FDS_EVT_GC results in NRF_SUCCESS but with remaining freeable words
We have nRF52832 in production on a custom board. Recently, we created a new functionality with the aim to handle flash more efficiently, and to avoid the case where peer manager will not have enough space and it will erase bonds. So, every time before saving any kind of record, words_used + new record size is checked that is less than the determined limit and then saving in flash is allowed. We also call two times a day the fds_gc, as long as there is no BLE connection at the time.
The problem is that from many clients devices we receive logs that we have set in order to track gc behaviour. This kind of log is set after FDS_EVT_GC and if this event returns NRF_SUCCESS. In this case we call fds_stat to witness the result of garbage collector, but unfortunately, it returns the same number of freeable words at every gc call. We have this log from many users for days, and we do not know why this happens, and why it doesn't delete all freeable words but still returns nrf_success?
When I say the same number I mean same number again and again for each user, e.g. one user has 1458, another 2012, etc.
Why does this happen?
How can we solve this problem?
Thank you in advance.
Dimitra
  • Ok, I run a test where the error occurred because I turned off power after flash was full.
    Here are the files:
    before1.hex
    after.hex
    I hope it helps.
    Do you think I should do soft-reset when it gc returns SUCCESS but there are freeable remaining records?
    If you cannot find something that would help me, do you think it is ok to do soft reset when it happens?
    Thank you
    Dimitra
    Similar to your observation, based on your flash dump, I can see that the GC for some reason is not performed 100%. This can happen if a record fail CRC. Do you have CRC enabled and could you try to disable it and see if you're still able to reproduce this issue?
    I don't see how a soft-reset or any reset would have any effect on the garbage collection after the fds event handler has retuned with a FDS_EVT_GC.
    regards
    Jared
  • In my sdk_config.h file I have these settings:
    FDS_CRC_CHECK_ON_READ 0
    FDS_CRC_CHECK_ON_WRITE 0
    CRC16_ENABLED 1
    CRC32_ENABLED 0
    Is this the one you are talking about or there is another configuration missing?
    I will disable CRC16_ENABLED and try to reproduce it.
    I was thinking about calling fds_gc again after a reset which would hopefully work normally, but maybe it is not a safe approach..
    Dimitra
    Yes and set FDS_CRC_CHECK_ON_READ to 0.
    I'm not sure if it has any effect but I can't see how calling gc after a reset would effect the flash negatively except for the added time. What's important is that you wait for the FDS events to be generated before you reset as the module is asynchronous.
    regards
    Jared
    It looks like it didn't work..
    I run the test again and after getting full flash I turned off the power in order to try to reproduce the error. I turned on the power again, connected, collected data and then gc was called and returned success with 2002 freeable words.
    But this time I noticed that after collecting all data, peer manager tried to clean flash. So could it be maybe that I call gc at the same time peer manager does or right after and there is a conflict or something?
    		// mobile is connected
    00> <info> app: No more records were found to send!  Valid Measurements: 0
    		// sampling
    00> <info> app: Event: FDS_EVT_UPDATE received (NRF_SUCCESS)
    00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Local database, action: Update
    00> <info> app: Successfully wrote Unix time: 1739524052
    00> <info> app: Gmt: 2
    00> <info> app: ## FULL FLASH ##		// log that states full flash state - records were just deleted, in some seconds this goes away
    00> <info> app: Valid Measurements: 0. Errors saved: 0
    00> <info> app: Disconnected, reason 0x13.
    		// mobile diconnected: this means that GC is called by me at this point if there are freeable words
    00> Logs dropped (9)
    00> <info> peer_manager_handler: Attempting to clean flash.
    00> <info> app: Event: FDS_EVT_GC received (FDS_ERR_OPERATION_TIMEOUT)
    00> <warning> peer_manager_handler: Flash garbage collection failed with error Unknown error code.
    00> <warning> peer_manager_handler: Flating to clean flash.
    00> ting to clean flash.
    00> <info> peer_manager_handler: Attempash garbage collection failed with error Unknown error code.
    00> Logs dropped (10)
    00> ived (FDS_ERR_OPERATION_TIMEOUT)
    00> ash garbage collection failed with error Unknown error code.
    00> <info> app: Event: FDS_EVT_GC rece<info> app: Fast advertising.
    00> <info> app: Event: FDS_EVT_GC received (NRF_SUCCESS)
    		// below logs: (freeable_words, words_used)
    00> <info> app: AFTER GC STAT: (2002, 2092)  (origin 4)
    00> <info> app: AFTER GC STAT UNDER LIMIT: (2002, 2092)
    		// sampling continues...
    00> <info> app: No 2. call of GC	// GC is called again because of timestamp (this happens at midnight)
    00> <info> app: Unix limit is: 1739570400
    00> <info> app: AFTER GC STAT: (2008, 2098)  (origin 4)
    00> <info> app: AFTER GC STAT UNDER LIMIT: (2008, 2098)
    		// sampling
    		// sampling
    Is there a way that I have knowledge that gc has been already called from peer manager and so I do not call it again while it is running ?
    Or perhaps this happens if GC is called while there is another active action in flash like writing/updating a record?
    Finally, could you explain me more about CRC? Why should I set it enabled or disabled? and now that it was reproduced should I enable CRC16_ENABLED again?
    Dimitra
