SPI for nrf5340dk in ncsv2.8
nrfConnectSDK V2.8
Toolchain
Board: nrf5340dk
Hi, while compiling ncs-spi-master-slave-example , I am getting below errors
In function 'spi_init':
C:/Users/hello/spi/src/main.c:34:8: error: macro "GPIO_DT_SPEC_GET_BY_IDX_OR" requires 4 arguments, but only 3 given
34 | struct gpio_dt_spec spim_cs_gpio = MY_SPI_MASTER_CS_DT_SPEC;
In file included from C:/Users/hello/spi/src/main.c:11:
C:/ncs/v2.8.0/zephyr/include/zephyr/drivers/spi.h:213:9: error: 'GPIO_DT_SPEC_GET_BY_IDX_OR' undeclared (first use in this function)
213 | GPIO_DT_SPEC_GET_BY_IDX_OR(DT_BUS(spi_dev), cs_gpios, \
C:/Users/hello/spi/src/main.c:44:8: error: macro "GPIO_DT_SPEC_GET_BY_IDX_OR" requires 4 arguments, but only 3 given
44 | .cs = {.gpio = MY_SPI_MASTER_CS_DT_SPEC, .delay = 0},
C:/ncs/v2.8.0/zephyr/include/zephyr/drivers/spi.h:213:9: error: 'GPIO_DT_SPEC_GET_BY_IDX_OR' undeclared here (not in a function)
Is it related to sdk version? Can anyone help to resolve ?
  • Hi Andreas,
    1. Tried with a different pc where ncs2.6.1 and toolchain 2.7 were installed, it is building.
    2.Reinstalled ncs  and all tools again.
       ncs 2.9
      tool chain 2.9. Able to build the sample.
    But in both the cases it is giving error related to overlay file
    And also, do we have to add different overlay for application and network core?
    When building the same sample for configuration nrf5340dk/nrf5340/cpunet, it is giving errors
    Thank you
       ncs 2.9
    Great! Glad to hear that
    To be frank, the Problem-tab is quite misleading in some cases and might through warnings and red-underline some issues that is not there at all. But if I would guess if the error is a real one, I would guess that it is because some naming has changed between v2.5.1 (where the sample was built) and v2.6.1. On second thought, it might actually be due to hardware model changes https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/releases_and_maturity/migration/migration_hwmv2.html
    For the 5340 you only need to have a board file for the cpuapp and the non-secure version of cpuapp, i.e cpuapp/ns unless you have custom netcore firmware with custom board changes. As it is by default: The build system will add the companion components it needs to add for the netcore if you add the relevant configurations to prj.conf or sysbuild.conf and sysbuild/<your_companion_image>.conf and .overlay. See https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/lessons/lesson-3-elements-of-an-nrf-connect-sdk-application/ for a great explanation of the components in an NCS application and https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-8-sysbuild/topic/sysbuild-explained/ for the sysbuild expandation
    This is roughly the same errors that you got previously, where the build fault log states that it can't find the items in main.c that is specified in <your_build_target>.overlay, since there are no nrf5340dk/nrf5340/cpunet overlay files that states that the various SPIM/S instances should be on the board.
    Let me know if this answers your questions!
    Andreas
  • Hi, we do have our custom board where we want to read sensor data using spi and send it through bt.
    Able to test bt.
    prj.conf:
    CONFIG_BT=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DEVICE_NAME="nRF5340 DKK BLE"
    CONFIG_BT_GATT_CLIENT=y
    But when integrating bt in the sample where spi is working, it is building for cpuapp but not for cpunet. It is giving errors like i mentioned before.
    1. Can you explain how to get "custom netcore firmware with custom board changes"?
    2. For our requirement do we need to add overlay for cpunet also?
    Thank you
    I can't quite see why this is relevant, since you can always set the SPI up on the appcore (which is recommended) and simply send the data using BLE, for instance NUS over BLE.
    If I  understand you're issue correct, you're now struggling with adding BLE to the SPI applicaiton. In NCS v2.9.0 we're using "sysbuild" and "companion images" instead og child/parent-images which was previously used.
    What you need to do to get BLE is the same as is done in the BLE samples for nrf5340, where you build the hci_ipc companion component for the netcore through sysbuild. https://academy.nordicsemi.com/courses/bluetooth-low-energy-fundamentals/ should explain it, but in case it does not you can see the sysbuild images here:https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/app_dev/config_and_build/sysbuild/sysbuild_images.html
    Enabling SB_CONFIG_NETCORE_HCI_IPC in sysbuild.conf adds the netcore image to the application.
    I strongly recommend you go through https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-8-sysbuild/topic/sysbuild-explained/
    I believe the answer to this is within my answer to 1 as well.
    Apologies for not supplying you with a simple sample, but I would recommend you to go through any BLE sample in the SDK that is built for the nrf5340 and copy the settings and setup to your application.
    This will be a multi-image build, and you don't have to build for the netcore itself. By enabling the correct components (such as SB_CONFIG_NETCORE_HCI_IPC), the build system will drag in the required images to generate the hex that will flash both the appcore and netcore.
    Andreas
  • Hi Andreas,
    Thank you for your guidance in resolving bt issue, flashed hci_ipc sample to network core and our application to application core. Able to transfer data.
    Now we have our custom board where AD5940 is connected to nrf5340 through spi. Not able to read chip id of ad5940. Tried with the example above.
    Taken reference from Exercise 1 – Interfacing with a sensor over SPI and sample from github mentioned in the exercise, spi_example. Modified spi pins in overlay.
    Using ad5940library.
     * Copyright (c) 2024 Nordic Semiconductor ASA
    #include <zephyr/kernel.h>
    /* STEP 1.2 - Include the header files for SPI, GPIO and devicetree */
    #include <zephyr/device.h>
    #include <zephyr/drivers/spi.h>
    #include "ad5940.h"
    LOG_MODULE_REGISTER(Lesson5_Exercise1, LOG_LEVEL_INF);
    #define DELAY_VALUES 1000
    const struct gpio_dt_spec ledspec = GPIO_DT_SPEC_GET(DT_NODELABEL(led0), gpios);
    /* STEP 3 - Retrieve the API-device structure */
    // #define SPIOP	SPI_WORD_SET(8) | SPI_TRANSFER_MSB
    // struct spi_dt_spec spispec = SPI_DT_SPEC_GET(DT_NODELABEL(bme280), SPIOP, 0);
    const struct device *spi_dev;
    const struct device *gpio_dev= DEVICE_DT_GET(DT_NODELABEL(gpio0));
    struct spi_config spi_cfg = {
    	.operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB | SPI_MODE_CPOL | SPI_MODE_CPHA,
    	.frequency = 1000000,
    	.slave = 0,
    	int err;
    	err = gpio_is_ready_dt(&ledspec);
    	if (!err)
    		LOG_ERR("Error: GPIO device is not ready, err: %d", err);
    		return 0;
    	spi_dev = DEVICE_DT_GET(DT_NODELABEL(spi1));
    	/* STEP 10.1 - Check if SPI and GPIO devices are ready */
    	// err = spi_is_ready_dt(&spispec);
    	// err = spi_is_ready(spi_dev);
    	// if (!err) {
    	if (spi_dev == NULL)
    		LOG_ERR("Error: SPI device is not ready, err: %d", err);
    		return 0;
    	// printk("SPI : %s",spispec.bus->name);
    	printk("SPI : %s", spi_dev->name);
    	gpio_pin_configure_dt(&ledspec, GPIO_OUTPUT_ACTIVE);
    	gpio_pin_configure(gpio_dev,11,GPIO_OUTPUT_INACTIVE);
    	// LOG_INF("Continuously read sensor samples, compensate, and display");
    	while (1)
    		/* STEP 10.4 - Continuously read sensor samples and toggle led */
    		AD5940_Initialize();
    		gpio_pin_toggle_dt(&ledspec);
    		k_msleep(DELAY_VALUES);
    	return 0;
    void AD5940_ReadWriteNBytes(unsigned char *pSendBuffer, unsigned char *pRecvBuff, unsigned long length)
    	int err;
    	struct spi_buf tx_spi_buf = {.buf = (void *)&pSendBuffer, .len = length};
    	struct spi_buf_set tx_spi_buf_set = {.buffers = &tx_spi_buf, .count = 1};
    	struct spi_buf rx_spi_bufs = {.buf = pRecvBuff, .len = length};
    	struct spi_buf_set rx_spi_buf_set = {.buffers = &rx_spi_bufs, .count = 1};
    	/* STEP 4.2 - Call the transceive function */
    	// err = spi_transceive_dt(&spispec, &tx_spi_buf_set, &rx_spi_buf_set);
    	err = spi_transceive(spi_dev, &spi_cfg, &tx_spi_buf_set, &rx_spi_buf_set);
    	if (err < 0)
    		LOG_ERR("spi_transceive_dt() failed, err: %d", err);
    void AD5940_CsClr(void)
    	// gpio_pin_set_dt(spispec.config.cs.gpio.pin,1);
    	gpio_pin_set(gpio_dev,11,1);
    void AD5940_CsSet(void)
    	// gpio_pin_set_dt(spispec.config.cs.gpio.pin,0);
    	gpio_pin_set(gpio_dev,11,0);
    void AD5940_RstSet(void)
    void AD5940_RstClr(void)
    void AD5940_Delay10us(uint32_t time)
    	if (time > 0)
    		k_usleep(time * 10); // Delay in microseconds
    When we are tyring to read chipid, getting output as below
    *** Booting nRF Connect SDK v2.9.0-7787b2649840 ***
    *** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
    SPI : spi@9000
    00000000
