Issues Enabling NRFX_DPPI on nRF54
Based on this example, I am working on porting a pulse counter to the nRF54 and have encountered issues enabling the DPPI peripheral.
The problem is when enabling CONFIG_NRFX_DPPI in my prj.conf, I got the following warning:
warning: NRFX_DPPI (defined at modules/hal_nordic/nrfx/Kconfig:32,
modules/hal_nordic/nrfx/Kconfig:32) was assigned the value 'y' but got the value 'n'
and then I got these errors:
undefined reference to `nrfx_dppi_channel_alloc`
undefined reference to `nrfx_dppi_channel_enable`
I attached the code and the config file.
4111.prj.conf
 * Copyright (c) 2016 Intel Corporation
#include <zephyr/kernel.h>
#include <nrfx_dppi.h>
#include <nrfx_gpiote.h>
#include <nrfx_timer.h>
LOG_MODULE_REGISTER(main, LOG_LEVEL_INF);
/* 1000 msec = 1 sec */
#define SLEEP_TIME_MS 1000
/* The devicetree node identifier for the "led0" alias. */
#define LED0_NODE DT_ALIAS(led0)
 * A build error on this line means your board is unsupported.
 * See the sample documentation for information on how to fix this.
static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
static const struct gpio_dt_spec button =
    GPIO_DT_SPEC_GET(DT_N_ALIAS_sw0, gpios);
nrfx_timer_t timer_inst = NRFX_TIMER_INSTANCE(130);
nrfx_gpiote_t gpiote_inst = NRFX_GPIOTE_INSTANCE(130);
static void pulse_count_init(uint32_t pin) {
  uint32_t err;
  // Initialize the GPIOTE library
  err = nrfx_gpiote_init(&gpiote_inst, NRFX_GPIOTE_DEFAULT_CONFIG_IRQ_PRIORITY);
  NRFX_ASSERT(err == NRFX_SUCCESS);
  // Allocate a GPIOTE channel to be used to generate input events
  uint8_t gpiote_ch;
  err = nrfx_gpiote_channel_alloc(&gpiote_inst, &gpiote_ch);
  nrf_gpio_pin_pull_t pull_cfg = NRF_GPIO_PIN_PULLUP;
  // Set the trigger configuration to use the recently allocated channel, and
  // the HITOLO trigger setting
  nrfx_gpiote_trigger_config_t trigger_cfg = {
      .p_in_channel = &gpiote_ch,
      .trigger = NRFX_GPIOTE_TRIGGER_HITOLO,
  // Set up the pin configuration with pullup enabled, in order to use a DK
  // button
  nrfx_gpiote_input_pin_config_t gpiote_cfg = {
      .p_pull_config = &pull_cfg,
      .p_trigger_config = &trigger_cfg,
  // Configure the GPIOTE IN channel with the defined settings
  err = nrfx_gpiote_input_configure(&gpiote_inst, pin, &gpiote_cfg);
  // Enable triggering on the pin in order to enable event generation. Interrupt
  // is not required
  nrfx_gpiote_trigger_enable(&gpiote_inst, pin, false);
  // Initialize the timer in counter mode
  nrfx_timer_config_t timer_cfg = {
      .mode = NRF_TIMER_MODE_COUNTER,
      .bit_width = NRF_TIMER_BIT_WIDTH_32,
      .frequency = 1000000,
  err = nrfx_timer_init(&timer_inst, &timer_cfg, NULL);
  // Declare DPPI channel
  uint8_t dppi_channel;
  // Allocate a DPPI channel
  err = nrfx_dppi_channel_alloc(&dppi_channel);
  // Configure the DPPI channel to connect the GPIOTE event to the TIMER COUNT
  // task
  err = nrfx_dppi_channel_enable(dppi_channel);
  // Enable the timer
  nrfx_timer_enable(&timer_inst);
static void pulse_count_reset(void) { nrfx_timer_clear(&timer_inst); }
static uint32_t pulse_count_sample(void) {
  nrfx_timer_capture(&timer_inst, NRF_TIMER_CC_CHANNEL0);
  return nrfx_timer_capture_get(&timer_inst, NRF_TIMER_CC_CHANNEL0);
int main(void) {
  int ret;
  LOG_INF("Pulse count sample started");
  if (!device_is_ready(led.port)) {
    return 0;
  ret = gpio_pin_configure_dt(&led, GPIO_OUTPUT_ACTIVE);
  if (ret < 0) {
    return 0;
  pulse_count_init(button.pin);
  while (1) {
    ret = gpio_pin_toggle_dt(&led);
    if (ret < 0) {
      return 0;
    // Reset the counter, go to sleep for a second, and print the result
    // afterwards
    pulse_count_reset();
    k_msleep(SLEEP_TIME_MS);
    LOG_INF("Pulse count: %i", pulse_count_sample());
  return 0;
Let me know if additional information is needed. I would appreciate any suggestions or guidance you can provide.
Marco.
