SLM XFOTA always fails
we are trying to perform FOTA updates with default SLM application based on SDK 2.9.0,
but the application always aborts unsuccessfully.
Via AT interface the application responds:
    XFOTA.fota_stage= 0 -> Init
    XFOTA.fota_status= 1 -> Error
    XFOTA.fota_info= 2 -> Update image rejected
Via RTT-Logging there is an error "DNS lookup failed"
I have made some small overlays only to get the correct UART pins, but havent changed the application besides that.
For another nRF9160 application (not based on SLM / XFOTA commands) the FOTA update with this server is working fine.
I made a modem trace of one XFOTA attempt:
trace-2025-03-08T16-56-02.721Z.mtrace
Would appreciate any hint to get it running.
Thank you and best regards,
Bernhard
  • Hello Sigurd,
    yes, with CONFIG_SLM_PPP=n it is working perfectly fine
    00> *** Booting nRF Connect SDK v2.9.0-7787b2649840 ***
    00> *** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
    00> [00:00:00.255,584] <inf> at_cmd_custom: Custom AT commands enabled with 38 entries.
    00> [00:00:00.261,566] <inf> fs_nvs: 2 Sectors of 4096 bytes
    00> [00:00:00.261,566] <inf> fs_nvs: alloc wra: 0, fe8
    00> [00:00:00.261,596] <inf> fs_nvs: data wra: 0, 0
    00> [00:00:00.498,992] <inf> slm: lib_modem init: 0
    00> [00:00:00.499,511] <inf> mcuboot_util: Image index: 0, Swap type: none
    00> [00:00:00.499,511] <inf> slm: Serial LTE Modem
    00> [00:00:00.592,895] <inf> nrf_cloud_info: Device ID: 504b5839-3736-4e69-8022-202375aab4b4
    00> [00:00:00.598,144] <inf> nrf_cloud_info: IMEI:      350457794629749
    00> [00:00:00.690,399] <inf> nrf_cloud_info: UUID:      504b5839-3736-4e69-8022-202375aab4b4
    00> [00:00:00.696,136] <inf> nrf_cloud_info: Modem FW:  mfw_nrf9160_1.3.7
    00> [00:00:00.696,166] <inf> nrf_cloud_info: Protocol:          MQTT
    00> [00:00:00.696,19HTTPS
    00>
    00> [00:01:07.955,505] <inf> download_client: Downloading: terminal-modem/delta_1.3.7_to_1.3.7-FOTA-TEST/modem.bin [0]
    00> [00:01:08.443,908] <inf> download_client: Connecting to 35.173.69.207
    00> [00:01:09.249,908] <inf> download_client: Downloaded 2048/14248 bytes (14%)
    00> [00:01:09.250,274] <inf> dfu_target_modem_delta: Modem firmware version: e7a1c54a-b07c-4512-9c3e-8ecbbfe2641d
    00> [00:01:10.047,790] <inf> download_client: Downloaded 4096/14248 bytes (28%)
    00> [00:01:10.821,014] <inf> download_client: Downloaded 6144/14248 bytes (43%)
    00> [00:01:11.179,962] <inf> download_client: Downloaded 8192/14248 bytes (57%)
    00> [00:01:11.749,023] <inf> download_client: Downloaded 10240/14248 bytes (71%)
    00> [00:01:12.076,934] <inf> download_client: Downloaded 12288/14248 bytes (86%)
    00> [00:01:12.797,973] <inf> download_client: Downloaded 14248/14248 bytes (100%)
    00> [00:01:12.956,970] <inf> download_client: Download complete
    00> [00:01:13.082,550] <inf> dfu_target_modem_delta: Scheduling modem firmware upgrade at next boot
    Not sure what to do with this information, PPP is the only reason for this whole application so I am not able to deactivate it. Does it give any further hint on how to fix it?
    Thank you.
  • Hi!
    PPP + other socket operations at the same time will not work. See https://docs.nordicsemi.com/bundle/ncs-latest/page/nrfxlib/nrf_modem/doc/sockets/raw_sockets.html
    As a workaround, could you try temporarily disable PPP with AT#XPPP=0, then do XFOTA, and then enable PPP again with AT#XPPP=1
  • Hello Sigurt,
    thank you a lot, that did the trick!
    Would be nice to also add a hint on this page:
    https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/applications/serial_lte_modem/doc/FOTA_AT_commands.html
    Bernhard
