When enabling RTT the program runs until the first NRF_LOG_PROCESS() Verification and then directly in the HardFault-Handler
our project which started 7 years ago with SDK13.0 has been migrated some time ago to SDK 15.3 and now to SDK17.1. At the beginning we were quite happy with the RTT functions, but since a certain time (maybe beginning with SDK15.3) we can not use it any more because the firmware runs directly to the HardFault handler.
We have verified and updated our code already using some tickets from this forum like
  • Case ID: 123565: RTT & RTT disable sdk 12/13 nRF52832/nRF52840
    or
  • Case ID: 213834: RTT Logging not working when building with ARM GCC
    or
  • Case ID: 128187: RTT logs broken in SDK14.2 with GCC
but still RTT does not work.
In sdk_config.h we have defined
NRF_LOG_ENABLED = 1
NRF_LOG_BACKEND_RTT_ENABLED = 1
NRF_LOG_BACKEND_SERIAL_USES_RTT = 1
NRF_LOG_BACKEND_SERIAL_USES_UART = 0
I have joined a screenshot from the debugging phase where the first NRF_LOG_PROCESS() check is done, at the left side of the screenshot
you can see how the µC runs to the HardFault Handler.
We use the nRF52840 and gcc GNU_ARM/9 2020-q2-update.
What can we do to make RTT run?
BR, matthK
  • Hi Sigurd,
    I have the following data:
    SEGGER J-Link GDB Server V8.18 Command Line Version
    JLinkARM.dll V8.18 (DLL compiled Mar 5 2025 14:42:43)
    Command line: -if swd -device nRF52840_xxAA -endian little -speed 2000 -port 2331 -swoport 2332 -telnetport 2333 -vd -ir -localhostonly 1 -singlerun -strict -timeout 0 -nogui
    -----GDB Server start settings-----
    GDBInit file: none
    GDB Server Listening port: 2331
    SWO raw output listening port: 2332
    Terminal I/O port: 2333
    Accept remote connection: localhost only
    Generate logfile: off
    Verify download: on
    Init regs on start: on
    Silent mode: off
    Single run mode: on
    Target connection timeout: 0 ms
    ------J-Link related settings------
    J-Link Host interface: USB
    J-Link script: none
    J-Link settings file: none
    ------Target related settings------
    Target device: nRF52840_xxAA
    Target device parameters: none
    Target interface: SWD
    Target interface speed: 2000kHz
    Target endian: little
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link OB-nRF5340-NordicSemi compiled Feb 11 2025 17:15:35
    Hardware: V1.00
    S/N: 1050281280
    Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    Checking target voltage...
    Target voltage: 3.30 V
    Listening on TCP/IP port 2331
    Connecting to target...
    ERROR: Could not connect to target.
    Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
    Shutting down...
    Shall I try to modify the settings to have them identical to yours?
    BR, matthK
  • I have just modified the non-equal parameters, but still the same result:
    Command line: -if swd -device nRF52840_xxAA -endian little -speed 1000 -port 2331 -swoport 2332 -telnetport 2333 -noir -localhostonly 1 -strict -timeout 5000 -nogui
    GDBInit file: none
    Verify download: off
    Init regs on start: off
    Silent mode: off
    Single run mode: off
    Target connection timeout: 5000 ms
    J-Link script: none
    Target interface speed: 1000kHz
    Hardware: V1.00
    S/N: 1050281280
    Shutting down...
    I have the impression, that the communication between PC and the debug (Segger) chip works, but the communication at the PCA10056 between the Segger chip and the nRF52840 might be problematic. What do you think?
    BBR matthK
  • Hi Sigurd,
    I have just looked for another PCA10056, and with this and your settings finally this works. I can compile, download and run the application - thanks for your support!
    The only thing which doesn't work correctly is when setting a breakpoint in a line and let run then the stop is not in the selected line but 4 or 5 lines later - do you have any idea how to solve that?
    Now I will continue migrating my firmware application from our target electronics to the PCA10056; finally what we want is to be able to search a special bug with trace functionality...
    For this I will keep SDK15.3 to create a minimum of new bugs while migration to PCA10056.
    If you have any special recommendations please feel free to send them to me.
    BR, matthK
  • I have just looked for another PCA10056, and with this and your settings finally this works. I can compile, download and run the application - thanks for your support!
    Great!
    Could be because of optimization level for the build, see this post:  nrf52810 Eclipse Debug Problems
  • Yes, the modification of the optimization from 3 to 0 brought the expected behavior -thanks a lot!
    Now I can continue with the migration of our firmware to PCA10056...
    Have a nice week-end!
    BR, matthK
