Does the RAM power-down library support nRF9160?
Hello everyone.
I am developing a custom board using the nRF9160. I tried using the RAM power-down library based on the Power optimization recommendations page of the nRF Connect SDK.
CONFIG_RAM_POWER_DOWN_LIBRARY=y
However, when building I got the following message:
warning: RAM_POWER_DOWN_LIBRARY (defined at C:/ncs/v2.6.1/nrf\lib\ram_pwrdn/Kconfig:7) was assigned
the value 'y' but got the value 'n'. Check these unsatisfied dependencies: (SOC_NRF52840 ||
SOC_NRF52833 || SOC_NRF5340_CPUAPP) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_RAM_POWER_DOWN_LIBRARY and/or look up
RAM_POWER_DOWN_LIBRARY in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
It seems that the RAM power down library does not support nRF9160, so please tell me how to use the RAM power down library with the nRF9160.
Thanks in advance.
  • Hello matsuura,
    I didn't think about disabling RAM with the Partition Manager, but that certainly works.
    You can also disable it via the DeviceTree. This will work both when RAM partitioning is done with and without Partition Manager. I tested this and it reduces RAM size to 128kB.
    &sram0 {
    	reg = <0x20000000 DT_SIZE_K(128)>;
    I don't have a nRF9160 DK to test with at the moment, but I tested both the Partition Manager and the DeviceTree method on a nRF52840 DK, and it works. The key point being power consumption is lowered, and the application is linked with less RAM.
    Your usage of the API shows you already know about the separation of RAM into secure and non-secure domain. Please pay attention to that too.
    Finally, I assume this is done to save power consumption. Please try to measure the current consumption before and after to confirm the change is effective.
  • Hello hieu,
    Thanks for the advice. I'll try measuring the power consumption this way !!
