Custom DFU imlementation
I am implementing DFU using my own transport to retrieve the binary image from AWS.
I'm developing in 2.6.0.
I am using the DFU TARGET libraries.
When I start my download I look at the first 512 byte block with
     i=dfu_target_img_type   (  buffer2,xblocksize); I get 1 (I think that this is DFU_TARGET_IMAGE_TYPE_MCUBOOT)
But I can't get past dfu_target_init().
When I run   i=dfu_target_init(DFU_TARGET_IMAGE_TYPE_MCUBOOT,0,filesize,NULL); I get an error 19 (No Such Device)
When I run i=dfu_target_reset(); I get an error 13 (Permission Denied)
I believe the issue lies either in my prj.conf or my static partition.
Currently, prj.conf has
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_BOOTLOADER_MCUBOOT=y
# Small blue diamond Enable DFU Target Library
CONFIG_DFU_TARGET=y
CONFIG_DFU_TARGET_MCUBOOT=y
# Small blue diamond Enable MCUboot Image Manager (if using MCUboot)
CONFIG_STREAM_FLASH=y
CONFIG_STREAM_FLASH_ERASE=y
CONFIG_IMG_MANAGER=y
CONFIG_MCUBOOT_IMG_MANAGER=y
My static partition  is
app:
address: 0xc200
end_address: 0x85000
region: flash_primary
mcuboot:
address: 0x0
end_address: 0xc000
placement:
before:
- mcuboot_primary
mcuboot_pad:
address: 0xc000
end_address: 0xc200
placement:
align:
start: 0x1000
before:
- mcuboot_primary_app
mcuboot_primary:
address: 0xc000
orig_span: &id001
- mcuboot_pad
- app
sharers: 0x1
span: *id001
mcuboot_primary_app:
address: 0xc200
orig_span: &id002
- app
span: *id002
mcuboot_secondary:
address: 0x85000
end_address: 0xfe000
placement:
after:
- mcuboot_primary
align:
start: 0x1000
share_size:
- mcuboot_primary
settings_storage:
address: 0xfe000
end_address: 0x100000
placement:
align:
start: 0x1000
before:
- end
sram_primary:
address: 0x20000000
end_address: 0x20040000
region: sram_primary
I've been playing with this for five days - any help would be greatly appreciatd.
