DFU on nrf52832
Hi, I am having problem making DFU work on nrf52832 using nrf connect sdk 2.6.0.  Below is my mcuboot.conf under child_image and prj.conf. Please guide me where I am wrong. Also when I set CONFIG_SINGLE_APPLICATION_SLOT, it builds fine but when I disables it, it doesn't build due to size issue.
&flash0 {
partitions {
#address-cells = <1>;
#size-cells = <1>;
boot_partition: partition@0 {
label = "mcuboot";
reg = <0x00000000 0xC000>;
slot0_partition: partition@C000 {
label = "image-0";
reg = <0x0000C000 0x2C000>;
slot1_partition: partition@38000 {
label = "image-1";
reg = <0x00038000 0x2C000>;
storage_partition: partition@64000 {
label = "storage";
reg = <0x00064000 0x4000>;
# Logging
CONFIG_LOG=y
CONFIG_MCUBOOT_LOG_LEVEL_WRN=y
# CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x15000
CONFIG_SINGLE_APPLICATION_SLOT=y
and prj.conf
# Copyright (C) 2024 Walk With Path Corp. All Rights Reserved.
# Project Configuration File
# This file contains configuration settings for Bluetooth, logging, peripherals,
# memory optimization, DFU support, and other key features for Zephyr-based applications.
# General Debugging and Logging
CONFIG_LOG=y # Enable logging framework
CONFIG_LOG_BACKEND_UART=y # Use UART backend for logs
CONFIG_LOG_PRINTK=y # Allow printk for logs
CONFIG_CBPRINTF_FP_SUPPORT=y # Enable floating-point support in logs
# Enable console for debug purposes
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_DEBUG=y # Enable debugging
CONFIG_PRINTK=y # Enable printk debugging
CONFIG_SHELL=n # Enable Zephyr Shell for debugging
CONFIG_SHELL_LOG_BACKEND=y
CONFIG_SHELL_CMD_BUFF_SIZE=128
# Enable RTT (Real-Time Transfer) for logs (alternative to UART)
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=y # Disable UART console if RTT is enabled
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=512
CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL=y
CONFIG_LOG_BLOCK_IN_THREAD=y
CONFIG_LOG_BUFFER_SIZE=256
CONFIG_DEBUG_INFO=y
CONFIG_DEBUG_THREAD_INFO=y
# CONFIG_NCS_BOOT_BANNER=y # Enable NCS boot banner
CONFIG_BOOT_BANNER=y
CONFIG_PRINTK=y
# Enable UART support
CONFIG_SERIAL=y
# Peripheral and Sensor Drivers
CONFIG_I2C=y # Enable I2C interface
CONFIG_SPI=y # Enable SPI interface
CONFIG_ADC=y # Enable ADC driver
CONFIG_SENSOR=y # Enable generic sensor support
CONFIG_TMP116=y # Enable TMP116 temperature sensor
CONFIG_BMI270=y # Enable BMI270 accelerometer
CONFIG_BMI270_TRIGGER_GLOBAL_THREAD=y
CONFIG_WATCHDOG=y # Enable watchdog timer
CONFIG_WDT_LOG_LEVEL_DBG=y
CONFIG_WDT_DISABLE_AT_BOOT=n
# Enable LED and regulator drivers
CONFIG_LED=y
CONFIG_REGULATOR=y
# Enable power management IC (NPMX)
# CONFIG_NPMX=y
# CONFIG_NPMX_DEVICE_NPM1300=y
# Enable Nordic Fuel Gauge and BMI270 (Accelerometer and Gyroscope)
CONFIG_NRF_FUEL_GAUGE=y
# Disable SPI NOR flash driver (if not used)
CONFIG_SPI_NOR=n
# Power and Memory Optimizations
# Power management configuration
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_RUNTIME=y
# Memory Optimizations
# Configure memory pool and stack sizes
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_HEAP_MEM_POOL_SIZE=1024
# Flash Configuration
CONFIG_FLASH=y # Enable flash memory support
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_BT_SETTINGS=y # Enable Bluetooth settings
CONFIG_SETTINGS=y # Enable settings subsystem
CONFIG_NVS=y # Enable Non-Volatile Storage
CONFIG_NVS_LOG_LEVEL_DBG=y
# Bluetooth Settings
CONFIG_NCS_SAMPLES_DEFAULTS=y
# Enable Bluetooth and controller settings
CONFIG_BT=y
CONFIG_BT_HCI=y
CONFIG_BT_CTLR=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_BROADCASTER=n
CONFIG_BT_SMP=y
CONFIG_BT_BONDABLE=y
CONFIG_BT_CTLR_ADV_EXT=n
CONFIG_BT_DEVICE_APPEARANCE=1345
CONFIG_BT_DEVICE_NAME_DYNAMIC=y
CONFIG_BT_GATT_CLIENT=y
# Bluetooth security and bonding settings
CONFIG_BT_KEYS_OVERWRITE_OLDEST=y
CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE=y
CONFIG_BT_ID_UNPAIR_MATCHING_BONDS=y
CONFIG_BT_PRIVACY=n
CONFIG_BT_TINYCRYPT_ECC=y
CONFIG_BT_CTLR_PHY_2M=y
CONFIG_BT_USER_PHY_UPDATE=y
# Bluetooth buffer and connection settings
CONFIG_BT_BUF_ACL_RX_SIZE=247
CONFIG_BT_ATT_PREPARE_COUNT=2
CONFIG_BT_BUF_ACL_TX_SIZE=256
CONFIG_BT_BUF_ACL_TX_COUNT=10
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_L2CAP_TX_BUF_COUNT=10
CONFIG_BT_L2CAP_DYNAMIC_CHANNEL=y
CONFIG_BT_CTLR_DATA_LENGTH_MAX=247
CONFIG_BT_CTLR_RX_BUFFERS=2
CONFIG_BT_CONN_TX_MAX=10
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
CONFIG_BT_GATT_DM=y
# Allow only LESC pairing
# CONFIG_BT_SMP_SC_PAIR_ONLY=y
# Configure Bluetooth connection settings
CONFIG_BT_CTLR_TX_PWR_0=y
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
# Enable PHY updates
CONFIG_BT_USER_DATA_LEN_UPDATE=y
# Enable Bluetooth shell for debugging
CONFIG_BT_SHELL=n
# Enable BT NUS (Nordic UART Service) shell for testing
# CONFIG_SHELL_BT_NUS=y
# Enable Battery Service (BAS) for battery level reporting
CONFIG_BT_BAS=y
# Cryptography
CONFIG_TINYCRYPT=y # Enable TinyCrypt for secure operations
# Reboot and Misc Settings
CONFIG_REBOOT=y # Enable reboot functionality
# DFU Support and Bootloader
# Enable mcumgr.
CONFIG_MCUMGR=y
# Enable MCUboot and FOTA
CONFIG_BOOTLOADER_MCUBOOT=y
# CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="bootloader/mcuboot/root-rsa-2048.pem"
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
# Enable image management
CONFIG_MCUMGR_TRANSPORT_BT=y
CONFIG_MCUMGR_TRANSPORT_BT_AUTHEN=n
CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y
CONFIG_IMG_MANAGER=n
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# Enable logging for mcumgr (DFU)
CONFIG_MCUMGR_LOG_LEVEL_DBG=y
CONFIG_MCUMGR_LOG_LEVEL_INF=y
# Enable logging for image management subsystem
CONFIG_IMG_MANAGER_LOG_LEVEL_DBG=y
CONFIG_IMG_MANAGER_LOG_LEVEL_INF=y
# # Enable mcumgr DFU in application
# # Enable MCUMGR
# # Enable MCUMGR management for both OS and Images
# CONFIG_MCUMGR_GRP_OS=y
# CONFIG_MCUMGR_GRP_IMG=y
# Support for taskstat command
CONFIG_MCUMGR_GRP_OS_TASKSTAT=y
# Enable statistics and statistic names.
CONFIG_STATS=y
CONFIG_STATS_NAMES=y
# Enable most core commands.
CONFIG_MCUMGR_GRP_STAT=y
  • You can stick with 2.6.0, no worries
    As mentioned here: "In Zephyr, a set of configurations are needed to enable FOTA. An example of how to set this up can be seen in the SMP Server sample. However, the nRF Connect SDK includes the option CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU, which sets all needed configurations for us. This option makes it easier for us to enable FOTA, so we will use that. This configuration is named CONFIG_NCS_SAMPLE… as it makes some assumptions about the project. For your custom project, I recommend that you look at what configurations CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU set for you, and include the ones from there you need instead."
    Meaning that you can have a look at https://docs.nordicsemi.com/bundle/ncs-2.6.1/page/kconfig/index.html#CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU  and choose to add the relevant configurations line by line instead of using the "include all NCS_SAMPLE" configuration option which I've done here in the sample I sent you: https://github.com/aHaugl/samples_for_NCS/blob/f2dc920a9edd84dea711febb6f642fcbb3155e55/bootloader/spi/smp_ble_feat_spi/prj.conf.
    Andreas
  • Hi Andreas, bootloader is not getting build. Getting same above errors. For some reason, it doesn't like SPI. See files attached.
    Any chance to have a live session? Thanks Moh
    3644.mcuboot.overlay8424.mcuboot.conf
    1581.prj_release.conf
  • Hi Andreas, If I don't include at25xe321d in overlay, mcuboot builds fine and eventually the app. Any idea why it doesn't like at25xe321d?
    /delete-node/ &at25xe321d;
    /delete-node/ &i2c0;
    /delete-node/ &i2c1;
    chosen {
    // nordic,pm-ext-flash = &at25xe321d;
  • Hi
    Unfortunately we typically don't do live sessions and when we do they have to be arranged through your regional sales manager.
    Ok, this is good since we now have isolated that the issue is with configuring the external flash and presumably that everything else works as it should. Could you post the build log with errors for the unsuccessful build with the external flash (for the setup without using CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU)? I still see in the latest 1581.prj_release.conf that you're using this configuration
    Andreas
  • Hi Andreas,
    Please find the log attached. I have also attached the prj_release file. As you can see, I have commented out  CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU. I have also attached log from devicetree.generated.h for undefined __device_dts_ord_105
    /* Node's dependency ordinal: */
    #define DT_N_S_soc_S_i2c_40004000_ORD 105
    #define DT_N_S_soc_S_i2c_40004000_ORD_STR_SORTABLE 00105
    0005.prj_release.conf
    [1/349] Preparing syscall dependency handling
    [9/349] Generating include/generated/version.h
    -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.0/zephyr), build: v3.5.99-ncs1
    [1/271] Preparing syscall dependency handling
    [4/271] Generating include/generated/version.h
    [266/271] Linking C executable zephyr/zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /Users/mohsin/path-feel-zephyr-fw/app/build_release/mcuboot/zephyr/zephyr_pre0.map
    : && ccache /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/Users/mohsin/path-feel-zephyr-fw/app/build_release/mcuboot/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/soc/soc/arm/nordic_nrf/libsoc__arm__nordic_nrf.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/mbedtls/libmbedTLSBase.a  modules/mbedtls/libmbedTLSCrypto.a  modules/mbedtls/libmbedTLSX509.a  modules/mbedtls/libmodules__mbedtls.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m/nofp"  -L/Users/mohsin/path-feel-zephyr-fw/app/build_release/mcuboot/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  modules/mbedtls/libmbedTLSBase.a  modules/mbedtls/libmbedTLSCrypto.a  modules/mbedtls/libmbedTLSX509.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie && cd /Users/mohsin/path-feel-zephyr-fw/app/build_release/mcuboot/zephyr && /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/cmake/3.21.0/bin/cmake -E true
    /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/flash/libdrivers__flash.a(spi_nor.c.obj): in function `k_sleep':
    /Users/mohsin/path-feel-zephyr-fw/app/build_release/mcuboot/zephyr/include/generated/syscalls/kernel.h:135: undefined reference to `z_impl_k_sleep'
    /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /Users/mohsin/path-feel-zephyr-fw/app/build_release/mcuboot/zephyr/include/generated/syscalls/kernel.h:135: undefined reference to `z_impl_k_sleep'
    /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/flash/libdrivers__flash.a(spi_nor.c.obj):(.rodata.spi_nor_config_0+0x0): undefined reference to `__device_dts_ord_105'
    collect2: error: ld returned 1 exit status
