As shown below, which configuration should I use to resolve the error?
You can solve the issue by enabling legacy mbedTLS crypto. However, Matter uses PSA crypto, and combining legacy and modern crypto drivers can cause issues. I strongly recommend using PSA crypto instead. You can find samples that use PSA crypto under the Cryptography samples section in our documentation.
To enable legacy crypto, set CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y in prj.conf. Please note that this can result in issues and unexpected behavior.
Marte
After using CONFIG_MBEDTLS_LEGACY_CRYPTO_C, many warnings appear during compilation, including prompts that CONFIG_MBEDTLS_LEGACY_CRYPTO_C has been deprecated. If you believe there are risks, please let me know how this version should be resolved.
You should be fine if you use the PSA Crypto API, i.e., the modern crypto driver, instead of legacy. As I stated in my previous reply, PSA Crypto is used in our crypto samples, so I recommend looking at them to learn how to use it. You can see a list of samples here: Cryptograpghy samples.
Marte
Due to some compatibility issues with the internal project, I am forced to use LEGACY encryption methods. If the current version can only be handled this way, I’ll have to make do. Nevertheless, I still appreciate your response.
