persistent EdDSA key generate ,detroy and generate
Hi! I’m trying to generate an EdDSA key pair and store it in persistent storage. I then delete the keys and regenerate them. However, after a few successful iterations, my program freezes.
I also noticed that when I enable the hardware accelerator (CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y), the program freezes immediately during key generation.
Additionally, I’m having trouble debugging my program, likely due to the large number of files in my project.
I’m using the CPN003 board with SDK v2.7.0. What could be c
##Crypto
# Enable nordic security backend and PSA APIs
# The Zephyr CMSIS emulation assumes that ticks are ms, currently
CONFIG_SYS_CLOCK_TICKS_PER_SEC=1000
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_NRF_SECURITY=y
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=8192
CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE=y
CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT=y
CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT=y
CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255=y
CONFIG_PSA_WANT_ALG_SHA_512=y
CONFIG_PSA_WANT_ALG_PURE_EDDSA=y
# Using hardware crypto accelerator
CONFIG_PSA_CRYPTO_DRIVER_OBERON=y
# For key generation
CONFIG_PSA_WANT_GENERATE_RANDOM=y
#ECDH
CONFIG_PSA_WANT_ALG_ECDH=y
CONFIG_PSA_WANT_ECC_MONTGOMERY_255=y
#HKDF
CONFIG_PSA_WANT_ALG_HKDF=y
CONFIG_PSA_WANT_ALG_HMAC=y
CONFIG_PSA_WANT_ALG_SHA_256=y
CONFIG_PSA_WANT_KEY_TYPE_HMAC=y
#AES GCM
CONFIG_PSA_WANT_KEY_TYPE_AES=y
CONFIG_PSA_WANT_ALG_GCM=y
# Enable persistent storage APIs
CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C=y
CONFIG_PSA_WANT_ALG_CTR=y
CONFIG_TFM_ITS_ENCRYPTED=y
CONFIG_REBOOT=y
# Enable secure storage APIs
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_NVS=y
CONFIG_TRUSTED_STORAGE=y
#CMAC
CONFIG_PSA_WANT_ALG_CMAC=y
CONFIG_PSA_WANT_ALG_ECB_NO_PADDING=y
ausing these issues, and how can I resolve them?
  • Hey,
    Thank you for your response .I cound not enable TFM logging due to that Error (Actual TF-M version is not available from Git repository.) during compiling .
    here the autoconf.h
    #define CONFIG_UART_INTERRUPT_DRIVEN 1
    #define CONFIG_SPI 1
    #define CONFIG_BT_HCI_ACL_FLOW_CONTROL 1
    #define CONFIG_BT_HCI_VS 1
    #define CONFIG_FLASH_LOAD_SIZE 0x40000
    #define CONFIG_SRAM_SIZE 448
    #define CONFIG_FLASH_LOAD_OFFSET 0x10000
    #define CONFIG_MBOX_NRFX_IPC 1
    #define CONFIG_HEAP_MEM_POOL_ADD_SIZE_BOARD 4096
    #define CONFIG_NUM_IRQS 69
    #define CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC 32768
    #define CONFIG_FLASH_SIZE 1024
    #define CONFIG_FLASH_BASE_ADDRESS 0x0
    #define CONFIG_MP_MAX_NUM_CPUS 1
    #define CONFIG_PLATFORM_SPECIFIC_INIT 1
    #define CONFIG_SYS_CLOCK_TICKS_PER_SEC 1000
    #define CONFIG_ROM_START_OFFSET 0x0
    #define CONFIG_PINCTRL 1
    #define CONFIG_BUILD_OUTPUT_BIN 1
    #define CONFIG_XIP 1
    #define CONFIG_MAIN_STACK_SIZE 8192
    #define CONFIG_IDLE_STACK_SIZE 320
    #define CONFIG_HAS_FLASH_LOAD_OFFSET 1
    #define CONFIG_CPU_HAS_ARM_MPU 1
    #define CONFIG_TICKLESS_KERNEL 1
    #define CONFIG_CLOCK_CONTROL_INIT_PRIORITY 30
    #define CONFIG_USE_DT_CODE_PARTITION 1
    #define CONFIG_HW_STACK_PROTECTION 1
    #define CONFIG_SERIAL_INIT_PRIORITY 50
    #define CONFIG_GPIO 1
    #define CONFIG_SERIAL 1
    #define CONFIG_TINYCRYPT 1
    #define CONFIG_KERNEL_ENTRY "__start"
    #define CONFIG_LOG 1
    #define CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE 8192
    #define CONFIG_DCACHE_LINE_SIZE 32
    #define CONFIG_GEN_IRQ_VECTOR_TABLE 1
    #define CONFIG_SOC "nrf5340"
    #define CONFIG_ARCH_SW_ISR_TABLE_ALIGN 4
    #define CONFIG_NRF_RTC_TIMER 1
    #define CONFIG_IPC_SERVICE_BACKEND_RPMSG_SHMEM_RESET 1
    #define CONFIG_LOG_DOMAIN_NAME ""
    #define CONFIG_BUILD_OUTPUT_HEX 1
    #define CONFIG_CLOCK_CONTROL 1
    #define CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT 1
    #define CONFIG_SOC_HAS_TIMING_FUNCTIONS 1
    #define CONFIG_FLASH_INIT_PRIORITY 50
    #define CONFIG_GEN_ISR_TABLES 1
    #define CONFIG_GEN_IRQ_START_VECTOR 0
    #define CONFIG_GEN_SW_ISR_TABLE 1
    #define CONFIG_SRAM_OFFSET 0x0
    #define CONFIG_REBOOT 1
    #define CONFIG_CONSOLE 1
    #define CONFIG_SOC_SERIES "nrf53"
    #define CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN 4
    #define CONFIG_ISR_STACK_SIZE 2048
    #define CONFIG_ICACHE_LINE_SIZE 32
    #define CONFIG_PRIVILEGED_STACK_SIZE 1024
    #define CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED 1
    #define CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED 1
    #define CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED 1
    #define CONFIG_DT_HAS_ARM_CRYPTOCELL_312_ENABLED 1
    #define CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED 1
    #define CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED 1
    #define CONFIG_DT_HAS_GPIO_KEYS_ENABLED 1
    #define CONFIG_DT_HAS_GPIO_LEDS_ENABLED 1
    #define CONFIG_DT_HAS_MMIO_SRAM_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_OSCILLATORS_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_QSPI_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_SPU_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_USBREG_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_QSPI_NOR_ENABLED 1
    #define CONFIG_DT_HAS_PWM_LEDS_ENABLED 1
    #define CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED 1
    #define CONFIG_DT_HAS_VND_SPI_DEVICE_ENABLED 1
    #define CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED 1
    #define CONFIG_DT_HAS_ZEPHYR_CDC_ACM_UART_ENABLED 1
    #define CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED 1
    #define CONFIG_MBOX 1
    #define CONFIG_NUM_METAIRQ_PRIORITIES 0
    #define CONFIG_LOG_BUFFER_SIZE 8192
    #define CONFIG_INIT_STACKS 1
    #define CONFIG_MBEDTLS_HEAP_SIZE 8192
    #define CONFIG_MBEDTLS_PSA_KEY_SLOT_COUNT 32
    #define CONFIG_MPSL_WORK_STACK_SIZE 1024
    #define CONFIG_MBEDTLS_ENABLE_HEAP 1
    #define CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C 1
    #define CONFIG_WARN_EXPERIMENTAL 1
    #define CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE 2475
    #define CONFIG_BT_BUF_CMD_TX_COUNT 10
    #define CONFIG_INIT_ARCH_HW_AT_BOOT 1
    #define CONFIG_NORDIC_QSPI_NOR 1
    #define CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE 4096
    #define CONFIG_NCS_INCLUDE_RPMSG_CHILD_IMAGE 1
    #define CONFIG_NCS_SAMPLE_HCI_IPC_CHILD_IMAGE 1
    #define CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE 4
    #define CONFIG_UPDATEABLE_IMAGE_NUMBER 2
    #define CONFIG_NRF53_UPGRADE_NETWORK_CORE 1
    #define CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP 1
    #define CONFIG_BT_L2CAP_TX_MTU 498
    #define CONFIG_BT_BUF_ACL_TX_SIZE 251
    #define CONFIG_BT_BUF_ACL_RX_SIZE 502
    #define CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_VALIDATION 1
    #define CONFIG_PM_PARTITION_SIZE_PROVISION 0x280
    #define CONFIG_PM_PARTITION_SIZE_B0_IMAGE 0x8000
    #define CONFIG_SB_VALIDATION_INFO_MAGIC 0x86518483
    #define CONFIG_SB_VALIDATION_POINTER_MAGIC 0x6919b47e
    #define CONFIG_SB_VALIDATION_INFO_CRYPTO_ID 1
    #define CONFIG_SB_VALIDATION_INFO_VERSION 2
    #define CONFIG_SB_VALIDATION_METADATA_OFFSET 0
    #define CONFIG_SB_VALIDATE_FW_SIGNATURE 1
    #define CONFIG_BT_COMPANY_ID_NORDIC 0x0059
    #define CONFIG_BT_COMPANY_ID 0x0059
    #define CONFIG_BT_MAX_CONN 1
    #define CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE 1
    #define CONFIG_BT_HCI_TX_STACK_SIZE 1024
    #define CONFIG_BT_RX_STACK_SIZE 4096
    #define CONFIG_SYSTEM_WORKQUEUE_PRIORITY -1
    #define CONFIG_BT_GATT_AUTO_SEC_REQ 1
    #define CONFIG_HEAP_MEM_POOL_SIZE 8192
    #define CONFIG_BT_DRIVERS 1
    #define CONFIG_BT_PERIPHERAL 1
    #define CONFIG_BT_BROADCASTER 1
    #define CONFIG_BT_CONN 1
    #define CONFIG_BT_PHY_UPDATE 1
    #define CONFIG_BT_DATA_LEN_UPDATE 1
    #define CONFIG_BT_BUF_ACL_TX_COUNT 3
    #define CONFIG_BT_BUF_ACL_RX_COUNT 6
    #define CONFIG_BT_BUF_EVT_RX_SIZE 68
    #define CONFIG_BT_BUF_EVT_RX_COUNT 10
    #define CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE 43
    #define CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT 3
    #define CONFIG_BT_BUF_CMD_TX_SIZE 65
    #define CONFIG_BT_HAS_HCI_VS 1
    #define CONFIG_BT_RPA 1
    #define CONFIG_BT_ASSERT 1
    #define CONFIG_BT_ASSERT_VERBOSE 1
    #define CONFIG_BT_DEBUG_NONE 1
    #define CONFIG_BT_LONG_WQ 1
    #define CONFIG_BT_LONG_WQ_STACK_SIZE 1300
    #define CONFIG_BT_LONG_WQ_PRIO 10
    #define CONFIG_BT_LONG_WQ_INIT_PRIO 50
    #define CONFIG_BT_HCI_HOST 1
    #define CONFIG_BT_HCI_TX_PRIO 7
    #define CONFIG_BT_RECV_WORKQ_BT 1
    #define CONFIG_BT_RX_PRIO 8
    #define CONFIG_BT_DRIVER_RX_HIGH_PRIO 6
    #define CONFIG_BT_HOST_CRYPTO 1
    #define CONFIG_BT_HOST_CRYPTO_PRNG 1
    #define CONFIG_BT_SETTINGS 1
    #define CONFIG_BT_SETTINGS_CCC_LAZY_LOADING 1
    #define CONFIG_BT_SETTINGS_DELAYED_STORE 1
    #define CONFIG_BT_SETTINGS_DELAYED_STORE_MS 1000
    #define CONFIG_BT_SETTINGS_CCC_STORE_ON_WRITE 1
    #define CONFIG_BT_SETTINGS_CF_STORE_ON_WRITE 1
    #define CONFIG_BT_SETTINGS_USE_PRINTK 1
    #define CONFIG_BT_LIM_ADV_TIMEOUT 30
    #define CONFIG_BT_CONN_TX_USER_DATA_SIZE 8
    #define CONFIG_BT_CONN_TX_MAX 3
    #define CONFIG_BT_AUTO_PHY_UPDATE 1
    #define CONFIG_BT_AUTO_DATA_LEN_UPDATE 1
    #define CONFIG_BT_SMP 1
    #define CONFIG_BT_BONDABLE 1
    #define CONFIG_BT_SMP_ENFORCE_MITM 1
    #define CONFIG_BT_SMP_MIN_ENC_KEY_SIZE 7
    #define CONFIG_BT_L2CAP_TX_BUF_COUNT 3
    #define CONFIG_BT_L2CAP_TX_FRAG_COUNT 2
    #define CONFIG_BT_L2CAP_RESCHED_MS 1000
    #define CONFIG_BT_ATT_TX_COUNT 3
    #define CONFIG_BT_ATT_PREPARE_COUNT 0
    #define CONFIG_BT_ATT_RETRY_ON_SEC_ERR 1
    #define CONFIG_BT_GATT_SERVICE_CHANGED 1
    #define CONFIG_BT_GATT_DYNAMIC_DB 1
    #define CONFIG_BT_GATT_CACHING 1
    #define CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION 1
    #define CONFIG_BT_GATT_READ_MULTIPLE 1
    #define CONFIG_BT_GATT_READ_MULT_VAR_LEN 1
    #define CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS 1
    #define CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS 1
    #define CONFIG_BT_PERIPHERAL_PREF_MIN_INT 40
    #define CONFIG_BT_PERIPHERAL_PREF_MAX_INT 53
    #define CONFIG_BT_PERIPHERAL_PREF_LATENCY 0
    #define CONFIG_BT_PERIPHERAL_PREF_TIMEOUT 400
    #define CONFIG_BT_MAX_PAIRED 1
    #define CONFIG_BT_CREATE_CONN_TIMEOUT 3
    #define CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT 5000
    #define CONFIG_BT_CONN_PARAM_RETRY_COUNT 3
    #define CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT 5000
    #define CONFIG_BT_DEVICE_NAME "TOST_000_20191009_00002"
    #define CONFIG_BT_DEVICE_APPEARANCE 0
    #define CONFIG_BT_ID_MAX 1
    #define CONFIG_BT_ECC 1
    #define CONFIG_BT_CRYPTO 1
    #define CONFIG_PCD_VERSION_PAGE_BUF_SIZE 2046
    #define CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME 1
    #define CONFIG_NRF_CLOUD_CLIENT_ID "my-client-id"
    #define CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA 1
    #define CONFIG_FOTA_DL_TIMEOUT_MIN 15
    #define CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL 3
    #define CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL 1
    #define CONFIG_NRF_CLOUD_LOG_BUF_SIZE 256
    #define CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NRF_CLOUD_LOG_LOG_LEVEL 3
    #define CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NRF_CLOUD_LOG_LEVEL 3
    #define CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MPSL_FEM_LOG_LEVEL 3
    #define CONFIG_MPSL_THREAD_COOP_PRIO 8
    #define CONFIG_MPSL_TIMESLOT_SESSION_COUNT 0
    #define CONFIG_MPSL_LOW_PRIO_IRQN 26
    #define CONFIG_MPSL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MPSL_LOG_LEVEL 3
    #define CONFIG_PARTITION_MANAGER_ENABLED 1
    #define CONFIG_FLASH_MAP_CUSTOM 1
    #define CONFIG_SRAM_BASE_ADDRESS 0x20000000
    #define CONFIG_RPMSG_NRF53_SRAM_SIZE 0x10000
    #define CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE 0x2000
    #define CONFIG_PM_PARTITION_ALIGN_SETTINGS_STORAGE 0x4000
    #define CONFIG_PM_SINGLE_IMAGE 1
    #define CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER 1
    #define CONFIG_PM_EXTERNAL_FLASH_BASE 0x0
    #define CONFIG_PM_EXTERNAL_FLASH_ENABLED 1
    #define CONFIG_PM_EXTERNAL_FLASH_PATH "/soc/peripheral@50000000/qspi@2b000/W25Q128JVPIM@0"
    #define CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS 134217728
    #define CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY 1
    #define CONFIG_PM_SRAM_BASE 0x20000000
    #define CONFIG_PM_SRAM_SIZE 0x80000
    #define CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MGMT_FMFU_LOG_LEVEL 3
    #define CONFIG_MGMT_SUITFU_TRIGGER_UPDATE_RESET_DELAY_MS 100
    #define CONFIG_MGMT_SUITFU_AUTO_REGISTER_HANDLERS 1
    #define CONFIG_MGMT_SUITFU_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MGMT_SUITFU_LOG_LEVEL 3
    #define CONFIG_NRF_SECURITY 1
    #define CONFIG_MBEDTLS_CFG_FILE "nrf-config.h"
    #define CONFIG_MBEDTLS_USER_CONFIG_FILE "nrf-config-user-empty.h"
    #define CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG_FILE "nrf-psa-crypto-want-config.h"
    #define CONFIG_MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE "nrf-psa-crypto-config.h"
    #define CONFIG_GENERATE_MBEDTLS_CFG_FILE 1
    #define CONFIG_MBEDTLS_PSA_CRYPTO_C 1
    #define CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT 1
    #define CONFIG_PSA_WANT_ALG_SHA_256 1
    #define CONFIG_PSA_WANT_GENERATE_RANDOM 1
    #define CONFIG_PSA_WANT_ALG_CTR_DRBG 1
    #define CONFIG_PSA_HAS_KEY_SUPPORT 1
    #define CONFIG_PSA_WANT_KEY_TYPE_HMAC 1
    #define CONFIG_PSA_WANT_KEY_TYPE_AES 1
    #define CONFIG_PSA_WANT_KEY_TYPE_CHACHA20 1
    #define CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY 1
    #define CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT 1
    #define CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT 1
    #define CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE 1
    #define CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_BASIC 1
    #define CONFIG_PSA_HAS_AEAD_SUPPORT 1
    #define CONFIG_PSA_WANT_ALG_GCM 1
    #define CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 1
    #define CONFIG_PSA_HAS_MAC_SUPPORT 1
    #define CONFIG_PSA_WANT_ALG_CMAC 1
    #define CONFIG_PSA_WANT_ALG_HMAC 1
    #define CONFIG_PSA_HAS_HASH_SUPPORT 1
    #define CONFIG_PSA_WANT_ALG_SHA_512 1
    #define CONFIG_PSA_HAS_CIPHER_SUPPORT 1
    #define CONFIG_PSA_WANT_ALG_ECB_NO_PADDING 1
    #define CONFIG_PSA_WANT_ALG_CTR 1
    #define CONFIG_PSA_HAS_KEY_AGREEMENT 1
    #define CONFIG_PSA_WANT_ALG_ECDH 1
    #define CONFIG_PSA_HAS_KEY_DERIVATION 1
    #define CONFIG_PSA_WANT_ALG_HKDF 1
    #define CONFIG_PSA_HAS_ASYM_SIGN_SUPPORT 1
    #define CONFIG_PSA_WANT_ECC_MONTGOMERY_255 1
    #define CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 1
    #define CONFIG_PSA_WANT_ALG_PURE_EDDSA 1
    #define CONFIG_PSA_CORE_OBERON 1
    #define CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS 1
    #define CONFIG_PSA_CRYPTO_DRIVER_OBERON 1
    #define CONFIG_PSA_USE_CTR_DRBG_DRIVER 1
    #define CONFIG_PSA_USE_CC3XX_CTR_DRBG_DRIVER 1
    #define CONFIG_PSA_WANT_AES_KEY_SIZE_128 1
    #define CONFIG_PSA_WANT_AES_KEY_SIZE_192 1
    #define CONFIG_PSA_WANT_AES_KEY_SIZE_256 1
    #define CONFIG_PSA_MAX_RSA_KEY_BITS 0
    #define CONFIG_PSA_ACCEL_GENERATE_RANDOM 1
    #define CONFIG_PSA_NEED_CC3XX_CTR_DRBG_DRIVER 1
    #define CONFIG_CRACEN_LOG_LEVEL_DEFAULT 1
    #define CONFIG_CRACEN_LOG_LEVEL 3
    #define CONFIG_PSA_NEED_OBERON_GCM_AES 1
    #define CONFIG_PSA_NEED_OBERON_CHACHA20_POLY1305 1
    #define CONFIG_PSA_NEED_OBERON_AEAD_DRIVER 1
    #define CONFIG_PSA_NEED_OBERON_CTR_AES 1
    #define CONFIG_PSA_NEED_OBERON_ECB_NO_PADDING_AES 1
    #define CONFIG_PSA_NEED_OBERON_CIPHER_DRIVER 1
    #define CONFIG_PSA_NEED_OBERON_ECDH_MONTGOMERY_255 1
    #define CONFIG_PSA_NEED_OBERON_ECDH 1
    #define CONFIG_PSA_NEED_OBERON_KEY_AGREEMENT_DRIVER 1
    #define CONFIG_PSA_NEED_OBERON_PURE_EDDSA_TWISTED_EDWARDS_255 1
    #define CONFIG_PSA_NEED_OBERON_ECDSA_VERIFY 1
    #define CONFIG_PSA_NEED_OBERON_ECDSA_SIGN 1
    #define CONFIG_PSA_NEED_OBERON_SHA_256 1
    #define CONFIG_PSA_NEED_OBERON_SHA_512 1
    #define CONFIG_PSA_NEED_OBERON_HASH_DRIVER 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_PUBLIC_KEY_MONTGOMERY_255 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_IMPORT_MONTGOMERY_255 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_EXPORT_MONTGOMERY_255 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_GENERATE_MONTGOMERY_255 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_PUBLIC_KEY_TWISTED_EDWARDS_255 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_IMPORT_TWISTED_EDWARDS_255 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_EXPORT_TWISTED_EDWARDS_255 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_GENERATE_TWISTED_EDWARDS_255 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_PUBLIC_KEY_MONTGOMERY 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_IMPORT_MONTGOMERY 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_EXPORT_MONTGOMERY 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_GENERATE_MONTGOMERY 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_PUBLIC_KEY_TWISTED_EDWARDS 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_IMPORT_TWISTED_EDWARDS 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_EXPORT_TWISTED_EDWARDS 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_GENERATE_TWISTED_EDWARDS 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_PUBLIC_KEY 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_IMPORT 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_EXPORT 1
    #define CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_GENERATE 1
    #define CONFIG_PSA_NEED_OBERON_KEY_MANAGEMENT_DRIVER 1
    #define CONFIG_PSA_NEED_OBERON_HMAC 1
    #define CONFIG_PSA_NEED_OBERON_CMAC 1
    #define CONFIG_PSA_NEED_OBERON_MAC_DRIVER 1
    #define CONFIG_PSA_NEED_OBERON_HKDF 1
    #define CONFIG_PSA_NEED_OBERON_KEY_DERIVATION_DRIVER 1
    #define CONFIG_PSA_NEED_OBERON_ASYMMETRIC_SIGNATURE_DRIVER 1
    #define CONFIG_MBEDTLS_USE_PSA_CRYPTO 1
    #define CONFIG_MBEDTLS_PLATFORM_MEMORY 1
    #define CONFIG_MBEDTLS_PLATFORM_C 1
    #define CONFIG_MBEDTLS_MEMORY_C 1
    #define CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C 1
    #define CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT 1
    #define CONFIG_MBEDTLS_AES_SETKEY_ENC_ALT 1
    #define CONFIG_MBEDTLS_AES_SETKEY_DEC_ALT 1
    #define CONFIG_MBEDTLS_AES_ENCRYPT_ALT 1
    #define CONFIG_MBEDTLS_AES_DECRYPT_ALT 1
    #define CONFIG_MBEDTLS_CHACHA20_ALT 1
    #define CONFIG_MBEDTLS_POLY1305_ALT 1
    #define CONFIG_MBEDTLS_ECDH_GEN_PUBLIC_ALT 1
    #define CONFIG_MBEDTLS_ECDH_COMPUTE_SHARED_ALT 1
    #define CONFIG_MBEDTLS_ECDSA_GENKEY_ALT 1
    #define CONFIG_MBEDTLS_ECDSA_SIGN_ALT 1
    #define CONFIG_MBEDTLS_ECDSA_VERIFY_ALT 1
    #define CONFIG_MBEDTLS_ECJPAKE_ALT 1
    #define CONFIG_MBEDTLS_SHA1_ALT 1
    #define CONFIG_MBEDTLS_SHA224_ALT 1
    #define CONFIG_MBEDTLS_SHA256_ALT 1
    #define CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256 1
    #define CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES 1
    #define CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY 1
    #define CONFIG_OBERON_ONLY_PSA_ENABLED 1
    #define CONFIG_OBERON_ONLY_ENABLED 1
    #define CONFIG_MBEDTLS_MPI_WINDOW_SIZE 6
    #define CONFIG_MBEDTLS_MPI_MAX_SIZE 256
    #define CONFIG_MBEDTLS_CIPHER_C 1
    #define CONFIG_AUDIO_MODULE_NAME_SIZE 20
    #define CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_AUDIO_MODULE_LOG_LEVEL 3
    #define CONFIG_TRUSTED_STORAGE 1
    #define CONFIG_TRUSTED_STORAGE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_TRUSTED_STORAGE_LOG_LEVEL 3
    #define CONFIG_PSA_INTERNAL_TRUSTED_STORAGE 1
    #define CONFIG_PSA_INTERNAL_TRUSTED_STORAGE_PREFIX "its"
    #define CONFIG_TRUSTED_STORAGE_BACKEND_AEAD 1
    #define CONFIG_TRUSTED_STORAGE_BACKEND_AEAD_MAX_DATA_SIZE 256
    #define CONFIG_TRUSTED_STORAGE_BACKEND_AEAD_CRYPTO_PSA_CHACHAPOLY 1
    #define CONFIG_TRUSTED_STORAGE_BACKEND_AEAD_NONCE_PSA_SEED_COUNTER 1
    #define CONFIG_TRUSTED_STORAGE_BACKEND_AEAD_KEY_DERIVE_FROM_HUK 1
    #define CONFIG_TRUSTED_STORAGE_STORAGE_BACKEND_SETTINGS 1
    #define CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE -1
    #define CONFIG_POSIX_MAX_FDS 4
    #define CONFIG_WFA_QT_LOG_LEVEL_DEFAULT 1
    #define CONFIG_WFA_QT_LOG_LEVEL 3
    #define CONFIG_WFA_QT_THREAD_STACK_SIZE 4096
    #define CONFIG_WFA_QT_REBOOT_TIMEOUT_MS 1000
    #define CONFIG_WFA_QT_DEFAULT_INTERFACE "nordic_wlan0"
    #define CONFIG_WPAS_READY_TIMEOUT_MS 10000
    #define CONFIG_NRF_SPU_FLASH_REGION_SIZE 0x4000
    #define CONFIG_FPROTECT_BLOCK_SIZE 0x4000
    #define CONFIG_HW_UNIQUE_KEY_SRC 1
    #define CONFIG_HW_UNIQUE_KEY_SUPPORTED 1
    #define CONFIG_HW_UNIQUE_KEY 1
    #define CONFIG_HW_UNIQUE_KEY_RANDOM 1
    #define CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE 0x0
    #define CONFIG_NCS_BOOT_BANNER 1
    #define CONFIG_NCS_NCS_BOOT_BANNER_STRING "nRF Connect SDK"
    #define CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING "Zephyr OS"
    #define CONFIG_HW_CC3XX 1
    #define CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS 1
    #define CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS 1
    #define CONFIG_ZEPHYR_NRF_MODULE 1
    #define CONFIG_SIGN_IMAGES 1
    #define CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE 1
    #define CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE 4
    #define CONFIG_DT_FLASH_WRITE_BLOCK_SIZE 4
    #define CONFIG_MCUBOOT_USB_SUPPORT 1
    #define CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS 1
    #define CONFIG_ZEPHYR_MCUBOOT_MODULE 1
    #define CONFIG_ZEPHYR_MBEDTLS_MODULE 1
    #define CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE 1
    #define CONFIG_TFM_BOARD "C:/ncs/v2.7.0/zephyr/modules/trusted-firmware-m/nordic/nrf5340_cpuapp"
    #define CONFIG_BOOTLOADER_MCUBOOT 1
    #define CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE 1
    #define CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE 1
    #define CONFIG_ZEPHYR_SOC_HWMV1_MODULE 1
    #define CONFIG_ZEPHYR_CJSON_MODULE 1
    #define CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE 1
    #define CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE 1
    #define CONFIG_ZEPHYR_OPENTHREAD_MODULE 1
    #define CONFIG_SUIT_ENVELOPE_TEMPLATE ""
    #define CONFIG_SUIT_ENVELOPE_TARGET ""
    #define CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT "merged.hex"
    #define CONFIG_SUIT_ENVELOPE_OUTPUT_MPI_MERGE 1
    #define CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE 1
    #define CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT 1
    #define CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE 1
    #define CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE 1
    #define CONFIG_ZEPHYR_COREMARK_MODULE 1
    #define CONFIG_ZEPHYR_CANOPENNODE_MODULE 1
    #define CONFIG_ZEPHYR_CHRE_MODULE 1
    #define CONFIG_ZEPHYR_LZ4_MODULE 1
    #define CONFIG_ZEPHYR_NANOPB_MODULE 1
    #define CONFIG_NANOPB 1
    #define CONFIG_NANOPB_MAX_REQUIRED_FIELDS 64
    #define CONFIG_NANOPB_BUFFER_ONLY 1
    #define CONFIG_ZEPHYR_TF_M_TESTS_MODULE 1
    #define CONFIG_ZEPHYR_ZSCILIB_MODULE 1
    #define CONFIG_ZEPHYR_CMSIS_MODULE 1
    #define CONFIG_HAS_CMSIS_CORE 1
    #define CONFIG_HAS_CMSIS_CORE_M 1
    #define CONFIG_ZEPHYR_CMSIS_DSP_MODULE 1
    #define CONFIG_ZEPHYR_CMSIS_NN_MODULE 1
    #define CONFIG_ZEPHYR_FATFS_MODULE 1
    #define CONFIG_ZEPHYR_HAL_NORDIC_MODULE 1
    #define CONFIG_HAS_NORDIC_DRIVERS 1
    #define CONFIG_HAS_NRFX 1
    #define CONFIG_NRFX_CLOCK 1
    #define CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED 1
    #define CONFIG_NRFX_DPPI 1
    #define CONFIG_NRFX_GPIOTE 1
    #define CONFIG_NRFX_GPIOTE0 1
    #define CONFIG_NRFX_IPC 1
    #define CONFIG_NRFX_NVMC 1
    #define CONFIG_NRFX_POWER 1
    #define CONFIG_NRFX_PWM 1
    #define CONFIG_NRFX_PWM0 1
    #define CONFIG_NRFX_QSPI 1
    #define CONFIG_NRFX_SPIM 1
    #define CONFIG_NRFX_SPIM0 1
    #define CONFIG_NRFX_USBREG 1
    #define CONFIG_ZEPHYR_HAL_ST_MODULE 1
    #define CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE 1
    #define CONFIG_ZEPHYR_LIBMETAL_MODULE 1
    #define CONFIG_ZEPHYR_LIBLC3_MODULE 1
    #define CONFIG_ZEPHYR_LITTLEFS_MODULE 1
    #define CONFIG_ZEPHYR_LORAMAC_NODE_MODULE 1
    #define CONFIG_ZEPHYR_LVGL_MODULE 1
    #define CONFIG_ZEPHYR_MIPI_SYS_T_MODULE 1
    #define CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE 1
    #define CONFIG_ZEPHYR_OPEN_AMP_MODULE 1
    #define CONFIG_ZEPHYR_PICOLIBC_MODULE 1
    #define CONFIG_ZEPHYR_SEGGER_MODULE 1
    #define CONFIG_HAS_SEGGER_RTT 1
    #define CONFIG_ZEPHYR_TINYCRYPT_MODULE 1
    #define CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE 1
    #define CONFIG_ZEPHYR_ZCBOR_MODULE 1
    #define CONFIG_ZCBOR 1
    #define CONFIG_ZCBOR_MAX_STR_LEN 256
    #define CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE 0x4e8
    #define CONFIG_NRFXLIB_CRYPTO 1
    #define CONFIG_HAS_HW_NRF_CC3XX 1
    #define CONFIG_NRF_CC3XX_PLATFORM 1
    #define CONFIG_CC3XX_MUTEX_LOCK 1
    #define CONFIG_NRF_802154_SOURCE_NRFXLIB 1
    #define CONFIG_ZEPHYR_NRFXLIB_MODULE 1
    #define CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE 1
    #define CONFIG_LIBMETAL 1
    #define CONFIG_LIBMETAL_SRC_PATH "libmetal"
    #define CONFIG_OPENAMP 1
    #define CONFIG_OPENAMP_SRC_PATH "open-amp"
    #define CONFIG_OPENAMP_MASTER 1
    #define CONFIG_OPENAMP_SLAVE 1
    #define CONFIG_TINYCRYPT_SHA256 1
    #define CONFIG_TINYCRYPT_SHA256_HMAC 1
    #define CONFIG_TINYCRYPT_SHA256_HMAC_PRNG 1
    #define CONFIG_TINYCRYPT_AES 1
    #define CONFIG_TINYCRYPT_AES_CMAC 1
    #define CONFIG_MCUBOOT_CMAKE_WEST_SIGN_PARAMS "--quiet"
    #define CONFIG_MCUBOOT_SIGNATURE_KEY_FILE ""
    #define CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION "0.0.0+0"
    #define CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS ""
    #define CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH 1
    #define CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE 1
    #define CONFIG_MCUBOOT_BOOTUTIL_LIB 1
    #define CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG 1
    #define CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MCUBOOT_UTIL_LOG_LEVEL 3
    #define CONFIG_BOOT_IMAGE_ACCESS_HOOKS 1
    #define CONFIG_BOARD "cpn0003"
    #define CONFIG_BOARD_REVISION ""
    #define CONFIG_BOARD_TARGET "cpn0003/nrf5340/cpuapp"
    #define CONFIG_BOARD_CPN0003 1
    #define CONFIG_BOARD_CPN0003_NRF5340_CPUAPP 1
    #define CONFIG_BOARD_QUALIFIERS "nrf5340/cpuapp"
    #define CONFIG_BOARD_ENABLE_DCDC_APP 1
    #define CONFIG_BOARD_ENABLE_DCDC_NET 1
    #define CONFIG_BOARD_ENABLE_DCDC_HV 1
    #define CONFIG_BOARD_ENABLE_CPUNET 1
    #define CONFIG_DOMAIN_CPUNET_BOARD "cpn0003/nrf5340/cpunet"
    #define CONFIG_SOC_FAMILY "nordic_nrf"
    #define CONFIG_SOC_FAMILY_NORDIC_NRF 1
    #define CONFIG_SOC_SERIES_NRF53X 1
    #define CONFIG_SOC_NRF5340_CPUAPP 1
    #define CONFIG_SOC_NRF5340_CPUAPP_QKAA 1
    #define CONFIG_HAS_HW_NRF_CC312 1
    #define CONFIG_HAS_HW_NRF_CLOCK 1
    #define CONFIG_HAS_HW_NRF_CTRLAP 1
    #define CONFIG_HAS_HW_NRF_DCNF 1
    #define CONFIG_HAS_HW_NRF_DPPIC 1
    #define CONFIG_HAS_HW_NRF_EGU0 1
    #define CONFIG_HAS_HW_NRF_EGU1 1
    #define CONFIG_HAS_HW_NRF_EGU2 1
    #define CONFIG_HAS_HW_NRF_EGU3 1
    #define CONFIG_HAS_HW_NRF_EGU4 1
    #define CONFIG_HAS_HW_NRF_EGU5 1
    #define CONFIG_HAS_HW_NRF_GPIO0 1
    #define CONFIG_HAS_HW_NRF_GPIO1 1
    #define CONFIG_HAS_HW_NRF_GPIOTE0 1
    #define CONFIG_HAS_HW_NRF_IPC 1
    #define CONFIG_HAS_HW_NRF_KMU 1
    #define CONFIG_HAS_HW_NRF_MUTEX 1
    #define CONFIG_HAS_HW_NRF_NVMC_PE 1
    #define CONFIG_HAS_HW_NRF_OSCILLATORS 1
    #define CONFIG_HAS_HW_NRF_POWER 1
    #define CONFIG_HAS_HW_NRF_PWM0 1
    #define CONFIG_HAS_HW_NRF_QSPI 1
    #define CONFIG_HAS_HW_NRF_REGULATORS 1
    #define CONFIG_HAS_HW_NRF_RESET 1
    #define CONFIG_HAS_HW_NRF_SPIM0 1
    #define CONFIG_HAS_HW_NRF_SPU 1
    #define CONFIG_HAS_HW_NRF_UARTE1 1
    #define CONFIG_HAS_HW_NRF_USBD 1
    #define CONFIG_HAS_HW_NRF_USBREG 1
    #define CONFIG_HAS_HW_NRF_VMC 1
    #define CONFIG_HAS_HW_NRF_WDT0 1
    #define CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED 1
    #define CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND 1
    #define CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND 1
    #define CONFIG_SOC_NRF53_RTC_PRETICK 1
    #define CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET 10
    #define CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET 11
    #define CONFIG_SOC_DCDC_NRF53X_APP 1
    #define CONFIG_SOC_DCDC_NRF53X_NET 1
    #define CONFIG_SOC_DCDC_NRF53X_HV 1
    #define CONFIG_NRF_SPU_FLASH_REGION_ALIGNMENT 0x4000
    #define CONFIG_NRF_SPU_RAM_REGION_SIZE 0x2000
    #define CONFIG_NRF_SPU_RAM_REGION_ALIGNMENT 0x2000
    #define CONFIG_SOC_NRF53_CPUNET_MGMT 1
    #define CONFIG_SOC_ENABLE_LFXO 1
    #define CONFIG_SOC_LFXO_CAP_INT_7PF 1
    #define CONFIG_SOC_HFXO_CAP_DEFAULT 1
    #define CONFIG_NRF_ENABLE_CACHE 1
    #define CONFIG_NRF53_SYNC_RTC 1
    #define CONFIG_SYNC_RTC_LOG_LEVEL_DEFAULT 1
    #define CONFIG_SYNC_RTC_LOG_LEVEL 3
    #define CONFIG_NRF53_SYNC_RTC_INIT_PRIORITY 90
    #define CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT 1
    #define CONFIG_NRF53_SYNC_RTC_LOG_TIMESTAMP 1
    #define CONFIG_NRF53_SYNC_RTC_IPM_OUT 7
    #define CONFIG_NRF53_SYNC_RTC_IPM_IN 8
    #define CONFIG_IPM_MSG_CH_8_ENABLE 1
    #define CONFIG_IPM_MSG_CH_8_RX 1
    #define CONFIG_NRF_SOC_SECURE_SUPPORTED 1
    #define CONFIG_NRF_APPROTECT_USE_UICR 1
    #define CONFIG_NRF_SECURE_APPROTECT_USE_UICR 1
    #define CONFIG_GPIO_INIT_PRIORITY 40
    #define CONFIG_SOC_LOG_LEVEL_DEFAULT 1
    #define CONFIG_SOC_LOG_LEVEL 3
    #define CONFIG_SOC_COMPATIBLE_NRF 1
    #define CONFIG_SOC_COMPATIBLE_NRF53X 1
    #define CONFIG_SOC_COMPATIBLE_NRF5340_CPUAPP 1
    #define CONFIG_ARCH "arm"
    #define CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT 1
    #define CONFIG_CPU_CORTEX 1
    #define CONFIG_KOBJECT_TEXT_AREA 256
    #define CONFIG_ARM_MPU 1
    #define CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE 32
    #define CONFIG_MPU_ALLOW_FLASH_WRITE 1
    #define CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK 1
    #define CONFIG_ARM_ON_EXIT_CPU_IDLE 1
    #define CONFIG_CPU_CORTEX_M 1
    #define CONFIG_ISA_THUMB2 1
    #define CONFIG_ASSEMBLER_ISA_THUMB2 1
    #define CONFIG_COMPILER_ISA_THUMB2 1
    #define CONFIG_STACK_ALIGN_DOUBLE_WORD 1
    #define CONFIG_FAULT_DUMP 2
    #define CONFIG_BUILTIN_STACK_GUARD 1
    #define CONFIG_ARM_STACK_PROTECTION 1
    #define CONFIG_FP16 1
    #define CONFIG_FP16_IEEE 1
    #define CONFIG_CPU_CORTEX_M33 1
    #define CONFIG_CPU_CORTEX_M_HAS_SYSTICK 1
    #define CONFIG_CPU_CORTEX_M_HAS_DWT 1
    #define CONFIG_CPU_CORTEX_M_HAS_BASEPRI 1
    #define CONFIG_CPU_CORTEX_M_HAS_VTOR 1
    #define CONFIG_CPU_CORTEX_M_HAS_SPLIM 1
    #define CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS 1
    #define CONFIG_CPU_CORTEX_M_HAS_CMSE 1
    #define CONFIG_ARMV7_M_ARMV8_M_MAINLINE 1
    #define CONFIG_ARMV8_M_MAINLINE 1
    #define CONFIG_ARMV8_M_SE 1
    #define CONFIG_ARMV7_M_ARMV8_M_FP 1
    #define CONFIG_ARMV8_M_DSP 1
    #define CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE 1
    #define CONFIG_ARM_TRUSTZONE_M 1
    #define CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE 32
    #define CONFIG_CPU_HAS_NRF_IDAU 1
    #define CONFIG_HAS_SWO 1
    #define CONFIG_ARM 1
    #define CONFIG_ARCH_IS_SET 1
    #define CONFIG_ARCH_LOG_LEVEL_DEFAULT 1
    #define CONFIG_ARCH_LOG_LEVEL 3
    #define CONFIG_LITTLE_ENDIAN 1
    #define CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT 100
    #define CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES 16
    #define CONFIG_GEN_PRIV_STACKS 1
    #define CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED 1
    #define CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS 1
    #define CONFIG_EXCEPTION_DEBUG 1
    #define CONFIG_ARCH_HAS_TIMING_FUNCTIONS 1
    #define CONFIG_ARCH_HAS_TRUSTED_EXECUTION 1
    #define CONFIG_ARCH_HAS_STACK_PROTECTION 1
    #define CONFIG_ARCH_HAS_USERSPACE 1
    #define CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT 1
    #define CONFIG_ARCH_HAS_RAMFUNC_SUPPORT 1
    #define CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION 1
    #define CONFIG_ARCH_SUPPORTS_COREDUMP 1
    #define CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT 1
    #define CONFIG_ARCH_SUPPORTS_ROM_START 1
    #define CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO 1
    #define CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE 1
    #define CONFIG_ARCH_HAS_SUSPEND_TO_RAM 1
    #define CONFIG_ARCH_HAS_THREAD_ABORT 1
    #define CONFIG_ARCH_HAS_CODE_DATA_RELOCATION 1
    #define CONFIG_CPU_HAS_TEE 1
    #define CONFIG_CPU_HAS_FPU 1
    #define CONFIG_CPU_HAS_MPU 1
    #define CONFIG_MPU 1
    #define CONFIG_MPU_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MPU_LOG_LEVEL 3
    #define CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS 1
    #define CONFIG_MPU_GAP_FILLING 1
    #define CONFIG_SRAM_REGION_PERMISSIONS 1
    #define CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS 1
    #define CONFIG_KERNEL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_KERNEL_LOG_LEVEL 3
    #define CONFIG_MULTITHREADING 1
    #define CONFIG_NUM_COOP_PRIORITIES 16
    #define CONFIG_NUM_PREEMPT_PRIORITIES 15
    #define CONFIG_MAIN_THREAD_PRIORITY 0
    #define CONFIG_COOP_ENABLED 1
    #define CONFIG_PREEMPT_ENABLED 1
    #define CONFIG_PRIORITY_CEILING -127
    #define CONFIG_THREAD_STACK_INFO 1
    #define CONFIG_SCHED_DUMB 1
    #define CONFIG_WAITQ_DUMB 1
    #define CONFIG_LIBC_ERRNO 1
    #define CONFIG_ERRNO 1
    #define CONFIG_CURRENT_THREAD_USE_TLS 1
    #define CONFIG_BOOT_DELAY 0
    #define CONFIG_THREAD_MONITOR 1
    #define CONFIG_THREAD_NAME 1
    #define CONFIG_THREAD_MAX_NAME_LEN 32
    #define CONFIG_BARRIER_OPERATIONS_ARCH 1
    #define CONFIG_ATOMIC_OPERATIONS_BUILTIN 1
    #define CONFIG_TIMESLICING 1
    #define CONFIG_TIMESLICE_SIZE 0
    #define CONFIG_TIMESLICE_PRIORITY 0
    #define CONFIG_POLL 1
    #define CONFIG_NUM_MBOX_ASYNC_MSGS 10
    #define CONFIG_KERNEL_MEM_POOL 1
    #define CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN 1
    #define CONFIG_SWAP_NONATOMIC 1
    #define CONFIG_SYS_CLOCK_EXISTS 1
    #define CONFIG_TIMEOUT_64BIT 1
    #define CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS 365
    #define CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS 1
    #define CONFIG_MEM_DOMAIN_ISOLATED_STACKS 1
    #define CONFIG_MP_NUM_CPUS 1
    #define CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE 1
    #define CONFIG_THREAD_LOCAL_STORAGE 1
    #define CONFIG_KERNEL_INIT_PRIORITY_OBJECTS 30
    #define CONFIG_KERNEL_INIT_PRIORITY_DEFAULT 40
    #define CONFIG_KERNEL_INIT_PRIORITY_DEVICE 50
    #define CONFIG_APPLICATION_INIT_PRIORITY 90
    #define CONFIG_BT_HCI_IPC 1
    #define CONFIG_BT_DRV_TX_STACK_SIZE 256
    #define CONFIG_BT_DRV_RX_STACK_SIZE 256
    #define CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_CLOCK_CONTROL_LOG_LEVEL 3
    #define CONFIG_CLOCK_CONTROL_NRF 1
    #define CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL 1
    #define CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM 1
    #define CONFIG_CLOCK_CONTROL_NRF_ACCURACY 50
    #define CONFIG_CONSOLE_INPUT_MAX_LINE_LEN 128
    #define CONFIG_CONSOLE_HAS_DRIVER 1
    #define CONFIG_CONSOLE_INIT_PRIORITY 60
    #define CONFIG_UART_CONSOLE 1
    #define CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_UART_CONSOLE_LOG_LEVEL 3
    #define CONFIG_FLASH_HAS_DRIVER_ENABLED 1
    #define CONFIG_FLASH_HAS_PAGE_LAYOUT 1
    #define CONFIG_FLASH_JESD216 1
    #define CONFIG_FLASH 1
    #define CONFIG_FLASH_LOG_LEVEL_DEFAULT 1
    #define CONFIG_FLASH_LOG_LEVEL 3
    #define CONFIG_FLASH_PAGE_LAYOUT 1
    #define CONFIG_SOC_FLASH_NRF 1
    #define CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE 1
    #define CONFIG_NORDIC_QSPI_NOR_INIT_PRIORITY 41
    #define CONFIG_NORDIC_QSPI_NOR_TIMEOUT_MS 500
    #define CONFIG_GPIO_LOG_LEVEL_DEFAULT 1
    #define CONFIG_GPIO_LOG_LEVEL 3
    #define CONFIG_GPIO_HOGS 1
    #define CONFIG_GPIO_HOGS_INIT_PRIORITY 41
    #define CONFIG_GPIO_NRFX 1
    #define CONFIG_GPIO_NRFX_INTERRUPT 1
    #define CONFIG_HWINFO 1
    #define CONFIG_HWINFO_LOG_LEVEL_DEFAULT 1
    #define CONFIG_HWINFO_LOG_LEVEL 3
    #define CONFIG_HWINFO_NRF 1
    #define CONFIG_INTC_INIT_PRIORITY 40
    #define CONFIG_INTC_LOG_LEVEL_DEFAULT 1
    #define CONFIG_INTC_LOG_LEVEL 3
    #define CONFIG_MBOX_INIT_PRIORITY 40
    #define CONFIG_MBOX_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MBOX_LOG_LEVEL 3
    #define CONFIG_PINCTRL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_PINCTRL_LOG_LEVEL 3
    #define CONFIG_PINCTRL_STORE_REG 1
    #define CONFIG_PINCTRL_NRF 1
    #define CONFIG_PWM 1
    #define CONFIG_PWM_LOG_LEVEL_DEFAULT 1
    #define CONFIG_PWM_LOG_LEVEL 3
    #define CONFIG_PWM_INIT_PRIORITY 50
    #define CONFIG_PWM_NRFX 1
    #define CONFIG_SERIAL_HAS_DRIVER 1
    #define CONFIG_SERIAL_SUPPORT_ASYNC 1
    #define CONFIG_SERIAL_SUPPORT_INTERRUPT 1
    #define CONFIG_UART_LOG_LEVEL_DEFAULT 1
    #define CONFIG_UART_LOG_LEVEL 3
    #define CONFIG_UART_NRFX 1
    #define CONFIG_UART_NRFX_UARTE 1
    #define CONFIG_UART_NRFX_UARTE_LEGACY_SHIM 1
    #define CONFIG_UART_1_INTERRUPT_DRIVEN 1
    #define CONFIG_UART_1_ENHANCED_POLL_OUT 1
    #define CONFIG_UART_1_NRF_TX_BUFFER_SIZE 32
    #define CONFIG_SPI_ASYNC 1
    #define CONFIG_SPI_INIT_PRIORITY 50
    #define CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE 200
    #define CONFIG_SPI_LOG_LEVEL_DEFAULT 1
    #define CONFIG_SPI_LOG_LEVEL 3
    #define CONFIG_SPI_NRFX 1
    #define CONFIG_SPI_NRFX_SPIM 1
    #define CONFIG_SPI_NRFX_RAM_BUFFER_SIZE 8
    #define CONFIG_SPI_NRFX_WAKE_TIMEOUT_US 200
    #define CONFIG_SYSTEM_CLOCK_INIT_PRIORITY 0
    #define CONFIG_TICKLESS_CAPABLE 1
    #define CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT 1
    #define CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY 1
    #define CONFIG_USB_DEVICE_DRIVER 1
    #define CONFIG_USB_DEVICE_REMOTE_WAKEUP 1
    #define CONFIG_USB_NRFX 1
    #define CONFIG_USB_NRFX_EVT_QUEUE_SIZE 32
    #define CONFIG_USB_NRFX_WORK_QUEUE_STACK_SIZE 1024
    #define CONFIG_USB_NRFX_ATTACHED_EVENT_DELAY 0
    #define CONFIG_USB_DRIVER_LOG_LEVEL_DEFAULT 1
    #define CONFIG_USB_DRIVER_LOG_LEVEL 3
    #define CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NRF_USBD_COMMON_LOG_LEVEL 3
    #define CONFIG_NRF_USBD_COMMON 1
    #define CONFIG_NRF_USBD_ISO_IN_ZLP 1
    #define CONFIG_USBC_LOG_LEVEL_DEFAULT 1
    #define CONFIG_USBC_LOG_LEVEL 3
    #define CONFIG_FULL_LIBC_SUPPORTED 1
    #define CONFIG_MINIMAL_LIBC_SUPPORTED 1
    #define CONFIG_NEWLIB_LIBC_SUPPORTED 1
    #define CONFIG_PICOLIBC_SUPPORTED 1
    #define CONFIG_PICOLIBC 1
    #define CONFIG_HAS_NEWLIB_LIBC_NANO 1
    #define CONFIG_COMMON_LIBC_ABORT 1
    #define CONFIG_COMMON_LIBC_MALLOC 1
    #define CONFIG_COMMON_LIBC_CALLOC 1
    #define CONFIG_COMMON_LIBC_REALLOCARRAY 1
    #define CONFIG_PICOLIBC_USE_TOOLCHAIN 1
    #define CONFIG_PICOLIBC_HEAP_SIZE -2
    #define CONFIG_PICOLIBC_IO_LONG_LONG 1
    #define CONFIG_STDOUT_CONSOLE 1
    #define CONFIG_NEED_LIBC_MEM_PARTITION 1
    #define CONFIG_CRC 1
    #define CONFIG_SYS_HEAP_ALLOC_LOOPS 3
    #define CONFIG_SYS_HEAP_AUTO 1
    #define CONFIG_MPSC_PBUF 1
    #define CONFIG_HAS_POWEROFF 1
    #define CONFIG_CBPRINTF_COMPLETE 1
    #define CONFIG_CBPRINTF_FULL_INTEGRAL 1
    #define CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL 3
    #define CONFIG_CBPRINTF_CONVERT_CHECK_PTR 1
    #define CONFIG_POSIX_ENV_LOG_LEVEL_DEFAULT 1
    #define CONFIG_POSIX_ENV_LOG_LEVEL 3
    #define CONFIG_SEM_VALUE_MAX 32767
    #define CONFIG_SEM_NAMELEN_MAX 16
    #define CONFIG_POSIX_RTSIG_MAX 0
    #define CONFIG_POSIX_PAGE_SIZE_BITS 6
    #define CONFIG_LIBGCC_RTLIB 1
    #define CONFIG_RING_BUFFER 1
    #define CONFIG_NOTIFY 1
    #define CONFIG_ONOFF 1
    #define CONFIG_BT 1
    #define CONFIG_BT_HCI 1
    #define CONFIG_BT_CONN_TX 1
    #define CONFIG_BT_LOG 1
    #define CONFIG_BT_LOG_LEVEL_WRN 1
    #define CONFIG_BT_LOG_LEVEL 2
    #define CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_HCI_DRIVER_LOG_LEVEL 2
    #define CONFIG_BT_RPA_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_RPA_LOG_LEVEL 2
    #define CONFIG_BT_AICS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_AICS_LOG_LEVEL 2
    #define CONFIG_BT_AICS_CLIENT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_AICS_CLIENT_LOG_LEVEL 2
    #define CONFIG_BT_BAP_STREAM_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_STREAM_LOG_LEVEL 2
    #define CONFIG_BT_BAP_BASE_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_BASE_LOG_LEVEL 2
    #define CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_AUDIO_CODEC_LOG_LEVEL 2
    #define CONFIG_BT_ASCS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_ASCS_LOG_LEVEL 2
    #define CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL 2
    #define CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL 2
    #define CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL 2
    #define CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL 2
    #define CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL 2
    #define CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL 2
    #define CONFIG_BT_BAP_ISO_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_ISO_LOG_LEVEL 2
    #define CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL 2
    #define CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CAP_INITIATOR_LOG_LEVEL 2
    #define CONFIG_BT_CAP_COMMANDER_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CAP_COMMANDER_LOG_LEVEL 2
    #define CONFIG_BT_CAP_COMMON_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CAP_COMMON_LOG_LEVEL 2
    #define CONFIG_BT_CAP_STREAM_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CAP_STREAM_LOG_LEVEL 2
    #define CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL 2
    #define CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL 2
    #define CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL 2
    #define CONFIG_BT_HAS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_HAS_LOG_LEVEL 2
    #define CONFIG_BT_HAS_CLIENT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_HAS_CLIENT_LOG_LEVEL 2
    #define CONFIG_BT_MCS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MCS_LOG_LEVEL 2
    #define CONFIG_BT_MCC_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MCC_LOG_LEVEL 2
    #define CONFIG_MCTL_LOG_LEVEL_INHERIT 1
    #define CONFIG_MCTL_LOG_LEVEL 2
    #define CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL 2
    #define CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL 2
    #define CONFIG_BT_MPL_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MPL_LOG_LEVEL 2
    #define CONFIG_BT_PACS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_PACS_LOG_LEVEL 2
    #define CONFIG_BT_TBS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_TBS_LOG_LEVEL 2
    #define CONFIG_BT_TBS_CLIENT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_TBS_CLIENT_LOG_LEVEL 2
    #define CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_VCP_VOL_REND_LOG_LEVEL 2
    #define CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL 2
    #define CONFIG_BT_VOCS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_VOCS_LOG_LEVEL 2
    #define CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_VOCS_CLIENT_LOG_LEVEL 2
    #define CONFIG_BT_PBP_LOG_LEVEL_DEFAULT 1
    #define CONFIG_BT_PBP_LOG_LEVEL 3
    #define CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CRYPTO_LOG_LEVEL 2
    #define CONFIG_BT_ATT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_ATT_LOG_LEVEL 2
    #define CONFIG_BT_GATT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_GATT_LOG_LEVEL 2
    #define CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_L2CAP_LOG_LEVEL 2
    #define CONFIG_BT_EAD_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_EAD_LOG_LEVEL 2
    #define CONFIG_BT_DF_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_DF_LOG_LEVEL 2
    #define CONFIG_BT_SETTINGS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_SETTINGS_LOG_LEVEL 2
    #define CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_HCI_CORE_LOG_LEVEL 2
    #define CONFIG_BT_CONN_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CONN_LOG_LEVEL 2
    #define CONFIG_BT_ISO_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_ISO_LOG_LEVEL 2
    #define CONFIG_BT_KEYS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_KEYS_LOG_LEVEL 2
    #define CONFIG_BT_SMP_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_SMP_LOG_LEVEL 2
    #define CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_SERVICE_LOG_LEVEL 2
    #define CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CTLR_ISOAL_LOG_LEVEL 2
    #define CONFIG_BT_RFCOMM_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_RFCOMM_LOG_LEVEL 2
    #define CONFIG_BT_HFP_HF_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_HFP_HF_LOG_LEVEL 2
    #define CONFIG_BT_HFP_AG_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_HFP_AG_LOG_LEVEL 2
    #define CONFIG_BT_AVDTP_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_AVDTP_LOG_LEVEL 2
    #define CONFIG_BT_A2DP_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_A2DP_LOG_LEVEL 2
    #define CONFIG_BT_SDP_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_SDP_LOG_LEVEL 2
    #define CONFIG_BT_MESH_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_LOG_LEVEL 2
    #define CONFIG_BT_MESH_NET_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_NET_LOG_LEVEL 2
    #define CONFIG_BT_MESH_RPL_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_RPL_LOG_LEVEL 2
    #define CONFIG_BT_MESH_TRANS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_TRANS_LOG_LEVEL 2
    #define CONFIG_BT_MESH_BEACON_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_BEACON_LOG_LEVEL 2
    #define CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_CRYPTO_LOG_LEVEL 2
    #define CONFIG_BT_MESH_KEYS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_KEYS_LOG_LEVEL 2
    #define CONFIG_BT_MESH_PROV_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_PROV_LOG_LEVEL 2
    #define CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL 2
    #define CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL 2
    #define CONFIG_BT_MESH_ACCESS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_ACCESS_LOG_LEVEL 2
    #define CONFIG_BT_MESH_MODEL_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_MODEL_LOG_LEVEL 2
    #define CONFIG_BT_MESH_DFU_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_DFU_LOG_LEVEL 2
    #define CONFIG_BT_MESH_ADV_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_ADV_LOG_LEVEL 2
    #define CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL 2
    #define CONFIG_BT_MESH_FRIEND_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_FRIEND_LOG_LEVEL 2
    #define CONFIG_BT_MESH_PROXY_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_PROXY_LOG_LEVEL 2
    #define CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_SETTINGS_LOG_LEVEL 2
    #define CONFIG_BT_MESH_CDB_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_CDB_LOG_LEVEL 2
    #define CONFIG_BT_MESH_CFG_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_CFG_LOG_LEVEL 2
    #define CONFIG_BT_BAS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_BT_BAS_LOG_LEVEL 3
    #define CONFIG_BT_HRS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_BT_HRS_LOG_LEVEL 3
    #define CONFIG_BT_TPS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_BT_TPS_LOG_LEVEL 3
    #define CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_IAS_CLIENT_LOG_LEVEL 2
    #define CONFIG_BT_IAS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_BT_IAS_LOG_LEVEL 3
    #define CONFIG_BT_OTS_CLIENT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_OTS_CLIENT_LOG_LEVEL 2
    #define CONFIG_BT_OTS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_BT_OTS_LOG_LEVEL 3
    #define CONFIG_PRINTK 1
    #define CONFIG_EARLY_CONSOLE 1
    #define CONFIG_ASSERT_VERBOSE 1
    #define CONFIG_DEBUG_THREAD_INFO 1
    #define CONFIG_IMG_MANAGER 1
    #define CONFIG_MCUBOOT_IMG_MANAGER 1
    #define CONFIG_MCUBOOT_TRAILER_SWAP_TYPE 1
    #define CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE 0x0
    #define CONFIG_IMG_BLOCK_BUF_SIZE 512
    #define CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT 1
    #define CONFIG_IMG_MANAGER_LOG_LEVEL 3
    #define CONFIG_NVS 1
    #define CONFIG_NVS_LOG_LEVEL_WRN 1
    #define CONFIG_NVS_LOG_LEVEL 2
    #define CONFIG_IPC_SERVICE 1
    #define CONFIG_IPC_SERVICE_REG_BACKEND_PRIORITY 46
    #define CONFIG_IPC_SERVICE_BACKEND_RPMSG 1
    #define CONFIG_IPC_SERVICE_BACKEND_RPMSG_WQ_STACK_SIZE 1024
    #define CONFIG_IPC_SERVICE_BACKEND_RPMSG_NUM_ENDPOINTS_PER_INSTANCE 2
    #define CONFIG_IPC_SERVICE_RPMSG 1
    #define CONFIG_IPC_SERVICE_STATIC_VRINGS 1
    #define CONFIG_IPC_SERVICE_STATIC_VRINGS_MEM_ALIGNMENT 4
    #define CONFIG_IPC_SERVICE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_IPC_SERVICE_LOG_LEVEL 3
    #define CONFIG_LLEXT_EDK_NAME "llext-edk"
    #define CONFIG_LOG_CORE_INIT_PRIORITY 0
    #define CONFIG_LOG_MODE_DEFERRED 1
    #define CONFIG_LOG_DEFAULT_LEVEL 3
    #define CONFIG_LOG_OVERRIDE_LEVEL 0
    #define CONFIG_LOG_MAX_LEVEL 4
    #define CONFIG_LOG_PRINTK 1
    #define CONFIG_LOG_MODE_OVERFLOW 1
    #define CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD 10
    #define CONFIG_LOG_PROCESS_THREAD 1
    #define CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS 0
    #define CONFIG_LOG_PROCESS_THREAD_SLEEP_MS 1000
    #define CONFIG_LOG_PROCESS_THREAD_STACK_SIZE 768
    #define CONFIG_LOG_TRACE_SHORT_TIMESTAMP 1
    #define CONFIG_LOG_FUNC_NAME_PREFIX_DBG 1
    #define CONFIG_LOG_BACKEND_SHOW_COLOR 1
    #define CONFIG_LOG_TAG_MAX_LEN 0
    #define CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP 1
    #define CONFIG_LOG_BACKEND_UART 1
    #define CONFIG_LOG_BACKEND_UART_BUFFER_SIZE 1
    #define CONFIG_LOG_BACKEND_UART_AUTOSTART 1
    #define CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT 1
    #define CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT 0
    #define CONFIG_LOG_DOMAIN_ID 0
    #define CONFIG_LOG_USE_VLA 1
    #define CONFIG_LOG_SIMPLE_MSG_OPTIMIZE 1
    #define CONFIG_LOG_FAILURE_REPORT_PERIOD 1000
    #define CONFIG_LOG_OUTPUT 1
    #define CONFIG_MEM_ATTR 1
    #define CONFIG_MCUMGR 1
    #define CONFIG_MCUMGR_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MCUMGR_LOG_LEVEL 3
    #define CONFIG_MCUMGR_SMP_CBOR_MAX_MAIN_MAP_ENTRIES 15
    #define CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVELS 2
    #define CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVEL_2 1
    #define CONFIG_MCUMGR_SMP_CBOR_MAX_DECODING_LEVELS 2
    #define CONFIG_MCUMGR_SMP_CBOR_MIN_ENCODING_LEVELS 0
    #define CONFIG_MCUMGR_SMP_CBOR_MAX_ENCODING_LEVELS 0
    #define CONFIG_MCUMGR_SMP_SUPPORT_ORIGINAL_PROTOCOL 1
    #define CONFIG_MCUMGR_GRP_IMG 1
    #define CONFIG_MCUMGR_GRP_IMG_UPDATABLE_IMAGE_NUMBER 2
    #define CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_SECONDARY 1
    #define CONFIG_MCUMGR_GRP_IMG_TOO_LARGE_DISABLED 1
    #define CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL 3
    #define CONFIG_MCUMGR_GRP_OS 1
    #define CONFIG_MCUMGR_GRP_OS_RESET_MS 250
    #define CONFIG_MCUMGR_GRP_OS_ECHO 1
    #define CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO 1
    #define CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MCUMGR_GRP_OS_LOG_LEVEL 3
    #define CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_STACK_SIZE 2048
    #define CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_THREAD_PRIO 3
    #define CONFIG_MCUMGR_TRANSPORT_REASSEMBLY 1
    #define CONFIG_MCUMGR_TRANSPORT_NETBUF_COUNT 4
    #define CONFIG_MCUMGR_TRANSPORT_NETBUF_MIN_USER_DATA_SIZE 8
    #define CONFIG_MCUMGR_TRANSPORT_NETBUF_USER_DATA_SIZE 8
    #define CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL 3
    #define CONFIG_MCUMGR_TRANSPORT_BT 1
    #define CONFIG_MCUMGR_TRANSPORT_BT_REASSEMBLY 1
    #define CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL 1
    #define CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_MIN_INT 6
    #define CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_MAX_INT 9
    #define CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_LATENCY 0
    #define CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_TIMEOUT 42
    #define CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_RESTORE_TIME 5000
    #define CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_RETRY_TIME 1000
    #define CONFIG_MCUMGR_TRANSPORT_BT_DYNAMIC_SVC_REGISTRATION 1
    #define CONFIG_NET_BUF 1
    #define CONFIG_NET_BUF_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_BUF_LOG_LEVEL 3
    #define CONFIG_NET_BUF_ALIGNMENT 0
    #define CONFIG_TIMER_RANDOM_INITIAL_STATE 123456789
    #define CONFIG_SETTINGS 1
    #define CONFIG_SETTINGS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_SETTINGS_LOG_LEVEL 3
    #define CONFIG_SETTINGS_DYNAMIC_HANDLERS 1
    #define CONFIG_SETTINGS_NVS 1
    #define CONFIG_SETTINGS_NVS_SECTOR_SIZE_MULT 1
    #define CONFIG_SETTINGS_NVS_SECTOR_COUNT 8
    #define CONFIG_FLASH_MAP 1
    #define CONFIG_STREAM_FLASH 1
    #define CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT 1
    #define CONFIG_STREAM_FLASH_LOG_LEVEL 3
    #define CONFIG_COVERAGE_GCOV_HEAP_SIZE 16384
    #define CONFIG_USB_DEVICE_STACK 1
    #define CONFIG_USB_DEVICE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_USB_DEVICE_LOG_LEVEL 3
    #define CONFIG_USB_DEVICE_VID 0x2FE3
    #define CONFIG_USB_DEVICE_PID 0x0110
    #define CONFIG_USB_DEVICE_MANUFACTURER "ZEPHYR"
    #define CONFIG_USB_DEVICE_PRODUCT "USB-DEV"
    #define CONFIG_USB_DEVICE_SN "0123456789ABCDEF"
    #define CONFIG_USB_COMPOSITE_DEVICE 1
    #define CONFIG_USB_MAX_NUM_TRANSFERS 4
    #define CONFIG_USB_DEVICE_BLUETOOTH_BIG_BUF 1
    #define CONFIG_USB_REQUEST_BUFFER_SIZE 128
    #define CONFIG_USB_MAX_ALT_SETTING 8
    #define CONFIG_USB_NUMOF_EP_WRITE_RETRIES 3
    #define CONFIG_USB_SELF_POWERED 1
    #define CONFIG_USB_MAX_POWER 50
    #define CONFIG_USB_WORKQUEUE 1
    #define CONFIG_USB_WORKQUEUE_STACK_SIZE 1024
    #define CONFIG_USB_WORKQUEUE_PRIORITY -1
    #define CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT 1
    #define CONFIG_USB_CDC_ACM 1
    #define CONFIG_USB_CDC_ACM_RINGBUF_SIZE 1024
    #define CONFIG_CDC_ACM_INTERRUPT_EP_MPS 16
    #define CONFIG_CDC_ACM_BULK_EP_MPS 64
    #define CONFIG_CDC_ACM_TX_DELAY_MS 100
    #define CONFIG_CDC_ACM_IAD 1
    #define CONFIG_USB_CDC_ACM_LOG_LEVEL_DEFAULT 1
    #define CONFIG_USB_CDC_ACM_LOG_LEVEL 3
    #define CONFIG_TOOLCHAIN_ZEPHYR_0_16 1
    #define CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE 1
    #define CONFIG_LINKER_ORPHAN_SECTION_WARN 1
    #define CONFIG_ROM_END_OFFSET 0x0
    #define CONFIG_LD_LINKER_SCRIPT_SUPPORTED 1
    #define CONFIG_LD_LINKER_TEMPLATE 1
    #define CONFIG_LINKER_SORT_BY_ALIGNMENT 1
    #define CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT 1
    #define CONFIG_LINKER_LAST_SECTION_ID 1
    #define CONFIG_LINKER_LAST_SECTION_ID_PATTERN 0xE015E015
    #define CONFIG_LINKER_USE_RELAX 1
    #define CONFIG_LINKER_ITERABLE_SUBALIGN 4
    #define CONFIG_LINKER_DEVNULL_SUPPORT 1
    #define CONFIG_REQUIRES_STD_C99 1
    #define CONFIG_REQUIRES_STD_C11 1
    #define CONFIG_STD_C11 1
    #define CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS 1
    #define CONFIG_DEBUG_OPTIMIZATIONS 1
    #define CONFIG_COMPILER_TRACK_MACRO_EXPANSION 1
    #define CONFIG_COMPILER_COLOR_DIAGNOSTICS 1
    #define CONFIG_FORTIFY_SOURCE_COMPILE_TIME 1
    #define CONFIG_COMPILER_OPT ""
    #define CONFIG_RUNTIME_ERROR_CHECKS 1
    #define CONFIG_KERNEL_BIN_NAME "zephyr"
    #define CONFIG_OUTPUT_STAT 1
    #define CONFIG_OUTPUT_PRINT_MEMORY_USAGE 1
    #define CONFIG_BUILD_OUTPUT_META 1
    #define CONFIG_BUILD_OUTPUT_STRIP_PATHS 1
    #define CONFIG_CHECK_INIT_PRIORITIES 1
    #define CONFIG_WARN_DEPRECATED 1
    #define CONFIG_ENFORCE_ZEPHYR_STDINT 1
    #define CONFIG_NCS_MCUMGR_BT_OTA_DFU 1
  • Amanda Hsieh said:
    CONFIG_SPM_LOG_LEVEL_DEBUG=y
    Sorry, it's CONFIG_TFM_SPM_LOG_LEVEL_DEBUG=y. Please try again and provide the log.
