VSCode Extension Host Keeps Crashing As Soon as First Project is Added
Bit baffled by this one, I assume it's related to the attempted nRF SDK Intellisense magic:
We do have a monorepo for various controller projects that includes two zephyr setups in lib/zephyr (latest, for non nRF projects) and lib/nordic (for nRF projects), both gitignored and set up as per respective installation instructions. Command line builds are invoked by either source .venv/bin/activate && west build ... for native Zephyr projects or nrfutil toolchain-manager launch west build -- ... for Nordic ones, with ZEPHYR_BASE etc set beforehand, and build well with all the right respective variables and dirs set.
The issue is that on an M2 MacBook, as soon as we add a project dir to the NRF CONNECT extension, the Extension Host keeps crashing every 30 seconds or so.
No error is given in any of the consoles / outputs, including the vscode js developer console. Intuitively it feels like some logic looking for manifest files, includes, ways to set up Intellisense etc gets lost or runs out of memory / in circles.
Observations:
- Most functionality of the extension does work (until it crashes), including adding build configurations, building, flashing, connecting do devices and outputs etc.
- At startup, the Extension reports multiple, mostly lib/zephyr/zephyr and lib/nordic/zephyr, but sometimes random (Found manifest file: /Users/bruno/meso/firmware/lib/nordic/modules/hal/nxp/mcux/mcux-sdk/west.yml) manifest files and suggests to initialize them, despite the main West workspaces already being initialized.
- Occasional nRF error being shown: "HMv2 SOCs must be passed to determine identifier components."
What we tried so far:
- Creating a completely blank c_cpp_properties.json configuration, cleaning up settings.json, and disabling all other Extensions with Extension bisect and manually.
- Trying to find any traces of the actual error.
- Trying to figure out if the NRF Extension traverses the entire monorepo (way too much) when trying to automate the Intellisense setup, or if it can be limited to our lib/nordic folder within it.
Support Information including full PATH etc:
// IMPORTANT: The following data can contain sensitive or confidential information about your environment.
// If you do not want others to see this information, make sure to remove it before sharing the data.
// For help and support, visit Nordic Semiconductor's DevZone at devzone.nordicsemi.com/.
"platform": {
"os": "darwin",
"osVersion": "Darwin Kernel Version 24.0.0: Tue Sep 24 23:37:13 PDT 2024; root:xnu-11215.1.12~1/RELEASE_ARM64_T8112",
"osKernel": "24.0.0",
"vscode": "1.96.4",
"electron": "32.2.6",
"node": "v20.18.1"
"system": {
"date": "2025-01-24T12:36:15.199Z",
"vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
"vscodeUptime": "00:00:08",
"osUptime": "169:49:12",
"cpu": "Apple M2"
"workspace": {
"name": "meso-firmware (Workspace)",
"workspaceFile": "/Users/bruno/meso/firmware/config/meso-firmware.code-workspace",
"folders": [
"/Users/bruno/meso/firmware"
"sdks": [
"version": "v4.0.99",
"path": "/Users/bruno/meso/firmware/lib/zephyr"
"version": "v3.7.99",
"path": "/Users/bruno/meso/firmware/lib/nordic"
"activeBuild": "/Users/bruno/meso/firmware/cabinet/brain/build/brain",
"apps": [
"workspace": "/Users/bruno/meso/firmware",
"uri": "/Users/bruno/meso/firmware/cabinet/brain",
"buildConfigurations": [
"id": "/Users/bruno/meso/firmware/cabinet/brain/build",
"name": "build",
"boardId": "nrf54l15dk/nrf54l15/cpuapp",
"type": "Sysbuild",
"isChild": false,
"isStale": true,
"taskBindings": {
"build": [],
"pristineBuild": [],
"flash": [],
"eraseAndFlash": []
"toolchain": "Zephyr SDK 0.17.0"
"toolchains": [
"version": "2.9.0",
"path": "/opt/nordic/ncs/toolchains/b8efef2ad5"
"version": "2.8.0",
"path": "/opt/nordic/ncs/toolchains/15b490767d"
"version": "0.17.0",
"path": "/Users/bruno/zephyr-sdk-0.17.0"
"connectedDevices": [],
"tools": {
"/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.17.0 (arm64)",
"/Applications/SEGGER/JLink/JLinkExe": "8.10j (x64,arm64)",
"/usr/local/bin/nrfjprog": "10.24.2 (x64,arm64)",
"/Users/bruno/meso/firmware/lib/nordic/nrfutil": "7.13.0 (x64,arm64)",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/cmake": "3.21.0 (arm64)",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/west": "1.2.0",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/python3": "3.12.4 (arm64)",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/ninja": "1.10.2 (arm64)",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/gperf": "3.1 (arm64)",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/dtc": "1.6.1 (arm64)",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/gn": "2202 (arm64)",
"/opt/nordic/ncs/toolchains/b8efef2ad5/bin/git": "2.37.3 (arm64)",
"arm-gdbPath": "/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb",
"riscv-gdbPath": "/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/riscv64-zephyr-elf/bin/riscv64-zephyr-elf-gdb"
"nrfutil": {
"nrfutil-device": {
"version": "2.7.9",
"binPath": "/Users/bruno/.vscode/extensions/nordic-semiconductor.nrf-connect-2025.1.127-darwin-arm64/platform/nrfutil/bin/nrfutil-device",
"jlinkInfo": {
"description": "This version of SEGGER J-Link is different from the J-Link version that was used to test nrfutil device commands",
"expectedVersion": {
"version": "JLink_V7.94i",
"versionFormat": "string"
"name": "JlinkARM",
"version": "JLink_V8.10j",
"nrfutil-toolchain-manager": {
"version": "0.14.4",
"binPath": "/Users/bruno/.vscode/extensions/nordic-semiconductor.nrf-connect-2025.1.127-darwin-arm64/platform/nrfutil/bin/nrfutil-toolchain-manager"
"environment": {
"westEnv": {
"GIT_EXEC_PATH": "/opt/nordic/ncs/toolchains/b8efef2ad5/Cellar/git/2.37.3/libexec/git-core",
"HOME": "/Users/bruno",
"PATH": "/opt/nordic/ncs/toolchains/b8efef2ad5/bin:/opt/nordic/ncs/toolchains/b8efef2ad5/usr/bin:/opt/nordic/ncs/toolchains/b8efef2ad5/usr/local/bin:/opt/nordic/ncs/toolchains/b8efef2ad5/opt/bin:/opt/nordic/ncs/toolchains/b8efef2ad5/opt/nanopb/generator-bin:/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin:/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/riscv64-zephyr-elf/bin:/Users/bruno/.bun/bin:/Applications/Postgres.app/Contents/Versions/latest/bin:/opt/homebrew/opt/postgresql@15/bin:/opt/homebrew/bin:/opt/homebrew/sbin:/opt/ST/STM32CubeCLT_1.17.0:/opt/ST/STM32CubeCLT_1.17.0/GNU-tools-for-STM32/bin:/opt/ST/STM32CubeCLT_1.17.0/STM32CubeProgrammer/bin:/opt/ST/STM32CubeCLT_1.17.0/STLink-gdb-server/bin:/opt/ST/STM32CubeCLT_1.17.0/CMake/bin:/opt/ST/STM32CubeCLT_1.17.0/Ninja/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/Apple/usr/bin:/Users/bruno/meso/firmware/lib/nordic:/Applications/ArmGNUToolchain/14.2.rel1/aarch64-none-elf/bin:/Users/bruno/.bun/bin:/Applications/Postgres.app/Contents/Versions/latest/bin:/opt/homebrew/opt/postgresql@15/bin:/opt/homebrew/bin:/opt/homebrew/sbin:/opt/ST/STM32CubeCLT_1.17.0:/opt/ST/STM32CubeCLT_1.17.0/GNU-tools-for-STM32/bin:/opt/ST/STM32CubeCLT_1.17.0/STM32CubeProgrammer/bin:/opt/ST/STM32CubeCLT_1.17.0/STLink-gdb-server/bin:/opt/ST/STM32CubeCLT_1.17.0/CMake/bin:/opt/ST/STM32CubeCLT_1.17.0/Ninja/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/Apple/usr/bin:/Users/bruno/meso/firmware/lib/nordic:/Applications/ArmGNUToolchain/14.2.rel1/aarch64-none-elf/bin",
"ZEPHYR_BASE": "/Users/bruno/meso/firmware/lib/nordic/zephyr",
"ZEPHYR_SDK_INSTALL_DIR": "/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk",
"USER": "bruno"
"inherited": {
"ELECTRON_RUN_AS_NODE": "1",
"PATH": "/Users/bruno/.bun/bin:/Applications/Postgres.app/Contents/Versions/latest/bin:/opt/homebrew/opt/postgresql@15/bin:/opt/homebrew/bin:/opt/homebrew/sbin:/opt/ST/STM32CubeCLT_1.17.0:/opt/ST/STM32CubeCLT_1.17.0/GNU-tools-for-STM32/bin:/opt/ST/STM32CubeCLT_1.17.0/STM32CubeProgrammer/bin:/opt/ST/STM32CubeCLT_1.17.0/STLink-gdb-server/bin:/opt/ST/STM32CubeCLT_1.17.0/CMake/bin:/opt/ST/STM32CubeCLT_1.17.0/Ninja/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/Apple/usr/bin:/Users/bruno/meso/firmware/lib/nordic:/Applications/ArmGNUToolchain/14.2.rel1/aarch64-none-elf/bin",
"USER": "bruno"
"terminal": {
"defaultProfile": null
"config": {
"topdir": "",
"toolchain": {
"path": ""
"ozonePath": "",
"applications": [
"${workspaceFolder}/cabinet/brain"
"applicationOptions": {},
"kconfig": {
"interface": "kconfig"
"west": {
"env": {
"$base": "terminal"
"boardRoots": [],
"taskBindings": {},
"buildTerminal": {
"condensedProgress": true
"debugging": {
"flash": false,
"bindings": {
"${workspaceFolder}/cabinet/brain/build_1/brain": "Launch brain"
"justMyCode": false
"flash": {
"softreset": false,
"erase": false,
"recover": false
"enableTelemetry": true,
"thirdpartyIntegration": {},
"toolchainManager": {
"indexURL": null,
"installDirectory": null
"nrfutil": {
"home": null
"defaultOpenAction": "ask",
"terminalProfile": {
"shell": null
"terminalMode": "character"
"extensions": {
"internal": {
"version": "2025.1.127",
"path": "/Users/bruno/.vscode/extensions/nordic-semiconductor.nrf-connect-2025.1.127-darwin-arm64",
"isActive": true
"version": "2024.9.14",
"path": "/Users/bruno/.vscode/extensions/nordic-semiconductor.nrf-terminal-2024.9.14",
"isActive": true
"version": "2024.12.15",
"path": "/Users/bruno/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2024.12.15",
"isActive": true
"version": "2024.12.13",
"path": "/Users/bruno/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2024.12.13",
"isActive": true
"external": {
"marus25.cortex-debug": null,
"ms-vscode.cpptools": "1.22.11",
"ms-vscode.js-debug": "1.96.0",
"dan-c-underwood.arm": "1.7.4",
"GitHub.codespaces": "1.17.3",
"hangxingliu.vscode-systemd-support": "3.0.0",
"mcu-debug.debug-tracker-vscode": "0.0.15",
"mcu-debug.memory-view": "0.0.25",
"mcu-debug.peripheral-viewer": "1.4.6",
"mcu-debug.rtos-views": "0.0.7",
"ms-python.debugpy": "2024.14.0",
"ms-python.python": "2024.22.2",
"ms-python.vscode-pylance": "2024.12.1",
"ms-toolsai.jupyter": "2024.11.0",
"ms-toolsai.jupyter-keymap": "1.1.2",
"ms-toolsai.jupyter-renderers": "1.0.21",
"ms-toolsai.vscode-jupyter-cell-tags": "0.1.9",
"ms-toolsai.vscode-jupyter-slideshow": "0.1.6",
"ms-vscode.hexeditor": "1.11.1",
"ms-vscode.makefile-tools": "0.11.13",
"twxs.cmake": "0.0.17",
"ZixuanWang.linkerscript": "1.0.4"
  • Unfortunately not. We did have some success with "C_Cpp.intelliSenseCacheSize": 0 in settings.json stopping the underlying extension from being told to run amok (similar to this issue) and produce terabyte sized cache files saturating discs. It does help, in combination with
    "C_Cpp.exclusionPolicy": "checkFolders",
    "C_Cpp.files.exclude": {
    "${workspaceFolder}/lib/**": true
    "files.watcherExclude": {
    but at that point you're starting to defeat the purpose of having VS Code for your development in the first place. Given that it's also near impossible to have NCS and CLI/West builds coexist we stopped investigating the issue and scrapped using the NCS VS Code plugins altogether.
    As a heavy VS Code user and embedded n00b, this seemed annoying initially but turned out OK - Similar to the ST IDE you can always spin up a quick isolated project to learn/develop/test something, and then transfer it over to your main codebase. Plus you get to feel closer closer to the VIM/CLI cool kids on your team..
  • No luck for me either :( just suffering. I thought it might have been a conflict with the Cmake tools extension, but I think the error messages I saw there were collateral damage of whatever underlying issue is present here.
  • Tried giving the SDK a shot again, but this got significantly worse - it now somehow manages to crash VS Code in way that leaves the process in an UE state (uninterruptable, trying to exit), which means the only way to restart VS Code is by literally restarting your computer. The old trick of setting Intellisense cache size to 0 also doesn't work anymore.
    Bit weird to see this thread abandoned by the support team.
    Thank you for the inputs, but we are still not able to reproduce it at our end.
    This is a pretty old ticket, and since the first report, there have been a lot of updates on various stuff like the VSCode versions, toolchains, JLinks, etc etc. Please make sure that you have updated everything to the latest versions.
    You can also use the following to narrow it down to the extension that creates this issue:
    -Priyanka
  • Completely fresh install on new machine with latest version as per docs. Bisect doesn't work, but deactivating nrfSDK in VSCode is what prevents the error.
    Again, my assumption is that the way you scan the repo leads to some infinite/recursive issue exhausting system memory, last year it looked like you were using the standard C/C++ plugin in some specific ways under the hood.
