Build Fail when trying to modify SLM application sample
I've been trying to modify the v2.4.0 Serial LTE Modem application sample for my nRF-9160 custom board, in order for it to communicate with our external MCU through UART2 at PO.28/29, while outputting modem trace log through another UART at PO.03/PO.04(From the reply of Nordic AI, I assume the default port of outputting LOG was uart1?).
I haven't change any original code files, but I've copied the "nrf9160dk_nrf9160_ns.conf", "nrf9160dk_nrf9160_ns.overlay" to modify, and also create an extra "open_uart_trace.conf" file.
I add these 3 files as extra Kconfig fragments and extra Devicetree overlays.
However when I build it, it would end up error, and from the build log it seems like there's a conflict about interrupt?
I can't figure out what did I need to do to fix the problem, please could someone help, thanks!
Below are the 3 files and the build Log.
custom_9160.conf
# Copyright (c) 2021 Nordic Semiconductor ASA
# Configuration file for nRF9160DK.
# This file is merged with prj.conf in the application folder, and options
# set here will take precedence if they are present in both files.
# Use UART_0 (when working with PC terminal)
# unmask the following config
#CONFIG_UART_0_NRF_HW_ASYNC_TIMER=2
#CONFIG_UART_0_NRF_HW_ASYNC=y
#CONFIG_SLM_WAKEUP_PIN=6
#CONFIG_SLM_INDICATE_PIN=2
# Use UART_2 (when working with external MCU)
CONFIG_UART_2_NRF_HW_ASYNC_TIMER=2
CONFIG_UART_2_NRF_HW_ASYNC=y
CONFIG_SLM_WAKEUP_PIN=31
custom_9160.overlay
 * Copyright (c) 2021 Nordic Semiconductor ASA
    chosen {
        ncs,slm-uart = &uart2;
&uart0 {
    status = "disabled";
&uart1 {
    current-speed = <230400>;
    status = "okay";
    pinctrl-0 = <&uart1_default_alt>;
    pinctrl-1 = <&uart1_sleep_alt>;
&uart2 {
    current-speed = <115200>;
    status = "okay";
    hw-flow-control;
    pinctrl-0 = <&uart2_default_alt>;
    pinctrl-1 = <&uart2_sleep_alt>;
&i2c2 {
&pinctrl {
    uart1_default_alt: uart1_default_alt {
        group1 {
            psels = <NRF_PSEL(UART_RX, 0, 3)>;
            bias-pull-up;
        group2 {
            psels = <NRF_PSEL(UART_TX, 0, 4)>;
    uart1_sleep_alt: uart1_sleep_alt {
        group1 {
            psels = <NRF_PSEL(UART_TX, 0, 4)>,
            low-power-enable;
    uart2_default_alt: uart2_default_alt {
        group1 {
            psels = <NRF_PSEL(UART_RX, 0, 28)>;
            bias-pull-up;
        group2 {
            psels = <NRF_PSEL(UART_TX, 0, 29)>,
                <NRF_PSEL(UART_RTS, 0, 12)>,
                <NRF_PSEL(UART_CTS, 0, 13)>;
    uart2_sleep_alt: uart2_sleep_alt {
        group1 {
                <NRF_PSEL(UART_RX, 0, 28)>,
            low-power-enable;
# Segger RTT
CONFIG_LOG_BACKEND_RTT=n
CONFIG_LOG_BACKEND_UART=y
# Enable below for modem trace
CONFIG_NRF_MODEM_LIB_TRACE=y
====Build Log====
* Executing task: nRF Connect: Generate config nrf9160dk_nrf9160_ns for d:\Nordic\Projects\SLM_v2.4.0
Building SLM_v2.4.0
C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir d:/Nordic/Projects/SLM_v2.4.0/uart_trace d:/Nordic/Projects/SLM_v2.4.0 --pristine --board nrf9160dk_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION=NONE -DEXTRA_CONF_FILE=Extra_configs/uart_trace.conf;boards/custom_9160_A1_1.conf -DEXTRA_DTC_OVERLAY_FILE=boards/custom_9160_A1_1.overlay -DBOARD_ROOT=d:/nordic/projects/slm_v2.4.0"
-- Application: D:/Nordic/Projects/SLM_v2.4.0
-- CMake version: 3.20.5
-- Found Python3: C:/ncs/toolchains/31f4403e35/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.4.0/zephyr/.cache
-- Zephyr version: 3.3.99 (C:/ncs/v2.4.0/zephyr)
-- Found west (found suitable version "1.0.0", minimum required is "0.7.1")
-- Board: nrf9160dk_nrf9160_ns, Revision: 0.7.0
-- Found host-tools: zephyr 0.16.0 (C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.0 (C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/31f4403e35/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.4.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
-- Found devicetree overlay: D:/Nordic/Projects/SLM_v2.4.0/boards/nrf9160dk_nrf9160_ns.overlay
-- Found devicetree overlay: boards/custom_9160_A1_1.overlay
-- Generated zephyr.dts: D:/Nordic/Projects/SLM_v2.4.0/uart_trace/zephyr/zephyr.dts
-- Generated devicetree_generated.h: D:/Nordic/Projects/SLM_v2.4.0/uart_trace/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: D:/Nordic/Projects/SLM_v2.4.0/uart_trace/zephyr/dts.cmake
Parsing D:/Nordic/Projects/SLM_v2.4.0/Kconfig
Loaded configuration 'C:/ncs/v2.4.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns_defconfig'
Merged configuration 'D:/Nordic/Projects/SLM_v2.4.0/prj.conf'
Merged configuration 'D:/Nordic/Projects/SLM_v2.4.0/boards/nrf9160dk_nrf9160_ns.conf'
Merged configuration 'D:/Nordic/Projects/SLM_v2.4.0/Extra_configs/uart_trace.conf'
Merged configuration 'D:/Nordic/Projects/SLM_v2.4.0/boards/custom_9160_A1_1.conf'
Configuration saved to 'D:/Nordic/Projects/SLM_v2.4.0/uart_trace/zephyr/.config'
Kconfig header saved to 'D:/Nordic/Projects/SLM_v2.4.0/uart_trace/zephyr/include/generated/autoconf.h'
warning: UART_0_NRF_HW_ASYNC (defined at drivers/serial/Kconfig.nrfx:84) was assigned the value 'y'
but got the value 'n'. Check these unsatisfied dependencies: UART_0_NRF_UARTE (=n), (UART_0_NRF_UART
|| UART_0_NRF_UARTE) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UART_0_NRF_HW_ASYNC and/or look up
UART_0_NRF_HW_ASYNC in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: UART_0_NRF_HW_ASYNC_TIMER (defined at drivers/serial/Kconfig.nrfx:103) was assigned the
value '2' but got the value ''. Check these unsatisfied dependencies: UART_0_NRF_HW_ASYNC (=n),
(UART_0_NRF_UART || UART_0_NRF_UARTE) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UART_0_NRF_HW_ASYNC_TIMER and/or look up
UART_0_NRF_HW_ASYNC_TIMER in the menuconfig/guiconfig interface. The Application Development Primer,
helpful too.
warning: LOG_BACKEND_UART (defined at subsys/logging\backends\Kconfig.uart:4) was assigned the value
'y' but got the value 'n'. Check these unsatisfied dependencies: UART_CONSOLE (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_BACKEND_UART and/or look up
LOG_BACKEND_UART in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: Experimental symbol TFTP_LIB is enabled.
warning: Experimental symbol HTTP_CLIENT is enabled.
-- Found GnuLd: c:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Found Python3: C:/ncs/toolchains/31f4403e35/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
Changed board to secure nrf9160dk_nrf9160 (NOT NS)
=== child image mcuboot - begin ===
loading initial cache file D:/Nordic/Projects/SLM_v2.4.0/uart_trace/mcuboot/child_image_preload.cmake
CMake Warning (dev) at D:/Nordic/Projects/SLM_v2.4.0/uart_trace/mcuboot/child_image_preload.cmake:8 (set):
Syntax error in cmake code at
when parsing string
C:\ncs\toolchains\31f4403e35\opt\bin\python.exe
Invalid escape sequence \3
Policy CMP0010 is not set: Bad variable reference syntax is an error. Run
"cmake --help-policy CMP0010" for policy details. Use the cmake_policy
command to set the policy and suppress this warning.
This warning is for project developers. Use -Wno-dev to suppress it.
-- Application: C:/ncs/v2.4.0/bootloader/mcuboot/boot/zephyr
-- Board: nrf9160dk_nrf9160, Revision: 0.7.0
-- Found BOARD.dts: C:/ncs/v2.4.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
-- Found devicetree overlay: C:/ncs/v2.4.0/bootloader/mcuboot/boot/zephyr/app.overlay
-- Generated zephyr.dts: D:/Nordic/Projects/SLM_v2.4.0/uart_trace/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: D:/Nordic/Projects/SLM_v2.4.0/uart_trace/mcuboot/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: D:/Nordic/Projects/SLM_v2.4.0/uart_trace/mcuboot/zephyr/dts.cmake
Parsing C:/ncs/v2.4.0/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration 'C:/ncs/v2.4.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
Merged configuration 'C:/ncs/v2.4.0/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/ncs/v2.4.0/nrf/modules/mcuboot/tfm.conf'
Merged configuration 'C:/ncs/v2.4.0/nrf/modules/mcuboot/fih_low_enable.conf'
Merged configuration 'C:/ncs/v2.4.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'D:/Nordic/Projects/SLM_v2.4.0/child_image/mcuboot.conf'
Merged configuration 'D:/Nordic/Projects/SLM_v2.4.0/uart_trace/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'D:/Nordic/Projects/SLM_v2.4.0/uart_trace/mcuboot/zephyr/.config'
Kconfig header saved to 'D:/Nordic/Projects/SLM_v2.4.0/uart_trace/mcuboot/zephyr/include/generated/autoconf.h'
CMake Warning at C:/ncs/v2.4.0/zephyr/CMakeLists.txt:838 (message):
No SOURCES given to Zephyr library: lib__libc__common
Excluding target from build.
No SOURCES given to Zephyr library: drivers__console
MCUBoot bootloader key file: C:/ncs/v2.4.0/bootloader/mcuboot/root-ec-p256.pem
-- Configuring done
-- Generating done
-- Build files have been written to: D:/Nordic/Projects/SLM_v2.4.0/uart_trace/mcuboot
=== child image mcuboot - end ===
CMake Warning at C:/ncs/v2.4.0/nrf/modules/mcuboot/CMakeLists.txt:310 (message):
--- WARNING: Using default MCUBoot key, it should not ---
--- be used for production. ---
-- Configuring done
-- Generating done
[1/396] Generating include/generated/version.h
-- Zephyr version: 3.3.99 (C:/ncs/v2.4.0/zephyr), build: v3.3.99-ncs1
[1/182] Generating include/generated/version.h
[172/182] Linking C executable zephyr\zephyr_pre0.elf
[176/182] Linking C executable zephyr\zephyr_pre1.elf
[182/182] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 28546 B 48 KB 58.08%
RAM: 16360 B 32 KB 49.93%
IDT_LIST: 0 GB 2 KB 0.00%
[11/396] Generating ../../tfm/CMakeCache.txt
-- Found Git: C:/ncs/toolchains/31f4403e35/mingw64/bin/git.exe (found version "2.37.3.windows.1")
-- Configuring done
-- Generating done
-- Build files have been written to: D:/Nordic/Projects/SLM_v2.4.0/uart_trace/tfm
[22/396] Performing install step for 'tfm'
-- Install configuration: "MinSizeRel"
[377/396] Linking C executable zephyr\zephyr_pre0.elf
[381/396] Linking C executable zephyr\zephyr_pre1.elf
[383/396] Generating isr_tables.c, isrList.bin
FAILED: zephyr/isr_tables.c zephyr/isrList.bin
cmd.exe /C "cd /D D:\Nordic\Projects\SLM_v2.4.0\uart_trace\zephyr && C:\ncs\toolchains\31f4403e35\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-objcopy.exe --input-target=elf32-littlearm --output-target=binary --only-section=.intList D:/Nordic/Projects/SLM_v2.4.0/uart_trace/zephyr/zephyr_pre1.elf isrList.bin && C:\ncs\toolchains\31f4403e35\opt\bin\python.exe C:/ncs/v2.4.0/zephyr/scripts/build/gen_isr_tables.py --output-source isr_tables.c --kernel D:/Nordic/Projects/SLM_v2.4.0/uart_trace/zephyr/zephyr_pre1.elf --intlist isrList.bin --sw-isr-table --vector-table"
gen_isr_tables.py: error: multiple registrations at table_index 9 for irq 9 (0x9)
Existing handler 0x2c7f1, new handler 0x463b3
Has IRQ_CONNECT or IRQ_DIRECT_CONNECT accidentally been invoked on the same irq multiple times?
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\31f4403e35\opt\bin\cmake.EXE' --build 'd:\Nordic\Projects\SLM_v2.4.0\uart_trace'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
