Which files to commit to code repository to save build information (VS Code and git)
I'm trying to commit a VS Code project to source control and don't want to include the entire build directory (with all of the build-generated files).   But it seems that all of the information about the build configuration is stored in the build directory.  Is there a definitive list of files necessary (to save in a repository) to allow a successful build when cloning the project?
Thanks!
  • This is understood.
    But I think you might be missing my original question.
    I have a project that compiles in VS code using the Nordic nRF Connect extension.
    I want others to be able to clone the project (using git) and have a build configuration available.   I don't want them to have to go through the "add configuration", etc.     All of the build information seems to be saved in the build folder specified during the "add configuration" process.    I agree that the build folder shouldn't be included in the git commit.   But there should be a mechanism (other than a README that explains how to fill out the "add configuration" window) for defining one or more build configurations that can be part of source control saves.
    I don't see a way to do this using the currently recommended VS Code procedure.
    I could do this when I was using the Segger IDE.
    Thanks...
    I understand. However, that is not supporter (nor a request we see often). Perhaps you can elaborate on why you want the build configuration checked in? You can include moset configurations you want in the normal configuration (devictree or Kconfig) files, and and alternatively also in the CMakeLists.txt file for some special cases. And then someone building will typically jus thave to specify the build target board.
  • Perhaps I'm missing something...
    My code is for a controller in a much larger, complex system.   Those who are testing, debugging, or calibrating the other parts of the system simply want to be able to get the most recent (or appropriate version), build it and get on with their part of the system without having to deal too much with the IDE.
    So I would like to be able to define some configurations (ie. Debug1, Debug2, Release), and provide very simple instructions (as the others using the system are RF and Mechanical engineers) to clone the project, the open the project folder in VS Code, select the appropriate target (via  selecting the appropriate build), and click the "build" button.
    Is there a different way to do this, where creating a "build" configuration for use by VS code is not needed?
    Thanks...
    You can use additional configuration files that you refer to for making variants of the build. One example of that is how it is done in the Bluetooth peripheral UART sample (for instance, use prj_minimal.conf to build a minimal version of the project.
  • OK...   Understood...
    But the procedure to use this .conf is not "automated" in a way which allows easy usage (by others).
    To get an executable from a "clone" containing this .conf requires:
    1. Clone the project
    2. Open the project folder in VS Code
    3. Add a build configuration that:
    a. Names the SDK and ToolChain
    b. Names a build directory
    c. Selects one or more .conf files
    d. Selects one or more -D defines (in my case just one)
    e. Selects compiler flags
    f. Selects build type
    4. Execute the build configuration
    (Note that all of this information is stored in the build directory, which did not arrive with the clone.)
    I used to be able to Clone the project, Open Segger IDE, Select target, Click build
