NRFConnect does not allow us to flash new firmware OTA under certain conditions.
Going into better details, we are developing some firmware on the NRF 52833 and a required functionality is to be able to update the firmware using DFU FOTA.
I have scouted the forums a lot and I have the feeling our issue is due to firmware total size (app_update.bin), which in our current state is 188kB.
This is the corresponding prj.conf
CONFIG_SOC_SERIES_NRF52X=y CONFIG_SOC_NRF52833_QIAA=y CONFIG_NFCT_PINS_AS_GPIOS=y CONFIG_USE_SEGGER_RTT=y CONFIG_RTT_CONSOLE=y CONFIG_NRFX_USBD=y CONFIG_UART_CONSOLE=n CONFIG_USB_DEVICE_STACK=y CONFIG_I2C=y CONFIG_CBPRINTF_FP_SUPPORT=y #Enable floating point format specifiers CONFIG_ADC=y CONFIG_SPI=y CONFIG_NRFX_SPIM2=y CONFIG_SOC_NRF52832_ALLOW_SPIM_DESPITE_PAN_58=y CONFIG_PWM=y CONFIG_LED=y CONFIG_LED_PWM=y CONFIG_PM=y CONFIG_PM_DEVICE=y CONFIG_GPIO=y CONFIG_NUM_PREEMPT_PRIORITIES=0 CONFIG_NUM_COOP_PRIORITIES=3 CONFIG_SYSTEM_WORKQUEUE_NO_YIELD=y CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_IMG_MANAGER=y CONFIG_MCUBOOT_IMG_MANAGER=y CONFIG_BT=y CONFIG_BT_HCI=y CONFIG_BT_CTLR=y CONFIG_BT_LL_SW_SPLIT=y CONFIG_BT_DEVICE_NAME="MRA" CONFIG_BT_PERIPHERAL=y CONFIG_ADC=y CONFIG_ADC_ASYNC=y CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 # Enable mcumgr. CONFIG_MCUMGR=y # Enable most core commands. CONFIG_MCUMGR_CMD_IMG_MGMT=y CONFIG_MCUMGR_CMD_OS_MGMT=y # Ensure an MCUboot-compatible binary is generated. CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_IMG_MANAGER=y CONFIG_MCUBOOT_IMG_MANAGER=y # Allow for large Bluetooth data packets. CONFIG_BT_L2CAP_TX_MTU=252 CONFIG_BT_BUF_ACL_RX_SIZE=256 # Enable the Bluetooth (unauthenticated) and shell mcumgr transports. CONFIG_MCUMGR_SMP_BT=y CONFIG_MCUMGR_SMP_BT_AUTHEN=n # Some command handlers require a large stack. CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG=y # watchdog timer CONFIG_WDT_LOG_LEVEL_DBG=y CONFIG_WATCHDOG=y CONFIG_WDT_DISABLE_AT_BOOT=n #FLASH access CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_MPU_ALLOW_FLASH_WRITE=y CONFIG_BT_DEVICE_APPEARANCE=965 CONFIG_BT_MAX_CONN=1 CONFIG_BT_MAX_PAIRED=1 CONFIG_BT_SMP=y CONFIG_BT_L2CAP_TX_BUF_COUNT=5 CONFIG_BT_SETTINGS=y CONFIG_FLASH_MAP=y CONFIG_NVS=y CONFIG_SETTINGS=y CONFIG_BT_SMP_APP_PAIRING_ACCEPT=y CONFIG_BT_FILTER_ACCEPT_LIST=y CONFIG_BT_PRIVACY=y CONFIG_BT_BONDABLE=y CONFIG_BT_KEYS_OVERWRITE_OLDEST=y CONFIG_BT_CTLR_PRIVACY=y CONFIG_HEAP_MEM_POOL_SIZE=2048 CONFIG_BT_SMP_SC_PAIR_ONLY=n
This is the NRF Connect log whenever the DFU FOTA fails:
nRF Connect, 2025-01-21 Nordic_LBS (E9:28:DD:B4:12:7B) V 10:08:32.204 [McuMgr] Connecting... D 10:08:32.210 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M) D 10:08:32.288 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED) I 10:08:32.292 [McuMgr] Connected to E9:28:DD:B4:12:7B D 10:08:32.295 [McuMgr] wait(300) I 10:08:32.298 [McuMgr] MTU changed to: 252 V 10:08:32.600 [McuMgr] Discovering services... D 10:08:32.613 [McuMgr] gatt.discoverServices() I 10:08:32.628 [McuMgr] Services discovered V 10:08:32.634 [McuMgr] Primary service found V 10:08:32.639 [McuMgr] Requesting new MTU... D 10:08:32.642 [McuMgr] gatt.requestMtu(498) I 10:08:32.691 [McuMgr] MTU changed to: 252 D 10:08:32.695 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true) V 10:08:32.699 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48 D 10:08:32.702 [McuMgr] descriptor.setValue(0x01-00) D 10:08:32.705 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb) I 10:08:32.797 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb I 10:08:32.808 [McuMgr] Notifications enabled V 10:08:32.811 [McuMgr] Waiting for value change... V 10:08:32.814 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 10:08:32.816 [McuMgr] characteristic.setValue(0x000000010000FF06A0) D 10:08:32.819 [McuMgr] characteristic.setWriteType(WRITE COMMAND) D 10:08:32.822 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48) I 10:08:32.841 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 10:08:32.874 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-06-00-00-FF-06-BF-62-72-63-08-FF I 10:08:32.878 [McuMgr] Wait for value changed complete A 10:08:32.886 [McuMgr] Received Header (Version: 0, Op: 1, Flags: 0, Len: 6, Group: 0, Seq: 255, Command: 6) CBOR {"rc":8} W 10:08:32.889 [McuMgr] Error: NOT_SUPPORTED (8) V 10:08:32.893 [McuMgr] Requesting connection priority: HIGH (11.25–15ms, 0, 5s)... D 10:08:32.895 [McuMgr] gatt.requestConnectionPriority(HIGH) A 10:08:32.916 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 1, Group: 0, Seq: 0, Command: 8) CBOR {} I 10:08:33.019 Connection parameters updated (interval: 12.5ms, latency: 0, timeout: 5000ms) I 10:08:33.042 [McuMgr] Connection parameters updated (interval: 12.5ms, latency: 0, timeout: 5000ms) V 10:08:33.047 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 10:08:33.050 [McuMgr] characteristic.setValue(0x0800000100000008A0) D 10:08:33.055 [McuMgr] characteristic.setWriteType(WRITE COMMAND) D 10:08:33.058 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48) I 10:08:33.071 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 10:08:33.107 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-06-00-00-00-08-BF-62-72-63-08-FF A 10:08:33.134 [McuMgr] Received Header (Version: 0, Op: 1, Flags: 0, Len: 6, Group: 0, Seq: 0, Command: 8) CBOR {"rc":8} W 10:08:33.141 [McuMgr] Error: NOT_SUPPORTED (8) A 10:08:33.217 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 1, Group: 1, Seq: 1, Command: 0) CBOR {} V 10:08:33.222 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 10:08:33.225 [McuMgr] characteristic.setValue(0x0800000100010100A0) D 10:08:33.228 [McuMgr] characteristic.setWriteType(WRITE COMMAND) D 10:08:33.231 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48) I 10:08:33.266 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 10:08:33.356 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-86-00-01-01-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-A8-0C-14-26-22-AB-81-A6-63-48-9E-94-22-A1-25-A8-64-48-99-50-DA-60-CD-75-08-9D-A6-84-2D-B4-6A-CB-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF A 10:08:33.391 [McuMgr] Received Header (Version: 0, Op: 1, Flags: 0, Len: 134, Group: 1, Seq: 1, Command: 0) CBOR {"images":[{"slot":0,"version":"0.0.0","hash":"qAwUJiKrgaZjSJ6UIqElqGRImVDaYM11CJ2mhC20ass=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0} V 10:08:33.437 [McuMgr] Uploading firmware... V 10:08:34.275 [McuMgr] Disconnecting... D 10:08:34.281 [McuMgr] gatt.disconnect() D 10:08:34.329 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 0 (DISCONNECTED) I 10:08:34.334 [McuMgr] Disconnected D 10:08:34.339 [McuMgr] gatt.close()
As you can clearly see, i get a [McuMgr] ERROR: Not_supported (8), but that feels extremely generic and does not help us in debugging the behavior.
I have tried using the peripheral_LBS example by adding the DFU support (resulting size was 156 kB) and such firmware loads correctly into the board and starts regularly, which leads us to believe that total firmware size is the issue.
Could anyone confirm whethere a 188 kB f/w would work as DFU FOTA replacement?
In case it would not, how much space would we need to leave on the on-board FLASH for the functionality to properly work?
