834Z] Worker exited successfully
    [2025-01-16T15:19:11.288Z] [13476] ERROR -  NRFDLException(1): [Probe] Emulator error: No emulator with connection info 'Usb(JLinkSerialNumber(1057701372))' was found
    [2025-01-16T15:19:11.289Z] [13476] DEBUG - Task 0 is already completed
    [2025-01-16T15:19:11.289Z] [13476] TRACE - DeviceLister::shutDown()
    Thank you agian!
  • Thanks!
    I have forwarded internally and will get back to you as soon as I hear something
    Regards
    Runar
  • Hey Runar,
    I managed to make the flashing work.
    I read my message back and saw that teh log of command PS C:\Users\geert> nrfutil device --version mentioned being made for J-Link v8.10f while I had V7.94i. I was certain I had read that V7.94i was adviced for the nRF54l15DK in the specs but I can't find it back.
    Regardless, after installing V8.10f I was able to get throught the flashing proces of VSCode. At first it didn't change when I made a change in the code but I think that is something to do with how I build. I am still interested in what your internal forward will show thought!
    Regardless, thanks for all the help!
    Geert
  • The feedback I got was that the recommended installing the driver with the legacy mode I mentioned further down.
    It could also be that it with was a problem with the conflict between versions
    Regards
    Runar
