ERROR CONFIGURE UART IN CUSTOM BOARD NRF54L15
Hi everyone,
I have a problem when I tried to configure UART (baudrate, parity, data_bits, stop_bits, flow_ctrl).
I upload my project:
#include "myuart.h"
/* 1000 msec = 1 sec */
#define SLEEP_TIME_MS      1000
/* Define the size of the receive buffer */
#define DATA_LENGTH 15
#define DATA_COUNT 5
#define TOTAL_BUFFER_SIZE (DATA_LENGTH * DATA_COUNT) // 90 byte (18 x 5)
/* Define the receiving timeout period */
#define RECEIVE_TIMEOUT    100
//configure GPIO UART for NRF54L15
static const struct device *uart0_dev = DEVICE_DT_GET(DT_NODELABEL(uart30));
static const struct device *uart1_dev = DEVICE_DT_GET(DT_NODELABEL(uart20));
/* Cấu hình UART (baudrate, parity, v.v.) */
static struct uart_config uart_cfg = {
    .baudrate = 115200,
    .parity = UART_CFG_PARITY_NONE,
    .data_bits = UART_CFG_DATA_BITS_8,
    .stop_bits = UART_CFG_STOP_BITS_1,
    .flow_ctrl = UART_CFG_FLOW_CTRL_NONE,
void myuart_init(void)
    int ret;
    if (!device_is_ready(uart0_dev)) {
        printk("UART30 device not ready\n");
    if (!device_is_ready(uart1_dev)) {
        printk("UART20 device not ready\n");
    /* Configure UART0, UART1 */
    ret = uart_configure(uart0_dev, &uart_cfg);
    if (ret) {
        printk("Failed to configure UART30, err %d\n", ret);
    ret = uart_configure(uart1_dev, &uart_cfg);
    if (ret) {
        printk("Failed to configure UART20, err %d\n", ret);
    /* Gán callback cho UART0 */
    ret = uart_callback_set(uart0_dev, uart_cb, &uart_data_instance);
    if (ret) {
        printk("Failed to set UART20 callback, err %d\n", ret);
        return;
    ret = uart_rx_enable(uart0_dev, rx_buf, sizeof(rx_buf), RECEIVE_TIMEOUT);
    if (ret) {
        printk("ERROR RX for UART20: %d\n", ret);
        return;
    printk("uart_init Done!\n");
file .dts:
&uart20 {
    status = "okay";
    current-speed = <115200>;
    pinctrl-0 = <&uart20_default>;
    pinctrl-names = "default";
&uart30 {
    status = "okay";
    pinctrl-0 = <&uart30_default>;
file .dtsi:
&pinctrl {
    uart20_default: uart20_default {
        group1 {
            psels = <NRF_PSEL(UART_TX, 1, 4)>;
        group2 {
            psels = <NRF_PSEL(UART_RX, 1, 5)>;
            bias-pull-up;
    uart30_default: uart30_default {
        group1 {
            psels = <NRF_PSEL(UART_TX, 0, 0)>;
        group2 {
            psels = <NRF_PSEL(UART_RX, 0, 1)>;
            bias-pull-up;
but, when I flashed code in board, my error:
Failed to configure UART30, err -134
Failed to configure UART20, err -134
Can you help me for this problems, please?
