Automating FOTA Flashing for 20 boards of nRF52840 DK using BLE
I am working on automating the FOTA flashing process for 50 PCA10056 (nRF52840 DK) boards using a Python script. The goal is to efficiently flash firmware onto multiple boards simultaneously while ensuring reliability.
I have already tried using nrfutil, but I encounter the same error as described in Case ID: 256309. Additionally, mcumgr has never worked for me.
I would like guidance on:
  1. Best practices for automating FOTA updates on multiple nRF52840 DKs.
  2. Recommended tools and libraries (nrfutil,or other alternatives).
  3. The best command to use for this operation.
  4. Handling potential issues such as connection stability and flashing failures.
  5. Any existing scripts or references that could help streamline this process.
    I am glad to see most things are wokring. Regardign confirming the image, you need to provide the hash at the enf of you rcommand (so ...image confirm <HASH>)
  • Just to clarify if i need to confirm with hash from  image 0 slot 0  after reset? The flags changed from active to active confirmed for image 0 slot 0 . Anything to be done for image 0 slot 1 flags?
    user@raspberrypi:~ $ sudo mcumgr --conntype ble --connstring 'peer_name=oldSW' reset
    Done
    user@raspberrypi:~ $ sudo mcumgr --conntype ble --connstring 'peer_name=newSW' image list
    Images:
    image=0 slot=0
    version: 2.6.0
    bootable: true
    flags: active
    hash: 45e6a61863cc78237c8467359fed716e611a346cede52c0df087ec67718472c7
    image=0 slot=1
    version: 2.6.0
    bootable: true
    flags: confirmed
    hash: 8e30aa3cffb62bcf8a05cfb199505bb97843ccab8a5bc99abd97f0c132d2a052
    Split status: N/A (0)
    user@raspberrypi:~ $ sudo mcumgr --conntype ble --connstring 'peer_name=newSW' image confirm 45e6a61863cc78237c8467359fed716e611a346cede52c0df087ec67718472c7
    Images:
    image=0 slot=0
    version: 2.6.0
    bootable: true
    flags: active confirmed
    image=0 slot=1
    version: 2.6.0
    bootable: true
    flags:
    This looks good to me. Now the slot 0 is active and confirmed. Slot 1 does not have flags, and this is also expected as the flags in the trailer should be cleared when it was swapped out from slot 0 to slot 1. Does it not work as epxected?
  • Yes it works as expected now. another issue  I sometimes observe that mcumgr command image upload stops inbetween and uploading will be unsuccessful. 192.43 KiB / 201.76 KiB [===============================>-]  95.38% 11.15 KiB/sError: ImageUpload unexpected error after 197051/206599 bytes
    I see. I am not sure what caues that. Generally, failures and disconnect can happen, but then you should be able to start again right after. If you want to know more aboute what is happening, it could be wrorth enabling more logging in mcumgr and/or sniffing to see if there is an issue on air.
