Hi, I'm having problems with migrating my project to SDK v2.9.0. I'm using mcuboot and I want to use b0n on the net core and update support for the net core application via mcuboot (running on the application core). Everything was running fine on the SDK v2.5.3 with multi-image build, and I managed to port the project to sysbuild on SDK v2.9.0 with mcuboot, but when I try to enable the net core update, the build process fails.
I tried to re-create the configuration with the peripheral_lbs sample (SDK v2.9.0). After checking out the sample project, I added sysbuild.conf to the project folder:
#SB_CONFIG_NETCORE_APP_UPDATE=y #SB_CONFIG_SECURE_BOOT_NETCORE=y #SB_CONFIG_SECURE_BOOT_SIGNING_KEY_FILE="C:/<mypath>/mykey.pem" SB_CONFIG_BOOTLOADER_MCUBOOT=y SB_CONFIG_MCUBOOT_MODE_SINGLE_APP=n SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="C:/<mypath>/mykey.pem" SB_CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y SB_CONFIG_NETCORE_HCI_IPC=y
So far, everything compiled without any problem. But when I try to enable the upper three lines (for b0n and net core update support, the build process fails: I receive the following error message seven times before the build process is aborted:
In file included from C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/include/sysflash/sysflash.h:12,
from C:/ncs/v2.9.0/bootloader/mcuboot/boot/bootutil/src/bootutil_priv.h:33,
from C:/ncs/v2.9.0/bootloader/mcuboot/boot/bootutil/src/tlv.c:24:
C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h: In function '__flash_area_ids_for_slot':
C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:20:37: error: 'PM_MCUBOOT_PRIMARY_1_ID' undeclared (first use in this function); did you mean 'PM_MCUBOOT_PRIMARY_ID'?
20 | #define FLASH_AREA_IMAGE_1_SLOTS PM_MCUBOOT_PRIMARY_1_ID, PM_MCUBOOT_SECONDARY_1_ID,
C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:38:29: note: in expansion of macro 'FLASH_AREA_IMAGE_1_SLOTS'
38 | FLASH_AREA_IMAGE_1_SLOTS
C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:55:9: note: in expansion of macro 'ALL_AVAILABLE_SLOTS'
55 | ALL_AVAILABLE_SLOTS
C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:20:37: note: each undeclared identifier is reported only once for each function it appears in
C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:20:62: error: 'PM_MCUBOOT_SECONDARY_1_ID' undeclared (first use in this function); did you mean 'PM_MCUBOOT_SECONDARY_ID'?
It appears like the build system suddenly is using different partition names when I enable b0n?
Under SDK v2.5.3, the app core partitions were just named mcuboot_primary (mcuboot_primary_app) and mcuboot_secondary. Both net core update and app core update were loaded in mcuboot_secondary for flashing. Now, under SDK v2.9.0 and sysbuild, there seems to be a different naming convention (see PM_MCUBOOT_PRIMARY_1_ID error messages).
Some feedback would be appreciated. Is this a bug in the build/configuration system? Or is there a new convention for partition naming that changes when b0n is enabled?
Michael
PS: Update: I tried disabling SB_CONFIG_NETCORE_APP_UPDATE, but leave secure boot for the net core active. In this case, I get the following error messages:
In file included from C:/ncs/v2.9.0/nrf/include/dfu/pcd.h:28,
from C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/main.c:95:
C:/ncs/v2.9.0/nrf/include/dfu/pcd_common.h: In function 'pcd_write_cmd_lock_debug':
C:/ncs/v2.9.0/nrf/include/dfu/pcd_common.h:39:25: error: 'PM__PCD_SRAM_ADDRESS' undeclared (first use in this function); did you mean 'PM_SRAM_ADDRESS'?
39 | #define PCD_CMD_ADDRESS PM__PCD_SRAM_ADDRESS
Beside 'pcd_write_cmd_lock_debug', the same error occurs for functions 'pcd_read_cmd_done' and 'pcd_read_cmd_lock_debug'.
