Uploading Environmental Data to nRF Cloud
I am trying to upload data from two sensors, the BME280 and APDS9960, to the nRF Cloud. I have been able to extract data from the sensors with I2C, but it seems I am getting an error when trying to connect to the nRF Cloud. It is regarding the funcion `lte_lc_init_and_connect'.
I am coding on VSCode with the latest extension, v2.9.0 on Windows 10. I am still a novice with this, so any help would be appreciated.
I am attaching photos of my code and errors.
  • Hi Ryan,
    dejans said:
    Do you get the same error when you use separately unmodified nrf_cloud_rest_device_message and nrf_cloud_multi_service samples?
    How did you provision (and onboard) your device?
    Can you provide answers to these questions?
    RyanSG said:
    I have resolved the previous issue.
    Can you provide some details about this?
    Can you please provide details about the application that you used when you got the log you shared? Have you tried to use unmodified nrfcloud_multi_service sample?
    Dejan
  • No I did not receive the same error from the example codes. I am not sure as to what exactly I changed to make it work, I do believe it was now a CONFIG issue as now the code does work without fail each time.
    I have a follow up issue. The code I have does upload, but it doesn't upload the numerical value but prints *float* instead of a number.
    I'm not sure as to what the issue is as I've tried replacing the value and remains the same. The function, sensor_value_to_double or any double value returns the *float* text.
    static int send_data_to_cloud(struct sensor_value *temp, struct sensor_value *hum, struct sensor_value *light)
        int ret;
        cJSON *root;
        char *json_str;
        // Temperature
        root = cJSON_CreateObject();
        if (!root) {
            LOG_ERR("Failed to create JSON object");
            return -ENOMEM;
        cJSON_AddStringToObject(root, "appId", "TEMP");
        cJSON_AddNumberToObject(root, "data", sensor_value_to_double(temp));  // Must be a number
        cJSON_AddStringToObject(root, "messageType", "DATA");
        json_str = cJSON_PrintUnformatted(root);
        if (!json_str) {
            LOG_ERR("Failed to create JSON string");
            cJSON_Delete(root);
            return -ENOMEM;
        struct nrf_cloud_tx_data temp_msg = {
            .data.ptr = json_str, .data.len = strlen(json_str),
            .qos = MQTT_QOS_1_AT_LEAST_ONCE, .topic_type = NRF_CLOUD_TOPIC_MESSAGE
        LOG_INF("Sending temp: %s (value: %f)", json_str, sensor_value_to_double(temp));
        ret = nrf_cloud_send(&temp_msg);
        cJSON_free(json_str);
        cJSON_Delete(root);
        if (ret) return ret;
    (for example, it outputs)
    [00:48:44.018,432] <inf> main: Temp: 18.460000°C, Humidity: 41.272460%, Light: 155.000000 lux [00:48:44.018,798] <inf> main: Sending temp: {"appId":"TEMP","data":float,"messageType":"DATA"} (value: *float*) [00:48:44.029,113] <inf> main: Sending humid: {"appId":"HUMID","data":*float*,"messageType":"DATA"} [00:48:44.030,151] <inf> main: Sending light: {"appId":"LIGHT","data":*float*,"messageType":"DATA"} [00:48:44.781,890] <inf> main: Unhandled LTE event: 3
    I provided the main.c file and the prj,conf file.
    #include <zephyr/kernel.h>
    #include <zephyr/device.h>
    #include <zephyr/drivers/sensor.h>
    #include <modem/lte_lc.h>
    #include <zephyr/net/socket.h>
    #include <net/nrf_cloud.h>
    #include <modem/nrf_modem_lib.h>
    #include <modem/modem_info.h>
    #include <cJSON.h>
    static char device_id[NRF_CLOUD_CLIENT_ID_MAX_LEN + 1];
    LOG_MODULE_REGISTER(main, LOG_LEVEL_INF);
    K_SEM_DEFINE(lte_connected, 0, 1);
    /* Sensor devices */
    const struct device *bme280 = DEVICE_DT_GET_ANY(bosch_bme280);
    const struct device *apds = DEVICE_DT_GET_ANY(avago_apds9960);
    static void lte_handler(const struct lte_lc_evt *const evt)
        switch (evt->type) {
            case LTE_LC_EVT_NW_REG_STATUS:
                LOG_INF("Network registration status: %d", evt->nw_reg_status);
                if (evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_HOME ||
                    evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_ROAMING) {
                    LOG_INF("Connected to %s network",
                            evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_HOME ? "home" : "roaming");
                    k_sem_give(&lte_connected);
                } else if (evt->nw_reg_status == LTE_LC_NW_REG_NOT_REGISTERED ||
                           evt->nw_reg_status == LTE_LC_NW_REG_SEARCHING) {
                    LOG_INF("Network not registered or searching...");
                } else {
                    LOG_ERR("Unexpected registration status: %d", evt->nw_reg_status);
            case LTE_LC_EVT_CELL_UPDATE:
                LOG_INF("Cell update: Cell ID %d", evt->cell.id);
            case LTE_LC_EVT_LTE_MODE_UPDATE:
                LOG_INF("LTE mode update: %d", evt->lte_mode);
            case LTE_LC_EVT_MODEM_EVENT:
                LOG_INF("Modem event: %d", evt->modem_evt);
                LOG_INF("Unhandled LTE event: %d", evt->type);
    static int connect_to_lte(void)
        int err;
        LOG_INF("Waiting for network...");
        k_sem_reset(&lte_connected);
        err = lte_lc_connect_async(lte_handler);
        if (err) {
            LOG_ERR("Failed to init modem, error: %d", err);
            return err;
        k_sem_take(&lte_connected, K_FOREVER);
        LOG_INF("Connected to LTE");
        return 0;
    static int init(void)
        int err;
        err = nrf_modem_lib_init();
        if (err) {
            LOG_ERR("Failed to initialize modem library: 0x%X", err);
            return -EFAULT;
        err = modem_info_init();
        if (err) {
            LOG_ERR("Modem info initialization failed: %d", err);
            return err;
        LOG_INF("Modem library initialized");
        return 0;
    void cloud_event_handler(const struct nrf_cloud_evt *evt)
        if (evt == NULL) {
            LOG_ERR("Received NULL event");
            return;
            case NRF_CLOUD_EVT_TRANSPORT_CONNECTED:
                LOG_INF("Transport connected");
            case NRF_CLOUD_EVT_TRANSPORT_DISCONNECTED:
                LOG_INF("Transport disconnected");
            case NRF_CLOUD_EVT_READY:
                LOG_INF("Cloud connection ready");
            case NRF_CLOUD_EVT_ERROR:
                LOG_ERR("Cloud error occurred (type: %d)", evt->type);
            case NRF_CLOUD_EVT_RX_DATA_SHADOW:
                LOG_INF("Received shadow data");
                if (evt->data.ptr && evt->data.len > 0) {
                    LOG_INF("Shadow content: %s", (const char *)evt->data.ptr);
                } else {
                    LOG_INF("Shadow content: <empty>");
                LOG_INF("Unhandled cloud event: %d", evt->type);
    static int setup_connection(void)
        int err;
        err = connect_to_lte();
        if (err) {
            LOG_ERR("Failed to connect to cellular network: %d", err);
            return err;
        memset(device_id, 0, sizeof(device_id));
        err = nrf_cloud_client_id_get(device_id, sizeof(device_id));
        if (err) {
            LOG_ERR("Failed to get device ID, error: %d", err);
            return err;
        LOG_INF("Device ID: %s (length: %d)", device_id, strlen(device_id));
        LOG_INF("Attempting initial nRF Cloud connection...");
        struct nrf_cloud_init_param params = {
            .client_id = device_id,
            .event_handler = cloud_event_handler,
        err = nrf_cloud_init(&params);  // Fixed typo here
        if (err) {
            LOG_ERR("Failed to initialize nRF Cloud library: %d", err);
            return err;
        err = nrf_cloud_connect();
        if (err) {
            LOG_ERR("Initial nRF Cloud connection failed: %d", err);
            return err;
        LOG_INF("Connected to nRF Cloud");
        return 0;
    static int setup(void)
        int err;
        err = init();
        if (err) {
            LOG_ERR("Initialization failed.");
            return err;
        err = setup_connection();
        if (err) {
            LOG_ERR("Connection set-up failed.");
            return err;
        if (!device_is_ready(bme280)) {
            LOG_ERR("BME280 device is not ready");
            return -ENODEV;
        if (!device_is_ready(apds)) {
            LOG_ERR("APDS9960 device is not ready");
            return -ENODEV;
        return 0;
    static int read_sensors(struct sensor_value *temp, struct sensor_value *hum, struct sensor_value *light)
        int err, retries = 3;
        while (retries--) {
            err = sensor_sample_fetch(bme280);
            if (!err) break;
            LOG_ERR("BME280 fetch failed: %d, retries left: %d", err, retries);
            k_sleep(K_MSEC(100));
        if (err) return err;
        err = sensor_channel_get(bme280, SENSOR_CHAN_AMBIENT_TEMP, temp);
        if (err) {
            LOG_ERR("BME280 temp get failed: %d", err);
            return err;
        err = sensor_channel_get(bme280, SENSOR_CHAN_HUMIDITY, hum);
        if (err) {
            LOG_ERR("BME280 humidity get failed: %d", err);
            return err;
        err = sensor_sample_fetch(apds);
        if (err) {
            LOG_ERR("APDS9960 fetch failed: %d", err);
            return err;
        err = sensor_channel_get(apds, SENSOR_CHAN_LIGHT, light);
        if (err) {
            LOG_ERR("APDS9960 light get failed: %d", err);
            return err;
        return 0;
        int ret;
        cJSON *root;
        char *json_str;
        // Temperature
        if (!root) {
            return -ENOMEM;
        if (!json_str) {
            cJSON_Delete(root);
            return -ENOMEM;
        cJSON_Delete(root);
        // Humidity
        if (!root) {
            return -ENOMEM;
        cJSON_AddStringToObject(root, "appId", "HUMID");
        cJSON_AddNumberToObject(root, "data", sensor_value_to_double(hum));  // Must be a number
        if (!json_str) {
            cJSON_Delete(root);
            return -ENOMEM;
        struct nrf_cloud_tx_data hum_msg = {
        LOG_INF("Sending humid: %s", json_str);  // Log directly
        ret = nrf_cloud_send(&hum_msg);
        cJSON_Delete(root);
        // Light
        if (!root) {
            return -ENOMEM;
        cJSON_AddStringToObject(root, "appId", "LIGHT");
        cJSON_AddNumberToObject(root, "data", sensor_value_to_double(light));  // Must be a number
        if (!json_str) {
            cJSON_Delete(root);
            return -ENOMEM;
        struct nrf_cloud_tx_data light_msg = {
        LOG_INF("Sending light: %s", json_str);  // Log directly
        ret = nrf_cloud_send(&light_msg);
        cJSON_Delete(root);
        return ret;
    static bool cred_check(struct nrf_cloud_credentials_status *const cs)
            int ret;
            ret = nrf_cloud_credentials_check(cs);
    if (ret) {
            LOG_ERR("nRF Cloud credentials check failed, error: %d", ret);
            return false;
    /* Since this is a REST sample, we only need two credentials:
    	 *  - a CA for the TLS connections
    	 *  - a private key to sign the JWT
             LOG_INF("Checking credentials in sec tag %u", cs->sec_tag);
             if (!cs->ca) {
                 LOG_WRN("CA certificate missing");
             if (!cs->ca_aws) {
                 LOG_WRN("AWS CA certificate missing");
             if (!cs->prv_key) {
                 LOG_WRN("Private key missing");
             // For MQTT, you typically need CA and private key at minimum
             return (cs->ca && cs->prv_key);
        int err;
        struct nrf_cloud_credentials_status cs = {0};
        struct sensor_value temp, hum, light;
        struct modem_param_info modem_info;
        LOG_INF("Starting nRF9161 Sensor Cloud Application");
        err = setup();
        if (err) {
            LOG_ERR("Setup failed, stopping.");
            return err;
        if (!cred_check(&cs)) {
            LOG_ERR("Credentials check failed, stopping.");
            return -EACCES;
        while (1) {
            err = modem_info_params_get(&modem_info);
            if (!err) {
                LOG_INF("Signal strength: %d dBm", modem_info.network.rsrp.value);
            } else {
                LOG_WRN("Failed to get modem info: %d (continuing)", err);
            if (read_sensors(&temp, &hum, &light) == 0) {
                LOG_INF("Temp: %d.%06d°C, Humidity: %d.%06d%%, Light: %d.%06d lux",
                        temp.val1, temp.val2, hum.val1, hum.val2, light.val1, light.val2);
                err = send_data_to_cloud(&temp, &hum, &light);
                if (err) {
                    LOG_ERR("Data send failed, will retry");
            } else {
                LOG_ERR("Sensor read failed");
            k_sleep(K_SECONDS(10));
        return 0;
    # Enable logging for debugging
    CONFIG_LOG=y
    CONFIG_LOG_DEFAULT_LEVEL=3
    # Enable I2C for sensor communication
    CONFIG_I2C=y
    # Enable sensor support
    CONFIG_SENSOR=y
    CONFIG_BME280=y
    CONFIG_APDS9960=y
    CONFIG_MAIN_STACK_SIZE=4096
    # Enable LTE connection and networking
    CONFIG_MODEM=y
    CONFIG_MODEM_INFO=y
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_NETWORKING=y
    CONFIG_NET_IPV4=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_OFFLOAD=y
    CONFIG_NRF_MODEM_LIB=y
    # Enable MQTT support
    CONFIG_MQTT_LIB=y
    CONFIG_MQTT_HELPER=y
    CONFIG_MQTT_KEEPALIVE=60
    # Enable nRF Cloud MQTT support
    CONFIG_NRF_CLOUD=y
    CONFIG_NRF_CLOUD_MQTT=y
    CONFIG_NRF_CLOUD_CHECK_CREDENTIALS=y
    CONFIG_JSON_LIBRARY=y
    # Define security tag for TLS authentication
    CONFIG_MQTT_HELPER_SEC_TAG=16842753
    # Power Management Settings
    CONFIG_PM=y
    CONFIG_PM_DEVICE=y
    CONFIG_PM_DEVICE_RUNTIME=y
    CONFIG_HEAP_MEM_POOL_SIZE=16384
    CONFIG_LOG_BUFFER_SIZE=512
    This issue might be related to float logging. You can look at this discussion (adding CONFIG_CBPRINTF_FP_SUPPORT=y) and this issue.
    Dejan
    I do not believe this is the case, as the cloud also sees the same message. Could something else be the cause? Thanks, Ryan
  • This was the issue nevermind. I appreciate the help!
