How program serialnumber on nRF54L15 in factory setup
Hi Nordic support
We have ealier used your legasy SDK16.0 on nRF52840 where we where programming our device serial number in the UIRC area.
NRF_UICR->CUSTOMER[0-4] where NRF_UIRC is at adress    0x10001000UL
It was done by generating a small hex file that contains the UIRC data and then flashed with NRJPROG
I can see that the new way on NRF Connect SDK 2.9.0 and nRF54L15 the UIRC register is not present and it is advised to use the  NVC
Im expect I should use the zephyr settings API to get the production parameters like serialnumber manufactor model etc.
I have added below in my prj.conf, to support settings api
# Below is setup to let DIS information be read from settings
CONFIG_BT_SETTINGS=y
CONFIG_SETTINGS_RUNTIME=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_NONE=y
CONFIG_BT_DIS_SETTINGS=y
CONFIG_BT_DIS_STR_MAX=21
Is there a tool to set the serialnumber, hw_rev, model_number in flash, so it can be done in production ?
Can i use nrfjprog with a specific address ?
Do you have an example on how this can be done ?
Best Regards
Tommy F Kristensen
PS. I have hardcoded it in the prj.conf as below, to do testing, but need to be able to generate the serial dynamically
# Bluetooth Device Settings config
CONFIG_BT_DIS=y
CONFIG_BT_DIS_PNP=n
CONFIG_BT_DIS_MODEL="0007-00-000-001"
CONFIG_BT_DIS_MANUF="MyFirm"
CONFIG_BT_DIS_SERIAL_NUMBER=y
CONFIG_BT_DIS_FW_REV=y
CONFIG_BT_DIS_HW_REV=n
CONFIG_BT_DIS_SW_REV=y
CONFIG_BT_DIS_SERIAL_NUMBER_STR="65533-255-311540"
CONFIG_BT_DIS_FW_REV_STR="0.0.0"
#CONFIG_BT_DIS_HW_REV_STR="Zephyr Hardware"
CONFIG_BT_DIS_SW_REV_STR="0.0.0"
