Hey,
I encountered a problem with the thread viewer, where the corresponding window is empty when I'm in a debug session. Inside the build configuration I used "Optimize for debugging (-Og)"
I tested this in the "threads" example. I used the nrf connect SDK v 2.9.0 and Toolchain v2.9.0 with an actinius icarus (nrf 9160) board and VS Code V 1.97.2 on windows 10.
// IMPORTANT: The following data can contain sensitive or confidential information about your environment.
// If you do not want others to see this information, make sure to remove it before sharing the data.
// For help and support, visit Nordic Semiconductor's DevZone at https://devzone.nordicsemi.com/.
"platform": {
"os": "win32",
"osVersion": "Windows 10 Pro",
"osKernel": "10.0.19045",
"vscode": "1.97.2",
"electron": "32.2.7",
"node": "v20.18.1"
"system": {
"date": "2025-03-06T11:46:29.610Z",
"vscodeRoot": "c:\\Program Files\\Microsoft VS Code\\resources\\app",
"vscodeUptime": "00:11:42",
"osUptime": "01:49:24",
"cpu": "Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz"
"workspace": {
"name": "threads",
"workspaceFile": null,
"folders": [
"c:\\Max\\threads"
"sdks": [
"version": "v2.9.0",
"path": "c:\\ncs\\v2.9.0"
"version": "v2.4.3",
"path": "c:\\ncs\\v2.4.3"
"version": "v2.2.0",
"path": "c:\\ncs\\v2.2.0"
"activeBuild": "c:\\Max\\threads\\build",
"apps": [
"workspace": "c:\\Max\\threads",
"uri": "c:\\Max\\threads",
"buildConfigurations": [
"id": "c:\\Max\\threads\\build",
"name": "build",
"boardId": "[email protected]/nrf9160/ns",
"type": "Sysbuild",
"isChild": false,
"isStale": false,
"taskBindings": {
"build": [],
"pristineBuild": [],
"flash": [],
"eraseAndFlash": []
"sdk": "c:\\ncs\\v2.9.0",
"toolchain": "nRF Connect SDK Toolchain v2.9.0"
"toolchains": [
"version": "2.9.0",
"path": "c:\\ncs\\toolchains\\b620d30767"
"version": "2.0.0",
"path": "c:\\ncs\\toolchains\\v2.0.0"
"connectedDevices": [
"serialNumber": "000261003821",
"boardVersion": null,
"deviceFamily": "NRF91_FAMILY",
"deviceVersion": "NRF9160_xxAA_REV2",
"jlinkObFirmwareVersion": "J-Link V11 compiled Dec 4 2023 10:22:45",
"protectionStatus": "NRFDL_PROTECTION_STATUS_NONE"
"tools": {
"C:\\ncs\\toolchains\\b620d30767\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.17.0",
"C:\\Program Files\\SEGGER\\JLink_V794i\\JLink.exe": "7.94i",
"C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.24.2",
"C:\\ncs\\toolchains\\b620d30767\\cmake": "3.21.0",
"C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\Scripts\\west.exe": "1.2.0",
"C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\python.exe": "3.12.4",
"C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\ninja.exe": "1.10.2",
"C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\gperf.exe": "3.1",
"C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\dtc.exe": "1.4.7",
"C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\gn.exe": "2202",
"C:\\ncs\\toolchains\\b620d30767\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
"arm-gdbPath": "c:\\ncs\\toolchains\\b620d30767\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe",
"riscv-gdbPath": "C:\\ncs\\toolchains\\b620d30767\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin\\riscv64-zephyr-elf-gdb.exe"
"nrfutil": {
"nrfutil-device": {
"version": "2.7.9",
"binPath": "c:\\Users\\FutureLab Admin\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.1.127-win32-x64\\platform\\nrfutil\\bin\\nrfutil-device",
"jlinkInfo": {
"name": "JlinkARM",
"version": "JLink_V7.94i",
"versionFormat": "string"
"nrfutil-toolchain-manager": {
"version": "0.14.4",
"binPath": "c:\\Users\\FutureLab Admin\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.1.127-win32-x64\\platform\\nrfutil\\bin\\nrfutil-toolchain-manager"
"environment": {
"westEnv": {
"HOME": "C:\\Users\\FutureLab Admin",
"HOMEDRIVE": "C:",
"HOMEPATH": "\\Users\\FutureLab Admin",
"PATH": "C:\\ncs\\toolchains\\b620d30767;C:\\ncs\\toolchains\\b620d30767\\mingw64\\bin;C:\\ncs\\toolchains\\b620d30767\\bin;C:\\ncs\\toolchains\\b620d30767\\opt\\bin;C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\Scripts;C:\\ncs\\toolchains\\b620d30767\\opt\\nanopb\\generator-bin;C:\\ncs\\toolchains\\b620d30767\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;C:\\ncs\\toolchains\\b620d30767\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin;c:\\Users\\FutureLab Admin\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.1.127-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\java8path;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Common Files\\Intel\\Shared Libraries\\redist\\intel64\\compiler;C:\\Users\\InnoGarage\\AppData\\Local\\Programs\\Python\\Python311\\Scripts;C:\\Users\\InnoGarage\\AppData\\Local\\Programs\\Python\\Python311;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;c:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\DAL;c:\\Program Files\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files\\Microsoft VS Code\\bin;C:\\Users\\Ulises\\AppData\\Roaming\\nvm;C:\\Program Files\\nodejsv18;C:\\Program Files\\nodejsv18\\;C:\\Program Files\\Autodesk\\webdeploy\\production\\6a0c9611291d45bb9226980209917c3d;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\CMake\\bin;C:\\ffmpeg\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\nodejs\\;C:\\Users\\FutureLab Admin\\AppData\\Local\\fnm_multishells\\8556_1736846109537;C:\\Users\\FutureLab Admin\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\FutureLab Admin\\AppData\\Local\\Microsoft\\WinGet\\Links;C:\\Users\\FutureLab Admin\\AppData\\Roaming\\npm;C:\\Program Files (x86)\\GnuWin32\\bin;",
"ZEPHYR_BASE": "c:\\ncs\\v2.9.0\\zephyr",
"ZEPHYR_SDK_INSTALL_DIR": "C:\\ncs\\toolchains\\b620d30767\\opt\\zephyr-sdk",
"PYTHONPATH": "C:\\ncs\\toolchains\\b620d30767\\opt\\bin;C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\Lib;C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\Lib\\site-packages"
"inherited": {
"HOMEDRIVE": "C:",
"Path": "C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\java8path;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Common Files\\Intel\\Shared Libraries\\redist\\intel64\\compiler;C:\\Users\\InnoGarage\\AppData\\Local\\Programs\\Python\\Python311\\Scripts;C:\\Users\\InnoGarage\\AppData\\Local\\Programs\\Python\\Python311;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;c:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\DAL;c:\\Program Files\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files\\Microsoft VS Code\\bin;C:\\Users\\Ulises\\AppData\\Roaming\\nvm;C:\\Program Files\\nodejsv18;C:\\Program Files\\nodejsv18\\;C:\\Program Files\\Autodesk\\webdeploy\\production\\6a0c9611291d45bb9226980209917c3d;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\CMake\\bin;C:\\ffmpeg\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\nodejs\\;C:\\Users\\FutureLab Admin\\AppData\\Local\\fnm_multishells\\8556_1736846109537;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\java8path;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Common Files\\Intel\\Shared Libraries\\redist\\intel64\\compiler;C:\\Users\\InnoGarage\\AppData\\Local\\Programs\\Python\\Python311\\Scripts;C:\\Users\\InnoGarage\\AppData\\Local\\Programs\\Python\\Python311;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\nodejsv18\\;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;c:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\DAL;c:\\Program Files\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files\\Microsoft VS Code\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\Ulises\\AppData\\Roaming\\nvm;C:\\Program Files\\PuTTY\\;C:\\Program Files\\CMake\\bin;C:\\Users\\FutureLab Admin\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\Ulises\\AppData\\Roaming\\nvm;C:\\Users\\FutureLab Admin\\AppData\\Local\\Microsoft\\WinGet\\Links;C:\\Program Files\\Autodesk\\webdeploy\\production\\6a0c9611291d45bb9226980209917c3d;C:\\Users\\FutureLab Admin\\AppData\\Roaming\\npm;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\ffmpeg\\bin;",
"PATH": "C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\java8path;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Common Files\\Intel\\Shared Libraries\\redist\\intel64\\compiler;C:\\Users\\InnoGarage\\AppData\\Local\\Programs\\Python\\Python311\\Scripts;C:\\Users\\InnoGarage\\AppData\\Local\\Programs\\Python\\Python311;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;c:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\DAL;c:\\Program Files\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files\\Microsoft VS Code\\bin;C:\\Users\\Ulises\\AppData\\Roaming\\nvm;C:\\Program Files\\nodejsv18;C:\\Program Files\\nodejsv18\\;C:\\Program Files\\Autodesk\\webdeploy\\production\\6a0c9611291d45bb9226980209917c3d;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\CMake\\bin;C:\\ffmpeg\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\nodejs\\;C:\\Users\\FutureLab Admin\\AppData\\Local\\fnm_multishells\\8556_1736846109537;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\java8path;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Common Files\\Intel\\Shared Libraries\\redist\\intel64\\compiler;C:\\Users\\InnoGarage\\AppData\\Local\\Programs\\Python\\Python311\\Scripts;C:\\Users\\InnoGarage\\AppData\\Local\\Programs\\Python\\Python311;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\nodejsv18\\;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;c:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\DAL;c:\\Program Files\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files\\Microsoft VS Code\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\Ulises\\AppData\\Roaming\\nvm;C:\\Program Files\\PuTTY\\;C:\\Program Files\\CMake\\bin;C:\\Users\\FutureLab Admin\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\Ulises\\AppData\\Roaming\\nvm;C:\\Users\\FutureLab Admin\\AppData\\Local\\Microsoft\\WinGet\\Links;C:\\Program Files\\Autodesk\\webdeploy\\production\\6a0c9611291d45bb9226980209917c3d;C:\\Users\\FutureLab Admin\\AppData\\Roaming\\npm;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\ffmpeg\\bin;"
"terminal": {
"defaultProfile": null
"config": {
"topdir": "",
"toolchain": {
"path": ""
"ozonePath": "",
"applications": [],
"applicationOptions": {},
"kconfig": {
"interface": "kconfig"
"west": {
"env": {
"$base": "terminal"
"boardRoots": [],
"taskBindings": {},
"buildTerminal": {
"condensedProgress": true
"debugging": {
"flash": true,
"bindings": {},
"justMyCode": false
"flash": {
"softreset": false,
"erase": false,
"recover": false
"enableTelemetry": true,
"thirdpartyIntegration": {},
"toolchainManager": {
"indexURL": null,
"installDirectory": null
"nrfutil": {
"home": null
"defaultOpenAction": "ask",
"terminalProfile": {
"shell": null
"terminalMode": "character"
"extensions": {
"internal": {
"version": "2025.1.127",
"path": "c:\\Users\\FutureLab Admin\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.1.127-win32-x64",
"isActive": true
"version": "2024.9.14",
"path": "c:\\Users\\FutureLab Admin\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2024.9.14",
"isActive": true
"version": "2024.12.15",
"path": "c:\\Users\\FutureLab Admin\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2024.12.15",
"isActive": true
"version": "2024.12.13",
"path": "c:\\Users\\FutureLab Admin\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2024.12.13",
"isActive": true
"external": {
"marus25.cortex-debug": null,
"ms-vscode.cpptools": "1.23.6",
"ms-vscode.js-debug": "1.97.1",
"josetr.cmake-language-support-vscode": "0.0.9",
"ms-dotnettools.vscode-dotnet-runtime": "2.2.8",
"ms-python.debugpy": "2025.4.0",
"ms-python.python": "2025.2.0",
"ms-python.vscode-pylance": "2025.3.1",
"ms-vscode-remote.remote-wsl": "0.88.5",
"ms-vscode.cpptools-extension-pack": "1.3.1",
"trond-snekvik.gnu-mapfiles": "1.1.0"
