Using the Mass example on my custom board, but first getting it running on the nRF52840dk QSPI flash
I've been using the nRF5 SDK (17.1.0) USB Mass storage code for a data logger I have made.  I am using a memory chip larger than 16KB and that code has bugs when you go over that size.  So I'm moving to the nRF Connect SDK on advice I read on different forums.  My first question is, has anyone used this code on a NOR Flash that is 2Gbit in size?  Will it work?
So, I've used the nRF5 SDK for many years and have recently moved over to the nRF Connect SDK.  It's a bit of a learning curve, but it's making sense.  I am missing something, though, when I try to build and run the Mass sample.  I am using the nRF52840dk which has a QSPI NOR flash attached.  Instead of using the adafruit board like in the example, I'd just like to get this running on the nRF52840dk (PCA10056).
I have copied the Mass folder into a different location where I keep all my examples (and DevAcademy files), so it's out of tree of the SDK.
I opened the existing application.  I created a new build based on the nRF52840dk_nrf52840.  In the build file I optimized for debugging so I could see what was going on.
Then I typed the following into the nRF Terminal:
west build -b nrf52840dk/nrf52840 -- -DCONFIG_APP_MSC_STORAGE_FLASH_FATFS=y
I left out the location of the files since I was in that directory (and the first time I tried it there was an error that it couldn't find the files).  I also changed the board to the nRF52480dk.
Everything build and compiles correctly and I can flash it on to my board.  However, when I then plug it into a windows machine, It says I need to format the device in order to use it.  Ok, that seems normal, but when I try to format it, I says the size is unknown and the sector size is unknown and the format fails.
Here is the output of the build after typing in the above command:
PS C:\Nordic\ExampleProjects\mass> west build -b nrf52840dk/nrf52840 -- -DCONFIG_APP_MSC_STORAGE_FLASH_FATFS=y
Loading Zephyr default modules (Zephyr base (cached)).
-- Application: C:/Nordic/ExampleProjects/mass
-- CMake version: 3.21.0
-- Cache files will be written to: C:/ncs/v2.7.0/zephyr/.cache
-- Zephyr version: 3.6.99 (C:/ncs/v2.7.0/zephyr)
-- Board: nrf52840dk, qualifiers: nrf52840
-- Found host-tools: zephyr 0.16.5 (C:/ncs/toolchains/ce3b5ff664/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.5 (C:/ncs/toolchains/ce3b5ff664/opt/zephyr-sdk)
-- Found BOARD.dts: C:/ncs/v2.7.0/zephyr/boards/nordic/nrf52840dk/nrf52840dk_nrf52840.dts
-- Found devicetree overlay: C:/Nordic/ExampleProjects/mass/boards/nrf52840dk_nrf52840.overlay
-- Generated zephyr.dts: C:/Nordic/ExampleProjects/mass/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/Nordic/ExampleProjects/mass/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/Nordic/ExampleProjects/mass/build/zephyr/dts.cmake
Parsing C:/Nordic/ExampleProjects/mass/Kconfig
Loaded configuration 'C:/Nordic/ExampleProjects/mass/build/zephyr/.config'
No change to configuration in 'C:/Nordic/ExampleProjects/mass/build/zephyr/.config'
No change to Kconfig header in 'C:/Nordic/ExampleProjects/mass/build/zephyr/include/generated/autoconf.h'
CMake Warning at C:/ncs/v2.7.0/zephyr/subsys/usb/device/CMakeLists.txt:22 (message):
CONFIG_USB_DEVICE_VID has default value 0x2FE3.
This value is only for testing and MUST be configured for USB products.
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Nordic/ExampleProjects/mass/build
←[92m-- west build: building application
[9/9] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 89260 B 1 MB 8.51%
RAM: 24272 B 256 KB 9.26%
IDT_LIST: 0 GB 32 KB 0.00%
Generating files from C:/Nordic/ExampleProjects/mass/build/zephyr/zephyr.elf for board: nrf52840dk
Here is the RTT output
SEGGER J-Link V8.10c - Real time terminal output
SEGGER J-Link (unknown) V1.0, SN=1050248664
Process: JLink.exe
*** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
*** Using Zephyr OS v3.6.99-100befc70c74 ***
[00:00:00.427,124] <inf> flashdisk: Initialize device NAND
[00:00:00.427,154] <inf> flashdisk: offset 0, sector size 512, page size 4096, volume size 131072
[00:00:00.427,368] <inf> main: Ian is Testing.
Area 0 at 0x0 on mx25r6435f@0 for 131072 bytes
[00:00:00.427,490] <inf> flashdisk: Initialize device NAND
[00:00:00.427,520] <inf> flashdisk: offset 0, sector size 512, page size 4096, volume size 131072
Mount /NAND:: 0
/NAND:: bsize = 512 ; frsize = 1024 ; blocks = 8128 ; bfree = 6082
/NAND: opendir: 0
F 0 000041C6.TXT
F 0 0000167E.TXT
F 0 00002781.TXT
D 0 SYSTEM~1
End of files
[00:00:00.489,135] <inf> main: The device is put in USB mass storage mode.
It looks like the memory chip is found and everything is okay.  I am worried that it says NAND, but I looked up the adafeather board in the example and it also seems to NOR not NAND.
When I plug the board into my computer, I don't see any more messages on the COM or RTT.
Thank you for you help,
ian
