No RTT output when enabling mcuboot
I am working on a custom board featuring a nrf9160, when i run the zephyr hello_world application with:
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=4096
CONFIG_LOG_MODE_IMMEDIATE=y
Everything works and i can see the output in JLinkRTTViewer. But when i enable:
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUBOOT_BOOTUTIL_LIB=y
i get no output at all. The application seems to be running since i can see the current consumption changing.
I found this: Cannot see both bootloader and application RTT output #53544 Closed which seems to be an issue with only being able to see either mcuboot logs or applications logs which is not really the case for me. I cant see anything.
But i tried to add the patches suggested by giansta but it still does not work. This is part of what i got from objdump on the .elf file:
objdump -t zephyr.elf | grep RTT
2000c568 l    d  _RTT_SECTION_NAME      00000000 _RTT_SECTION_NAME
00000000 l    df *ABS*  00000000 SEGGER_RTT.c
2000c578 l     O _RTT_SECTION_NAME      00001000 _acUpBuffer
2000c568 l     O _RTT_SECTION_NAME      00000010 _acDownBuffer
2000c568 l       _RTT_SECTION_NAME      00000000 $d
00000000 l    df *ABS*  00000000 SEGGER_RTT_zephyr.c
00000001 g     O *ABS*  00000000 CONFIG_SEGGER_RTT_SECTION_CUSTOM
0002843d g     F text   00000058 SEGGER_RTT_WriteNoLock
000284d9 g     F text   00000030 SEGGER_RTT_Init
00000000 g     O *ABS*  00000000 CONFIG_SEGGER_RTT_MODE
2000c568 g       _RTT_SECTION_NAME      00000000 __rtt_buff_data_start
00000001 g     O *ABS*  00000000 CONFIG_SEGGER_RTT_SECTION_CUSTOM_NAME
2000c580 g       _RTT_SECTION_NAME      00000000 _image_ram_start
2000d578 g     O _RTT_SECTION_NAME      000000a8 _SEGGER_RTT
2000d620 g       _RTT_SECTION_NAME      00000000 __rtt_buff_data_end
I have also tried to disable logs from mcuboot by adding a child_image/mcuboot.conf with:
CONFIG_USE_SEGGER_RTT=n
CONFIG_LOG_BACKEND_RTT=n
CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF=y
CONFIG_LOG=n
but this also did not work.
I am on Ubuntu 22.04.5 LTS
using nrf connect sdk 2.6.1 and J Link V7.94i.
