MESH CHAT
Hi nordic:
    I use two NRF52DKs and download MESH CHAT separately, hoping to achieve communication between the two NRF52DKs:
   SOFT VER: NCS2.8
  The specific process is as follows:
  NRF MESH Network Add Node, select mesh chat:
Elements Disp No elements were found;
Where did I not set it correctly?
 best regards
jermi
  • Hi  , sorry for my late response.
    1: I don't have a DK because I am using the nrf52840 with a custom PCB, with NCS v2.2.0
    2: I tried with another phone (Android) and it returned the same errors, see the screenshots below:
    3: Would you suggest any CONFIG_LOGS I can enable, so I can understand better where the error occurs?
    Thank you!
    When requesting Composition Data, what Node are you connected to as GATT Proxy? On the last image from an iPhone I see that it's "PheSensor". Did you try connecting directly to the MeshChat node?
    If you're using "PheSensor", are you able to send messages to this node, for example add / remove an App Key? Does this Node has proxy feature enabled? You can control it on Configuration Server screen.
    I'll give few reasons why you may get a timeout for requesting Composition Data:
    1. If you're connected to a freshly provisioned node - this should work. The app knows the Network key, it knows the Device Key, the Sequence Number is 0 and RPCL is empty. If it times out it means that the node ignored the receved message, i.e. failed to decode it.
    2. If you're connected using a Proxy in between, there may be more reasons:
    • Proxy Node does not know the Network key
    • Proxy Node expects higher Seq from the phone
    If you are able to send messages and get responses from a Proxy node, neither of these 2 are the reasons.
    • Proxy feature is disabled on the connected proxy node
    This is enabled by default in our samples.
    I would try to connect to the newly provisioned node as proxy (search after tapping CONNECT (Android) or disable Auto connection and connect manually (iOS).
