Cannot use UART1
Hello, I cannot use UART1, and I don`t know the reason for that.
I run the exercise: https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/lessons/lesson-4-serial-communication-uart/topic/exercise-1-5/
using UART0, and it works fine. When I replaced UART0 with UART1, I could not receive or transmit any data.
The overlay, the prj.conf, and the output in case UART1 are attached.
I am using NCS version 2.9.0
This is the output in case UART1 and the LEDs didn`t toggle.
This is the prj.conf file:
Here is the overlay file:
    What do you have connected to the other end of the UART to receive or transmit data? Have you connected the GPIOs of UART1 to something?
    Marte
  • No, I just connected the board to the laptop using USB and tried to receive messages from the board and display them on the terminal. Then, I tried transmitting messages to the board using the laptop keyboard. I updated this part of the DTS file to use uart1 rather than uart0.
    As I stated in one of my previous replies:
    Marte Myrvold said:
    The pins of UART0 are routed through the interface MCU on the nRF52840 DK, so this is the UART interface you can access through the physical port on the DK. If you want to use UART1, you must change the pins in the devicetree overlay so that UART1 uses the pins that are used by UART0. You must also change zephyr,console to UART1 in devicetree.
    The pins of UART1 are not connected to the USB connector on the DK, but the pins of UART0 are. In other words, you also need to change the UART1 node in the devicetree overlay such that it uses the pins that are originally used by UART0, i.e., the pins that are connected to the USB connector.
    Here you can see the default pins used by UART0 and UART1:
    UART0
    UART_TX
    P0.06
    UART_RX P0.08
    UART_RTS P0.06
    UART_CTS
    P0.07
    UART1
    UART_TX
    P1.02
    UART_RX P1.01
    Marte
