nRF5340 Dynamic Connection Event Length
I need to use two or more different event lengths for different modes. The event length should be set based on the mode before establishing a connection. I found that sdc_hci_cmd_vs_event_length_set() can be used for this purpose.
To implement this, I added the header:
#include <sdc_hci_vs.h>
Then, I tried to use the function with the following code:
uint8_t err;
static sdc_hci_cmd_vs_event_length_set_t event_length_param;
event_length_param.event_length_us = 5000;
err = sdc_hci_cmd_vs_event_length_set(&event_length_param);
if (err)
    printk("Failed to set event length (err %d)\n", err);
    printk("Event length set to %u units\n", event_length_param.event_length_us);
However, I am unable to compile the project due to the following error:
"Undefined reference to sdc_hci_cmd_vs_event_length_set."
Could you help me understand why this error occurs? Are there additional header files or configurations required?
Can you please provide an example implementation to make integration easier?
    The issue you observed might be related to APIs inability to access controller which is on the network core.
    You could try to use hci_vs_sdc which is currently recommended API for sending VS commands to the controller. This API will build and send HCI command to the controller and works even if the controller is on another CPU compared to the host/application. You can look at this commit.
    Dejan
    1. I have added the hci_vs_sdc.h file to the NCS library path:
    nRFConnectSDK\v2.6.1\zephyr\include\zephyr\bluetooth\hci_vs_sdc.h
    2. I have added the hci_vs_sdc.c file to the NCS library path:
    nRFConnectSDK\v2.6.1\zephyr\subsys\bluetooth\hci_vs_sdc.c
    3. I have modified the CMakeLists.txt file in the NCS library path:
    nRFConnectSDK\v2.6.1\zephyr\subsys\bluetooth\CMakeLists.txt
    Added the following line:
    zephyr_sources_ifdef(CONFIG_BT_LL_SOFTDEVICE hci_vs_sdc.c)
    add_library(subsys__bluetooth INTERFACE)
    target_include_directories(subsys__bluetooth INTERFACE ${CMAKE_CURRENT_SOURCE_DIR})
    add_subdirectory(common)
    add_subdirectory_ifdef(CONFIG_BT_HCI host)
    add_subdirectory_ifdef(CONFIG_BT_SHELL shell)
    add_subdirectory_ifdef(CONFIG_BT_CONN services)
    add_subdirectory_ifdef(CONFIG_BT_MESH mesh)
    add_subdirectory_ifdef(CONFIG_BT_AUDIO audio)
    add_subdirectory_ifdef(CONFIG_BT_CRYPTO crypto)
    if(CONFIG_BT_CTLR AND CONFIG_BT_LL_SW_SPLIT)
      add_subdirectory(controller)
    endif()
    zephyr_include_directories(${ZEPHYR_BASE}/subsys/bluetooth)
    add_subdirectory(lib)
    4. I have enabled the CONFIG_BT_LL_SOFTDEVICE option by adding CONFIG_BT_LL_SOFTDEVICE=y in both the app core and net core config files.
    But still I am getting the error
    main.c:118: undefined reference to `hci_vs_sdc_event_length_set'
     *  Executing task: nRF Connect: Build: C50T1_RideGrid_nRF5340/build (active)
    Building C50T1_RideGrid_nRF5340
    C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir d:/NORDIC/Projects/C50T1_RideGrid_nRF5340/build d:/NORDIC/Projects/C50T1_RideGrid_nRF5340"
    [0/25] Performing build step for 'mcuboot_subimage'
    ninja: no work to do.
    [26/26] Linking C executable zephyr\zephyr.elf
               FLASH:       22332 B      34176 B     65.34%
                 RAM:        3456 B        64 KB      5.27%
               SRAM1:          0 GB        64 KB      0.00%
            IDT_LIST:          0 GB        32 KB      0.00%
    [57/202] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/bluetooth/hci_vs_sdc.c.obj
    FAILED: zephyr/CMakeFiles/zephyr.dir/subsys/bluetooth/hci_vs_sdc.c.obj
    D:\NORDIC\nRFConnectSDK\toolchains\cf2149caf2\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DNRF5340_XXAA_NETWORK -DPICOLIBC_LONG_LONG_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -DVALIDATION_INFO_MAGIC=0x281ee6de,0x86518483,79106 -DVALIDATION_POINTER_MAGIC=0x281ee6de,0x6919b47e,79106 -D_FORTIFY_SOURCE=1 -D_POSIX_C_SOURCE=200809 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -ID:/NORDIC/nRFConnectSDK/v2.6.1/zephyr/kernel/include -ID:/NORDIC/nRFConnectSDK/v2.6.1/zephyr/arch/arm/include -ID:/NORDIC/nRFConnectSDK/v2.6.1/nrf/drivers/mpsl/clock_control -ID:/NORDIC/nRFConnectSDK/v2.6.1/zephyr/include -ID:/NORDIC/Projects/C50T1_RideGrid_nRF5340/build/hci_ipc/zephyr/include/generated -ID:/NORDIC/nRFConnectSDK/v2.6.1/zephyr/soc/arm/nordic_nrf/nrf53 -ID:/NORDIC/nRFConnectSDK/v2.6.1/zephyr/soc/common/nordic_nrf/. -ID:/NORDIC/nRFConnectSDK/v2.6.1/zephyr/soc/arm/nordic_nrf/common/. -ID:/NORDIC/nRFConnectSDK/v2.6.1/zephyr/subsys/bluetooth -ID:/NORDIC/nRFConnectSDK/v2.6.1/zephyr/subsys/settings/include -ID:/NORDIC/nRFConnectSDK/v2.6.1/nrf/include -ID:/NORDIC/nRFConnectSDK/v2.6.1/nrf/lib/multithreading_lock/. -ID:/NORDIC/nRFConnectSDK/v2.6.1/nrf/subsys/bluetooth/controller/. -ID:/NORDIC/nRFConnectSDK/v2.6.1/nrf/tests/include -ID:/NORDIC/nRFConnectSDK/v2.6.1/modules/hal/cmsis/CMSIS/Core/Include -ID:/NORDIC/nRFConnectSDK/v2.6.1/zephyr/modules/cmsis/. -ID:/NORDIC/nRFConnectSDK/v2.6.1/modules/hal/nordic/nrfx -ID:/NORDIC/nRFConnectSDK/v2.6.1/modules/hal/nordic/nrfx/drivers/include -ID:/NORDIC/nRFConnectSDK/v2.6.1/modules/hal/nordic/nrfx/mdk -ID:/NORDIC/nRFConnectSDK/v2.6.1/zephyr/modules/hal_nordic/nrfx/. -ID:/NORDIC/Projects/C50T1_RideGrid_nRF5340/build/hci_ipc/modules/libmetal/libmetal/lib/include -ID:/NORDIC/nRFConnectSDK/v2.6.1/modules/lib/open-amp/open-amp/lib/include -ID:/NORDIC/nRFConnectSDK/v2.6.1/modules/crypto/tinycrypt/lib/include -ID:/NORDIC/nRFConnectSDK/v2.6.1/nrfxlib/mpsl/fem/common/include -ID:/NORDIC/nRFConnectSDK/v2.6.1/nrfxlib/mpsl/fem/nrf21540_gpio/include -ID:/NORDIC/nRFConnectSDK/v2.6.1/nrfxlib/mpsl/fem/nrf21540_gpio_spi/include -ID:/NORDIC/nRFConnectSDK/v2.6.1/nrfxlib/mpsl/fem/simple_gpio/include -ID:/NORDIC/nRFConnectSDK/v2.6.1/nrfxlib/mpsl/fem/include -ID:/NORDIC/nRFConnectSDK/v2.6.1/nrfxlib/mpsl/fem/include/protocol -ID:/NORDIC/nRFConnectSDK/v2.6.1/nrfxlib/mpsl/include -ID:/NORDIC/nRFConnectSDK/v2.6.1/nrfxlib/mpsl/include/protocol -ID:/NORDIC/nRFConnectSDK/v2.6.1/nrfxlib/softdevice_controller/include -isystem D:/NORDIC/nRFConnectSDK/v2.6.1/zephyr/lib/libc/common/include -fno-strict-aliasing -O2 -imacros D:/NORDIC/Projects/C50T1_RideGrid_nRF5340/build/hci_ipc/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33+nodsp -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=D:/NORDIC/nRFConnectSDK/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros D:/NORDIC/nRFConnectSDK/v2.6.1/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=D:/NORDIC/nRFConnectSDK/v2.6.1/zephyr/samples/bluetooth/hci_ipc=CMAKE_SOURCE_DIR -fmacro-prefix-map=D:/NORDIC/nRFConnectSDK/v2.6.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=D:/NORDIC/nRFConnectSDK/v2.6.1=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -std=c99 -MD -MT zephyr/CMakeFiles/zephyr.dir/subsys/bluetooth/hci_vs_sdc.c.obj -MF zephyr\CMakeFiles\zephyr.dir\subsys\bluetooth\hci_vs_sdc.c.obj.d -o zephyr/CMakeFiles/zephyr.dir/subsys/bluetooth/hci_vs_sdc.c.obj -c D:/NORDIC/nRFConnectSDK/v2.6.1/zephyr/subsys/bluetooth/hci_vs_sdc.c
    D:/NORDIC/nRFConnectSDK/v2.6.1/zephyr/subsys/bluetooth/hci_vs_sdc.c:8:10: fatal error: bluetooth/hci_vs_sdc.h: No such file or directory
        8 | #include <bluetooth/hci_vs_sdc.h>
    compilation terminated.
    [65/202] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_driver.c.obj
    [4/25] Linking C executable zephyr\zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map D:/NORDIC/Projects/C50T1_RideGrid_nRF5340/build/zephyr/zephyr_pre0.map
    cmd.exe /C "cd . && D:\NORDIC\nRFConnectSDK\toolchains\cf2149caf2\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe  -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf  && cmd.exe /C "cd /D D:\NORDIC\Projects\C50T1_RideGrid_nRF5340\build\zephyr && D:\NORDIC\nRFConnectSDK\toolchains\cf2149caf2\opt\bin\cmake.exe -E true""
    d:/nordic/nrfconnectsdk/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: app/libapp.a(main.c.obj): in function `main':
    D:/NORDIC/Projects/C50T1_RideGrid_nRF5340/src/main.c:118: undefined reference to `hci_vs_sdc_event_length_set'
    collect2.exe: error: ld returned 1 exit status
    FAILED: modules/nrf/samples/hci_ipc_subimage-prefix/src/hci_ipc_subimage-stamp/hci_ipc_subimage-build hci_ipc/zephyr/zephyr.hex hci_ipc/zephyr/zephyr.elf hci_ipc/zephyr/merged_CPUNET.hex D:/NORDIC/Projects/C50T1_RideGrid_nRF5340/build/modules/nrf/samples/hci_ipc_subimage-prefix/src/hci_ipc_subimage-stamp/hci_ipc_subimage-build D:/NORDIC/Projects/C50T1_RideGrid_nRF5340/build/hci_ipc/zephyr/zephyr.hex D:/NORDIC/Projects/C50T1_RideGrid_nRF5340/build/hci_ipc/zephyr/zephyr.elf D:/NORDIC/Projects/C50T1_RideGrid_nRF5340/build/hci_ipc/zephyr/merged_CPUNET.hex
    cmd.exe /C "cd /D D:\NORDIC\Projects\C50T1_RideGrid_nRF5340\build\hci_ipc && D:\NORDIC\nRFConnectSDK\toolchains\cf2149caf2\opt\bin\cmake.exe --build . --"
    FATAL ERROR: command exited with status 1: 'D:\NORDIC\nRFConnectSDK\toolchains\cf2149caf2\opt\bin\cmake.EXE' --build 'd:\NORDIC\Projects\C50T1_RideGrid_nRF5340\build'
     *  The terminal process terminated with exit code: 1.
    Can you please confirm if the above steps are correct or if I am missing anything?
    There is a sample that demonstrates how to use hci_vs_sdc_event_length_set() - scanning while connecting. This sample builds for nrf53. In this sample, SoftDevice controller is on the network core while Zephyr host and application reside on the application core, and no cmake changes are needed.
    Dejan
  • Hi
    The file hci_vs_sdc.h is not there in my NCS 2.6.1 folder.
    Is this file available only in a higher version?
