After upgrading mcuboot, the device crashes upon power-up
hi,
  After upgrading mcuboot from NCS 2.6.1 to NCS 2.9.0, the upgrade file is downloaded, and the device restarts and runs normally. The mcuboot version number and active slot are updated as expected. However, when the device is powered off and then powered on again, it fails to work properly, almost as if it has crashed. What could be the cause of this issue?
In NCS 2.6.1, the default value of CONFIG_PM_PARTITION_SIZE_MCUBOOT is 0xc000, while in NCS 2.9.0, the default value is 0xbe00. A bug related to the MCUboot partition size was fixed on October 24, 2024. Could this bug have affected the upgrade failure?
Link:Fix MCUboot partition sizes
    I took over the problem and trying to fix him. I've reorganized the problem points.
    Problem Description
    Our application uses MCUBoot as an upgradeable bootloader in the order NSIB(B0) -> MCUBoot -> Application, now we adapted NCS2.9.0 and tried to upgrade MCUBoot from NCS2.6.1 to NCS2.9.0, after the device receives the upgrade package, confirms it and reset, the log shows that MCUBoot has carried the new upgrade package to the S1 partition, and the S1 partition version read on the application is 2. However, when I reset the device again, the program fails to run to the application, and it seems that the problem has already occurred at B0 or MCUBoot.
    Examples
    I wrote two examples using NCS2.6.1 and NCS2.9.0 and reproduced it on the nRF9160DK.
    Differences between the two test examples:
    - NCS2.6.1 examples : Sysbuild is not used.
    - NCS2.9.0 examples : Sysbuild is used.
    Differences between NCS2.6.1 examples and my application:
    - NCS2.6.1 Sample: B0 and MCUBoot configurations are basically the same as my application, the first difference is that the MCUBoot partition size is 0xBE00 to be consistent with NCS2.9.0 example(so far testing has shown that MCUBoot sizes of either 0xBE00 or 0xC000 both cause the above problems); The second difference is that the upgrade package is transmitted using the MCUMGR UART.
    Recurrence process and log
    1. Compile NCS2.6.1 examples with NCS2.6.1 SDK, program into nRF9160DK.
    2. Compile NCS2.9.0 examples with NCS2.9.0 SDK.
    3. The uart1 port is used by MCUMGR, running a command line in the NCS2.9.0 example directory to transfer the S1 upgrade package to the nRF9160DK
    mcumgr -t 60 --conntype serial --connstring=COM48 image upload .\build\signed_by_mcuboot_and_b0_s1_image.bin
    4. Get firmware information
    mcumgr -t 60 --conntype serial --connstring=COM48 image list
    5. Confirm the firmware
    mcumgr -t 60 --conntype serial --connstring=COM48 image confirm <hash> true
    6. Press the reset button to reset the DK, after booting you can see that the S1 version has been updated to 2.
    7. Press the reset button again, the device does not run to the application, and the logs show that it no longer logs after B0 is ready to jump to the S1 partition (the new MCUBoot firmware for S1 already has log printing enabled).
    The two attachments are examples of my tests:
    ncs2.6.1.zip
    ncs2.9.0.zip
  • Hi ,
    Is there any progress on this issue so far and what further information is needed from my side?
    Thanks
  • Looking at the examples you sent, pm_static.yml is mostly commented out.
    A pm_static.yml that defined all DFU partitions is required. Try to use the same pm_static.yml for both projects. Does DFU work then?
