How to send nRF8001 notifications
Hi, I have peripheral device using the nRF8001. I'm using the Android BLE SDK on the MCU to talk to it. I am having a problem where I am using lib_aci_set_local_data() SDK function and not receiving command responses for it once in a while. I think it is a "flow control" issue. I've read the user manual and searched these forums but can't figure out how to handle BLE "notifications" right.
So, I have some characteristics that are set up as notifications. The services.h file provides SET and TX pipes for each such characteristic. I also use other "write only" local data like BLE Device Information. And I use the Nordic UART Service. In general everything works great. It's just when too much happens at once I end up not receiving some command responses I expect.
The way I have coded the handling of notification characteristics is that I use lib_aci_set_local_data() with the SET pipe to set the local radio value for the characteristic and, if the lib_aci_is_pipe_available() function shows the characteristic TX pipe is open, I also use the lib_aci_send_data() function to send the data to the remote (central) device. Maybe I don't have to use both function calls? But, if not, why are there two pipes for the same characteristic.
I am also careful to try to follow the "flow control" rules. So I only do one system command at a time and I only do lib_aci_send_data() calls when there are data credits available. I also only do one lib_aci_set_local_data() call at a time. Since there are always a total of 2 data credits max with the nRF8001 I figure that means I never have more than 4 packets waiting to send to the radio. And the ACI library is set up with a queue length of 4 and, now that the official SDK uses the FIFO queuing scheme I proposed that allows all 4 packets to be used, the queue shouldn't overflow.
One thing I don't understand is whether there are other rules for flow control with setting local data? The SetLocalData radio command is listed as one of the "Data" commands. Does my code also need to check data credits before using that command and hold off until a credit is available? None of the examples really do that. In fact, I can't find any example that is real good about showing notifications at work.
Hopefully there is something I am doing wrong that someone can point out? Thanks. Fred
