URGENT: Random High Power Consumption Issue Causing Severe Battery Drain in Production
We are facing a critical power consumption issue in our nRF52-based Zephyr application, where some devices randomly enter a high-power consumption state (~80+ µA) instead of the expected 35-40 µA in idle mode.
Impact:
  • Users are experiencing severe battery drain.
  • Expected battery life has reduced to less than half in affected devices.
  • The issue is random, making it difficult to track and resolve.
This issue occurs in multiple scenarios:
  • On runtime under certain conditions
  • After a reset
  • After a firmware update
  • Randomly, without a clear trigger
We have a global float variable: float total_current = 0.0f;
  • This variable is modified in two places:
    • A worker thread
    • A BLE command receive event handler
  • When we commented out the function call in the BLE handler and flashed the firmware, the power consumption increased unexpectedly.
  • We initially suspected FPU lazy stacking or context-switching issues but could not confirm.
  • However, aligning the float variable using __aligned(8) or declaring it locally inside the function completely eliminated the power issue and we thought this will fix the issue and added __aligned(8) for all global float variables.
  • This led us to suspect a floating-point-related issue, but the behavior reappeared when we initialized an atomic variable globally, like this atomic_t is_bat_chargin = ATOMIC_INIT(0);
    and used it inside some timers and functions.
Need help with the following,
  1. Why does initializing a global float (or even an atomic variable) sometimes cause a high-power state?
  2. Could this be related to FPU context switching, stack alignment, or something else in Zephyr/nRF52?
  3. Why does aligning the float or declaring it locally fix the issue?
  4. Is there a better way to avoid such random power increases when using floating-point operations and atomic variables in Zephyr?
  5. Is there any extra configuration, debug setting, or power profiling tool we should enable to track down the exact cause of this issue?
Additional info
  • SoC: nRF52840
  • Zephyr Version: 2.6.1
  • CONFIG_FPU=y , CONFIG_FPU_SHARING=y
  • Optimization Level in Build: Optimize for size
  • Power Measurement Setup: Using a power profiler tool
This is a critical issue affecting production devices, and we urgently need guidance to identify the root cause and resolution.
Appreciate any insights into this issue! Is there anything extra we should check or enable to debug this further?
Vishnu
  • vishnu3391_uh said:
    Can crystal be a reason for this unpredictable high current behaviour on resets? If yes, what is the reason for the behaviour?
    I wouldn't think so.
    vishnu3391_uh said:
    But this has some issue and causing device not advertising issue
    Ok, so I assume that is why you are using the internal RC which triggered this issue in the first place.
    vishnu3391_uh said:
    Yes. The tickets are for this same design. Could the be related?
    Not sure. But I would assume that if the LFXTAL is present, but you configure your application to use the internal RC Oscillator, then the LFXTAL will remain unpowered. You don't use the XTAL pins P0.00 and P0.01 for anything else, right?
    Have you tried desoldering the XTAL to make sure that this is not what's spinning up (but I would be very surprised if this is actually the case).
    vishnu3391_uh said:
    Can you try to replicate this on DK or on your side. Just keep firing the nrfjprog --reset command for 20+ times continuously.
    I couldn't. Did you try? I assume it would require an application similar to the one that you are using. Can you please try to build the application for a DK, and see if you can replicate it there?
    Edvin
  •  Sorry I think you got it wrong. The thing is it is working in external LF and the high current issue happens only when we select internal RC only. This was replicating with BLE baecon sample as well with LF source as internal RC.
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
    CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_PERIOD=5000
    CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_LF_ALWAYS_ON=y
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_BOARD_ENABLE_DCDC=y
    This is the config we have .
  • I tried the NCS v2.6.1\zephyr\samples\bluetooth\beacon with the added config lines that you provided, flashed it to an nRF52840DK, and ran this reset-script:
    :loop
    nrfjprog --reset -f NRF52
    TIMEOUT 2
    goto loop
    But so far, the current consumption looks normal:
    But if I understand correctly, once it reaches the high current state, it will remain that way until I power cycle the kit, so I can leave it running over night.
    Let me know if you are able to reproduce it on a DK.
    But I would like to know a bit more about your HFXTAL issues. Perhaps it is related. Why did you decide to use the internal LFCLK? Is there an error with the XTAL? Or are the capacitors wrong?
    Edvin
  • But if I understand correctly, once it reaches the high current state, it will remain that way until I power cycle the kit, so I can leave it running over night.
    That is right. Only a power on reset or program with external LF configuration or doing a
    NRF_POWER->SYSTEMOFF = 1; and waking up from sleep only was fixing. We also found on one board, setting CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=n was fixing the issue. But this is not working on all boards.
     For the devices out there on field were going into not advertising state and we decided to go with internal RC. Now the issue counts are reduced drastically. Looks like problem with LF XTAL.
    Is it the same devices that would stop advertising that are showing symptoms of high current consumption? Is it all devices? Or just some of them?
    How many does it work on, and how many does this not work for? (approximate numbers, and a percentage of the total amount).
    What comes to mind is this errata:
    https://docs.nordicsemi.com/bundle/errata_nRF52840_Rev3/page/ERR/nRF52840/Rev3/latest/anomaly_840_36.html#anomaly_840_36
    But it is very old, and the workaround for this is already implemented in NCS (even in the nRF5 SDK).
    But for good measure, when you are in the state of the high currency, could you try to read out the status registers in the very beginning of the application? I suspect that they are already used when you hit main(), but you can check if there are any differences between the good runs and the bad ones.
    Still no luck on reproducing on nRF52DK?
    Edvin
