Provisiong a 9160 on our AWS VPC
We're attempting to provision one of our nRF9160-based IoT devices to our AWS VPC.
We're following this procedure:
Provisioning our eDude on AWS
Step 1: Provision the IoT Device (nRF9160)
  1. Install Required Software
Ensure your development environment is set up with:
  • nRF Connect for Desktop (for flashing firmware)
  • nRF SDK (nRF Connect SDK) – includes Zephyr RTOS
  • AWS IoT SDK for C (optional)
  • Segger Embedded Studio or VS Code with Zephyr extension (for development)
  1. Prepare Device Credentials
You'll need to securely load AWS IoT credentials onto your nRF9160:
  1. Obtain the AWS IoT Core Certificates
    • certificate.pem.crt
    • private.pem.key
    • AmazonRootCA1.pem
    • Download the following from AWS IoT Core:
    • Convert to a format suitable for your embedded system (if needed).
  2. Flash Certificates to the Device
    • Store the certificates in non-volatile storage (e.g., CONFIG_NVS in Zephyr).
    • Example approach using Zephyr's LittleFS or Flash FS:
    • #define CERTIFICATE_PATH "/certs/device_cert.pem"
    • #define PRIVATE_KEY_PATH "/certs/private_key.pem"
    • #define ROOT_CA_PATH "/certs/AmazonRootCA1.pem"
    • If using modem security credentials, provision certificates via AT commands:
    • AT%CMNG=0,16842753,0,"-----BEGIN CERTIFICATE-----..."
    • AT%CMNG=0,16842754,0,"-----BEGIN RSA PRIVATE KEY-----..."
    • AT%CMNG=0,16842755,0,"-----BEGIN CERTIFICATE-----..."
    • Verify storage using:  AT%CMNG=1
  1. Configure nRF9160 for Secure MQTT Connection
Modify your Zephyr application’s prj.conf:
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NRF_MODEM_LIB=y
CONFIG_NRF_CLOUD_MQTT=y
Set up AWS endpoint and credentials in Kconfig:
CONFIG_AWS_IOT_BROKER_HOST_NAME= “a3iodo1wh9ldbz-ats.iot.us-west-2.amazonaws.com"
CONFIG_AWS_IOT_SEC_TAG=12345
  • Replace "your-endpoint.amazonaws.com" with your AWS IoT Endpoint (found under IoT Core → Settings).
  • Set up AWS IoT security tag for modem storage (12345 is just an example).
Step 2: Connect nRF9160 to AWS IoT Core
Now, let's establish an MQTT connection and test message exchange.
  1. Initialize LTE & Connect to AWS IoT
Modify your Zephyr application’s main file (main.c):
#include <zephyr.h>
#include <net/mqtt.h>
#include <modem/lte_lc.h>
#include <modem/modem_key_mgmt.h>
#include <logging/log.h>
LOG_MODULE_REGISTER(my_mqtt_app, LOG_LEVEL_INF);
#define AWS_BROKER #define AWS_BROKER "a3iodo1wh9ldbz-ats.iot.us-west-2.amazonaws.com"
#define AWS_PORT 8883
#define MQTT_CLIENT_ID "nRF9160_device"
// MQTT buffers
static uint8_t rx_buffer[512];
static uint8_t tx_buffer[512];
static struct mqtt_client client;
static struct sockaddr_storage broker;
// Callback for MQTT events
void mqtt_event_handler(struct mqtt_client *client, const struct mqtt_evt *evt) {
    switch (evt->type) {
        case MQTT_EVT_CONNACK:
            LOG_INF("MQTT connected");
        case MQTT_EVT_DISCONNECT:
            LOG_INF("MQTT disconnected");
        case MQTT_EVT_PUBLISH:
            LOG_INF("Message received: %s", evt->param.publish.message.payload.data);
// Function to configure MQTT client
void mqtt_init(void) {
    struct sockaddr_in *broker4 = (struct sockaddr_in *)&broker;
    broker4->sin_family = AF_INET;
    broker4->sin_port = htons(AWS_PORT);
    net_addr_pton(AF_INET, AWS_BROKER, &broker4->sin_addr);
    mqtt_client_init(&client);
    client.broker = &broker;
    client.evt_cb = mqtt_event_handler;
    client.client_id.utf8 = MQTT_CLIENT_ID;
    client.client_id.size = strlen(MQTT_CLIENT_ID);
    client.transport.type = MQTT_TRANSPORT_SECURE;
    client.rx_buf = rx_buffer;
    client.rx_buf_size = sizeof(rx_buffer);
    client.tx_buf = tx_buffer;
    client.tx_buf_size = sizeof(tx_buffer);
// Function to connect to MQTT broker
void mqtt_connect(void) {
    int err = mqtt_connect(&client);
    if (err) {
        LOG_ERR("MQTT connection failed: %d", err);
        return;
    LOG_INF("MQTT connection successful");
// Entry point
void main(void) {
    LOG_INF("Initializing LTE...");
    lte_lc_init_and_connect();  // Establish LTE connection
    LOG_INF("Setting up MQTT...");
    mqtt_init();
    mqtt_connect();
  1. Publish Messages to AWS IoT
After establishing a connection, send an MQTT message:
void send_mqtt_message(void) {
    struct mqtt_publish_param param;
    char payload[] = "{ \"status\": \"active\", \"temperature\": 25 }";
    param.message.topic.qos = MQTT_QOS_0_AT_MOST_ONCE;
    param.message.topic.topic.utf8 = "iot/device/data";
    param.message.topic.topic.size = strlen(param.message.topic.topic.utf8);
    param.message.payload.data = payload;
    param.message.payload.len = strlen(payload);
    param.message_id = sys_rand32_get();
    int err = mqtt_publish(&client, &param);
    if (err) {
        LOG_ERR("Failed to publish message: %d", err);
    } else {
        LOG_INF("Message published successfully");
  1. Subscribe to Incoming Commands
Modify the MQTT event handler to process received messages:
case MQTT_EVT_PUBLISH: {
    struct mqtt_publish_param *p = &evt->param.publish;
    LOG_INF("Received topic: %.*s", p->message.topic.topic.size, p->message.topic.topic.utf8);
    LOG_INF("Payload: %.*s", p->message.payload.len, (char *)p->message.payload.data);
We have successfully flashed the certificates into the modem, however, the MQTT connection attempt times out.  Not sure how to troubleshoot this.
Can offer any advice?
