Dear Customer Support,
Wanted to open a case to follow up on this old one Case ID: 335484
nRF52840 with Zephyr RTOS: How to use RTC with struct rtc_time?
I initially looked at the counter alarm under
https://github.com/zephyrproject-rtos/zephyr/tree/main/samples/drivers/counter/alarm/src
using rtc0 and counter_set_channel_alarm
Test environment nRF52840, but this seems to be pretty generic to any other nRF platform
I have few high level questions:
1-what would be the pros and cons of using the Zephyr counter alarm feature versus using the plain Zephyr k_timer_start with a registered callback?
2-with the counter alarm feature, there is an upper limitation on the alarm duration around 8 second, as obtained by
counter_get_top_value or counter_get_max_top_value
how to increase that maximum tick value to configure a higher duration value?
3-if we force the device into a power off state using sys_poweroff(), is there a possibility to wake up the device through an RTC callback
There is an available sample that shows how to wake up using a button press, so the idea is to replace the button by a RTC wake up
Thank you
Jamal
PS
I will have more follow up questions later...
