NRF54L15 Zephyr Blinky Sample did not start at Power on
Hi
The Blinky Programm only starts when I give the reset Go command via jlink commander.
At Power cycle nothing happens.
If i give the SOC an external Pin reset the running programm stops but never starts
  • I compiled with NRF Connect 2.8 and the port toggle programm runs
    With pure zephyr the hex file size is 95kb
    With NRF Connect the hex file size is 233kb
    Could you help me to find the reason?
    Maybe a there is no startup/boot section included
    I hope some of the Nordic engineers on the forum could shed light on that. I don't know exactly.
    Best Regards,
    Magnus
    Sorry for the late reply (had to stay at home with the kids after being assigned your ticket).
    So it only runs if you start it manually using JLink commander, right?
    What HW are you running on? I suspect it is not an nRF54L15 DK, but a custom board, or a 3rd party kit?
    If it only runs when started by JLink, I suspect it is a clock "issue". That is usually the case when something only runs in a debug session, but not when run normally. The cause is usually that the LFCLOCK (32kHz) is not properly configured. Since the LFCLK XTALis optional, some 3rd party or custom boards don't have them, but most of the samples assume that it is present.
    If that is the case, try adding this line to your prj.conf:
    And see if it makes any difference. This will tell the application to use the internal RC oscillator instead of an external XTAL for the 32kHz clock source. Please let me know if it works or not.
    Edvin
  • Hi Edvin
    It did not work with "CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y"
    but ... when I added
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=n
    CONFIG_CLOCK_CONTROL_NRF=n
    to my prj.conf  a CMake warning came up "No SOURCES given to Zephyr library: drivers__clock_control"
    and the programm started as normal
    Does this help you to find the reason od my starting problem?
  • That is strange. Can you please zip and upload the application where this happened, and I can have a look. I don't know what happens if you don't provide any clock source. Perhaps it defaults to the RC Oscillator.
    What HW are you running this on? Custom hardware, or an nRF54L15 DK?
