NRF connect For Desktop Programmer program Fail
HI.
NRF connect For Desktop Programmer program Fail.
So I used command Tool (nrfjprog). command Tool worked.
Enviroment:
 - nRF Connect For Destop v5.1.0
 - Programmer v.4.5.0
 - Jlink V8.12c
 - Board : 52833 DK
Log:
10:57:32.730 Update files regions according to Application core
10:57:32.730 Parse memory regions for file
10:57:39.756 Recovering Application core
10:57:39.756 Recovering Application core 0%
10:57:40.955 Recovering Application core 100%
10:57:40.956 Recovering Application core completed
10:57:40.958 Writing HEX to Application core
10:57:41.092 Failed "writing hex to application core". Error: code: 1, description: Generic, message: Batch task program failed, [jlink] ��� ��Ƽ����Ʈ �ڵ��������� �����ڵ� ������ ������ �����ϴ�.
Is Any Way to Solved?
Thank you.
ps) I also Used to ppk2.
On Power Profiler(v4.0.0), also program Fail
Log:
11:00:58.610 Getting serialport options from persistent store DXXXXXXXXX.pc-nrfconnect-ppk
11:01:00.891 Failed to write to the target device: Failed with exit code 1. One or more program tasks failed. Message: Failed, [sdfu] ��� ��Ƽ����Ʈ �ڵ��������� �����ڵ� ������ ������ �����ϴ�.
11:01:00.892 Error while setting up device DXXXXXXXXXXX
11:01:00.892 Error: Failed with exit code 1. One or more program tasks failed. Message: Failed, [sdfu] ��� ��Ƽ����Ʈ �ڵ��������� �����ڵ� ������ ������ �����ϴ�.
  • Sorry Too late. In Korea, Long Weekend.
    I changed some word XXX to *** in Path. XXX is private info.
    XXX String include Korean.
    BEN_HBC
    2025-02-03T00_02_37.422Z-log.txt
  • No problem Ben,
    Have you tried nrfutil device as well? Could you check if for instance
    Fullscreen
    1
    nrfutil device program --firmware <path to .hex file> --log-level trace
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    works on an nRF52dk? It would be also interesting to see the log from that with
    Fullscreen
    1
    C:\Users\<USERNAME>\.nrfutil\logs\nrfutil-device.log
    Could you also get the me the output of "chcp" in a cmd terminal?
    Elfving
  • nrfutil device program --firmware <path to .hex file> --log-level trace
    => It works.
    In C:\Users\<USERNAME>\.nrfutil\logs\nrfutil-device.log, when use programming in ppk2, there is nothing.
    I think that My window system setting is problem. I don't Know What's problem. It works on coworker computer.
    I will Formmat and Reinstall Window. LOL
    Thank you for helping. After Check next reply, I will close ticket.
    ps) Here is Programmer Verbose Log.
    2025-02-05T08_39_01.575Z-log.txt
    Hehe I wouldn't necessarily go that far, but I guess you can if you want to.
    This might not be the easiest solution, but maybe it is the simplest.
    Elfving
1 2
