Issue with MCUboot integration in Zigbee R23 project for nRF54L15
Dear Nordic Technical Support,
I'm writing to report an issue I'm experiencing when trying to integrate MCUboot with a Zigbee R23 project for the nRF54L15 platform.
Issue Description: When attempting to build a basic Zigbee R23 project with MCUboot support (without any FOTA functionality yet), the build process fails during the MCUboot compilation phase. The main application builds successfully, but the bootloader build fails with the following error:
C:/ncs/ZB_for290_R23_031/ncs-zigbee/subsys/osif/zb_nrf_pwr_mgmt.c:9:10: fatal error: zboss_api.h: No such file or directory
9 | #include <zboss_api.h>
compilation terminated.
Environment:
  • Hardware: nRF54L15 Development Kit
  • SDK: nRF Connect SDK with Zigbee R23 add-on (ZB_for290_R23_031)
  • Build system: West/CMake
Steps Taken:
  1. Created a basic Zigbee R23 project that builds successfully without bootloader
  2. Added MCUboot configuration through sysbuild.conf with SB_CONFIG_BOOTLOADER_MCUBOOT=y
  3. Created configuration files in the sysbuild directory to disable components that shouldn't be needed for the bootloader:
    • Added mcuboot.conf with CONFIG_SERIAL=nCONFIG_SPI=nCONFIG_SPI_NOR=n, etc.
    • Attempted to disable Zigbee components in the bootloader with CONFIG_ZIGBEE=nCONFIG_ZIGBEE_ADD_ON=n
Despite these configurations, the build system still attempts to include Zigbee libraries in the bootloader build, which causes the compilation error.
Goal: My ultimate goal is to implement FOTA updates in my Zigbee R23 application, but I'm currently blocked at this initial stage of just integrating the bootloader.
I would appreciate any guidance on how to properly configure the build system to exclude Zigbee components from the MCUboot build, or any other approach to resolve this issue.
Thank you for your assistance.
Best regards, Andris M.
  • Hi Reinis,
    FOTA support for L15/L10 is available on main branch (still no officially released), tested, and it’s working.
    You can download the main branch and continue work with it temporarily.
    Temporary documentation is available here: Zigbee R23 add-on_documentation_html.zip
    -Amanda H.
  • Good day Amanda,
    Thanks a lot for the update and for confirming that Zigbee FOTA support is now available in the main branch for nRF54L15.
    I successfully integrated MCUboot using the sysbuild.conf method and generated a signed image with the following configuration:
    SB_CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
    SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="${APPLICATION_CONFIG_DIR}/priv.pem"
    I also added FOTA-specific options:
    CONFIG_ZIGBEE_FOTA=y
    CONFIG_ZIGBEE_FOTA_HW_VERSION=52
    CONFIG_ZIGBEE_FOTA_ENDPOINT=5
    CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="1.2.3"
    CONFIG_ZIGBEE_FOTA_COMMENT="light_switch"
    CONFIG_IMG_MANAGER=y
    CONFIG_STREAM_FLASH=y
    CONFIG_DFU_TARGET_MCUBOOT=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    CONFIG_ZIGBEE_FOTA_PROGRESS_EVT=y
    The application was built and signed successfully, and I copied the resulting partition map into pm_static.yaml.
    The firmware runs fine, and I can see the OTA cluster exposed on endpoint 5. Using deCONZ, I’m able to read OTA attributes, and when I trigger an OTA update, the device receives the image header correctly.
    To simulate a real update, I tried sending the same signed binary currently running on the device (so image size, version, and headers are correct) using the following nrfutil command:
    nrfutil nrf5sdk-tools pkg generate \
      --hw-version 52 \
      --sd-req 0x00 \
      --application-version 0x01020040 \
      --application zephyr.signed.bin \
      --key-file ../../../priv.pem \
      app_dfu_package.zip \
      --zigbee True \
      --zigbee-manufacturer-id 0x127f \
      --zigbee-image-type 0x0141 \
      --zigbee-comment good_image \
      --zigbee-ota-hw-version 52
    This created a .zigbee file: 127F-0141-01020040-good_image.zigbee
    However, the actual OTA update fails at the very beginning. Only 0.3% of the image is transferred before the process aborts. Logs from the device show the following:
    [00:14:23.794,935] <err> zigbee_fota: dfu_multi_image_write err -12 offset: 0 len: 15
    [00:14:23.794,981] <inf> zigbee_fota: Zigbee DFU Aborted
    [00:14:23.794,986] <inf> zigbee_fota: ABORT Zigbee DFU
    [00:14:23.794,997] <err> app: OTA image transfer failed.
    puzzle piece Questions / Request for Help
    1. What exactly does dfu_multi_image_write err -12 mean?
      I assume -12 is -ENOMEM, but the memory pool should be large enough.
    2. Could this error be related to how the .zigbee file is generated via nrfutil?
      Is there any official method to generate OTA packages (especially for multi-image DFU)?
    I’d appreciate any guidance or even just hints where to look next — especially to avoid wasting time debugging the wrong layer (OTA file, integration, or memory limits). Thank you!
    Andris Matveev
    Zigbee R23 NCS v1.0.0 can support nRF54L15 now. Please download via https://nrfconnect.github.io/ncs-app-index/ and refer to https://docs.nordicsemi.com/bundle/addon-zigbee-r23-1.0.0/page/samples/light_switch to build with extra config -DFILE_SUFFIX=fota to enable the FOTA functions and the external flash setting.
    You should use the one that is automatically generated in the build directory, for example, build/zephyr/127F-0141-01020003-light_switch.zigbee.
    If the above cannot help, please create a new support case.
    -Amanda H.
  • Hi Amanda,
    Thank you very much for your guidance!
    Following your advice, I first built and ran the light_switch sample and saw that the .zigbee file is indeed generated automatically in the build/zephyr/ folder. That clarified a lot. Then I reviewed my own project and identified the configuration pieces I had previously missed. After applying the necessary changes, I was able to successfully generate the OTA image and perform a firmware upgrade over Zigbee FOTA — everything worked smoothly.
    Additionally, I noticed the CONFIG_TICKLESS_KERNEL=y setting in the sample. I believe this may help me solve another issue I've been facing, related to entering System OFF mode and reliably waking up via timer — something that hasn't been working consistently so far.
    Thanks again for your support and for pointing me in the right direction!
    Andris
