NRC 2.9.1 or 2.9.0 Cannot run wifi scan example using SPI
I have a custom PCB that has been working fine in terms of the Wi-Fi on 2.6.2 but I needed to Port that to 2.9.x
I'm using sysbuild in the 2.9 projects but not in the 2.6.2 project.
I've tried making this work on my products project, the STA example, and the scan example and I feel like the scan examples probably the most straight forward for debugging the problem.  But all of them fail per the below.  I have tried manually removing the qspi nodes in the sdk .dts files, but that leads to other issues.  Error is in the build below.
Full log attached but note the errors in the log starting at line 73... QSPI is still referenced and it does not seem to be picking up some of the SPI stuff, but not sure.
Any help greatly appreciated.
3007.prj.conf        5164.nrf7002dk_nrf5340_cpuapp.overlay   2402.sysbuild.conf
ding scan
C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir c:/dev/scan/build c:/dev/scan --pristine --board nrf7002dk/nrf5340/cpuapp -- -DNCS_TOOLCHAIN_VERSION=NONE -DDTC_OVERLAY_FILE=boards/nrf7002dk_nrf5340_cpuapp.overlay -DBOARD_ROOT=c:/dev/scan"
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: C:/dev/NRF/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/dev/NRF/v2.9.1/zephyr/.cache
-- Board: nrf7002dk, qualifiers: nrf5340/cpuapp
Parsing C:/dev/NRF/v2.9.1/zephyr/share/sysbuild/Kconfig
Loaded configuration 'C:/dev/scan/build/_sysbuild/empty.conf'
Merged configuration 'c:/dev/scan/sysbuild.conf'
Configuration saved to 'C:/dev/scan/build/zephyr/.config'
Kconfig header saved to 'C:/dev/scan/build/_sysbuild/autoconf.h'
   * Running CMake for scan *
-- Application: C:/dev/scan
-- CMake version: 3.21.0
-- Zephyr version: 3.7.99 (C:/dev/NRF/v2.9.1/zephyr)
-- Found host-tools: zephyr 0.17.0 (C:/dev/NRF/toolchains/b620d30767/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (C:/dev/NRF/toolchains/b620d30767/opt/zephyr-sdk)
-- Found Dtc: C:/dev/NRF/toolchains/b620d30767/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/dev/NRF/v2.9.1/zephyr/boards/nordic/nrf7002dk/nrf7002dk_nrf5340_cpuapp.dts
-- Found devicetree overlay: boards/nrf7002dk_nrf5340_cpuapp.overlay
'label' is marked as deprecated in 'properties:' in C:/dev/NRF/v2.9.1/zephyr/dts/bindings\spi\nordic,nrf-spim.yaml for node /soc/peripheral@50000000/spi@9000.
'label' is marked as deprecated in 'properties:' in C:/dev/NRF/v2.9.1/zephyr/dts/bindings\mtd\jedec,spi-nor.yaml for node /soc/peripheral@50000000/spi@9000/spi-mx25r32@3.
'label' is marked as deprecated in 'properties:' in C:/dev/NRF/v2.9.1/zephyr/dts/bindings\spi\nordic,nrf-spim.yaml for node /soc/peripheral@50000000/spi@c000.
-- Generated zephyr.dts: C:/dev/scan/build/scan/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/dev/scan/build/scan/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: C:/dev/scan/build/scan/zephyr/dts.cmake
warning: Experimental symbol NRF_WIFI_RPU_RECOVERY is enabled.
warning: Experimental symbol NET_BUF_VARIABLE_DATA_SIZE is enabled.
Parsing C:/dev/scan/Kconfig
Loaded configuration 'C:/dev/NRF/v2.9.1/zephyr/boards/nordic/nrf7002dk/nrf7002dk_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/dev/scan/prj.conf'
Merged configuration 'C:/dev/scan/build/scan/zephyr/.config.sysbuild'
Configuration saved to 'C:/dev/scan/build/scan/zephyr/.config'
Kconfig header saved to 'C:/dev/scan/build/scan/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: c:/dev/nrf/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/dev/NRF/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Setting build type to 'MinSizeRel' as none was specified.
CMake Warning at C:/dev/NRF/v2.9.1/zephyr/CMakeLists.txt:2133 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: C:/dev/scan/build/scan
-- Configuring done
-- Generating done
[5/224] Generating include/generated/zephyr/version.h
-- Zephyr version: 3.7.99 (C:/dev/NRF/v2.9.1/zephyr), build: v3.7.99-ncs2-1
[90/224] Building C object modules/nrf_wifi/bus/CMakeFiles/nrf70-buslib.dir/spi_if.c.obj
FAILED: modules/nrf_wifi/bus/CMakeFiles/nrf70-buslib.dir/spi_if.c.obj
C:\dev\NRF\toolchains\b620d30767\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DK_HEAP_MEM_POOL_SIZE=25000 -DNRF52_ERRATA_215_ENABLE_WORKAROUND=0 -DNRF5340_XXAA_APPLICATION -DNRF53_ERRATA_159_ENABLE_WORKAROUND=0 -DNRF53_ERRATA_43_ENABLE_WORKAROUND=0 -DNRF70_ANT_GAIN_2G=0 -DNRF70_ANT_GAIN_5G_BAND1=0 -DNRF70_ANT_GAIN_5G_BAND2=0 -DNRF70_ANT_GAIN_5G_BAND3=0 -DNRF70_BAND_2G_LOWER_EDGE_BACKOFF_DSSS=0 -DNRF70_BAND_2G_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_2G_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_2G_UPPER_EDGE_BACKOFF_DSSS=0 -DNRF70_BAND_2G_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_2G_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_1_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_1_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_1_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_1_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_2A_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_2A_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_2A_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_2A_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_2C_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_2C_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_2C_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_2C_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_3_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_3_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_3_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_3_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_4_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_4_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_4_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_4_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_LOG_VERBOSE -DNRF70_MAX_TX_PENDING_QLEN=18 -DNRF70_MAX_TX_TOKENS=10 -DNRF70_PCB_LOSS_2G=0 -DNRF70_PCB_LOSS_5G_BAND1=0 -DNRF70_PCB_LOSS_5G_BAND2=0 -DNRF70_PCB_LOSS_5G_BAND3=0 -DNRF70_REG_DOMAIN=00 -DNRF70_RPU_PS_IDLE_TIMEOUT_MS=10 -DNRF70_RX_MAX_DATA_SIZE=1600 -DNRF70_RX_NUM_BUFS=48 -DNRF70_SCAN_ONLY -DNRF70_TCP_IP_CHECKSUM_OFFLOAD -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_WIFI_AP_DEAD_DETECT_TIMEOUT=20 -DNRF_WIFI_IFACE_MTU=1500 -DNRF_WIFI_LOW_POWER -DNRF_WIFI_MGMT_BUFF_OFFLOAD -DNRF_WIFI_PS_INT_PS=y -DNRF_WIFI_RPU_RECOVERY -DNRF_WIFI_RPU_RECOVERY_PS_ACTIVE_TIMEOUT_MS=50000 -DPICOLIBC_LONG_LONG_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/dev/NRF/v2.9.1/zephyr/modules/nrf_wifi/bus/inc -IC:/dev/scan/build/scan/zephyr/include/generated/zephyr -IC:/dev/NRF/v2.9.1/zephyr/include -IC:/dev/scan/build/scan/zephyr/include/generated -IC:/dev/NRF/v2.9.1/zephyr/soc/nordic -IC:/dev/NRF/v2.9.1/zephyr/soc/nordic/nrf53/. -IC:/dev/NRF/v2.9.1/zephyr/soc/nordic/common/. -IC:/dev/NRF/v2.9.1/zephyr/subsys/net/l2 -IC:/dev/NRF/v2.9.1/zephyr/drivers/wifi/nrf_wifi/inc -IC:/dev/NRF/v2.9.1/zephyr/subsys/net/ip -IC:/dev/NRF/v2.9.1/nrf/include -IC:/dev/scan/build/scan/zephyr/misc/generated -IC:/dev/NRF/v2.9.1/nrf/tests/include -IC:/dev/NRF/v2.9.1/modules/hal/cmsis/CMSIS/Core/Include -IC:/dev/NRF/v2.9.1/zephyr/modules/cmsis/. -IC:/dev/NRF/v2.9.1/modules/hal/nordic/nrfx -IC:/dev/NRF/v2.9.1/modules/hal/nordic/nrfx/drivers/include -IC:/dev/NRF/v2.9.1/modules/hal/nordic/nrfx/mdk -IC:/dev/NRF/v2.9.1/zephyr/modules/hal_nordic/nrfx/. -IC:/dev/NRF/v2.9.1/zephyr/modules/nrf_wifi/os -IC:/dev/NRF/v2.9.1/zephyr/modules/nrf_wifi/os/../bus -IC:/dev/NRF/v2.9.1/modules/lib/nrf_wifi/utils/inc -IC:/dev/NRF/v2.9.1/modules/lib/nrf_wifi/os_if/inc -IC:/dev/NRF/v2.9.1/modules/lib/nrf_wifi/bus_if/bus/qspi/inc -IC:/dev/NRF/v2.9.1/modules/lib/nrf_wifi/bus_if/bal/inc -IC:/dev/NRF/v2.9.1/modules/lib/nrf_wifi/fw_if/umac_if/inc -IC:/dev/NRF/v2.9.1/modules/lib/nrf_wifi/fw_load/mips/fw/inc -IC:/dev/NRF/v2.9.1/modules/lib/nrf_wifi/hw_if/hal/inc -IC:/dev/NRF/v2.9.1/modules/lib/nrf_wifi/hw_if/hal/inc/fw -IC:/dev/NRF/v2.9.1/modules/lib/nrf_wifi/fw_if/umac_if/inc/fw -IC:/dev/NRF/v2.9.1/modules/lib/nrf_wifi/fw_if/umac_if/inc/default -isystem C:/dev/NRF/v2.9.1/zephyr/lib/libc/common/include -isystem C:/dev/NRF/v2.9.1/nrfxlib/crypto/nrf_cc312_platform/include -Os -DNDEBUG -fno-strict-aliasing -Os -imacros C:/dev/scan/build/scan/zephyr/include/generated/zephyr/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=C:/dev/NRF/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/dev/NRF/v2.9.1/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/dev/scan=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/dev/NRF/v2.9.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/dev/NRF/v2.9.1=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -std=c99 -MD -MT modules/nrf_wifi/bus/CMakeFiles/nrf70-buslib.dir/spi_if.c.obj -MF modules\nrf_wifi\bus\CMakeFiles\nrf70-buslib.dir\spi_if.c.obj.d -o modules/nrf_wifi/bus/CMakeFiles/nrf70-buslib.dir/spi_if.c.obj -c C:/dev/NRF/v2.9.1/zephyr/modules/nrf_wifi/bus/spi_if.c
In file included from C:/dev/NRF/v2.9.1/zephyr/include/zephyr/toolchain/gcc.h:98,
                 from C:/dev/NRF/v2.9.1/zephyr/include/zephyr/toolchain.h:50,
                 from C:/dev/NRF/v2.9.1/zephyr/include/zephyr/sys/__assert.h:11,
                 from C:/dev/NRF/v2.9.1/zephyr/include/zephyr/irq_multilevel.h:15,
                 from C:/dev/NRF/v2.9.1/zephyr/include/zephyr/devicetree.h:20,
                 from C:/dev/NRF/v2.9.1/zephyr/include/zephyr/device.h:12,
                 from C:/dev/NRF/v2.9.1/zephyr/include/zephyr/drivers/spi.h:26,
                 from C:/dev/NRF/v2.9.1/zephyr/modules/nrf_wifi/bus/spi_if.c:14:
C:/dev/NRF/v2.9.1/zephyr/include/zephyr/device.h:92:41: error: '__device_dts_ord_144' undeclared here (not in a function); did you mean '__device_dts_ord_14'?
   92 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
C:/dev/NRF/v2.9.1/zephyr/include/zephyr/toolchain/common.h:137:26: note: in definition of macro '_DO_CONCAT'
  137 | #define _DO_CONCAT(x, y) x ## y
C:/dev/NRF/v2.9.1/zephyr/include/zephyr/device.h:92:33: note: in expansion of macro '_CONCAT'
C:/dev/NRF/v2.9.1/zephyr/include/zephyr/device.h:229:37: note: in expansion of macro 'DEVICE_NAME_GET'
  229 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_ID(node_id))
C:/dev/NRF/v2.9.1/zephyr/include/zephyr/device.h:246:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
  246 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
C:/dev/NRF/v2.9.1/zephyr/include/zephyr/drivers/spi.h:403:24: note: in expansion of macro 'DEVICE_DT_GET'
  403 |                 .bus = DEVICE_DT_GET(DT_BUS(node_id)),               \
C:/dev/NRF/v2.9.1/zephyr/modules/nrf_wifi/bus/spi_if.c:27:1: note: in expansion of macro 'SPI_DT_SPEC_GET'
   27 | SPI_DT_SPEC_GET(NRF7002_NODE, SPI_WORD_SET(8) | SPI_TRANSFER_MSB, 0);
C:/dev/scan/build/scan/zephyr/include/generated/zephyr/devicetree_generated.h:16224:41: error: 'DT_N_S_soc_S_peripheral_50000000_S_qspi_2b000_S_nrf7002_1_P_spi_max_frequency' undeclared here (not in a function); did you mean 'DT_N_S_soc_S_peripheral_50000000_S_spi_9000_S_nrf7002_0_P_spi_max_frequency'?
16224 | #define DT_N_NODELABEL_nrf70            DT_N_S_soc_S_peripheral_50000000_S_qspi_2b000_S_nrf7002_1
C:/dev/NRF/v2.9.1/zephyr/include/zephyr/devicetree.h:4879:29: note: in definition of macro 'DT_CAT3'
 4879 | #define DT_CAT3(a1, a2, a3) a1 ## a2 ## a3
C:/dev/NRF/v2.9.1/zephyr/include/zephyr/drivers/spi.h:349:30: note: in expansion of macro 'DT_PROP'
  349 |                 .frequency = DT_PROP(node_id, spi_max_frequency),       \
C:/dev/NRF/v2.9.1/zephyr/include/zephyr/drivers/spi.h:404:27: note: in expansion of macro 'SPI_CONFIG_DT'
  404 |                 .config = SPI_CONFIG_DT(node_id, operation_, delay_) \
C:/dev/NRF/v2.9.1/zephyr/include/zephyr/devicetree.h:4877:24: note: in expansion of macro 'DT_N_NODELABEL_nrf70'
 4877 | #define DT_CAT(a1, a2) a1 ## a2
C:/dev/NRF/v2.9.1/zephyr/include/zephyr/devicetree.h:200:29: note: in expansion of macro 'DT_CAT'
  200 | #define DT_NODELABEL(label) DT_CAT(DT_N_NODELABEL_, label)
C:/dev/NRF/v2.9.1/zephyr/modules/nrf_wifi/bus/spi_if.c:22:22: note: in expansion of macro 'DT_NODELABEL'
   22 | #define NRF7002_NODE DT_NODELABEL(nrf70)
C:/dev/NRF/v2.9.1/zephyr/modules/nrf_wifi/bus/spi_if.c:27:17: note: in expansion of macro 'NRF7002_NODE'
C:/dev/scan/build/scan/zephyr/include/generated/zephyr/devicetree_generated.h:16224:41: error: 'DT_N_S_soc_S_peripheral_50000000_S_qspi_2b000_S_nrf7002_1_P_duplex' undeclared here (not in a function); did you mean 'DT_N_S_soc_S_peripheral_50000000_S_spi_9000_S_nrf7002_0_P_duplex'?
C:/dev/NRF/v2.9.1/zephyr/include/zephyr/drivers/spi.h:351:25: note: in expansion of macro 'DT_PROP'
  351 |                         DT_PROP(node_id, duplex) |                      \
C:/dev/scan/build/scan/zephyr/include/generated/zephyr/devicetree_generated.h:16224:41: error: 'DT_N_S_soc_S_peripheral_50000000_S_qspi_2b000_S_nrf7002_1_P_frame_format' undeclared here (not in a function); did you mean 'DT_N_S_soc_S_peripheral_50000000_S_spi_9000_S_nrf7002_0_P_frame_format'?
C:/dev/NRF/v2.9.1/zephyr/include/zephyr/drivers/spi.h:352:25: note: in expansion of macro 'DT_PROP'
  352 |                         DT_PROP(node_id, frame_format) |                        \
[99/224] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
FAILED: _sysbuild/sysbuild/images/scan-prefix/src/scan-stamp/scan-build C:/dev/scan/build/_sysbuild/sysbuild/images/scan-prefix/src/scan-stamp/scan-build
cmd.exe /C "cd /D C:\dev\scan\build\scan && C:\dev\NRF\toolchains\b620d30767\opt\bin\cmake.exe --build ."
FATAL ERROR: command exited with status 1: 'C:\dev\NRF\toolchains\b620d30767\opt\bin\cmake.EXE' --build C:/dev/scan/build
# Copyright (c) 2023 Nordic Semiconductor
source "Kconfig.zephyr"
menu "Nordic Scan sample"
config WIFI_MAC_ADDRESS
	string "WiFi MAC address"
	default "F6:CE:36:00:00:01"
	help
		Wi-Fi MAC address to be used by the sample. If not set, the sample will
		use the default MAC address (locally administrative). This is only used
		when the nRF7002 OTP is not programmed with a MAC address.
config WIFI_SCAN_INTERVAL_S
	int "Scan interval (seconds)"
	default 10
	help
	  Specifies the scan interval in seconds.
config WIFI_SCAN_BANDS_LIST
	string "Frequency bands to scan"
	default "2" if WIFI_SCAN_PROFILE_2_4GHz_ACTIVE || WIFI_SCAN_PROFILE_2_4GHz_PASSIVE || WIFI_SCAN_PROFILE_2_4GHz_NON_OVERLAP_CHAN
	default "5" if WIFI_SCAN_PROFILE_5GHz_ACTIVE || WIFI_SCAN_PROFILE_5GHz_PASSIVE || WIFI_SCAN_PROFILE_5GHz_NON_DFS_CHAN
	default "2,5" if WIFI_SCAN_PROFILE_2_4GHz_NON_OVERLAP_AND_5GHz_NON_DFS_CHAN
	default ""
	help
	  Specifies the frequency bands to scan, as follows:
	  2 - 2.4 GHz,
	  5 - 5 GHz,
	  6 - 6 GHz,
	  "" - All bands allowed by the regulatory domain.
	  Multiple bands can be specified as comma separated band values.
	  Only regulatory domain permitted values are allowed.
config WIFI_SCAN_CHAN_LIST
	string "Channel list for scan"
	default "2:1,6,11" if WIFI_SCAN_PROFILE_2_4GHz_NON_OVERLAP_CHAN
	default "5:36,40,44,48,149,153,157,161,165" if WIFI_SCAN_PROFILE_5GHz_NON_DFS_CHAN
	default "2:1,6,11_5:36,40,44,48,149,153,157,161,165" if WIFI_SCAN_PROFILE_2_4GHz_NON_OVERLAP_AND_5GHz_NON_DFS_CHAN
	default ""
	help
	  Specifies the list of channels used to perform scan.
config WIFI_SCAN_DWELL_TIME_ACTIVE
	int "Active scan dwell time"
	default 50
	range 5 1000
	help
	  Active scan dwell time (in ms) per channel.
config WIFI_SCAN_DWELL_TIME_PASSIVE
	int "Passive scan dwell time"
	default 130
	range 10 1000
	help
	  Passive scan dwell time (in ms) per channel.
choice
	prompt "Choose a WiFi Scan Profile"
config WIFI_SCAN_PROFILE_DEFAULT
	bool "Scan in all bands and channels"
	help
	  Enable this profile to do Wi-Fi scan in all supported bands and channels.
config WIFI_SCAN_PROFILE_ACTIVE
	bool "Active scan"
	help
	  Enable this profile to do active scan where allowed.
config WIFI_SCAN_PROFILE_PASSIVE
	bool "Passive scan"
	help
	  Enable this profile to do passive scan on all channels.
config WIFI_SCAN_PROFILE_2_4GHz_ACTIVE
	bool "Scan in the 2.4 GHz band using active scan"
	help
	  Enable this profile to scan in the 2.4 GHz band using active scanning where allowed.
config WIFI_SCAN_PROFILE_2_4GHz_PASSIVE
	bool "Scan in the 2.4 GHz band using passive scan"
	help
	  Enable this profile to scan in the 2.4 GHz band using passive scanning on all channels.
config WIFI_SCAN_PROFILE_5GHz_ACTIVE
	bool "Scan in the 5 GHz band using active scan"
	help
	  Enable this profile to scan in the 5 GHz band using active scanning where allowed.
config WIFI_SCAN_PROFILE_5GHz_PASSIVE
	bool "Scan in the 5 GHz band using passive scan"
	help
	  Enable this profile to scan in the 5 GHz band using passive scanning on all channels.
config WIFI_SCAN_PROFILE_2_4GHz_NON_OVERLAP_CHAN
	bool "Scan only non-overlapping channels"
	help
	  Enable this profile to scan only non-overlapping channels (1, 6, 11)
	  in the 2.4 GHz band.
config WIFI_SCAN_PROFILE_5GHz_NON_DFS_CHAN
	bool "Scan only non-DFS channels"
	help
	  Enable this profile to scan only non-DFS channels (36, 40, 44,
	  48, 149, 153, 157, 161, 165) in the 5 GHz band.
config WIFI_SCAN_PROFILE_2_4GHz_NON_OVERLAP_AND_5GHz_NON_DFS_CHAN
	bool "Scan only non-overlapping and non-DFS channels"
	help
	  (1, 6, 11) in the 2.4 GHz band and non-DFS channels (36, 40, 44,
endchoice
endmenu
  • Ok, I finally had a chance take a careful look.  Here is what I found:
    1) build the vanilla scan example against nrf7002dk_nrf5340_cpuapp, compiles just fine.
    2) I looked at the output in build//zephry.dts to see what that looked like and saw the QSPI node.  I copied the entire nrf70:nrf7002@1 node and the chosen node shown below and deleted the QSPI node, shown here:
    /delete-node/ &qspi;
        chosen {
    		zephyr,wifi = &wlan0;
    &spi1 {
    	status = "okay";
    	label="spi1";
    	pinctrl-0 = <&spi1_default>;
    	pinctrl-1 = <&spi1_sleep>;
    	cs-gpios = <&gpio0 14 GPIO_ACTIVE_LOW >,<&gpio0 22 GPIO_ACTIVE_LOW >,<&gpio0 15 GPIO_ACTIVE_LOW >,<&gpio0 13 GPIO_ACTIVE_LOW>;
    	nrf70: nrf7002@0 {
    		status = "okay";
    		compatible = "nordic,nrf7002-spi";
    		reg = <0>;
    		label = "nrf7002_wlan";  // Add explicit label
    		spi-max-frequency = <8000000>;
    		/* Wi-Fi Pins used */
            iovdd-ctrl-gpios = <&gpio0 18 GPIO_ACTIVE_HIGH>;
            bucken-gpios = <&gpio0 5 GPIO_ACTIVE_HIGH>;
    		host-irq-gpios = <&gpio0 19 0>;
    		// Define WiFi properties directly - NO INCLUDES
            wifi-max-tx-pwr-2g-dsss = <21>;
            wifi-max-tx-pwr-2g-mcs0 = <16>;
            wifi-max-tx-pwr-2g-mcs7 = <16>;
            wifi-max-tx-pwr-5g-low-mcs0 = <9>;
            wifi-max-tx-pwr-5g-low-mcs7 = <9>;
            wifi-max-tx-pwr-5g-mid-mcs0 = <11>;
            wifi-max-tx-pwr-5g-mid-mcs7 = <11>;
            wifi-max-tx-pwr-5g-high-mcs0 = <13>;
            wifi-max-tx-pwr-5g-high-mcs7 = <13>;
    		wlan0: wlan {
    			compatible = "nordic,wlan";
    		coex {
    			status = "okay";
    			req-gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>;
    			status0-gpios = <&gpio1 15 GPIO_ACTIVE_HIGH>;
    			grant-gpios = <&gpio1 13 (GPIO_PULL_DOWN | GPIO_ACTIVE_LOW)>;
    			swctrl1-gpios = <&gpio1 12 GPIO_ACTIVE_HIGH>;
            /* Use full Windows path */
    		// #include "C:/ncs/v2.9.1/zephyr/boards/nordic/nrf7002dk/nrf70_common.dtsi"
    		// #include "C:/ncs/v2.9.1/zephyr/boards/nordic/nrf7002dk/nrf70_common_5g.dtsi"
    I then ported this to my project and it works.  Thanks for the help on this.  Using the zephyr.dts generate directly on the DK was super helpful.
