sysbuild & mcuboot custom pm_static.yml partition table matches default layout but will not build
I am nrf52dk/nRF52832 (512kB flash) nordic peripheral_lbs sample as a test environment for establishing OTA updates. In my product firmware, I am facing a situation where I need to reduce the size of mcuboot partition to 0x9000 (36kB). I would like to reallocate the freed up space to the primary and secondary partitions.
I have viewed many of the tickets on this forum for help - which have helped me reach the stage that I am so far.
Adjusting the slots sizes with MCU Boot
MCUBoot, Zephyr, and static partition manager
The following command gives me this output.
west build -b nrf52dk/nrf52832 --sysbuild -d build . -t partition_manager
I have checked that the size of the peripheral_lbs firmware should fit inside the image partitions. However, when I try to build the full application with
I get the following error
←[0mninja: error: '_sysbuild/mcuboot_primary_app_hex', needed by 'mcuboot_primary.hex', missing and no known rule to make it
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Ryan/Downloads/peripheral-lbs-sysbuild-main/build_app/peripheral-lbs-sysbuild-main
-- Found partition manager static configuration : C:/Users/Ryan/Downloads/peripheral-lbs-sysbuild-main/pm_static.yml
Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
Partition 'settings_storage' is not included in the dynamic resolving since it is statically defined.
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
-- Generating done
←[92m-- west build: building application
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\ce3b5ff664\opt\bin\cmake.EXE' --build C:/Users/Ryan/Downloads/peripheral-lbs-sysbuild-main/build_app
Here is the .yml file I used to define the partitioning
app:
  address: 0x9200
  end_address: 0x43800
  region: flash_primary
  size: 0x3A600 # -200??
mcuboot:
  address: 0x0
  end_address: 0x9000
  placement:
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0x9000
  end_address: 0x9200
  placement:
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x9000
  orig_span: &id001
  - mcuboot_pad
  - mcuboot_primary_app # originally just app
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0x9200
  orig_span: &id002
  - app
  size: 0x3A600 # 200 less due to padding
  span: *id002
mcuboot_secondary:
  address: 0x43800
  end_address: 0x7E000
settings_storage:
  address: 0x7E000
  end_address: 0x80000
  placement:
    after: mcuboot_secondary
sram_primary:
  address: 0x20000000
  end_address: 0x20010000
  region: sram_primary
  size: 0x1000 # previously 10000
Previously, I was getting some issues about too many or too little gaps in the partition table. However that seems to have resolved itself. If anyone could also explain what that means in relation to dynamic and static partitioning - that would be divine. Here is the error I got for context
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Ryan/Downloads/peripheral-lbs-sysbuild-main/build/peripheral-lbs-s
Partition manager failed: Incorrect amount of gaps found in static configuration. There must be exactly one gap namic partitions (such as 'app'). Gaps found (0): The most common solution to this problem is to fill the smalle until there is only one gap left. Alternatively re-order the already defined static partitions so that only one
Failed to partition region flash_primary, size of region: 524288
Partition Configuration:
app:
mcuboot:
mcuboot_pad:
mcuboot_primary:
mcuboot_secondary:
settings_storage:
  placement:
  • Thank you so much!
    This solution worked for me as well.
  • Thanks, this was also a blocking issue for me. btw, this appears to only be an issue with sysbuild (the old multi-image build does not bug in this case).
  • For future visitors to this thread, below is a full example pm_static.yml with the fix suggested by @ .
    mcuboot:
      address: 0x0
      placement:
        before: [mcuboot_primary]
        align: { start: 0x8000, end: 0x8000 }
    mcuboot_primary:
      address: 0x10000
      placement:
        align: {start: 0x1000}
      span: [mcuboot_pad, app]
    mcuboot_pad:
      address: 0x10000
      placement:
        before: [mcuboot_primary_app]
      address: 0x10200
      span: [tfm, app]
      inside: [mcuboot_primary]
      placement:
        after: [mcuboot_pad]
    tfm_secure:
      address: 0x10000
    tfm:
      address: 0x10200
      inside: [tfm_secure]
      placement:
    tfm_nonsecure:
      address: 0x20000
      span: [app]
    app:
      address: 0x20000
    mcuboot_secondary:
      address: 0x80000
      placement:
        after: [mcuboot_primary]
      share_size: [mcuboot_primary]
