USB Mass Storage with SD card Example Works in NCS 2.6 but Fails in NCS 2.8/2.9
Description:
I am working with the USB mass storage example provided in github.com/.../mass
The example works as expected when built and flashed using NCS v2.6. However, when I attempt to build and run the same example using NCS v2.8 or v2.9, the functionality no longer works.
the NCS 2.6.0 output
*** Booting nRF Connect SDK v3.5.99-ncs1 ***
[00:00:00.308,410] <inf> sd: Maximum SD clock is under 25MHz, using clock of 24000000Hz
Mount /SD:: 0
/SD:: bsize = 512 ; frsize = 32768 ; blocks = 973584 ; bfree = 973579
/SD: opendir: 0
  F 0 SOME.DAT
  D 0 SOME
  D 0 SYSTEM~1
End of files
[00:00:00.367,309] <inf> main: The device is put in USB mass storage mode.
the NCS 2.9.0 output
*** Booting nRF Connect SDK v2.9.0-7787b2649840 ***
*** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
[00:00:00.274,047] <inf> sd: Card does not support CMD8, assuming legacy card
[00:00:00.275,543] <err> usb_msc: Storage init ERROR !!!! - Aborting USB init
[00:00:00.295,043] <inf> sd: Card does not support CMD8, assuming legacy card
[00:00:00.296,508] <err> fs: fs mount error (-5)
[00:00:00.296,508] <err> main: Failed to mount filesystem
[00:00:00.296,691] <inf> main: The device is put in USB mass storage mode.
add two files to example for SD Card
sd.overlay
&spi4 {
	status = "okay";
	cs-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>;
        pinctrl-0 = <&spi4_default>;
	pinctrl-1 = <&spi4_sleep>;
	sdhc0: sdhc@0 {
		compatible = "zephyr,sdhc-spi-slot";
		reg = <0>;
		status = "okay";
		sdmmc {
			compatible = "zephyr,sdmmc-disk";
			status = "okay";
		spi-max-frequency = <24000000>;
&pinctrl{
    spi4_default: spi4_default {
		group1 {
			psels = <NRF_PSEL(SPIM_SCK, 0, 8)>,
				<NRF_PSEL(SPIM_MISO, 0, 10)>,
				<NRF_PSEL(SPIM_MOSI, 0, 9)>;
	spi4_sleep: spi4_sleep {
		group1 {
			low-power-enable;
sd.conf
CONFIG_SPI=y
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=8192
CONFIG_DISK_ACCESS=y
CONFIG_DISK_DRIVERS=y
CONFIG_DISK_DRIVER_SDMMC=y
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_APP_MSC_STORAGE_SDCARD=y
Flash the firmware to the nRF device (nRF5340 DK)
Are there any known changes or breaking updates in NCS 2.8/2.9 that could affect the USB mass storage functionality?
Thank you for your assistance!
