VSCode Extension Host Keeps Crashing As Soon as First Project is Added
Bit baffled by this one, I assume it's related to the attempted nRF SDK Intellisense magic:
We do have a monorepo for various controller projects that includes two zephyr setups in lib/zephyr (latest, for non nRF projects) and lib/nordic (for nRF projects), both gitignored and set up as per respective installation instructions. Command line builds are invoked by either source .venv/bin/activate && west build ... for native Zephyr projects or nrfutil toolchain-manager launch west build -- ... for Nordic ones, with ZEPHYR_BASE etc set beforehand, and build well with all the right respective variables and dirs set.
The issue is that on an M2 MacBook, as soon as we add a project dir to the NRF CONNECT extension, the Extension Host keeps crashing every 30 seconds or so.
No error is given in any of the consoles / outputs, including the vscode js developer console. Intuitively it feels like some logic looking for manifest files, includes, ways to set up Intellisense etc gets lost or runs out of memory / in circles.
Observations:
- Most functionality of the extension does work (until it crashes), including adding build configurations, building, flashing, connecting do devices and outputs etc.
- At startup, the Extension reports multiple, mostly lib/zephyr/zephyr and lib/nordic/zephyr, but sometimes random (Found manifest file: /Users/bruno/meso/firmware/lib/nordic/modules/hal/nxp/mcux/mcux-sdk/west.yml) manifest files and suggests to initialize them, despite the main West workspaces already being initialized.
- Occasional nRF error being shown: "HMv2 SOCs must be passed to determine identifier components."
What we tried so far:
- Creating a completely blank c_cpp_properties.json configuration, cleaning up settings.json, and disabling all other Extensions with Extension bisect and manually.
- Trying to find any traces of the actual error.
- Trying to figure out if the NRF Extension traverses the entire monorepo (way too much) when trying to automate the Intellisense setup, or if it can be limited to our lib/nordic folder within it.
Support Information including full PATH etc:
// IMPORTANT: The following data can contain sensitive or confidential information about your environment.
// If you do not want others to see this information, make sure to remove it before sharing the data.
// For help and support, visit Nordic Semiconductor's DevZone at devzone.nordicsemi.com/.
"platform": {
"os": "darwin",
"osVersion": "Darwin Kernel Version 24.0.0: Tue Sep 24 23:37:13 PDT 2024; root:xnu-11215.1.12~1/RELEASE_ARM64_T8112",
"osKernel": "24.0.0",
"vscode": "1.96.4",
"electron": "32.2.6",
"node": "v20.18.1"
"system": {
"date": "2025-01-24T12:36:15.199Z",
"vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
"vscodeUptime": "00:00:08",
"osUptime": "169:49:12",
"cpu": "Apple M2"
"workspace": {
"name": "meso-firmware (Workspace)",
"workspaceFile": "/Users/bruno/meso/firmware/config/meso-firmware.code-workspace",
"folders": [
"/Users/bruno/meso/firmware"
"sdks": [
"version": "v4.0.99",
"path": "/Users/bruno/meso/firmware/lib/zephyr"
"version": "v3.7.99",
"path": "/Users/bruno/meso/firmware/lib/nordic"
"activeBuild": "/Users/bruno/meso/firmware/cabinet/brain/build/brain",
"apps": [
"workspace": "/Users/bruno/meso/firmware",
"uri": "/Users/bruno/meso/firmware/cabinet/brain",
"buildConfigurations": [
"id": "/Users/bruno/meso/firmware/cabinet/brain/build",
"name": "build",
"boardId": "nrf54l15dk/nrf54l15/cpuapp",
"type": "Sysbuild",
"isChild": false,
"isStale": true,
"taskBindings": {
"build": [],
"pristineBuild": [],
"flash": [],
"eraseAndFlash": []
"toolchain": "Zephyr SDK 0.17.0"
"toolchains": [
"version": "2.9.0",
"path": "/opt/nordic/ncs/toolchains/b8efef2ad5"
"version": "2.8.0",
"path": "/opt/nordic/ncs/toolchains/15b490767d"
"version": "0.17.0",
"path": "/Users/bruno/zephyr-sdk-0.17.0"
"connectedDevices": [],
"tools": {
"/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.17.0 (arm64)",
"/Applications/SEGGER/JLink/JLinkExe": "8.10j (x64,arm64)",
"/usr/local/bin/nrfjprog": "10.24.2 (x64,arm64)",
"/Users/bruno/meso/firmware/lib/nordic/nrfutil": "7.13.0 (x64,arm64)",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/cmake": "3.21.0 (arm64)",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/west": "1.2.0",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/python3": "3.12.4 (arm64)",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/ninja": "1.10.2 (arm64)",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/gperf": "3.1 (arm64)",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/dtc": "1.6.1 (arm64)",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/gn": "2202 (arm64)",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/git": "2.37.3 (arm64)",
"arm-gdbPath": "/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb",
"riscv-gdbPath": "/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/riscv64-zephyr-elf/bin/riscv64-zephyr-elf-gdb"
"nrfutil": {
"nrfutil-device": {
"version": "2.7.9",
"binPath": "/Users/bruno/.vscode/extensions/nordic-semiconductor.nrf-connect-2025.1.127-darwin-arm64/platform/nrfutil/bin/nrfutil-device",
"jlinkInfo": {
"description": "This version of SEGGER J-Link is different from the J-Link version that was used to test nrfutil device commands",
"expectedVersion": {
"version": "JLink_V7.94i",
"versionFormat": "string"
"name": "JlinkARM",
"version": "JLink_V8.10j",
"nrfutil-toolchain-manager": {
"version": "0.14.4",
"binPath": "/Users/bruno/.vscode/extensions/nordic-semiconductor.nrf-connect-2025.1.127-darwin-arm64/platform/nrfutil/bin/nrfutil-toolchain-manager"
"environment": {
"westEnv": {
"GIT_EXEC_PATH": "/opt/nordic/ncs/toolchains/b8efef2ad5/Cellar/git/2.37.3/libexec/git-core",
"HOME": "/Users/bruno",
"PATH": "/opt/nordic/ncs/toolchains/b8efef2ad5/bin:/opt/nordic/ncs/toolchains/b8efef2ad5/usr/bin:/opt/nordic/ncs/toolchains/b8efef2ad5/usr/local/bin:/opt/nordic/ncs/toolchains/b8efef2ad5/opt/bin:/opt/nordic/ncs/toolchains/b8efef2ad5/opt/nanopb/generator-bin:/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin:/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/riscv64-zephyr-elf/bin:/Users/bruno/.bun/bin:/Applications/Postgres.app/Contents/Versions/latest/bin:/opt/homebrew/opt/postgresql@15/bin:/opt/homebrew/bin:/opt/homebrew/sbin:/opt/ST/STM32CubeCLT_1.17.0:/opt/ST/STM32CubeCLT_1.17.0/GNU-tools-for-STM32/bin:/opt/ST/STM32CubeCLT_1.17.0/STM32CubeProgrammer/bin:/opt/ST/STM32CubeCLT_1.17.0/STLink-gdb-server/bin:/opt/ST/STM32CubeCLT_1.17.0/CMake/bin:/opt/ST/STM32CubeCLT_1.17.0/Ninja/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/Apple/usr/bin:/Users/bruno/meso/firmware/lib/nordic:/Applications/ArmGNUToolchain/14.2.rel1/aarch64-none-elf/bin:/Users/bruno/.bun/bin:/Applications/Postgres.app/Contents/Versions/latest/bin:/opt/homebrew/opt/postgresql@15/bin:/opt/homebrew/bin:/opt/homebrew/sbin:/opt/ST/STM32CubeCLT_1.17.0:/opt/ST/STM32CubeCLT_1.17.0/GNU-tools-for-STM32/bin:/opt/ST/STM32CubeCLT_1.17.0/STM32CubeProgrammer/bin:/opt/ST/STM32CubeCLT_1.17.0/STLink-gdb-server/bin:/opt/ST/STM32CubeCLT_1.17.0/CMake/bin:/opt/ST/STM32CubeCLT_1.17.0/Ninja/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/Apple/usr/bin:/Users/bruno/meso/firmware/lib/nordic:/Applications/ArmGNUToolchain/14.2.rel1/aarch64-none-elf/bin",
"ZEPHYR_BASE": "/Users/bruno/meso/firmware/lib/nordic/zephyr",
"ZEPHYR_SDK_INSTALL_DIR": "/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk",
"USER": "bruno"
"inherited": {
"ELECTRON_RUN_AS_NODE": "1",
"PATH": "/Users/bruno/.bun/bin:/Applications/Postgres.app/Contents/Versions/latest/bin:/opt/homebrew/opt/postgresql@15/bin:/opt/homebrew/bin:/opt/homebrew/sbin:/opt/ST/STM32CubeCLT_1.17.0:/opt/ST/STM32CubeCLT_1.17.0/GNU-tools-for-STM32/bin:/opt/ST/STM32CubeCLT_1.17.0/STM32CubeProgrammer/bin:/opt/ST/STM32CubeCLT_1.17.0/STLink-gdb-server/bin:/opt/ST/STM32CubeCLT_1.17.0/CMake/bin:/opt/ST/STM32CubeCLT_1.17.0/Ninja/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/Apple/usr/bin:/Users/bruno/meso/firmware/lib/nordic:/Applications/ArmGNUToolchain/14.2.rel1/aarch64-none-elf/bin",
"USER": "bruno"
"terminal": {
"defaultProfile": null
"config": {
"topdir": "",
"toolchain": {
"path": ""
"ozonePath": "",
"applications": [
"${workspaceFolder}/cabinet/brain"
"applicationOptions": {},
"kconfig": {
"interface": "kconfig"
"west": {
"env": {
"$base": "terminal"
"boardRoots": [],
"taskBindings": {},
"buildTerminal": {
"condensedProgress": true
"debugging": {
"flash": false,
"bindings": {
"${workspaceFolder}/cabinet/brain/build_1/brain": "Launch brain"
"justMyCode": false
"flash": {
"softreset": false,
"erase": false,
"recover": false
"enableTelemetry": true,
"thirdpartyIntegration": {},
"toolchainManager": {
"indexURL": null,
"installDirectory": null
"nrfutil": {
"home": null
"defaultOpenAction": "ask",
"terminalProfile": {
"shell": null
"terminalMode": "character"
"extensions": {
"internal": {
"version": "2025.1.127",
"path": "/Users/bruno/.vscode/extensions/nordic-semiconductor.nrf-connect-2025.1.127-darwin-arm64",
"isActive": true
"version": "2024.9.14",
"path": "/Users/bruno/.vscode/extensions/nordic-semiconductor.nrf-terminal-2024.9.14",
"isActive": true
"version": "2024.12.15",
"path": "/Users/bruno/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2024.12.15",
"isActive": true
"version": "2024.12.13",
"path": "/Users/bruno/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2024.12.13",
"isActive": true
"external": {
"marus25.cortex-debug": null,
"ms-vscode.cpptools": "1.22.11",
"ms-vscode.js-debug": "1.96.0",
"dan-c-underwood.arm": "1.7.4",
"GitHub.codespaces": "1.17.3",
"hangxingliu.vscode-systemd-support": "3.0.0",
"mcu-debug.debug-tracker-vscode": "0.0.15",
"mcu-debug.memory-view": "0.0.25",
"mcu-debug.peripheral-viewer": "1.4.6",
"mcu-debug.rtos-views": "0.0.7",
"ms-python.debugpy": "2024.14.0",
"ms-python.python": "2024.22.2",
"ms-python.vscode-pylance": "2024.12.1",
"ms-toolsai.jupyter": "2024.11.0",
"ms-toolsai.jupyter-keymap": "1.1.2",
"ms-toolsai.jupyter-renderers": "1.0.21",
"ms-toolsai.vscode-jupyter-cell-tags": "0.1.9",
"ms-toolsai.vscode-jupyter-slideshow": "0.1.6",
"ms-vscode.hexeditor": "1.11.1",
"ms-vscode.makefile-tools": "0.11.13",
"twxs.cmake": "0.0.17",
"ZixuanWang.linkerscript": "1.0.4"
  • Hi Bruno,
    I check this internally with experts and they asked whether you could share your environment setup and confirm whether you have this issue on multiple machines?
    Priyanka
  • Hi Priyanka, env itself should be in the support information I posted, machine is an M2 Macbook, but it happens on both Windows and Mac.
    To help with usage/debugging in the meantime: see my previous questions if there's a way to tell nRF Connect to not traverse the entire monorepo? We're still getting various "west.yml found" messages, despite our application(s) already having proper build configurations pointing to the zephyr / SDK folders we want to use, which tells me that Connect is still looking everywhere across the repo.
    Something along the lines of the now deprecated nrf-connect.toolchain.path or nrf-connect.topdir.
  • From the logs we don't see that the firmware directory or the application in it would be a west workspace.
    I assume that it is a "freestanding" application. In that case it's also a bit unusual that the "SDK"s i.e. lib/nordic and lib/zephyr are under this directory - We would recommend to move them outside of firmware
    This is unrelated, but it can also be seen that the environment of toolchain 2.9.0 is referred but it's mixed with /Users/bruno/zephyr-sdk-0.17.0, is there any reason for this? The toolchain 2.9.0 already includes zephyr-sdk-0.17.0, this is just confusing and also leads to potential conflicting requirements for tools to be installed in PATH for no reason.
     We don't suggest to use python virtual environments, that will not work under VS Code.
    -Priyanka
  • Neither of them is, as mentioned firmware is our monorepo for all firmware development. It contains about 20 different projects, 4 of which are freestanding zephyr projects, two of them Nordic based, two STM32.
    The two West workspaces are in lib/zephyr (latest Zephyr 4.0…) and lib/nordic (latest Nordic fork).
    The Nordic one works with nrfutil, the latest Zephyr one with venv, as is recommended by Zephyr and works as it should. The zephyr sdk 0.17.0 is needed and used for building STM32 based zephyr projects.
    All builds work, it’s just the VSCode Extension that keeps crashing.
  • Glad to hear I'm not the only one! Thought I was going crazy...
    I've been experiencing the same thing for a couple months now, seems like the extension host crashes every ~60-180sec. It seems to dramatically slow down in the several seconds prior to crash.
    So far, I had also tried a full VS Code reinstall with only the nRF Connect for VS Code Extension Pack installed but that resulted in the same behavior. I'm on an M1 mac and use freestanding applications.
    The only interesting thing that I'd also note, is that the host only seems to crash after I've built an application. For example, if I create a new blank application using the extension, I can use the extension to view serial output from my DK indefinitely. However, as soon as I create and build a new configuration in the new application, the extension host will crash a few minutes later, along with the serial terminal.
