CONFIG_NET_L2_OPENTHREAD=y leads to failure in gpio pins.
I noticed an issue with CONFIG_NET_L2_OPENTHREAD=y in my project, and I prepared a newer, simpler project to investigate in the issue.
The new program simply sets pins to high and low. After flashing it onto an external module and plugging the external module onto a baseboard, all of the LEDs on the base board should be flashing one by one in a cycle..
As I slowly add more configurations to prj.conf, I realize that adding CONFIG_NET_L2_OPENTHREAD=y when CONFIG_NETWORKING=y will lead to all the external module pins behaving unexpectedly. None of the LEDs on the base board will turn on. What does CONFIG_NET_L2_OPENTHREAD do exactly? How does it interfere with the gpio pins?
  • Allan-led said:
    err = mpsl_init(&clock_cfg, CONFIG_MPSL_LOW_PRIO_IRQN, m_assert_handler);
    Are you able to see what the return value from mpsl_init is? Is it an error (-NRF_EPERM or -NRF_EINVAL) or a success code?
    Allan-led said:
    Are you able to tell anything from this? Please update me on it if you have time to take a look at this, thanks!
    Other than finding out the return code I can't tell much from this no.
    I'll be able to get some debugging tips early next week!
    Allan-led said:
    Could there be an issue with how the hardware of my external module was designed?
    Maybe. Is your module a commercially available one or is it custom to you and not yet on the market?
    If it is custom -- and you haven't done the following before -- we offer hardware reviews here on DevZone. Just post your schematics/layout files in a new private ticket and then one of our hardware engineers can review them.
    Maria
  • Hi Maria,
    The value of the err variable is 0, as shown in the picture below. However, I don't think this is the expected retval, as it should be able to at least execute or evaluate the next line (396), but no matter how I work with the debugger, it will not jump further. From my experience I feel like it is likely that the mpsl_init function never returned, thus the err value stayed as 0. This also matches the behaviour of the debugger, as when I press continue or step over, it just gets stuck in a stale state and does not show the next breakpoint or the line being executed. Only when I press pause, does it highlight the line as shown below.
    I'm wondering if it is possible to get blocked or stuck in an infinite while loop in mpsl_init?
    The module that I'm working with is a custom one, and it isn't commercially available.
    I look forward to your reply.
    Allan Wang
  • Hey Allan,
    This note indicates that it is possible to cause a deadlock, but it seems unlikely that this is happening. If CONFIG_SYSTEM_CLOCK_NO_WAIT is non-zero, the note is not relevant at all.
    Errata 39 could potentially be a cause for the behaviour, and a workaround was introduced in nRF Connect SDK v2.9.1. Please to a trial with v2.9.1 and let me know if you see any difference.
    Alright. Do you know if Nordic has performed a hardware review of that module?
    Maria
  • Hi Maria,
    Thanks for your insights. I just completed a trial with v2.9.1. However, I don't think there are any differences, I'm still getting stuck at the same place in the program.
    I don't think Nordic has performed hardware review. I will contact the hardware engineer about this. Thank you.
    Allan Wang
  • Hey Allan,
    Thank you for testing with v2.9.1.
    I'll post an internal ticket to try to get some more insights into what the source issue could be.
    I look forward to your update on this.
    Maria
